²úÆ·Ãû³Æ£º
MARSH¹ý³Ì¾«ÃÜѹÁ¦±í
ÐÍ ºÅ£º
PϵÁйý³Ì¾«ÃÜѹÁ¦±í
MARSH¹ý³Ì¾«ÃÜѹÁ¦±í
¾«¶ÈAccuracy |
ASME Grade 2A ¨C ¡À0.5% of full scale |
±í¾¶Case Sizes |
4-1/2" and 6" diameter |
Íâ¿Ç²ÄÖÊCase Material |
Safecase polypropylene (turret style only) & safecase aluminum |
°²×°·½Ê½Case Style |
4-1/2" G ¨C Back flanged case (aluminum) H ¨C Front flange hinged ring (aluminum) T ¨C Turret (polypropylene) 6" G ¨C Back flanged case |
ÄÚо²ÄÖÊTube & Socket |
Copper alloy or 316 stainless steel |
Ô˶¯¼þ²ÄÖÊMovement |
Stainless Steel |
½Ó¿ÚConnection |
1/4 or 1/2 NPT LM ¨CLower Mount LBM ¨C Lower Back Mount |
²âÁ¿·¶Î§Ranges |
0 to 30" Hg VAC; Compound 30" Hg VAC to 300 psi; 15 to 20,000 psi |
¿Ì¶ÈÅÌDial Standard |
Single Scale psi |
¿Ì¶ÈÅÌÑÕÉ«Dial Color |
Black markings on white |
Ö¸ÕëPointer |
Aluminum Adjustable Micrometer, black painted |
´°¿ÚWindow |
Acrylic |
³äÒº½éÖÊFill Medium |
Dry or filled. Note: ALL 4-1/2" lower mount Process Gauges are field- fillable. Optional factory filled glycerin or silicone |
±£ÏÕ¼þSafecase |
Safecase construction standard on all Process Gauges |
ÅÅÆøVent |
Internal compensating diaphragm |
4-1/2" MARSH¹ý³Ì¾«ÃÜѹÁ¦±í¶©»õÑ¡ÐÍ Part Numbers |
Case Material |
Polypropylene |
Polypropylene |
Aluminum |
Aluminum |
Internals |
Copper Alloy |
Stainless Steel |
Copper Alloy |
Stainless Steel |
Mounting |
LM |
LBM |
LM |
LBM |
LM |
LBM |
LM |
LBM |
LM |
LM |
LBM |
LBM |
LBM |
LBM |
LM |
LM |
LBM |
LBM |
LBM |
LBM |
Case Style |
T |
T |
T |
T |
T |
T |
T |
T |
G |
G |
G |
G |
H |
H |
G |
G |
G |
G |
H |
H |
Connection |
1/4 NPT |
1/4 NPT |
1/2 NPT |
1/2 NPT |
1/4 NPT |
1/4 NPT |
1/2 NPT |
1/2 NPT |
1/4 NPT |
1/2 NPT |
1/4 NPT |
1/2 NPT |
1/4 NPT |
1/2" NPT |
1/4 NPT |
1/2 NPT |
1/4 NPT |
1/2 NPT |
1/4 NPT |
1/2 NPT |
0 to 30" Hg VAC |
P0105 |
P0205 |
P0505 |
P0605 |
P5105 |
P5205 |
P5605 |
P5705 |
P10005 |
P10505 |
P11005 |
P11505 |
P16005 |
P16505 |
P14005 |
P14505 |
P15005 |
P15505 |
P18005 |
P18505 |
30" Hg VAC to 15 psi |
P0110 |
P0210 |
P0510 |
P0610 |
P5110 |
P5210 |
P5610 |
P5710 |
P10010 |
P10510 |
P11010 |
P11510 |
P16010 |
P16510 |
P14010 |
P14510 |
P15010 |
P15510 |
P18010 |
P18510 |
30" Hg VAC to 30 psi |
P0112 |
P0212 |
P0512 |
P0612 |
P5112 |
P5212 |
P5612 |
P5712 |
P10012 |
P10512 |
P11012 |
P11512 |
P16012 |
P16512 |
P14012 |
P14512 |
P15012 |
P15512 |
P18012 |
P18512 |
30" Hg VAC to 60 psi |
P0114 |
P0214 |
P0614 |
P5114 |
P5214 |
P5614 |
P5714 |
P10014 |
P10514 |
P11014 |
P11514 |
P16014 |
P16514 |
P14014 |
P14514 |
P15014 |
P15514 |
P18014 |
P18514 |
30" Hg VAC to 100 psi |
P0116 |
P0216 |
P0516 |
P0616 |
P5116 |
P5216 |
P5616 |
