产品名称: |
专业提供Honeywell DCS卡件
型 号: |
TDC2000、TDC3000 |
价 格: |
0.00 |
品 牌: |
霍尼韦尔(Honeywell) |
产品介绍: |
专业提供Honeywell DCS卡件,诚信服务,绝对保证是原装Honeywell全新卡件,服务范围涉及S9000、PLANTSCAPE,TDC2000、TDC3000(US操作站)、TPS(GUS操作站)、PKS 等Honeywell DCS集散型控制系统,现列部分卡件列表以供参考
联系人:市场销售部韩洪瑞
电话:13814078406 85363991
传真:025-85231050
QQ:457127487
邮编:210048
http://yigonghan.applegold.com.cn/
01-W2039E02A 60MB SCSI CD ROM EA 51196707-100 01-W2223E01A ATX TOWER CHASSIS W/O PWR SUPPLY EA 01-W2223E02A ATX DESK CHASSIS W/O PWR SUPPLY EA 01-W2734D01A TOWER W/PS EA 51196708-100 01-W2747D01B 1.44MB FLOPPY DRIVE EA 51196703-100 01-W2950D03A 1GBSCSI H/D EA 51196704-200 01W2728D02A TOWER P/S EA 51196708-110 03267 FILLER PLATE EA 51196982-910 0458C 350MGHX1 PROCESSOR H EA 04670008-037 FUSE, 1.6A EA 51107142-125 0562D GX1 MOTHERBOARD EA 51196982-912 06087 TOSHIBA 32X CDROM IDE EA 07890 2GB H/D EA 51196935-922 09552 PWB RISER (DELL) EA 09714 TERM 2ND PROG EA 51196935-902 11860 CD,680M,12/24X EA 15253 DELL 400Mhz ADAPTEC DUAL UW EA 15279 PROCESSOR,2334M,512KN/ECC EA 15283 PROCESSOR, 80522, 266MH,512,ECC EA 15284 PROCESSOR 80522 300MH 512K ECC C1 EA 15753655-001 KEYLOCK ASSM FOR HIWAY OR LCN MARKHON EA 15831 P/S DELL EA 17463 DATA CBL 50 PIN EA 17464 CABLE, DATA EA 1756-IM16I AC IN 220VAC ISO EA TC-IDW161 1784-KTCX CTRLNET EISA MOD EA 9904-KTCX15 18614 DATA CBL 40P, INT, EIDE EA 18618 FLOPPY CABLE EA 18783 DELL 400Mhz FLOPPY DRIVE EA 2162C KEYBOARD, 104 EA 4939R 24978 CASTERS NON-LOCKING EA 24979 CASTER, LOCKING EA 30-W2762D01A SCSI CABLE EA 30076014-001 FUSE, 1A 250V EA 30076014-002 FUSE, 2A EA 30076014-003 FUSE, 5A EA 30076014-004 FUSE, .25A 250V EA 30076014-005 FUSE, 8A EA 30076014-006 FUSE AGC 1/2 EA 30076014-009 FUSE, 3A 250V EA 30076014-010 FUSE, .75 AMP EA 30076014-011 FUSE, .125A 250V EA 30076014-012 FUSE, 10A EA 30076014-014 FUSE, 15A EA 30076014-023 FUSE, .6A EA 30076014-025 FUSE, 4A EA 30185-H ESD KIT EA 30351949-003 FUSE (PACK OF 2) EA 30351949-005 FUSE EA 30351949-006 FUSE 1.6A,250V, SLOBLO EA 30351949-008 FUSE EA 30353315-002 NEON GLOW LAMP EA 30357380-002 SWITCH EA 30640014-017 GROUND LUG EA 30640014-018 CABLE CLAMP EA 30669206-001 C-AC100 SINGLE UNIT CASE EA 30669314-001 SINGLE UNIT CASE EA 30669206-001 30669316-001 FLEX CIRCUIT ASSY EA 30669635-003 TRIM STRIP 48 INCHES LONG EA 30670531-001 I/F ADAPTER EA 30670531-501 30670559-001 GPCI ADAPTER EA 30671400-001 ANTI-PERSONNEL SCREEN FOR CABINET FAN ASSY EA 30671408-002 CARRYING CASE EA 30671456-001 SHORT MOUNTING PLATE EA 30671467-001 SYSTEM REFERENCE BUSBAR EA 30671467-002 SYSTEM REFERENCE BUSBAR EA 30671467-006 SYSTEM REFERENCE BUSBAR EA 30671467-007 SYSTEM REFERENCE BUSBAR EA 30671467-008 SYSTEM REFERENCE BUSBAR EA 30671471-001 PORT-A-DEP (EC) EA 30671471-002 PORT-A-DEP (BC) EA 30671513-001 TERM PANEL, HI-DEN C-TCB30 EA 30671517-001 GROUND LUG EA 30671526-001 ESD LO-POP KIT EA 30671526-002 ESD HI-POD KIT EA 30671526-003 ESD MODULE KIT EA 30671526-004 ESD END PANEL KI EA 30671529-001 CABLE, 3FT LCN HOOTER EA 30671529-002 CABLE, 7FT LCN HOOTER EA 30671529-003 CABLE 12FT LCN HOOTER EA 30678484-001 LAMP EA 30680582-005 FUSE PIGTAIL 2.3 EA 30680582-006 FUSE PIGTAIL .26 