DCR® IV Light Source
DC regulated light source with integrated Equalizer™ light feedback to provide
stabilized light output for the most demanding machine vision inspection applications. (See DCR® III Plus datasheet for base description.)
Benefits
1. Stable lamp output over the life of the lamp and minimized lamp to lamp variation.
2. Remote controllable using integrated RS232 interface.
Standard Features
1. Flexible - Two configurations available:
A. DCR® IV used with a reference Modulamp® unit and off-the-shelf fiber
optics, maintains DDL lamp output a
¡À2% over the life of the lamp and ¡À8% lamp to lamp.
B. For even greater control, use the DCR® IV with fiber optic products that have an integrated reference bundle; special order only. This will maintain DDL lamp output and lamp to lamp variation within ¡À1%.
2. All of the features of the DCR® III Plus Light Source including control of up to three additional DCR® III light sources via an expansion cable.
3. LED¡¯s located on the front panel indicate that the lamp intensity is stabilized.
4. Easy to use front panel controls for calibration and intensity control.
5. CSA certified to UL, CE compliant to low voltage and EMC directives.
6. Universal input voltage ¨C accepts 90 to 265 VAC, 50/60 Hz. |
