Ê×Ò³ - ÐÂÎÅ - ÕÐƸ - ÏÂÔØ - ²úÆ· - ³§ÉÌ - ·½°¸ - ÎÄÕª - Çó¹º - Õ¹ÀÀ
Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú MARSH 63mm³äÓÍÄÍÕðѹÁ¦±í
²úÆ·Ãû³Æ£º MARSH 63mm³äÓÍÄÍÕðѹÁ¦±í
ÐÍ ºÅ£º MARSH JϵÁгäÓÍÄÍÕðѹÁ¦±í
¾«¶ÈAccuracy
ASME Grade B ¨C ¡À3/2/3% (¡À2% of range across middle half of scale)
±í¾¶Case Size
63mm (2.47") diameter
Íâ¿Ç²ÄÖÊCase Material
304 Stainless Steel
°²×°·½Ê½Case Style
Rolled ring, hermetically sealed case
CB ¨C Center Back Mount
LM ¨C Lower Mount
UC ¨C U-Clamp Mount
ÄÚо²ÄÖÊTube & Socket
Copper alloy or 316 stainless steel
Ô˶¯¼þ²ÄÖÊMovement
Brass
½Ó¿ÚConnection
1/4" NPT
²âÁ¿·¶Î§Ranges
0 to 30" Hg VAC; Compound 30" Hg to 400 psi; 15 to 10,000 psi
¿Ì¶ÈÅÌDial Standard
Dual scale psi and kPa
¿Ì¶ÈÅÌÑÕÉ«Dial Color
Black markings on white
Ö¸ÕëPointer
Aluminum, Black painted
´°¿ÚWindow
Polycarbonate
ÏÞλÆ÷Restrictor
Standard, all ranges
³äÒº²ÄÖÊFill Medium
Glycerine standard
ÅÅÆøÈûVent Plug
Removable tip for venting
MARSH 63mm ³äÓÍÄÍÕðѹÁ¦±í¶©»õÑ¡ÐÍPart Numbers:
Type: 63 mm Severe Service Gauge
Internals
Copper Alloy
Stainless Steel
Mounting / Case Style
LM
UC
CB
LM
UC
CB
0 to 30" Hg VAC
J7605P
J7205P
J6405P
J7805P
J7405P
J6605P
30" Hg VAC to 15 psi
xx
xx
xx
xx
xx
xx
30" Hg VAC to 30 psi
J7612P
xx
xx
xx
xx
xx
30" Hg VAC to 60 psi
J7614P
xx
xx
xx
xx
xx
30"Hg VAC to 100 psi
xx
xx
xx
xx
xx
xx
30" Hg VAC to 150 psi
J7618P
J7218P
J6418P
J7818P
J7418P
J6618P
30" Hg VAC to 200 psi
J7620P
J7220P
J6420P
J7820P
J7420P
J6620P
30" Hg VAC to 300 psi
J7624P
J7224P
J6424P
J7824P
J7424P
J6624P
30" Hg VAC to 400 psi
J7626P
J7226P
J6426P
J7826P
J7426P
J6626P
0 to 15 psi
J7640P
J7240P
J6440P
J7840P
J7440P
J6640P
0 to 30 psi
J7642P
J7242P
J6442P
J7842P
J7442P
J6642P
0 to 60 psi
J7646P
J7246P
J6446P
J7846P
J7446P
J6646P
0 to 100 psi
J7648P
J7248P
J6448P
J7848P
J7448P
J6648P
0 to 160 psi
J7652P
J7252P
J6452P
J7852P
J7452P
J6652P
0 to 200 psi
J7654P
J7254P
J6454P
J7854P
J7454P
J6654P
0 to 300 psi
J7658P
J7258P
J6458P
J7858P
J7458P
J6658P
0 to 400 psi
J7660P
J7260P
J6460P
J7860P
J7460P
J6660P
0 to 600 psi
J7664P
J7264P
J6464P
J7864P
J7464P
J6664P
0 to 1,000 psi
J7672P
J7272P
J6472P
J7872P
J7472P
J6672P
0 to 1,500 psi
J7674P
J7274P
J6474P
J7874P
J7474P
J6674P
0 to 2,000 psi
J7676P
J7276P
J6476P
J7876P
J7476P
J6676P
0 to 3,000 psi
J7678P
J7278P
J6478P
J7878P
J7478P
J6678P
0 to 5,000 psi
J7682P
J7282P
J6482P
J7882P
J7482P
J6682P
0 to 6,000 psi
J7684P
J7284P
J6484P
J7884P
J7484P
J6684P
0 to 10,000 psi
xx
xx
xx
J7890P
J7490P
J6690P
NOTE: shaded areas indicate items are available on special order, however, minimums and lead times apply. Consult factory.
¹«Ë¾Ãû³Æ£º ±±¾©½ÜµÂÀ³ÌؿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 010 85501516 / ÍõÇ¿
ÊÖ»ú£º 15601046548
µØ Ö·£º ±±¾©Êг¯ÑôÇø³¯Ñô·67ºÅ²ÆÂú½Ö8ºÅÂ¥01110ÊÒ
ÓÊ ±à£º 100025
Ö÷ Ò³£º http://www.guidelight.com.cn
  • TESCOM±³Ñ¹µ÷ѹ·§-26-25ϵÁÐ
  • TESCOM×°±¸ÆøÊÒµ÷ѹ·§-26-12ϵÁÐ
  • TESCOM¸ßѹµ÷ѹ·§-44-42ϵÁÐ
  • TESCOMҺѹµ÷ѹ·§-54-28ϵÁÐ
  • TESCOM±³Ñ¹µ÷ѹ·§44-23ϵÁÐ
  • TESCOMµÍѹµ÷ѹ·§-26-16ϵÁÐ
  • TESCOM¸ßѹµ÷ѹ·§-44-13ϵÁÐ
  • TESCOM¸ßѹµ÷ѹ·§-BB-1ϵÁÐ
  • TESCOM¸ßѹµ÷ѹ·§-44-11ϵÁÐ
  • ÃÀ¹ú BLUE WHITE õëÂÖʽÁ÷Á¿¼Æ F-2000ϵÁÐ
    °æȨËùÓÐ ¹¤¿ØÍø Copyright@ Gkong.com, All Rights Reserved