P5716 |
P10016 |
P10516 |
P11016 |
P11516 |
P16016 |
P16516 |
P14016 |
P14516 |
P15016 |
P15516 |
P18016 |
P18516 |
30" Hg VAC to 200 psi |
P0120 |
P0220 |
P0520 |
P0620 |
P5120 |
P5220 |
P5620 |
P5720 |
P10020 |
P10520 |
P11020 |
P11520 |
P16020 |
P16520 |
P15020 |
P15520 |
P18020 |
P18520 |
30" Hg VAC to 300 psi |
P0124 |
P0224 |
P0524 |
P0624 |
P5124 |
P5224 |
P5624 |
P5724 |
P10024 |
P10524 |
P11024 |
P11524 |
P16024 |
P16524 |
P15024 |
P15524 |
P18024 |
P18524 |
0 to 15 psi |
P0140 |
P0240 |
P0540 |
P0640 |
P5140 |
P5240 |
P5640 |
P5740 |
P10040 |
P10540 |
P11040 |
P11540 |
P16040 |
P16540 |
P14040 |
P14540 |
P15040 |
P15540 |
P18040 |
P18540 |
0 to 30 psi |
P0142 |
P0242 |
P0542 |
P0642 |
P5142 |
P5242 |
P5642 |
P5742 |
P10042 |
P10542 |
P11042 |
P11542 |
P16042 |
P16542 |
P14042 |
P14542 |
P15042 |
P15542 |
P18042 |
P18542 |
0 to 60 psi |
P0146 |
P0246 |
P0546 |
P0646 |
P5146 |
P5246 |
P5646 |
P5746 |
P10046 |
P10546 |
P11046 |
P11546 |
P16046 |
P16546 |
P14046 |
P14546 |
P15046 |
P15546 |
P18046 |
P18546 |
0 to 100 psi |
P0148 |
P0248 |
P0548 |
P0648 |
P5148 |
P5248 |
P5648 |
P5748 |
P10048 |
P10548 |
P11048 |
P11548 |
P16048 |
P16548 |
P14048 |
P14548 |
P15048 |
P15548 |
P18048 |
P18548 |
0 to 160 psi |
P0152 |
P0252 |
P0552 |
P0652 |
P5152 |
P5252 |
P5652 |
P5752 |
P10052 |
P10552 |
P11052 |
P11552 |
P16052 |
P16552 |
P14052 |
P14552 |
P15052 |
P15552 |
P18052 |
P18552 |
0 to 200 psi |
P0154 |
P0254 |
P0554 |
P0654 |
P5154 |
P5254 |
P5654 |
P5754 |
P10054 |
P10554 |
P11054 |
P11554 |
P16054 |
P16554 |
P14054 |
P14554 |
P15054 |
P15554 |
P18054 |
P18554 |
0 to 300 psi |
P0158 |
P0258 |
P0558 |
P0658 |
P5158 |
P5258 |
P5658 |
P5758 |
P10058 |
P10558 |
P11058 |
P11558 |
P16058 |
P16558 |
P14058 |
P14558 |
P15058 |
P15558 |
P18058 |
P18558 |
0 to 400 psi |
P0160 |
P0260 |
P0560 |
P0660 |
P5160 |
P5260 |
P5660 |
P5760 |
P10060 |
P10560 |
P11060 |
P11560 |
P16060 |
P16560 |
P14060 |
P14560 |
P15060 |
P15560 |
P18060 |
P18560 |
0 to 600 psi |
P0164 |
P0264 |
P0564 |
P0664 |
P5164 |
P5264 |
P5664 |
P5764 |
P10064 |
P10564 |
P11064 |
P11564 |
P16064 |
P16564 |
P14064 |
P14564 |
P15064 |
P15564 |
P18064 |
P18564 |
0 to 1,000 psi |
P0168 |
P0268 |
P0568 |
P0668 |
P5168 |
P5268 |
P5668 |
P5768 |
P10068 |
P10568 |
P11068 |
P11568 |
P16068 |
P16568 |
P14068 |
P14568 |
P15068 |
P15568 |
P18068 |
P18568 |
0 to 1,500 psi |
P0574 |
P5174 |
P5274 |
P5674 |
P5774 |
P14574 |
P15074 |
P15574 |
P18074 |
P18574 |
0 to 2,000 psi |
P0576 |
P5176 |
P5276 |
P5676 |
P5776 |
P14576 |
P15076 |
P15576 |
P18076 |
P18576 |
0 to 3,000 psi |
P0578 |
P5178 |
P5278 |
P5678 |