EA 30682112-001 LAMP EXTRACTOR EA 30682951-002 FUSE, 5AMP EA 30731391-001 TERM PANEL, AUX C-TAF00 EA 30731406-001 TERM PANEL EA 30751315-001 30731408-001 TERM PANEL, RED/IND C-TRD00 EA 30731539-001 METER, HORIZONTAL INDICATOR EA 30731539-002 METER, HORIZONTAL INDICATOR EA 30731540-001 SINGLE VERT METER EA 30731540-501 30731540-002 DUAL VERT METER EA 30731540-502 30731540-501 SINGLE VERT METER EA 30731540-502 DUAL VERT METER EA 30731565-001 PWR SPLY, 7A/24V, 115V/60HZ V-PWR71 EA 30731565-002 PWR SPLY, 20A/24V, 115V/60HZ V-PWR61 EA 30731565-003 PWR SPLY, 7A/24V, 120V/50HZ V-PWR73 EA 30731565-004 PWR SPLY, 20A/24V, 120V/50HZ V-PWR51 EA 30731565-005 PWR SPLY, 7A/24V, 240V/50HZ V-PWR72 EA 30731565-006 PWR SPLY, 20A/24V, 240V/50Hz V-PWR52 EA 30731575-001 AUXILIARY FILE ASSM, C-AF000 EA 30731575-002 AUXILIARY FILE ASSY, C-AF002 EA 30731582-001 TOGGLE SWITCH EA 30731611-002 FTA I/O CBL, 2M EA 51201420-002 30731611-003 FTA I/O CBL, 3M EA 51201420-003 30731611-005 FTA I/O CBL, 5M EA 51201420-005 30731611-008 FTA I/O CBL, 8M EA 51201420-008 30731611-030 FTA I/O CBL, 30M EA 51201420-030 30731611-045 FTA I/O CBL, 45M EA 51201420-045 30731611-060 FTA I/O CBL, 60M EA 51201420-060 30731611-901 FTA I/O CBL, 1.5M EA 51201420-915 30731611-902 FTA I/O CBL, 3M EA 51201420-003 30731614-007 ROCKER SWITCH EA 30731618-001 KEYSWITCH & KEY EA 30731619-003 P B SWITCH EA 30731619-006 P.B. SWITCH EA 30731619-007 P.B. SWITCH EA 30731619-008 SWITCH PUSHBUTTON EA 30731620-001 LAMP INCANDESCENT EA 30731642-001 SWITCH, PUSHBUTTON EA 30731642-002 SWITCH, PUSHBUTTON EA 30731674-001 RELAY (C-AR000) EA 30731686-001 PWA, ANALOG DISPLAY EA 30731686-501 30731686-002 PWA, ANALOG DISPLAY EA 30731686-502 30731686-004 PWA, ANALOG DISPLAY EA 30731686-504 30731686-005 PWA, ANALOG DISPLAY EA 30731686-505 30731686-006 PWA, ANALOG DISPLAY EA 30731686-506 30731686-007 PWA, ANALOG DISPLAY EA 30731686-507 30731686-008 PWA, ANALOG DISPLAY EA 30731686-508 30731686-501 PWA, ANALOG DISPLAY EA 30731686-502 PWA, ANALOG DISPLAY EA 30731686-504 PWA, ANALOG DISPLAY EA 30731686-506 PWA, ANALOG DISPLAY EA 30731686-507 PWA, ANALOG DISPLAY EA 30731686-508 PWA, ANALOG DISPLAY EA 30731689-001 JNCT PANEL,SHORT EA 30731691-001 JNCT PANEL,B.C. EA 30731702-001 MODE LAMP EA 30731709-001 SINGLE VERT METER EA 30731540-501 30731709-002 DUAL VERT METER EA 30731540-502 30731710-001 HORIZ MTR ASSY EA 30731710-501 30731710-501 HORIZ MTR ASSY EA 30731710-502 METER HORIZ INDI EA 30731719-001 C-ASD00 (W10/98) AUXILIARY EA 30731720-001 C-AXD00 (W10/98)MULT/DIV AUX EA 30731721-001 C-AML01 2MV/I AUX EA 30731721-002 30731721-002 C-AML01 2MV/I AUX EA 30731721-003 C-AML02 2MV/I AUX EA 30731721-004 MV/I I/P 2-100 C-AML03 EA 30731722-002 C-AEX01 SQ ROOT EXTR EA 30731723-001 C-AMH00 AUX PWA EA 30731724-001 R/I FM+CSA APPRO EA 30731724-002 30731724-002 R/I FM+CSA APPRO C-ARB01 EA 30731724-003 C-ARB02 R/I AUX BASEEFA EA 30731724-004 C-ARB03 R/I AUX BASEEFA EA 30731737-003 C-LAS00 ANALOG DISPLAY ASSM EA 30731737-005 C-LC101 MANUAL W/ STANDBY MANUAL CAP EA 30731737-006 C-LA201 AUTO/MANUAL W/SNDBY MANL CAP EA 30731738-002 C-LD100 SGL INDICTOR EA 30731738-003 ASSM,DUAL