½éÖÊMedium: |
Oil free, dry air, filtered to 5micron |
Êä³öѹÁ¦Output Pressure: |
0.2-1.0bar(3-15psig), 0.2-2.0bar(3-30psig), 0.2-4.0bar (360psig), two wire version
0.2-6 bar (2-90psig) 0.2-8bar (2-120psig) three wire version |
Á÷Á¿Flow Capacity: |
Up to 300Nl/min (10scfm) |
¿ÕÆøÏûºÄAir Consumption: |
<4bar: 0.85l/min (0.03scfm) typical >4bar: 1.75l/min (0.06scfm) typical |
¹¤×÷ѹÁ¦Operating Pressure: |
At least 0.7bar above maximum required output pressure |
½Ó¿ÚConnections: |
G1/4 |
¹¤×÷ζÈOperating Temperature |
-20 ¡æto 70¡æ |
ÏìӦʱ¼äResponse Time:
<2bar/30psig: less than 0.5seconds for 10-90% step change >2bar/30psig: 2 seconds for 10-90% step change |
½á¹¹²ÄÖÊMaterial of Construction:
Zinc die-casting passivated and epoxy paint, nitrile diaphragms, stainless steel/nylon flapper nozzle and supply valve |
ÖÊÁ¿Mass:
1500g approx. |
