¾«¶ÈAccuracy |
¡À 0.5 % Full Scale (Best Fit Straight Line); ¡À 1.0% Terminal Point; ¡À 0.25 % optional (Includes the combined effecls ol linearity, hysteresis and repeatability) |
Öظ´¾«¶ÈRepeatability |
¡Ü ¡À 0.05% Full scale |
³ÙÖ;«¶ÈHysteresis |
¡Ü ¡À 0.1% Full scale |
Îȶ¨ÐÔStability |
¡Ü ¡À 0.2% Full scale per year, non-accumulating |
ÏìӦʱ¼äResponse Time |
¡Ü 4 ms (between 10% and 90% Full scale) |
µçÔ´Power Supply |
8 Vdc to 30 Vdc unregulated for 4 mA to 20 mA output, 0 Vdc to 5 Vdc output and 1 Vdc to 5 Vdc outputs; 5 Vdc ¡À 10% for 0.5 Vdc to 4.5 Vdc output, unregulated |
Êä³öÏÞÖµLoad Limitations |
¡Ü (VPower - 10)/0.020 Amp for 4 mA to 20 mA output ¡Ü 5,000 ¦¸ for 1 Vdc to 5 Vdc output ¡Ü 10,000 ¦¸ for 0 Vdc to 10 Vdc output ¡Ü 4,500 ¦¸ for 0.5 Vdc to 4.5 Vdc oulput |
½Ó´¥Ãæ²ÄÖÊWetted Materials |
316 stainless steel for absolute through 150psi 13-8PH stainless steel sensing diaphragm and 316 stainless steel process connection for higher ranges |
Íâ¿Ç²ÄÁÏHousing Material |
316L Stainless steel |
ζȷ¶Î§Temperature Ranges |
Compensated 32¡ãF to 176¡ãF (0¡ãC to 80¡ãC) Storage -4¡ãF to 176¡ãF (O¡ãC to 80¡ãC) Media 32¡ãF to 176¡ãF (O¡ãC to 80¡ãC) Ambient 32¡ãF to 176¡ãF (O¡ãC to 80¡ãC) |
»·¾³µÈ¼¶Environmental Rating |
IP65 to IP67 depending on electrical connection |
µçÆøµÈ¼¶Electromagnetic Rating |
CE compliant to EMC norm EN61326:1997/A1:1998 RFI, EMI and ESD protection |
µçÆø·À»¤Electical Protection |
Reverse polarity, over-voltage and short circuit protection |
ÖØÁ¿Weight |
Approximately 2.8 oz. |
NOSHOK 300ϵÁнô´ÕÐÍOEMѹÁ¦´«¸ÐÆ÷Ñ¡ÐÍ±í£ºÈçÓÐÐèÒªÇëÁªÏµ±¾¹«Ë¾¡£ |