VERT EA 30731739-002 C-LMD00 MANUAL LOADRW/INDICATOR EA 30731740-002 MANUAL W/STDBY EA 30731746-001 SWITCH MODE EA 30731746-002 SW PADDLE ASSY EA 30731746-003 SWITCH .R/L EA 30731765-001 PANEL,DATA ENTRY EA 30731765-002 30731765-002 PANEL,DATA ENTRY EA 30731779-501 PWB, KEYBOARD ASSM EA 30731782-501 LOGIC X PWB EA 30731783-501 LOGIC Y PWB EA 30731784-001 VOLT REG PWB EA 30731784-501 30731784-501 VOLT REG PWB EA 30731787-501 DISPLAY PWB EA 30731795-001 C-DPX00 DEP SELCTOR EA 30731804-002 SLOT SEL. LOG. PWB EA 30731804-501 30731804-501 SLOT SEL.LOG.PWB EA 30731808-001 PWA, REGULATOR EA 30731808-503 30731808-002 PWA, REGULATOR EA 30731808-504 30731808-003 PWA REGULATOR CARD EA 30731808-503 30731808-004 PWA, REGULATOR EA 30731808-504 30731808-501 PWA, REGULATOR EA 30731808-503 30731808-502 PWA, REGULATOR EA 30731808-504 30731808-503 PWA, REGULATOR EA 51196989-100 30731808-504 PWA, REGULATOR EA 51196989-100 30731811-001 PWA, OUTPUT EA 30731811-501 30731811-002 OUTPUT PWB EA 30731811-501 30731811-003 PWA, OUTPUT EA 30731811-501 30731811-501 PWA, OUTPUT EA 30731811-503 OUTPUT PWB EA 30731811-501 30731814-002 P/W BD ASSY-HWY #2 EA 30750338-505 30731814-003 PWA HIWAY #2 EA 30750338-505 30731814-004 PWA ASSM HIWAY #2 EA 30750338-505 30731814-005 PWA HIWAY #2 EA 30750338-505 30731814-501 PWB,HWY II ANALG EA 30750338-506 30731814-502 P W BOARD HWY#2 EA 30750338-505 30731814-503 PWA HIWAY #2 EA 30750338-505 30731814-504 PWB ASSY HIGHWAY #2 EA 30750338-505 30731814-505 PWB, HIWAY #2 EA 30750338-505 30731817-005 PWAY HIWAY #1 EA 30731817-506 30731817-503 P W BOARD HWY #1 EA 30731817-506 30731817-504 PWB, HIWAY #1 EA 30731817-506 30731817-505 PWB, HIWAY #1 EA 30731817-506 30731817-506 PWB, HIWAY #1 EA 30731820-001 PWA DEP I/F EA 30750318-501 30731820-501 PWA DEP I/F EA 30750318-501 30731823-001 A/D MUX PWB EA 30731823-501 30731823-501 A/D MUX PWB EA 30731829-005 12K ROM 1K RAM EA 30750218-510 30731829-006 12K ROM 1K RAM EA 30750218-510 30731829-505 PW BOARD ASSY-MEMORY BD EA 30750218-510 30731829-506 PW BOARD ASSY-MEMORY BD EA 30750218-510 30731832-001 PWA, PROCESSOR EA 30731832-501 30731832-002 PWA, PROCESSOR EA 30731832-502 30731832-501 PWA, PROCESSOR EA 30731832-502 PWA, PROCESSOR EA 30731832-504 PWA, PROCESSOR EA 30731832-505 PWA, PROCESSOR (PIU & OP STATION FILES ONLY) EA 30731832-506 PWA, PROCESSOR (FOR DHP FILES ONLY) EA 30731832-507 PWA CPU OP. STATION EA 30731857-001 C-TPM02 LOCAL MARSHALLING PANEL EA 30731865-001 C-TPM01 REMOTE MARSHALLING PANEL EA 30731866-001 C-DPL00 DEP CBL LEFT EA 30731866-002 C-DPR00 DEP CBL RGHT EA 30731900-012 BASIC CTLR W/O DEP EA 30731900-013 BASIC CTLR W/DEP EA 30731900-014 EXTENDED CTLR W/O DIDEP EA 30731900-015 EXTENDED CTLR W/DIDEP EA 30731900-502 FILE & BACKPLANE EA 30731900-511 30731900-505 FILE & BACKPLANE EA 30731900-511 30731900-506 FILE & BACKPLANE EA 30731900-511 30731900-507 FILE & BACKPLANE EA 30731900-511 30731900-508 FILE & BACKPLANE EA 30731900-511 30731900-509 FILE & BACKPLANE EA 30731900-511 30731900-511 FILE & BACKPLANE EA 30731900-891 CONTR FILE KIT EA 30731906-001 C-ATC00 EXT CARD FOR AF000 EA 30731944-001 C-LPX00 (COVER) EA 30731950-001 