²úÆ·Ãû³Æ£º
MFJ9-27YC½»Á÷ʪʽ·§Óõç´ÅÌú
ÐÍ ºÅ£º
Ïêϸ˵Ã÷£º
MFJ9-27YC½»Á÷ʪʽ·§Óõç´ÅÌú |
¶î¶¨µçѹ Reated voltage (V) |
AC:110 220 50Hz AC:120 240 60Hz |
¶î¶¨ÎüÁ¦ Rated force (N) |
27 |
¶î¶¨ÐÐ³Ì Rated stroke (mm) |
3 |
È«ÐÐ³Ì Total stroke (mm) |
¡Ý6.5 |
ͨÓóÖÐøÂÊ Duty cycle (%) |
100 |
¾øÔµµÈ¼¶ Insulation class |
H |
×î¸ß²Ù×÷ƵÂÊ Max operation frequency (t/h) |
12000 |
ÔÊÐíµçѹ²¨¶¯·¶Î§ Supply voltage tolerance (%) |
+10¡«-15 |
·À»¤µÈ¼¶ Degree of protection |
IP65 |
µ¼Ì׳ÐÊÜÓÍѹ Working pressure (MPa) |
21 |
ÏûºÄ¹¦ÂÊ Power consumption (W) |
¡ª |
Æ𶯷ü°² Inrush VA (VA) |
¡Ü188 |
Îü³Ö·ü°² Holding VA (VA) |
¡Ü60 |
