²úÆ·Ãû³Æ£º
°îÄÉBANNERDX70ÎÞÏßͨѶģ¿é
ÐÍ ºÅ£º
DX70
²úÆ·¼¼Êõ¹æ¸ñ SureCross DX70 wireless networks consist of a radio frequency network system built around two devices and configured I/O.
- A network includes a Gateway and one Node that operate in the same frequency band.
- 900 MHz or 2.4 GHz frequency models are available to accommodate worldwide communication standards.
- Models include discrete and analog I/O.
- Input-to-output mapping is controlled by a configured Gateway.
- Open design supports inputs from sensors and devices made by Banner and other manufacturers.
- Frequency Hopping Spread Spectrum (FHSS) and Time Division Multiple Access (TDMA) architecture combine to ensure reliable data delivery.
- Rotary switch for network identity is easy to set and change.
- Gateways and Nodes require 10 to 30V dc power.
- Models with internal or external antennas are available, depending on application requirements.
- Wiring terminals are accessible without removal from mounting.
- Base is designed for four-point flat mounting or DIN-rail mounting.
- Housing is rated IEC IP67; NEMA 6 for long-lasting performance in rugged environments.
ÉîÛÚÊлªÎ°´ï¿Æ¼¼ÓÐÏÞ¹«Ë¾×¨ÒµÌṩ¹¤ÒµÎÞÏßÍøÂç½â¾ö·½°¸¡£ ÁªÏµµç»°£º0755-61665101 15818601503Ò×С½ã ´«Õ棺0755-61665102 QQ£º877026684 Email£ºhuaweida@qq.com MSN£ºhuaweida2009@hotmail.com ÍøÖ·£ºhttp://www.hwdauto.com
