²úÆ·Ãû³Æ£º
MARSH ÆÕͨѹÁ¦±í
ÐÍ ºÅ£º
JϵÁÐÆÕͨѹÁ¦±í
MARSH ÆÕͨѹÁ¦±í
¾«¶ÈAccuracy |
ASME Grade B¨C¡À3/2/3% (¡À2% of range across middle half of scale) |
±í¾¶Case Size |
1-1/2", 2", 2-1/2", 3-1/2", 4-1/2" diameter |
Íâ¿Ç²ÄÖÊCase Material |
Steel, black painted |
°²×°·½Ê½Case Style |
CB ¨C Center Back Mount LM ¨C Lower Mount UC ¨C U-Clamp Mount See option tables for Front Flange |
ÄÚо²ÄÖÊTube & Socket |
Copper alloy |
Ô˶¯¼þ²ÄÖÊMovement |
Brass |
½Ó¿ÚConnection |
18260;8 & 1/4 NPT |
²âÁ¿·¶Î§Ranges |
0 to 30" Hg VAC; Compound 30" Hg vac to 400 psi; 15 to 5,000 psi |
¿Ì¶ÈÅÌDial Standard |
Dual scale psi and kPa |
¿Ì¶ÈÅÌÑÕÉ«Dial Color |
Black markings on white |
Ö¸ÕëPointer |
Aluminum, Black painted |
´°¿ÚWindow |
1-1/2", 2", 2-1/2", 3-1/2": acrylic, twist-in Clearlok 4-1/2": flat glass window with steel friction ring |
ÏÞλÆ÷Restrictor |
Standard for ranges 1,000 psi and above |
MARSH ÆÕͨѹÁ¦±í¶©»õÑ¡ÐÍ Part Numbers£º1-1/2"£»2" |
Size |
1-1/2" |
2" |
Case Material |
Steel |
Steel |
Internals |
Copper Alloy |
Copper Alloy |
Mounting / Case Style ase Style |
LM |
UC |
CB |
LM |
LM |
CB |
CB |
UC |
UC |
Connection |
18260;8 NPT |
18260;8 NPT |
18260;8 NPT |
18260;8 NPT |
18260;4 NPT |
18260;8 NPT |
18260;4 NPT |
18260;8 NPT |
18260;4 NPT |
Scale Standard |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
0 to 30" Hg VAC |
J0405 |
J0505 |
J0605 |
J1105 |
J1405 |
J1805 |
J2005 |
J2405 |
J2605 |
30" Hg VAC to 15 psi |
30" Hg VAC to 30 psi |
J1412 |
30" Hg VAC to 60 psi |
J1414 |
30" Hg VAC to 100 psi |
30" Hg VAC to 150 psi o 150 psi |
J0418 |
J0518 |
J0618 |
J1118 |
J1418 |
J1818 |
J2018 |
J2418 |
J2618 |
30" Hg VAC to 200 psi o 200 psi |
J0420 |
J0520 |
J0620 |
J1120 |
J1420 |
J1820 |
J2020 |
J2420 |
J2620 |
30" Hg VAC to 300 psi o 300 psi |
J0424 |
J0524 |
J0624 |
J1124 |
J1424 |
J1824 |
J2024 |
J2424 |
J2624 |
30" Hg VAC to 400 psi |
J1126 |
J1426 |
J1826 |
J2026 |
J2426 |
J2626 |
0 to 15 psi |
J0440 |
J0540 |
J0640 |
J1140 |
J1440 |
J1840 |
J2040 |
J2440 |
J2640 |
0 to 30 psi |
J0442 |
J0542 |
J0642 |
J1142 |
J1442 |
J1842 |
J2042 |
J2442 |
J2642 |
0 to 60 psi |
J0446 |
J0546 |
J0646 |
J1146 |
J1446 |
J1846 |
J2046 |
J2446 |
J2646 |
0 to 100 psi |
J0448 |
J0548 |
J0648 |
J1148 |
J1448 |
J1848 |
J2048 |
J2448 |
J2648 |
0 to 160 psi |
J0452 |
J0552 |
J0652 |
J1152 |
J1452 |
J1852 |
J2052 |
J2452 |
J2652 |
0 to 200 psi |
J0454 |
J0554 |
J0654 |
J1154 |
J1454 |
J1854 |
J2054 |
J2454 |
J2654 |
0 to 300 psi |
J0458 |
J0558 |
J0658 |
J1158 |
J1458 |
J1858 |
J2058 |
J2458 |
J2658 |
