ÉϺ£¾©¹¤ÊµÒµÓÐÏÞ¹«Ë¾ÊÇÒ»¸ö×ۺϹúÄÚÍâÓÅÐãÉú»¯ÊµÑéÉ豸ÖÆÔì¾Ñé¶À¼ÒÉú²úµÄZF-1ÐÍÈýÓÃ×ÏÍâ·ÖÎöÒÇ£¬½øÐÐϵͳÏê½â£¬¿É¿ìËÙ²éѯ²úÆ·µÄ×îб¨¼Û¡¢Í¼Æ¬¡¢¼¼Êõ²ÎÊý£¬»òÕß½øÐвúÆ·ÐÔÄܱȽϣ¬Ê¹Ó÷dz£·½±ã¡£
ZF-1ÐÍÈýÓÃ×ÏÍâ·ÖÎöÒÇÒÇÆ÷Ìص㣺
ZF-1ÐÍÈýÓÃ×ÏÍâ·ÖÎöÒÇ×ÏÍâµÆµÆ¹Ü·¢³öµÄ¹â¾Â˹âƬÂËÈ¥¿É¼û¹â£¬´Ó¶øΪӫ¹â·ÖÎöÌṩÁËÇ¿ÁÒµÄ254nmºÍ365nm×ÏÍâ¹â¡£
ZF-1ÐÍÈýÓÃ×ÏÍâ·ÖÎöÒǾßÓÐÏûºÄ¹¦ÂÊС£¬ÈÈÁ¿µÍ£¬¿ÉÒÔ³¤Ê±¼äÁ¬ÐøʹÓã¬×î´óµÄÓŵãÊÇ¿ÉÒÔË濪Ëæ¹ØÒ»¿ª¼´¿ÉʹÓã¬Ê®·Ö·½±ã¡£
ZF-1ÐÍÈýÓÃ×ÏÍâ·ÖÎöÒÇÓÃ;
¢Å ÔÚ¿ÆѧʵÑ鹤×÷Öмì²â£¬Ðí¶àÖ÷ÒªÎïÖÊÈçµ°°×ÖÊ¡¢ºËÜÕËáµÈ¡£
¢Æ ÔÚÒ©ÎïÉú²úºÍÑо¿ÖУ¬¿ÉÓÃÀ´¼ì²é¼¤ËØÉúÎï¼î£¬Î¬ÉúËصȸ÷ÖÖÄÜ£»²úÉúÓ«¹âÒ©Æ·ÖÊÁ¿£¬ËüÌرðÊÊÒË×÷±¡²ã·ÖÎöºÍÖ½²ã·ÖÎö°ßµãºÍ¼ì²â¡£
¢Ç ÔÚȾÁÏÍ¿ÁÏÏ𽺡¢Ê¯Ó͵Ȼ¯Ñ§ÐÐÒµÖУ¬²â¶¨¸÷ÖÖÓ«¹â²ÄÁÏ£¬Ó«¹âָʾ¼Á¼°Ìí¼Ó¼Á£¬¼ø±ð²»Í¬ÖÖÀàµÄÔÓͺÍÏð½ºÖÆÆ·¡£
¢È ·ÄÖ¯»¯Ñ§ÏËάÖпɲⶨ²»Í¬ÖÖÀàµÄÔ²ÄÁÏ¡£ÈçÑò룬ÕæË¿ÈËÔìÏËά£¬ÃÞ»¨£¬ºÏ³ÉÏËά£¬²¢¿É¼ì²é³ÉÆ·ÖÊÁ¿¡£
¢É ÔÚÁ¸ÓÍ£¬Ê߲ˣ¬Ê³Æ·²¿ÃÅ£¬¿ÉÓÃÓÚ¼ì²é¶¾ËØ¡££¨Èç»ÆÇúùËصȣ©Ê³Æ·Ìí¼Ó¼Á£¬±äÖʵÄÊ߲ˡ¢Ë®¹û¡¢¿É¿É¶¹ô³¡¢ÇÉ¿ËÁ¦¡¢Ö¬·¾¡¢·äÃÛ¡¢Ìǵ°µÈµÄÖÊÁ¿¡£
¢Ê ÔÚµØÖÊ¡¢¿¼¹ÅµÈ²¿ÃÅ£¬¿ÉÆðµ½·¢ÏÖ¸÷ÖÖ¿óÎïÖÊ£¬ÅбðÎÄÎﻯʯµÄÕæα¡£
¢Ë ÔÚ¹«°²²¿Ãſɼì²éÖ¸ºÛ²â¶¨ÃÜд×Ö¼£µÈ¡£
ϵÁвúÆ·£º¶Ì²¨×ÏÍâ·ÖÎöÒÇ¡¢³¤²¨×ÏÍâ·ÖÎöÒÇ£¬ËÄÓÃ×ÏÍâ·ÖÎöÒÇ¡£
ZF-1ÐÍÈýÓÃ×ÏÍâ·ÖÎöÒÇΪZSZ-6-AºÍZSZ-6-B×ÏÍâÏߵƹܼ°Â˹âƬ×é³É¡£ZSZ-6-A·¢³ö£¨¶Ì²¨£©254-mm²¨³¤£¬ZSZ-6-B³ö£¨³¤²¨£©365-nm²¨³¤£¬Ò»»úÒàÄÜͬʱ·¢³ö£¬»ìºÏÁ½ÖÖ²¨³¤¡£
This instrument consists of an ultraviolet lamp with the type of ZSZ-6-A £ánd an ultraviolet lamp with the type of ZSZ-6-B £ánd the filters.The lamp of ZSZ-6-A emits the light with short wavelength of 254nm £ánd the lamp of ZSZ-6-B emits the light with long wavelength of 365nm. This instrument can also emit the two lights mixed with the wavelength mentioned above.
