IEEE1394.b 黑白 逐行扫描相机
KP-F140F, KP-F83F, KP-F32F
品牌:日立(HITACHI)
主要特点
IEEE1394.b
高清晰度、高帧数
KP-F140F: 145万像素(SXGA)、15帧/秒
KP-F83F : 80万像素(XGA)、30帧/秒
KP-F32F : 33万像素(VGA)、60帧/秒
各种功能:电子快门、外同步、外触发、局部扫描、串联、远程控制
系列:医用白色外观 (KP-Fxxx-S1)
技术参数:
Model |
KP-F140F |
KP-F83F |
KP-F32F |
Imaging device |
1/2-inch interline CCD |
1/3-inch interline CCD |
Total pixels |
1434 (H) x 1050 (V) |
1079(H) x 789(V) |
692(H) x 504(V) |
Effective pixels |
1392 (H) x 1024 (V) |
1034(H) x 779(V) |
656(H) x 492(V) |
Pixel size |
4.65 µm (H) x 4.65 µm (V) |
9.9 µm (H) x 9.9 µm (V) |
Color filter |
Scanning system |
Progressive scan |
Synchronization |
Internal / external (auto selection) |
Video signal output |
Interface |
IEEE1394.b (FireWire800) Protocol: IEEE1394-based Digital Camera Specification Version 1.31 compliant Transfer rate: 800 / 400 / 200 Mbps |
Image format |
MONO8 / MONO16 |
Image size |
1360(H)x1024(V), 1280(H)x960(V) |
1024(H) x 768(V) |
656 (H) x 492 (V) |
1024(H)x768(V), 800(H)x600 (V) |
800(H) x 600(V) |
640 (H) x 480 (V) |
640 (H)x480(V) |
640(H) x 480(V) |
Frame rate |
15fps (Mono8, 1360 x 1024) |
30fps (Mono8, 1024 x 768) |
60fps (Mono8, 656 x 492) |
Standard sensitivity |
2000 lx F8 |
2000 lx F5.6 |
Gain |
Auto / Manual (0 dB to 18 dB) |
Electric shutter |
Auto (AES) / Manual (VARIABLE) 1/100,000 second to 10 second |
External trigger shutter |
Mode |
Fixed shutter (Mode0), One trigger (Mode1),Reset control (Mode14), VD Sync (Mode15) |
Input |
Software Trigger: 1394 Cable Hardware Trigger: 1394 Cable (Hitachi System) standard model, or 12 pin connector on S2 or S3 model. |
White balance |
Dimensions |
44 (W) x 44 (H) x 48 (D) mm (not including lens) |
Mass |
Approx. 130 g (not including lens) |
