²úÆ·Ãû³Æ£º
Marsh 63mm 100mmѹÁ¦±í
ÐÍ ºÅ£º
JϵÁУ¬XϵÁÐ,WϵÁÐ
63mmϵÁгäÓͲ»Ðâ¸ÖѹÁ¦±í |
Case Material |
stainless steel |
Internals |
Copper Alloy |
Stainless Steel |
Mounting |
LM |
U |
CB |
LM |
U |
CB |
Connection(NPT) |
1/4" |
1/4" |
1/4" |
1/4" |
1/4" |
1/4" |
Dual Scal Standard |
psi/kPa |
0 to 30" Hg VAC |
J7605P |
J7205P |
J6405P |
J7805P |
J7405P |
J6605P |
30" Hg VAC to 15 psi |
30" Hg VAC to 30 psi |
J7612P |
30" Hg VAC to 60 psi |
J7614P |
30"Hg VAC to 100 psi |
30" Hg VAC to 150 psi |
J7618P |
J7218P |
J6418P |
J7818P |
J7418P |
J6618P |
30" Hg VAC to 200 psi |
J7620P |
J7220P |
J6420P |
J7820P |
J7420P |
J6620P
30" Hg VAC to 300 psi |
J7624P |
J7224P |
J6424P |
J7824P |
J7424P |
J6624P
30" Hg VAC to 400 psi |
J7626P |
J7226P |
J6426P |
J7826P |
J7426P |
J6626P |
0 to 15 psi |
J7640P |
J7240P |
J6440P |
J7840P |
J7440P |
J6640P
0 to 30 psi |
J7642P |
J7242P |
J6442P |
J7842P |
J7442P |
J6642P
0 to 60 psi |
J7646P |
J7246P |
J6446P |
J7846P |
J7446P |
J6646P |
0 to 100 psi |
J7648P |
J7248P |
J6448P |
J7848P |
J7448P |
J6648P
0 to 160 psi |
J7652P |
J7252P |
J6452P |
J7852P |
J7452P |
J6652P
0 to 200 psi |
J7654P |
J7254P |
J6454P |
J7854P |
J7454P |
J6654P
0 to 300 psi |
J7658P |
J7258P |
J6458P |
J7858P |
J7458P |
J6658P
0 to 400 psi |
J7660P |
J7260P |
J6460P |
J7860P |
J7460P |
J6660P
0 to 600 psi |
J7664P |
J7264P |
J6464P |
J7864P |
J7464P |
J6664P |
0 to 1,000 psi |
J7672P |
J7272P |
J6472P |
J7872P |
J7472P |
J6672P
0 to 1,500 psi |
J7674P |
J7274P |
J6474P |
J7874P |
J7474P |
J6674P
0 to 2,000 psi |
J7676P |
J7276P |
J6476P |
J7876P |
J7476P |
J6676P |
0 to 3,000 psi |
J7678P |
J7278P |
J6478P |
J7878P |
J7478P |
J6678P
0 to 5,000 psi |
J7682P |
J7282P |
J6482P |
J7882P |
J7482P |
J6682P
0 to 6,000 psi |
J7684P |
J7284P |
J6484P |
J7884P |
J7484P |
J6684P
0 to 10,000 psi |
J7890P |
J7490P |
J6690P |
Internals Copper Alloy Stainless Steel Mounting / Case Style LM UC CB LM UC CB |
100mmϵÁгäÓͲ»Ðâ¸ÖѹÁ¦±í |
Case Material |
stainless steel |
Internals |
Copper Alloy |
Stainless Steel |
Mounting |
LM |
CB |
UC |
LM |
CB |
UC |
Connection(NPT) |
1/4" |
1/4" |
1/4" |
1/4" |
1/4" |
1/4" |
psi/kPa |
0 to 30" Hg VAC |
X32965P |
X32967P |
X32501P |
X32502P |
X32887P |
X32901P |
X32894P |
X32929P |
X32941P |
X32935P |
X32888P
X32902P |
X32895P |
X32930P |
X32942P |
X32936P
X32889P |
X32903P |
X32896P |
X32931P |
X32943P |
X32937P
0 to 15 psi |
X32504P |
X32546P |
X32525P |
X32630P |
X32678P |
X32654P |
0 to 30 psi |
X32505P
X32547P |
X32526P |
X32631P |
X32679P |
X32655P
0 to 60 psi |
X32506P |
X32548P |
X32527P |
X32632P |
X32680P |
X32656P
0 to 100 psi |
X32507P |
X32549P |
X32528P |
X32633P |
X32681P |
X32657P |
0 to 160 psi |
X32508P
X32550P |
X32529P |
X32634P |
X32682P |
X32658P
0 to 200 psi |
X32509P |
X32551P |
X32530P |
X32635P |
X32683P |
X32659P
0 to 300 psi |
X32510P |
X32552P |
X32531P |
X32636P |
X32684P |
X32660P |
0 to 400 psi |
X32511P
X32553P |
X32532P |
X32637P |
X32685P |
X32661P
0 to 600 psi |
X32512P |
X32554P |
X32533P |
X32638P |
X32686P |
X32662P
0 to 1,000 psi |
X32513P |
X32555P |
X32534P |
X32639P |
X32687P |
X32663P |
0 to 1,500 psi |
X32514P |
X32556P |
X32535P |
0 to 2,000 psi |
X32515P
X32557P |
X32536P |
X32641P |
X32689P |
X32665P
0 to 3,000 psi |
X32516P |
X32558P |
X32537P |
X32642P |
X32690P |
X32666P
0 to 5,000 psi |
X32518P |
X32560P |
X32539P |
X32644P |
X32692P |
X32668P
0 to 6,000 psi |
X32519P |
X32561P |
X32540P |
X32645P |
X32693P |
X32669P |
0 to 10,000 psi |
X32647P |
X32695P |
X32671P |
NOTE: shaded areas indicate items are available on special order, however, minimums and lead times apply. Consult factory. |
