Frequency Range(MHz) 824-894/1710-1990 Bandwidth(MHz) 90/280 VSWR ≤1.5 Gain(dBi) 5 Max Input power(W) 60 Input Impedance(Ω) 50 Polarization Type Vertical Antenna Length(mm) 89±1 Cable Length﹙mm﹚ 2500 Cable Type RG174 Connector Type FME Straight Female etc. Mounting Magnetic Housing Black Storage Temperature -45℃ to +75℃ Operating Temperature -45℃ to+75℃
