ÏÔʾDisplay |
0.43" high Liquid Crystal Display |
λÊýDigits |
4 STD. 4½, up to 9999 |
¾«¶ÈAccuracy |
¡À0.5% Full Scale (BFSL); ¡À1% Terminal Point |
¸üÐÂËÙ¶ÈUpdate Rate |
5 times/second |
ѹÁ¦·¶Î§Pressure Ranges |
Standard ranges from 30 psig to 10,000 psig |
½Ó´¥Ãæ²ÄÖÊWetted Materials |
¡Ü 750 psig stainless steel, aluminum, NBR, ceramic measuring element ¡Ü 1000 psig stainless steel, thin-film measuring element |
Íâ¿Ç²ÄÖÊHousing Material |
Stainless steel |
µçÔ´Power Supply |
2 x 1.5V "AA" Battery 4000 hrs ("AA" 2000 mAh), unregulated |
¿É±à³Ì¹¦ÄÜProgrammable Functions Tare On/Off Measuring Unit |
Adjustable through front key pad ¡À 20% of Full Scale range Adjustable automatic turn off bar, psi, MPa |
ÖØÁ¿Weight |
0.88 lbs. |
NOSHOK 1000ϵÁÐÊý×ÖѹÁ¦±íÑ¡ÐÍ±í£ºÈçÓÐÐèÒªÇëÁªÏµ±¾¹«Ë¾¡£ |