C-JMP00 TERMINAL PNL EA 30731957-002 SWITCH TOGGLE 1P EA 30731958-001 JNCT PANEL, LONG EA 30731959-001 C-JCA00 W/82 JUNCT PNL EA 30731963-001 C-LT200 TRIM KIT DUAL TRIM EA 30731992-001 MTG. PLATE EA 30731993-001 RELAY MTG PANEL C-ARM00 EA 30731995-001 RANGE RES PKG (8 PER PACKAGE) EA 30731995-002 RANGE RES PKG (8 PER PACKAGE) EA 30731995-003 RANGE RES PKG (8 PER PACKAGE) EA 30731995-004 RANGE RES PKG (4 PER PACKAGE) EA 30731995-005 RANGE RES PKG (4 PER PACKAGE) EA 30731995-006 RANGE RES PKG (4 PER PACKAGE) EA 30731995-008 C-ARR12 RANGE RESISTORS EA 30731995-009 C-ARR13 RANGE RESISTORS EA 30731995-010 C-ARR14 RANGE RESISTORS EA 30731995-011 C-ARR15 RANGE RESISTORS EA 30731995-012 C-ARR16 RANGE RESISTORS EA 30731996-001 RGE RES, 100 OHM EA 30731996-002 RGE RES, 250 OHM EA 30731996-003 RGE RES,1000 OHM EA 30732003-001 FAN, VENTILATING EA 30733258-007 30732003-003 FAN VENTILATING EA 30732003-004 30732003-004 FAN, TUBEAXIAL CLE2T2,115VAC EA 38002994-115 30732003-005 FAN, TUBEAXIAL CLE3T2,220/240VAC EA 38002994-230 30732028-001 VENTILATING FAN EA 30732034-501 PWA, DISPLAY PANEL EA 30732036-001 BRACKET EA 30732037-001 DIAPLAY MODULE A EA 30732037-501 30732037-501 DISPLAY EA 30732038-001 CONNECTOR ADPTER EA 30732038-002 C-KD000 CBL SPLICE EA 30732048-001 PANEL EA 30732050-001 CONNECTOR,LARGE EA 30732051-001 COAX SPLICE EA 30732052-001 PLUG TERMINATOR EA 30732054-001 COAX CON (SMALL) FOR FM59 20 GAUGE COAX CBL EA 30732055-001 COAX TEE CONNECTOR EA 30732100-001 30732077-001 BUS BAR EA 30732079-001 SPACER EA 30732081-001 BUS BAR DIV EA 30732081-002 BUS BAR DIV EA 30732081-007 BUS BAR DIV EA 30732093-001 PARTS KIT EA 30732094-002 C-EPS20 MNTG PLATE 24IN EA 30732094-004 C-EPD20 MNTING PLATE EA 30732096-001 SUPP PARALLEL BUSBAR EA 30732096-002 SUPPORT PANEL&BU EA 30732098-001 INSULATOR BNC EA 30732100-001 COAX TEE KIT (QTY 1) EA 30732100-002 TEE CONN(2) KIT EA 30732101-001 C-MH128 BACKPANEL KIT 28IN EA 30732101-003 C-MH163 MOUNTING HDW EA 30732101-005 C-MH177 BACKPANEL KIT FOR 77IN CABINET EA 30732101-006 C-MH200 MOUNTING HDW EA 30732101-007 C-MHP00 SIDE PLATE EA 30732101-008 C-MH121 BACKPANEL KIT 21IN EA 30732102-001 PARTS KIT CABINET EA 30732102-002 PARTS KIT CABINET EA 30732104-001 SWITCH ELEC AIR EA 30732106-001 7A PWR SPLY KIT C-SSC61 EA 30732106-002 20A PWR SPLY KIT C-STC61 EA 30732106-004 20A 50HZ PWR SPLY EA 30732106-005 7A 50HZ PWR SPLY EA 30732106-006 20A 50HZ PWR SPL C-STC51 EA 30732106-890 7A P.S. MTG KIT EA 30732106-891 20A P.S. MTG KIT EA 30732107-006 COAX CON KIT-LGE EA 30732107-007 COAX SPLICE KIT EA 30732107-009 COAX TERM KIT (QTY 2) EA 30732107-010 SMALL CONN KIT (4) EA 30732107-011 CRIMP TOOL KIT EA 30732111-001 SWITCH, P.B. EA 30732126-001 Y - DEP EA 30732128-001 Y-MARSHAL. PANEL EA 30732130-001 Y - MANUAL EA 30732132-001 Y - AUTO/MANUAL EA 30732134-001 Y - TERM EA 30732138-001 RES ASSM(2) C-AJC00 EA 30732160-001 MTG BRKT KIT EA 30732160-002 C-MPK01 ANGLE BRACKT EA 30732171-002 BASIC CTRL, HWY EA 30732171-004 30732171-004 BASIC CTRL, HWY EA 30732171-005 KIT HWY I/F (C-HCB20) EA 30732172-204 C-SW204 PWR JUNC BLK EA 30732172-904 C-SW204 PWR JUNC BLK EA 30732175-001 