P5778 |
P14578 |
P15078 |
P15578 |
P18078 |
P18578 |
0 to 5,000 psi |
P0582 |
P5182 |
P5282 |
P5682 |
P5782 |
P14582 |
P15082 |
P15582 |
P18082 |
P18582 |
0 to 10,000 psi |
P0590 |
P5190 |
P5290 |
P5690 |
P5790 |
P14590 |
P15090 |
P15590 |
P18090 |
P18590 |
0 to 15,000 psi |
P5192 |
P5292 |
P5692 |
P5792 |
P14592 |
P15092 |
P15592 |
P18092 |
P18592 |
0 to 20,000 psi |
P5194 |
P5294 |
P5694 |
P5794 |
P14594 |
P15094 |
P15594 |
P18094 |
P18594 |
NOTE: Shaded area indicates items are available on special order, however, minimums and lead times apply. Consult factory. |
6" MARSH¹ý³Ì¾«ÃÜѹÁ¦±í¶©»õÑ¡ÐÍPart Numbers |
Internals |
Copper Alloy |
Stainless Steel |
Mounting |
LM |
LM |
LBM |
LBM |
LM |
LM |
LBM |
LBM |
Case Style |
G |
G |
G |
G |
G |
G |
G |
G |
Connection |
1/4 NPT |
1/2 NPT |
1/4 NPT |
1/2 NPT |
1/4 NPT |
1/2 NPT |
1/4 NPT |
1/2 NPT |
0 to 30" Hg VAC |
P20005 |
P20505 |
P21005 |
P21505 |
P24005 |
P24505 |
P25005 |
P25505 |
P20010 |
P20510 |
P21010 |
P21510 |
P24010 |
P25010 |
P25510 |
P20012 |
P20512 |
P21012 |
P21512 |
P24012 |
P24512 |
P25012 |
P25512 |
P20014 |
P20514 |
P21014 |
P21514 |
P24014 |
P24514 |
P25014 |
P25514 |
P20016 |
P20516 |
P21016 |
P21516 |
P24016 |
P24516 |
P25016 |
P25516 |
0 to 15 psi |
P20040 |
P20540 |
P21040 |
P21540 |
P24040 |
P24540 |
P25040 |
P25540 |
0 to 30 psi |
P20042 |
P20542 |
P21042 |
P21542 |
P24042 |
P24542 |
P25042 |
P25542 |
0 to 60 psi |
P20046 |
P20546 |
P21046 |
P21546 |
P24046 |
P24546 |
P25046 |
P25546 |
0 to 100 psi |
P20048 |
P20548 |
P21048 |
P21548 |
P24048 |
P24548 |
P25048 |
P25548 |
0 to 160 psi |
P20052 |
P20552 |
P21052 |
P21552 |
P24052 |
P24552 |
P25052 |
P25552 |
0 to 200 psi |
P20054 |
P20554 |
P21054 |
P21554 |
P24054 |
P24554 |
P25054 |
P25554 |
0 to 300 psi |
P20058 |
P20558 |
P21058 |
P21558 |
P24058 |
P24558 |
P25058 |
P25558 |
0 to 400 psi |
P20060 |
P20560 |
P21060 |
P21560 |
P24060 |
P24560 |
P25060 |
P25560 |
0 to 600 psi |
P20064 |
P20564 |
P21064 |
P21564 |
P24064 |
P24564 |
P25064 |
P25564 |
0 to 1,000 psi |
P20068 |
P20568 |
P21068 |
P21568 |
P24068 |
P24568 |
P25068 |
P25568 |
0 to 1,500 psi |
P24074 |
P24574 |
P25074 |
P25574 |
0 to 2,000 psi |
P24076 |
P24576 |
P25076 |
P25576 |
0 to 3,000 psi |
P24078 |
P24578 |
P25078 |
P25578 |
0 to 5,000 psi |
P24082 |
P24582 |
P25082 |
P25582 |
0 to 10,000 psi |
P24090 |
P24590 |
P25090 |
P25590 |
0 to 15,000 psi |
P24092 |
P24592 |
P25092 |
P25592 |
0 to 20,000 psi |
P24094 |
P24594 |
P25094 |
P25594 |
NOTE: shaded area indicates items are available on special order, however, minimums and lead times apply. Consult factory. |
