ϵÁÐSeries/Prefix |
NT3000 Series |
3 |
3 |
ͨѶCommunications |
4-20 mA |
0 |
0 |
ÌØÕ÷Diagnostics |
None |
0 |
0 |
²ÄÖÊMaterial |
Aluminum |
0 |
0 |
Stainless Steel |
1 |
ÈÏÖ¤Certification |
I/P 4-20 mA EExia EExib intrinsically safe NT 3000 ATEX II 1 GD |
04 |
04 |
I/P 4-20 mA SAA Explosion Proof Ex d, Intrinically safe Ex ia Ex N , (SAA) NT3000 |
05 |
I/P 4-20 mA EExd Exp proof NT 3000 ATEX II 2 GD |
07 |
I/P 4-20 mA Exp proof/intrinsically safe NT 3000 FM/CSA |
10 |
I/P 4-20 mA General purpose NT 3000 |
14 |
ѹÁ¦±íGauges (qty / material / units of measure) |
(1) / Stainless steel gauges with brass fittings / psi bar kPa |
2 |
2 |
(1) / Stainless steel gauges with Stainless steel fittings / psi bar kPa |
4 |
(1) / Stainless steel gauges with brass fittings / kg cm2 psi |
6 |
(1) / Stainless steel gauges with Stainless steel fittings / kg cm2 psi |
8 |
No gauges (Stainless steel plugs) |
9 |
Ãܷ⼰ζÈ
Soft Goods / Temperature |
(Standard) Buna-N, Fluorosilicone / -40¡ã to +185¡ãF (-40¡ã to +85¡ãC) |
S |
S |
Viton / -20¡ã to +185¡ãF (-29¡ã to +85¡ãC) |
V |
EPDM / -40¡ã to +185¡ãF (-40¡ã to +85¡ãC) |
E |
µçÆø½Ó¿Ú
Conduit Connection |
½" NPT |
N |
N |
M20 |
M |
ÅÅÆøVent |
Non-Vented |
1 |
1 |
Vented |
2 |
Íâ¹ÛÅçÍ¿Paint |
White |
W |
W |
Black |
B |
Food Grade |
F |
No paint (Stainless steel) |
S |