C-SJA00 P/S JUNCTASM+24V AND COM EA 30732175-002 P/S JUNCT.ASSM EA 30732214-002 CIRC BREAKER EA 30732219-001 PWB, CABLE LOGIC EA 30732219-504 30732219-002 PWB, CABLE LOGIC EA 30732219-504 30732219-003 PWB, CABLE LOGIC EA 30732219-504 30732219-004 PWB, CABLE LOGIC EA 30732219-504 30732219-501 PWA, CABLE LOGIC EA 30732219-504 30732219-502 PWA, CABLE LOGIC EA 30732219-504 30732219-503 PWA, CABLE LOGIC EA 30732219-504 30732219-504 PWB, CABLE LOGIC EA 30732233-001 PWB, CBL DRVS & RCRVRS EA 30732233-501 30732233-501 PWA, CABLE DR/REC EA 30732236-001 PL & SW ASSY EA 30732238-501 PWR END CAP EA 30732242-501 P/B SEL ASSY EA 30750272-501 30732254-001 PWA, DISPLAY GENERATOR DMA EA 30732254-501 30732254-501 PWA, DISPLAY GENERATOR DMA EA 30732260-001 CABLE ASSM EA 30732266-001 PWA, 8K MEMORY EA 30732266-501 30732266-002 PWA, 8K MEMORY EA 30732266-501 30732266-501 PWA, 8K MEMORY EA 30732307-001 FAN ASSY-REPL EA 30732307-501 30732307-501 FAN ASSY-REPL EA 30732316-001 OP STA BACKPLANE EA 30732316-002 OP STA BACKPLANE EA 30732316-003 OP STA BACKPLANE EA 30732316-004 OP STA BACKPLANE EA 30732329-001 CASSETTE, BLANK EA 30732333-001 POWER SUPPLY, 12V EA 30732333-002 POWER SUPPLY, 12V EA 30732344-501 PWR SPLY, AC/DC EA 30732356-501 SPARE FILE & BACKPLANE EA 30732356-504 30732356-502 SPARE FILE & BACKPLANE EA 30732356-504 30732356-503 SPARE FILE & BACKPLANE EA 30732356-504 30732356-504 SPARE FILE & BACKPLANE EA 30732367-002 TERMINAL BOARD EA 30732368-001 CABLE, KYBD I/F EA 30754513-001 30732372-002 POWER SUPPLY ASSY EA 30732372-502 30732372-502 POWER SUPPLY ASSY EA 30732383-001 GPCI FILE C-HC10 EA 30732383-501 FILE & BACKPLANE EA 30732386-501 TEST LOGIC PWB EA 30732389-501 T/P USED ON GPCI EA 30732389-502 TEST PANEL EA 30732393-001 DRIVER/RECEIVER EA 30732393-501 30732393-501 HIWAY DRI/REC EA 30732396-501 HIWAY LOGIC PWB EA 30732403-501 PWA, POWER MONITOR EA 30732406-001 LAMP (RED) EA 30732406-002 LAMP (YEL/AMB) EA 30732410-501 PWR SPLY, 1.5AMP EA 30732411-501 PWR SUPPLY, 3 AMP EA 30732416-001 I/O CABLE 25FT EA 30732416-002 RIBBON CABLE 1M EA 30732418-001 POWER SUPPLY ASSY EA 30732418-501 30732418-002 POWER SUPPLY ASSY EA 30732418-502 30732418-501 PS/CHARGER 115V EA 30732418-502 PS/CHARGER 240V EA 30732425-501 I/F PWB C-DSR01 EA 30732432-501 PWR SUPPLY, 24VDC EA 30732437-501 FAN EA 30732307-501 30732439-501 PWA, DISPLAY GENERATOR EA 51304797-100 30732439-502 PWA, DISPLAY GENERATOR EA 51304797-100 30732439-503 PWA, DISPLAY GENERATOR EA 51304797-100 30732463-001 TOGGLE SWITCH EA 30732480-001 POWER SUPPLY ASSY EA 30732480-501 30732480-002 POWER SUPPLY ASSY EA 30732480-502 30732480-501 POWER SUPPLY ASSY, 115V EA 30732480-502 POWER SUPPLY ASSY, 240V EA 30732485-002 COM I/F CABLE EA 30732486-001 LAMPHOLDER ASSY EA 30732486-002 LAMPHOLDER ASSY EA 30732487-001 RELAY EA 30732489-001 RELAY-PLUG IN EA 30732494-001 PLATE EA 30732495-001 24VAC XFMR, 60HZ C-SCD61 EA 30732498-001 TRANSFORMER EA 4DP7APPRT101 30732498-002 TRANSFORMER EA 4DP7APPRT102 30733155-501 REGULATOR PWB EA 51196989-100 30733157-001 CABLE I/F PWB EA 30733157-501 30733157-501 CABLE I/F PWB EA 30733159-501 PWB, HTD LOGIC EA 30733159-502 30733159-502 