#FEATURES OF THE INSTRUMENT:
¡¡¡¡Low power consumption.
¡¡¡¡Low thermal effect caused at the parts of the instrument.
¡¡¡¡The operation can run continually £ánd be lasting for a long time.
¡¡¡¡The most advantages are:
¡¡¡¡The operation starts immediately when switch on.It is very convenient to switch on £ánd switch off frequently optionally.
¡¡¡¡Provides the intensive ultraviolet lights of 254 £ánd 365nm for the fluorescent analysis by means of that the lights emitted from the ultraviolet lamps £ánd the visible light is filtered by passing through the filters.
#APPLICATIONS:
¡¡¡¡¢Å Detect various substances such as protein £ánd nucleotide,etc,at the scientific experiment areas.
¡¡¡¡¢Æ Examine the qualities of various medicines which can emit fluorescence at the medicines production £ánd development such as hormone,alkaloid,vitamins,etc.This instrument is particularly suitable to undertake the spots analysis £ánd detecting for thin-layer chromatography £ánd paper chromatography.
¡¡¡¡¢Ç Examine the various fluorescence emitting materials,fluorescence indicators £ánd additives,distinguish the different crude oil £ánd rubber products at the enterprises engaging in chemical products such as dyes,coating,rubber,petroleum,etc.
¡¡¡¡¢È Examine the different raw £ánd processed material such as wool,real silk,rayon, cotton,
synthetic fiber,etc £ánd check the ouelities of their products at the areas engaging in textil chemistry fiber,development.
¡¡¡¡¢É Check the toxin£¨such as flevacin£©,food additive,spoiled vegetables,fruits,ca-ca-os fat,
chocolate,fat,honey,sugar,eggs,etc at the departments engaging in food,oil £ánd vegetables development.
¡¡¡¡¢Ê Discover various minerals £ánd distinguish the real of false for the histonical relics £ánd fossils at the department of geology £ánd archaeology.
¡¡¡¡¢Ë Check the fingering trails £ánd characters trails written in secret at the publis security bureau.
ZF-1ÐÍÈýÓÃ×ÏÍâ·ÖÎöÒÇÖ÷Òª¼¼Êõ²ÎÊý
ÐÍ ºÅ ÍâÐͳߴçmm ³¤¡Á¿í¡Á¸ß Ö÷ Òª Åä Öà ÖØÁ¿£¨Kg£© µ¥¼Û£¨Ôª£©
ZF-1ÈýÓÃ×ÏÍâ·ÖÎöÒÇ 280¡Á265¡Á300 ²¨³¤£º254¡¢365nm£¬¿É¼û¹â£¬ÂËɫƬÃæ»ý:200¡Á50mm 3.5
ZF-2ÈýÓÃ×ÏÍâ·ÖÎöÒÇ 280¡Á265¡Á300 ²¨³¤£º254¡¢254nm£¬¿É¼û¹â£¬ÂËɫƬÃæ»ý:200¡Á50mm 3.5
ZF-3ÈýÓÃ×ÏÍâ·ÖÎöÒÇ 280¡Á265¡Á300 ²¨³¤£º365¡¢365nm£¬¿É¼û¹â£¬ÂËɫƬÃæ»ý:200¡Á50mm 3.5
