²úÆ·Ãû³Æ£º
NOSHOK 200ϵÁеÍѹĤºÐѹÁ¦±í
ÐÍ ºÅ£º
200ϵÁеÍѹĤºÐѹÁ¦±í
NOSHOK 200ϵÁеÍѹĤºÐѹÁ¦±í¼¼Êõ²ÎÊý£º
¾«¶ÈAccuracy |
25-200, 25-210, 25-224 |
¡À1.5% Full Scale ASME grade A |
25-206, 25-216 |
¡À 2.5% Full Scale ASME grade B |
40-200 |
¡À 1% Full Scale ASME grade 1A |
±í¾¶Case sizes |
2-1/2" 4" |
Íâ¿Ç²ÄÖÊ Case Material |
25-200, 25-210 |
Black painted steel |
25-206, 25-216, 25-224 |
BlackABS (Aeryl Nitril Butadien Styrol) with 25-224 includes zinc plated steel panel mount clamp |
40-200 |
304 Stainless Steel |
ĤºÐ²ÄÖÊ Diaphragm Capsule |
Phosphor bronze |
Ô˶¯¼þ²ÄÖÊ Movement |
Brass and Nickel-Silver with highly polished bearing surface |
´°¿Ú Lens |
Clear front plexiglass |
½Ó¿Ú Connection |
1/4" NPT brass |
Ö¸Õë Pointer |
Black finished aluminum |
¿Ì¶È Dial |
Aluminum, white background with black markings. Single scale except as noted in the dial configuration chart. UV resistant. |
NOSHOK 200ϵÁеÍѹĤºÐѹÁ¦±íÑ¡ÐÍ±í£ºÈçÓÐÐèÒªÇëÁªÏµ±¾¹«Ë¾¡£ |