PWB, HTD LOGIC EA 30733174-001 FILE&BACKPLANE HTD C-HTD00 EA 30733174-003 30733174-002 HTD/C-HTD20 EA 30733174-003 30733174-003 HTD/C-HTD20 EA 30733174-501 HTD FILE&BCKPLN EA 30733174-502 30733174-502 HTD FILE&BCKPLN EA 30733258-001 FAN & PLATE ASSM EA 30733258-002 C-EF151 FAN ASSEMBLY EA 30733258-003 FAN & PLATE ASSY EA 30733258-004 FAN & PLATE ASSM EA 30733258-005 FAN ASSM 24IN 220V (C-EF251) EA 30733258-007 FAN ASSY, 115VAC (INCL FAN CL2L2) EA 30733258-008 FAN ASSY, 220/240VAC (INCL FAN CL3L2) EA 30733262-501 PWA,CASSETTE I/F EA 30734500-001 C-SBU11 40A BATT B/U110/115V W/MERC RELAY EA 30734500-002 BATTERY BACKUP EA 30734500-003 C-SBU01 BATTERY BACKUP ASSM EA 30734500-505 BBU FILE ASSY EA 30734538-001 BLACK CABLE ASSY EA 30734538-002 RED CABLE ASSY EA 30734538-003 CABLE ASSEMBLY EA 30734551-001 RECRD TRIP STRIP EA 30734558-001 BBU PWB EA 30734558-501 30734558-501 BBU PWB EA 30734572-001 CRT, KIT EA 30734578-001 C-CBK00 CONTROLLER PARTS KIT EA 30734578-002 C-CBK01 CONTROLLER PARTS KIT EA 30734578-003 C-CBK02 CONTROLLER PARTS KIT EA 30734579-001 C-DPK00 SPARES KIT EA 30734592-001 C-LSM01 1-LOOP STBY EA 30734680-001 BBU MTG HARDWARE EA 30734680-002 C-SBH02 BBU TRAY KIT24" EA 30734772-001 PWB C-AA191 EA 30734772-002 PWB C-AA291 EA 30734910-501 PWB ASSY EA 30734980-004 TAPE, R300 DIAG EA 30734980-005 TAPE,HIWAY TEST EA 30734980-006 TAPE,R310 DIAG EA 30734980-300 TAPE,R310 PROG EA 30734980-310 30734980-301 TAPE,R310 TREND EA 30734980-311 30734980-310 TAPE,R310 PROG EA 30734980-311 TAPE,R310 TREND EA 30734982-001 PWA,CASS BOOTSTR EA 30750783-504 30734982-501 PWA,CASS BOOTSTR EA 30750783-504 30735047-001 PWB, INTEGRITY EA 30735047-501 30735087-001 BACKPLANE SUB-AS EA 30735088-002 C-SBK11 BBU TRAY KIT EA 30735150-002 ENH, HWY ACCESS EA 30735150-004 30735150-004 ENH, HWY ACCESS EA 30735150-503 FILE & BACKPLANE EA 30735150-504 SPARE PAE FILE EA 30735173-002 PWA, PAE LOGIC EA 30735173-502 30735173-501 PWA, PAE LOGIC EA 30735173-502 30735173-502 PWA, PAE LOGIC EA 30752608-003 30735465-001 C-LAK00 ANALOG DISP KIT EA 30735586-001 C-DEL00 ENERGY LMTR EA 30735589-001 FLAT WIRE CLIP EA 30735685-001 KEY BD ALARM_ EA 30735685-501 30735685-002 KYBD,ALARM OPSTN EA 30735685-502 30735685-003 KYBD,OP STN ALRM EA 30735685-503 30735685-004 KEYBOARD EA 30735685-504 30735685-501 KEY BD ALARM EA 30735685-502 KYBD,ALARM OPSTN EA 30735685-503 KYBD,OP STN ALRM EA 30735685-504 KEYBOARD EA 30735841-001 PWB, INTEGRITY EXT EA 30735857-001 PWB, CMOS MEMORY EA 30735857-501 30735857-005 PWB, CMOS MEMORY EA 30735857-505 30735857-501 PWB, CMOS MEMORY EA 30735857-505 PWB, CMOS MEMORY EA 30735860-001 TRANSCEIVER PWB EA 30735860-501 30735860-501 TRANSCEIVER PWB EA 30735863-001 SWITCHING PWB EA 30735863-501 30735863-002 C-CDS00 ANALOG SWITCHCARD EA 30735863-502 30735863-501 SWITCHING PWB EA 30735863-502 C-CDS00 ANALOG SWTCHCARD EA 30735866-001 DECODER PWB EA 30735866-501 30735866-501 DECODER PWB EA 30735871-002 EXT CTLR B/DIR EA 30735871-004 30735871-003 RCD FILE C-CD100 EA 30735871-004 30735871-004 UNIVERSAL RCD FILE (C-CD300) EA 30735871-501 FILE & BACKPLANE EA 30735871-503 30735871-502 FILE & BACKPLANE EA 