ROSE铸铝机箱——采矿业的理想之选
http://www.gkong.com 2017-09-11 10:25 来源:美卡诺元器件(上海)有限公司
    Sturdy aluminium enclosures withstand the most adverse conditions
    The mining of potash involves working in extreme environmental conditions which represent major challenges for the machines and equipment which are in use. The technology has to function perfectly even at temperatures higher than 50 degrees Celsius and when dust, spray water and aggressive salts are present. ROSE Systemtechnik's sturdy, corrosion-resistant enclosures provide sensitive electronics with effective protection against damage.
    ROSE's sturdy aluminium enclosures protect sensitive electronics under the harshest conditions in the mining sector, even in the presence of huge salt deposits
    The aluminium standard enclosures easily withstand difficult conditions such as those found underground, and this is because of the high-quality alloy which is used (acc. to DIN EN 1706). This alloy has an especially low copper content, which has a very positive effect on the surface quality.  “In this way, even without an additional coating our enclosures provide excellent resistance against corrosion in damp or saline conditions,” says Christine Stello, ROSE Systemtechnik's product manager for industrial enclosures. Even at a depth of 1,450 metres, the highly-durable material prevents damage to the electronics of conveyor systems or communication stations.
    All the aluminium enclosures in the standard range comply with protection class IP 66 acc. to DIN EN 60529, so they are dust-tight and water-tight. They provide impact strength of 10 Joule – based on DIN EN 60068-2-75 – and securely protect the electrical equipment against blows and knocks. ROSE carries out all quality tests in the in-house test laboratory. Christine Stello continues, “We are happy to advise our customers if they have questions about higher protection classes, and can carry out individual tests in our laboratories.” The use of different sealing materials means that the enclosures can be used in ambient temperatures of max. – 60°C up to + 130°C.
    Flexible enclosure solution as required
    With 42 different enclosure sizes, and dimensions from 45 x 50 x 30 mm to 600 x 600 x 202 mm, the standard product range provides a wide range of options for industrial applications. As Christine Stello says, “Our main goals are to offer our customers system solutions and to help them with the individual design of their product.” In the production facility at the Porta Westfalica site, the enclosures are processed in accordance with specifications and then fitted with electromechanical components or upgraded with special colours or coatings. “Many of our customers take advantage of the wide-ranging options available with our surface technology, plus engraving and screen printing, in order to give their product the appearance which matches their company's own corporate identity.”
    Thanks to their sturdy and secure structure, and the flexibility of design options, ROSE Systemtechnik's aluminium enclosures are indispensable in almost all sectors of industry. The very good technical characteristics of the enclosures allow use in both dusty production halls and outdoors, where they are permanently exposed to environmental influences. “This is why our customers can be found in classic mechanical engineering, in measuring and data system technology, and in transportation technology. They value us as competent suppliers of safe and secure enclosure solutions for customer-specific requirements,” Christine Stello reports.
    Caption
    About ROSE Systemtechnik
    ROSE Systemtechnik GmbH was founded in Porta Westfalica, Germany, in 1969 and is today one of the world’s leading and innovative providers of industrial enclosure system engineering. The company employs more than 350 staff. As part of Phoenix Mecano AG, Switzerland, the company develops and manufactures high-quality industrial enclosures and system solutions for the following sectors: mechanical and plant engineering, automation engineering, potentially explosive atmospheres, instrumentation, control and automation technology, as well as the food and beverage industry. In addition to standard industrial enclosures made of aluminium, stainless steel and plastics for individual installations of electrical connection technology and electronic components, the product range comprises operating and display enclosures based on aluminium profile systems and stainless steel materials for HMI applications, and components for explosion protection with junction boxes and control stations for worldwide use in potentially explosive atmospheres, as well as the petrochemical and chemical industry in both onshore and offshore environments.
    Additional information is available on www.rose-pw.de