0 to 400 psi |
J1160 |
J1460 |
J1860 |
J2060 |
J2460 |
J2660 |
0 to 600 psi |
J1464 |
J1864 |
0 to 1,000 psi |
0 to 1,500 psi |
0 to 2,000 psi |
0 to 3,000 psi |
J1478 |
J1878 |
J2078 |
J2478 |
J2678 |
0 to 5,000 psi |
J1482 |
NOTE: Shaded areas indicate items are available on special order. However, minimums and lead times apply. Consult factory. |
MARSH ÆÕͨѹÁ¦±í¶©»õÑ¡ÐÍ Part Numbers£º2-1/2"£»3-1/2"£»4-1/2" |
Size |
2-1/2" |
3-1/2" |
4-1/2" |
Case Material |
Steel |
Steel |
Steel |
Internals |
Copper Alloy |
Copper Alloy |
Copper Alloy |
LM |
LM |
CB |
CB |
UC |
UC |
LM |
CB |
UC |
LM |
Connection |
18260;8 NPT |
18260;4 NPT |
18260;8 NPT |
18260;4 NPT |
18260;8 NPT |
18260;4 NPT |
18260;4 NPT |
18260;4 NPT |
18260;4 NPT |
18260;4" NPT |
Scale Standard |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
psi/kPa |
0 to 30" Hg VAC |
J4005 |
J4605 |
J5005 |
J5405 |
J6005 |
J6205 |
J8005 |
J8605 |
J8805 |
J9005 |
J4612 |
J8012 |
J4614 |
J8014 |
J9014 |
J4018 |
J4618 |
J5018 |
J5418 |
J6018 |
J6218 |
J8018 |
J8618 |
J8818 |
J9018 |
J4020 |
J4620 |
J5020 |
J5420 |
J6020 |
J6220 |
J8020 |
J8620 |
J8820 |
J9020 |
J4024 |
J4624 |
J5024 |
J5424 |
J6024 |
J6224 |
J8024 |
J8624 |
J8824 |
J9024 |
30" Hg VAC to 400 psi o 400 psi |
J4026 |
J4626 |
J5026 |
J5426 |
J6026 |
J6226 |
J8026 |
J8626 |
J8826 |
J9026 |
0 to 15 psi |
J4040 |
J4640 |
J5440 |
J6240 |
J8040 |
J8640 |
J8840 |
J9040 |
0 to 30 psi |
J4042 |
J4642 |
J5042 |
J5442 |
J6042 |
J6242 |
J8042 |
J8642 |
J8842 |
J9042 |
0 to 60 psi |
J4046 |
J4646 |
J5046 |
J5446 |
J6046 |
J6246 |
J8046 |
J8646 |
J8846 |
J9046 |
0 to 100 psi |
J4048 |
J4648 |
J5048 |
J5448 |
J6048 |
J6248 |
J8048 |
J8648 |
J8848 |
J9048 |
0 to 160 psi |
J4052 |
J4652 |
J5052 |
J5452 |
J6052 |
J6252 |
J8052 |
J8652 |
J8852 |
J9052 |
0 to 200 psi |
J4054 |
J4654 |
J5054 |
J5454 |
J6054 |
J6254 |
J8054 |
J8654 |
J8854 |
J9054 |
0 to 300 psi |
J4058 |
J4658 |
J5058 |
J5458 |
J6058 |
J6258 |
J8058 |
J8658 |
J8858 |
J9058 |
0 to 400 psi |
J4060 |
J4660 |
J5060 |
J5460 |
J6060 |
J6260 |
J8060 |
J8660 |
J8860 |
J9060 |
0 to 600 psi |
J4664 |
J8064 |
J8664 |
J8864 |
J9064 |
0 to 1,000 psisi |
J4072 |
J4672 |
J5472 |
J6272 |
J8672 |
J8872 |
J9072 |
0 to 1,500 psi |
J4674 |
J8074 |
0 to 2,000 psi |
J4676 |
J5476 |
J6276 |
J9076 |
0 to 3,000 psi |
J4678 |
J5078 |
J5478 |
J6078 |
J6278 |
0 to 5,000 psi |
J4682 |
J8682 |
J8882 |
J9082 |
NOTE: shaded areas indicate items are available on special order, however, minimums and lead times apply. Consult factory. |
