100 kS/s , 12-bit High-Gain, PCI Multifunction Card |
Ö÷ÒªÌصã
16 single-ended or 8 differential analog inputs
12-bit A/D converter, with up to 100 kHz samping rate
Programmable gain
Automatic channel/gain scanning
On-board FIFO memory (1024 samples)
One 12-bit analog output channel
16 digital inputs and 16 digital outputs
Universal PCI bus (Support 3.3 V or 5 V PCI bus signal)
BoardID? switch |
PCI-1718ϵÁÐÓëPCI-818HϵÁж¼ÊÇ100kS/s¶à¹¦ÄÜÊý¾Ý²É¼¯¿¨,ÌṩÒÔÏÂÎåÖÖ²âÁ¿ºÍ¿ØÖƹ¦ÄÜ: 12λA/Dת»»¡¢D/Aת»»¡¢Êý×ÖÁ¿ÊäÈë¡¢Êý×ÖÁ¿Êä³ö¼°¼ÆÊýÆ÷/ ¶¨Ê±Æ÷¹¦ÄÜ¡£ÓÉÓÚÈýÖÖ·½Ê½µÄ¼æÈÝÐÔ£¬ISA×ÜÏß½«ÓпÉÄÜǨÒƵ½PCI×ÜÏß¡£HG¿¨ÓµÓÐÓëHD¿¨ÏàͬµÄ¹æ¸ñ£¬Í¬Ê±»¹Ìṩһ¸ö¸ßÔöÒæ¿É±à³Ì·Å´óÆ÷ÓÃÀ´¶ÁÈ¡ºÜµÍµÄÊäÈëÐźš£
