NOSHOK 900ϵÁÐABSºÍ³äÓͲ»Ðâ¸ÖѹÁ¦±í
NOSHOK 900ϵÁÐABSºÍ³äÓͲ»Ðâ¸ÖѹÁ¦±í¼¼Êõ²ÎÊý£º
¾«¶ÈAccuracy |
15-910 |
¡À 2.5% Full Scale ASME grade B |
25-900, 25-910, 25-901, 25-911 |
¡À 1.5% Full Scale ASME grade A |
±í¾¶Case sizes |
1-1/2" 2" 2-1/2" 4" |
Íâ¿Ç²ÄÖÊ Case Material |
15-910, 25-900, 25-910 |
ABS (Acryl Nitril Butadien Styrol) |
25-901, 25-911, 40-901, 40-911 |
304 Stainless steel |
²¨µÇ¹Ü²ÄÖÊ Bourdon tube |
15-910, 25-900, 25-910, 25-901, 25-911, 40-901, 40-911 (up to 600 psi) |
Phosphor bronze "C" tube |
15-910, 25-900, 25-910, 25-901, 25-911, 40-901, 40-911 (greater than 600 psi) |
Coiled safety tube |
Ô˶¯¼þ²ÄÖÊ Movement |
Brass and nylon with highly polished bearing surfaces |
´°¿Ú Lens |
Instrument glass |
½Ó¿Ú Connection |
15-910 |
1/8" NPT brass |
25-900, 25-910, 25-901, 25-911, 40-901, 40-911 |
1/4" NPT brass |
Ö¸Õë Pointer |
Molded plastic |
¿Ì¶È Dial |
Molded plastic Aluminum |
³äÓͲÄÖÊFill Liquid |
Glycerine and water. |
NOSHOK 900ϵÁÐABSºÍ³äÓͲ»Ðâ¸ÖѹÁ¦±íÑ¡ÐÍ±í£ºÈçÓÐÐèÒªÇëÁªÏµ±¾¹«Ë¾¡£ |
