产品名称: P4级4网口嵌入式主板
型  号: PRA-NB-8371GVE4
品  牌: 1079
产品特性 Product features
P44网口嵌入式主板
   Structure: P4 four Ethernet embedded motherboard
采用Intel 845GE/GV + ICH4芯片组
   Adopted Intel 845GE/GV + ICH4 chipsets
845GE/GV GMCH集成图形控制器
   845GE/GV GMCH integrated graphic controller
4Intel 82540EM 100/1000M Base-T 以太网控制器和1Intel 82562ET 100M Base-T 以太网控制器
   Four Intel 82540EM 100/1000M Base-T Ethernet controller and one Intel 82562ET 100M Base-T Ethernet controller
产品规格 Product specifications
系统参数 System parameters
结构类型:P44网口嵌入式主板
处理器:支持Intel Socket 478 Pentium 4 处理器和Celeron处理器
   Processor: support Intel Socket 478 Pentium 4 and Celeron processors
芯片组: Intel 845GE/GV + ICH4
   Chipset: Intel 845GE/GV + ICH4
内存: 支持DDR 266/333/400 SDRAM,最大内存容量达2GB
   Memory: support DDR 266/333/400 SDRAMthe largest memory up to 2GB
BIOS: Award  BIOS
ATA/IDE: 2IDE接口,支持4ATA-100 IDE设备
   ATA/IDE: two IDE connectors, support four ATA-100 devices
电子盘:支持DOM系列,支持CF,最大容量达1GB
   Electronic disk: support DOM series, support CF card, up to 1GB
看门狗: 256
   Watchdog: 256grade
硬件监测:支持对电压、风扇速度和CPU温度的监测
   Hardware monitor: support the monitoring to voltage, speed of fan and CPU temperature
I/O接口 I/O connector
串口: 2 x RS-232 接口
  Serial ports: 2 x RS-232 connector
并口: 1个并口,支持SPP/EPP/ECP 模式
   Parallel ports: One parallel port, support SPP/EPP/ECP
IrDA: SIR IrDA 1.1 兼容
   IrDA: SIR IrDA 1.1 Compatible
USB: 4 x USB 2.0 接口
   USD: 4 x USB 2.0 connector
键盘/鼠标:1 x PS/2键盘/鼠标接口
   Keyboard/mouse: 1 x PS/2 keyboard and mouse connector
扩展总线: 1 x 32bit PCI 总线接口
   Expansion bus: 1 x 32bit PCI Bus interface
网络 Network
芯片组: Chipset
   4Intel 82540EM 10/100/1000M Base-T 以太网控制器和1Intel 82562ET 100M  Base-T 以太网控制器 Flash BIOS内建启动 ROM, 支持网络唤醒
   Four Intel 82540EM 10/100/1000M Base-T Ethernet controller and one Intel 82562ET 100M  Base-T Ethernet controller build-in boot ROM, support network wake up
显示  Display
显示接口:CRT 显示最高支持2048×1536,刷新率60MHz
   VGA: CRT display support up to 2048×1536, refresh rate 60MHz
环境参数  Environment parameters
电源: ATX电源
   Power supply: ATX
工作温度: 055
   Operation temperature: 055
存储温度: -2070
   Storage temperature: -2070
储存湿度: 090% ,无冷凝
   Storage humidity: 090,non-condensing
外形尺寸: 305mm(L) x 180mm (W)
   Dimensions: 305mm(L) x 180mm(W)
EMI/EMC CCC CE/FCC认证,A
   EMI/EMC CCC CE/FCC approved, Class A
支持操作系统 Supported operation system
Dos6.22/Windows95/98/WindowsNT4.0/windows2000/XP,QNX 4.24, Unix, Linux,OS/2 4.0,Embedded NT
关 键 词:嵌入式, 工控, 强祥北
公司名称: 杭州祈飞科技有限公司
联 系 人: 冯小平
电  话: 0571 85028225
传  真: 0571-85028226
地  址: (浙江省)杭州市西湖区西溪路516号快威大厦103室
邮  编: 310012
主  页: www.hzprayfly.com
  • 网络安全专用主板(PRA-NP425)
  • 一体化工作站(PRA-WS-5212)
  • 一体化工作站(PRA-WS-4601)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
