>> System
Processor LGA775, Core 2 Duo/Pentium Dual-Core/Pentium EE/Pentium D/Pentium 4/ Celeron D
Chipset Intel 945GC + ICH7 + FWH with 533/800/1066MHz
DRAM 2 x 240PIN Dual Channel DDRII 533/667/800 max up to 4GB
BIOS 4MB AMI BIOS
BUS PICMG 1.0
Power Supply Support ACPI V2.0 specification
Watchdog 1~255 sec Watchdog timer selectable w/Reaset/NMI
Dimension 338mm x 122mm
>>Rear Panel I/O Ports
VGA 1 x DB-15 VGA port
LAN 1 x RJ-45 LAN ports
USB 2 x USB 2.0/1.1 ports
>> I/O Connectors
SATA 2 x SerialII ATA connector
IDE 1 x 40-pin IDE connector
LPT 1 x Parallel connector
USB 2 x connectors for 4 additional external USB 2.0/1.1 ports
Keyboard & Mouse 1 x mini-DIN-6 PS/2 keyboard & Mouse port
COM 2 x COM ports, COM1 for RS232, COM2 for RS232/422/485
Audio 1 x front audio connector for line-out and Mic-in jacks
CD-in 1 x CD-in internal audio connector
Power 1 x 4-pin ATX +12V power connector
Fan 2 x Fan connector
>> Display
Graphics Intel Graphic Media Accelerator 950, Max share 224MB memory
>> Environment
Operation Temperature 0¡ã~60¡ãC (32¡ã~140¡ãF)
Humidity 10~90%
