¾«¶ÈAccuracy |
¡À 2.5% Full Scale ASME grade B |
±í¾¶Case sizes |
1-1/2" 2" 2-1/2" 4" |
Íâ¿Ç²ÄÖÊ Case Material |
ABS (Acryl Nitril Butadien Styrol)
Black painted steel with chrome triangular bezel and U-Clamp
304 Stainless Steel |
²¨µÇ¹Ü²ÄÖÊ Bourdon tube |
Phosphor bronze
316 Stainless steel coiled safety tube |
Ô˶¯¼þ²ÄÖÊ Movement |
Brass & Nylon, or All-Brass with highly polished bearing surfaces |
´°¿Ú Lens |
Clear front Plexiglass |
½Ó¿Ú Connection |
1/8" NPT 1/4" NPT |
Ö¸Õë Pointer |
Molded plastic
Balanced micro-adjustable aluminum. black finish |
¿Ì¶È Dial |
White background with black psi scale and red kPa scale. |
NOSHOK 100ϵÁбê׼ѹÁ¦±íÑ¡ÐÍ±í£º ÇëÁªÏµ±¾¹«Ë¾¡£ |
