Watsonsmith T140µçÆøת»»Æ÷£¨´ø¹ÊÕϱ£»¤¹¦ÄÜ£©
Watsonsmith T140µçÆøת»»Æ÷ʹÓÃÏȽøµÄ±Õ»·¿ØÖÆÀ´µÃµ½×¼È·¡¢¸ß·Ö±æÂʵÄѹÁ¦¿ØÖÆ£¬Óб¾°²ÐÍ¡¢NEMA 4X ·À»¤ÐÍ ¼á¹ÌµÄ¹¹Ôì¡¢·ÀÕð·ÀÓêµÈÌص㣬ʹÆäÔÚ»§ÍâÒ²Óй㷺µÄÓ¦Óá£
Watsonsmith T140µçÆøת»»Æ÷¼¼Êõ²ÎÊý£º
ѹÁ¦¹©¸ø Supply Pressure |
1.2-10bar£¨18-150psig£© |
Êä³öѹÁ¦ Output Signal |
0.2-1bar£¨3-15psi£© |
Á÷Á¿Flow Capacity |
Up to 300Nl/min (10scfm) |
ºÄÆøÁ¿Air Consumption |
2.5 l/min (0.25scfm) typical. |
¾«¶È Accuracy |
<0.1% |
IP·À»¤ IP Rating |
IP66 MEMA 4X |
¹¤×÷ζÈOperating Temperature |
--40¡æ to +85¡æ |
½Ó¿ÚConnections |
1/4¡± NPT standard (1/4¡± BSP )available on request |
ÖØÁ¿ weight |
2.07kg |
Watsonsmith T140µçÆøת»»Æ÷Ñ¡ÐÍ±í£º
ÈÏÖ¤ CERTIFICATION |
Êä³öѹÁ¦ OUTPUT PRESSURE |
¶©»õºÅ ORDER CODE |
CENELEC |
0.2-1bar |
EX14001BJ4LE2 |
3-15psi |
EX14001PK4LE2 |
Triple certification |
0.2-1bar |
EX14001BJ4EE1 |
3-15psi |
EX14001PK4EE1 |