30735871-504 30735871-503 FILE & BACKPLANE EA 30735871-504 30735871-504 FILE & BACKPLANE EA 30735873-501 PWA, LOOP MANUAL EA 30735876-001 JNCT PANEL, PRIM EA 30735879-001 JNCT PANEL, RCD EA 30735887-001 P/W BOARD ASSY P EA 30735887-501 30735887-501 PWB, PRINTER I/F EA 30735892-001 CABLE ASSEMBLY EA 30735892-003 CABLE ASSY RESER EA 30735893-001 C-KR001 RBN CBL FOR UAC 1M EA 30735893-002 C-KR002 RBN CBL FOR UAC 2M EA 30735893-003 C-KR003 RBN CBL FOR UAC 3M EA 30735893-005 C-KR005 RBN CBL FOR UAC 5M EA 30735893-008 C-KR008 RBN CBL FOR UAC 8M EA 30735974-001 P/W BOARD ASSY TREND MEMORY EA 30735974-503 30735974-003 TREND MEMORY PWB EA 30735974-503 30735974-004 PWB, TREND MEM. EA 30735974-504 30735974-501 TREND MEMORY PWB EA 30735974-503 30735974-502 TREND MEMORY PWB EA 30735974-503 TREND MEMORY PWB FOR BASIC OPER STATION EA 30735974-504 PWB, TREND MEM. EA 30736012-001 KYBD MASK EA 30736012-002 KEYBD MASK ASSY EA 30736013-001 KEY-SWITCH ASSY EA 30736014-001 KEYLOCK/SWITCH EA 30736015-001 KEYBAROD, STD. EA 30736015-501 30736015-501 KEYBOARD ,STD. EA 30736020-001 KYBD MOUNTING BAR, RIGHT EA 30736020-002 KYBD MOUNTING BAR, LEFT EA 30736215-001 PWR SPLY, 5V EA 30736215-501 PWR SUPPLY 5VDC EA 30736216-001 POWER SUPPLY 5V EA 30736220-501 PWB, KYBD I/F EA 30750990-502 30736260-001 INTEGRITY CARD W/EXTENDER (C-FMH00) EA 30736275-001 RIBBON CABLE EA 30736324-001 BATTERY CLIP EA 30736325-001 BATTERY CABLE EA 30736326-001 BATTERY-NICKEL CADIUM 7.2V EA 30736335-001 POWER CABLE ASSM EA 30736337-001 PTR I/F CABLE EA 30736338-001 30736338-001 PTR I/F CABLE EA 30736346-001 C-CBM01 EA 51196689-100 30736346-002 UPGRADE BASIC CMOS EA 51196689-100 30736356-001 C-ASK00 SPARE PARTS KIT EA 30736388-001 PWR SUPPLY, OPERATOR STN EA 30736388-501 30736388-501 PWR SUPPLY, OPERATOR STN EA 30747002-001 CIRC BREAKER EA 30747003-001 CIRCUIT BREAKER BOX EA 30747074-003 PANDUIT EA 30747074-004 PANDUIT EA 30747074-005 PANDUIT 4X4 EA 30747074-007 PANDUIT 3X4 EA 30747074-010 PANDUIT COVER 2IN EA 30747074-012 PANDUIT COVER 4IN EA 30747074-013 PANDUIT 4 X 3 IN EA 30747083-001 DIODE ASSY EA 30747093-001 CIRCUIT BREAKER BOX EA 30747205-169 BARRIER GND BLK EA 30747225-001 YLW BARRIER-FM EA 30747225-002 GRN BARRIER-FM EA 30747225-003 RED BARRIER-CSA EA 30747225-004 RED BARRIER-FM EA 30747225-006 GRN BARRIER-CSA EA 30747243-001 RAIL TERM BLOCK EA 30747537-001 BOX-OUTLET-4 IN EA 30747538-001 COVER-BLANK-4 IN EA 30747646-001 GPCI ADAPTER EA 30747646-501 30747646-501 GPCI ADAPTER EA 30748679-001 HOOTER HORN EA 51190924-100 30748863-001 SHIELD ASSM 39IN EA 30750218-001 PWA EA 30750218-511 30750218-003 SS MEMORY PWB EA 30750218-511 30750218-005 12K ROM/IK RAM EA 30750218-511 30750218-007 12K ROM 1K RAM A EA 30750218-507 30750218-008 12K ROM 1K RAM EA 30750218-510 30750218-009 12K ROM 1K RAM EA 30750218-510 30750218-011 PWA EA 30750218-511 30750218-502 SS MEMORY PWB EA 51191556-100 30750218-503 SS MEMORY PWB EA 30750218-511 30750218-504 12K ROM 1K RAM A EA 30750218-507 30750218-505 12K ROM 1K RAM A EA 30750218-510 30750218-506 12K ROM 1K RAM A EA 30750218-507 30750218-507 PWA, 12K ROM 1K RAM EA 30750218-508 12K ROM 1K RAM EA 