¾«¶ÈAccuracy |
¡À 0.25% Full Scale ASME grade 3A |
±í¾¶Case sizes |
6" |
Íâ¿Ç²ÄÖÊ Case Material |
304 Stainless steel |
²¨µÇ¹Ü²ÄÖÊ Bourdon tube |
Berylium copper to 1000 psi 316 SS 1500 psi to 10000 psi NI Span C 15000 psi to 20000 psi |
Ô˶¯¼þ²ÄÖÊ Movement |
Brass with jeweled bearings nickel-silver pinion gear and shafts |
´°¿Ú Lens |
Instrument glass |
½Ó¿Ú Connection |
1/4" NPT bottom connection 1/2" NPT bottom connection for 20,000 psi |
Ö¸Õë Pointer |
Adjustable knife-edge pointer |
¿Ì¶È Dial |
Aluminum, white mirrored background with black graduations |
NOSHOK 800ϵÁо«ÃܲâÊÔѹÁ¦±íÑ¡ÐÍ±í£ºÈçÓÐÐèÒªÇëÁªÏµ±¾¹«Ë¾¡£ |
