²úÆ·Ãû³Æ£º
ѹ·§MCA|¼õѹ·§BRV|BRCV,ѹÁ¦¿ª¹ØJCD|JCS
ÐÍ ºÅ£º
Ïêϸ˵Ã÷£º
̨ÍåÓÍ˳»úе¹¤³§¹É·ÝÓÐÏÞ¹«Ë¾×¨ÒµÉú²ú¸÷ÀàҺѹԪ¼þ¡¢ÒºÑ¹³ÉÌ×ϵͳ¡¢±ê×¼¼°·Ç±ê׼Һѹ¸×¡£¹«Ë¾ÒÑͨ¹ýISO9001£º2000ÖÊÁ¿ÈÏÖ¤£¬²»¶Ï²ÉÓÃм¼Êõ¡¢Ð¹¤ÒÕ¡¢ÐÂ×°±¸£¬ÓµÓÐÐÛºñµÄ¼¼ÊõʵÁ¦ºÍÏȽøµÄÉú²úÉ豸£¬¾ßÓзḻµÄרҵÉè¼ÆÉú²ú¾Ñ飬²úÆ·¹ã·ºÓ¦ÓÃÓÚ¸÷ÖÖ»ú´²¡¢¸ÖÌúÒ±½ð¡¢¿óɽ¡¢»¯¹¤¡¢´¬²°¡¢Æû³µ¡¢Ë®µçÁ¦µÈÐÐÒµ£¬ÉîµÃ¹ã´ó¹Ë¿ÍÐÅÀµºÍÈÏ¿É¡£ | | |
ressure Reducing and Check Valves |
¼õѹ·§¸½ÄæÖ¹·§ | | | |
BRV |
03 |
G |
B |
ϵÁбàºÅ SERIES NUMBER R£ºREDUCING RC£ºREDUCING ADDED TO DESIGNATED INTEGRAL CHECK |
³Æºô¿Ú¾¶ VALVE SIZE |
½ÓÐøÐÍʽ TYPE OF CONNECTION G£ºSUB-PLATE TYPE T£ºTHREADED TYPE |
ѹÁ¦µ÷Õû·¶Î§ PRESSURE ADJ.RANGE | | |
¼õѹ·§ÐÍʽºÅÂëMODEL |
×î¸ßʹÓÃѹÁ¦MAX.OPERATED PRESSURE£¨kgf/cm2£© |
ѹÁ¦µ÷Õû·¶Î§PRESSURE ADJ.RANGE£¨kgf/cm2£© |
×î´óÁ÷Á¿MAX.FLOW l/min |
йÓÍÁ¿DRAIN l/min |
ÖØÁ¿ WEIGHT £¨kg£© |
×ùµæÐÍ SUB-PLATE TYPE |
Åä¹ÜÐÍTHREAD TYPE |
BRV-03G |
BRV-03T |
250 |
B£º5-70 C£º35-140 H£º70-210 |
50 |
0.8-1 |
4.5 |
4.3 |
BRV-06G |
BRV-06T |
125 |
0.8-1.1 |
6.8 |
6.9 |
BRV-10G |
BRV-10T |
250 |
1.2-1.5 |
11.0 |
12.0 |
BRCV-03G |
BRCV-03T |
50 |
1.8-1 |
5.4 |
4.8 |
BRCV-06G |
BRCV-06T |
125 |
0.8-1.1 |
8.1 |
7.8 |
BRCV-10G |
BRCV-10T |
250 |
1.2-1.5 |
13.8 |
13.8 | |
ack Pressure Control Valves |
±³Ñ¹·§ | |
Ñ¡¹ºÖ¸ÄÏ HOW TO ORDER | |
JCS |
02 |
NL |
ϵÁбàºÅ SERIES NUMBER |
ÐÔÄܱí SPECIFICATION | |
ѹÁ¦¿ª¹ØÐÍʽºÅÂëMODEL |
×î¸ßѹÁ¦ MAX. PRESSURE£¨kgf/cm2£© |
JCD-02-L |
3-30 |
70 |
0.8 |
JCS-02 |
N:30-210 NL:15-60 NLL:3-35 |
210 210 70 |
1
MCA |
06 |
G |
B |
½ÓÐøÐÍʽ TYPE OF CONNECTION |
±³Ñ¹·§ÐÍʽºÅÂë MODEL |
¶¨¸ñÁ÷Á¿ RATED FLOW l/min |
×ùµæÐÍSUB-PLATE TYPE |
MCA-06G |
B£º7-70 C£º35-140 H£º70-210 |
120 |
12 |
MCA-10G |
240 |
22 | | | |
