¾«¶ÈAccuracy |
¡À 0.25 % Full Scale (best fit straight line); ¡À 0.5% Terminal Point Includes the combined effects of linearity, hysteresis and repeatability ¡À 0.125 % Full Scale (optional) |
Öظ´¾«¶ÈRepeatability |
¡Ü ¡À 0.05% Full Scale |
³ÙÖ;«¶ÈHysteresis |
¡Ü ¡À 0.1% Full Scale |
Îȶ¨ÐÔStability |
¡Ü ¡À 0.2% Full Scale for 1 year, non accumulating |
ÏìӦʱ¼äResponse Time |
Less than 1 ms (between 10% and 90% Full Scale) |
µçÔ´Power Supply |
10 Vdc to 30 Vdc for current output, unregulated 14 Vdc to 30 Vdc for voltage output, unregulated |
Êä³öÏÞÖµLoad Limitations |
¡Ü (VPower -10)/0.020 Amp for 4 rnA to 20 rnA ¡Ý 10,000 ¦¸ for 0 Vdc to 10 Vdc, 3-wire ¡Ý 5,000 ¦¸ for 0 Vdc to 5 Vdc, 3-wire |
½Ó´¥Ãæ²ÄÖÊWetted Materials |
316 stainless steel for vacuum through 300 psi ; 17 -4PH stainless steel sensing diaphragm and 316 stainless steel process connection for higher ranges |
Íâ¿Ç²ÄÁÏHousing Material |
316 Stainless steel |
ζȷ¶Î§Temperature Ranges |
Compensated 32¡ãF to 175¡ãF / 0¡ãC to 80¡ãC Effect ¡À 0.01%/¡ãF for zero and span Storage - 40¡ãF to 212¡ãF / -40¡ãC to 100¡ãC Medium - 20¡ãF to 212¡ãF / -30¡ãC to 100¡ãC Ambient - 15¡ãF to 175¡ãF / -10¡ãC to 80 "C High temperature version available on request |
»·¾³µÈ¼¶Environmental Rating |
NEMA 4X, IP65 (IEC 529) |
µçÆøµÈ¼¶Electromagnetic Rating |
CE compliant to EMC norm EN 61326:1997/A1:1998 RFI, EMI and ESD protection |
µçÆø·À»¤Electical Protection |
Reverse polarity, over-voltage and short circuit protection |
ÖØÁ¿Weight |
Approximately 7.2 oz. |
NOSHOK 615 616ϵÁи߾«¶ÈÖظºÔØѹÁ¦´«¸ÐÆ÷Ñ¡ÐÍ±í£ºÈçÓÐÐèÒªÇëÁªÏµ±¾¹«Ë¾¡£ |
