Á÷ÌåMedium: |
Compressed air, filtered to 5 micron, non-lubricated |
¹¤×÷·½Ê½Operation: |
Proportional, direct acting piloted spool valve |
Êä³öѹÁ¦Output Pressure: |
User adjustable up to 10 bar |
×î´ó¹©¸øѹÁ¦Max Supply pressure: |
14bar max |
ÏìӦʱ¼äResponse Time (into 0.1litre load): |
Step response: 10-90% <100ms |
ºÄÆøÁ¿Air Consumption: |
<5Nl/min |
½Ó¿ÚPort Size: |
G1/4,1/4¡±NPT in lineManifold mounting |
¹¤×÷ζÈOperating Temperature (ambient): |
-20¡ã to 50¡ãC |
·À»¤µÈ¼¶Degree of Protection: |
IP65 in normal operation |
½á¹¹²ÄÖÊMaterial of Construction: |
Aluminium body, zinc diecast lid and end cover |
ÖÊÁ¿Mass: |
800g approx. |
¿ØÖÆÐźÅControl signal |
0-10 V / 4-20 mA |
µçÔ´Electrical Power input |
24Vdc ¡À25% |
Êä³öѹÁ¦·´À¡ÐźÅOutput pressure
feedback signal |
User Configurable: 0-10V
analogue or Hi-Lo mode |
ÊäÈë×迹Input resistance |
50 k¦¸(voltage)
220 ¦¸(current) |
µçÆøÁ¬½ÓConnections |
M12, 5 pin connector e.g.
Hirschmann 933 170-100 |
Á÷Á¿Flow Capacity |
1300 l/min |
ÏßÐÔ¶ÈLinearity |
<+/-50mbar<0.5% of span |
ÏìÓ¦ÁéÃô¶ÈResponse Sensitivity |
<1barovershoot10-90%<=80ms
90-10% <=120ms 100cc load |
³ÙÖÍHysteresis
<50mbar<0.5% of span |