30750218-510 30750218-509 12K ROM 1K RAM EA 30750218-510 30750218-510 12K ROM 1K RAM EA 30750218-511 SS MEMORY PWB EA 30750272-001 P/B SEL ASSM EA 30750272-501 30750272-501 P/B SEL ASSM EA 30750308-001 JUNCT PANEL, DI EA 30750318-001 PWA, DEP I/F (-501 OBSOLETE) EA 51196880-100 30750318-002 PWA, DEP I/F EA 30750318-502 30750318-003 PWA, DEP I/F EA 30750318-503 30750318-501 PWA, DEP I/F BASIC CTLR (C-DP100) EA 51196880-100 30750318-502 PWA, DEP I/F EXTENDED CTLR WITH DI (C-DP201) EA 51196882-100 30750318-503 PWA, DEP I/F EXTD CTLR W/OUT DI (C-DP200) EA 51196880-100 30750338-002 PWA, HIWAY #2 EA 30750338-504 30750338-003 PWA, HIWAY #2 EA 30750338-505 30750338-004 PWA, HIWAY #2 EA 30750338-504 30750338-005 PWA, HIWAY #2 EA 30750338-505 30750338-501 PWA, HIWAY #2 EA 30750338-504 30750338-502 PWA, HIWAY #2 EA 30750338-504 30750338-503 PWA, HIWAY #2 EA 30750338-505 30750338-504 PWA, HIWAY #2 EA 30750338-505 PWA, HIWAY #2 EA 30750354-001 CONNECTOR EA 30750362-001 LED (RED) EA 30750509-001 C-KDP01 DIGITAL CBL 1.25M EA 30750509-002 C-KDP02 DIGITAL CBL 2M EA 30750509-003 C-KDP03 DIGITAL CBL 3M EA 30750509-005 C-KDP05 DIGITAL CBL 5M EA 30750509-008 C-KDP08 DIGITAL CBL 8M EA 30750540-001 PWR SUPPLY OP ST (-502 OBSOLETE) EA 30750540-502 30750540-002 PWR SUPPLY OP ST (-502 OBSOLETE) EA 30750540-501 PWR SUPPLY OP ST (-502 OBSOLETE) EA 30750540-502 30750565-002 KEY REPL EA 30750565-003 KEY EA 30750565-004 CABINET KEY EA 30750730-501 PWA, DISKETTE I/F EA 30750732-501 PWA, CORE MEMORY EA 30750745-001 PARTS KIT, GPCI EA 30750768-003 DIGITAL SWITCH CARD EA 30750768-503 30750768-501 DIGITAL SWITCH CARD EA 30750768-503 30750768-502 PWA, DIGITAL I/O EA 30750768-503 PWA, DIGITAL I/O SWITCH EA 30750771-001 PWA, DIG I/O EA 30750771-501 30750771-501 PWA, DIGITAL I/O EA 30750774-003 PWB ASSY UAC DIGITAL OUTPUT EA 30750774-503 30750774-501 PWA, UAC D/O EA 30750774-503 30750774-502 PWA, UAC D/O EA 30750774-503 30750774-503 PWA, UAC D/O EA 30750780-001 RESERVE JUNC PNL EA 30750783-003 DISKETTE BOOTSTR EA 30750783-503 30750783-004 DISKETTE BOOTSTR EA 30750783-504 30750783-503 PWA,DISK BOOTSTR EA 30750783-504 PWA,CASS BOOTSTR EA 30750786-001 PWB, RAM/EDAC EA 51304528-100 30750786-501 PWB, RAM/EDAC EA 51304528-100 30750847-001 FLOPPY DISK DRIVE 8IN EA 30751177-503 30750851-001 RCD JUNCTION PNL EA 30750897-001 FILE, UAC DIG IO EA 30750897-501 FILE & BACKPLANE EA 30750903-001 CABLE, DIG I/O EA 30750944-001 KEYBOARD, STANDARD EA 30750944-501 30750944-003 KEYBOARD, OP STN STD EA 30750944-503 30750944-004 KEYBOARD EA 30750944-504 30750944-501 KEYBOARD ,STD. EA 30750944-503 KYBD,OP STN STD EA 30750944-504 KEYBOARD EA 30750947-001 FILTER PERM WASH EA 30750954-001 LAMP, 5V .075AMP EA 51109392-100 30750957-001 KEYBOARD MASK AS EA 30750957-003 KEYBOARD MASK EA 30750957-004 30750957-004 KEYBOARD MASK EA 30750990-001 PWB, KEYBOARD I/F EA 30750990-502 30750990-501 PWB, KEYBOARD I/F EA 30750990-502 30750990-502 PWA, KEYBOARD I/F EA 30751044-004 PWA, DHPII ROM EA 30751044-508 30751044-005 PWA, DHPII ROM EA 30751044-508 30751044-006 PWA, DHPII ROM EA 30751044-508 30751044-007 PWA, DHIPII ROM EA 30751044-508 30751044-008 PWA, DHPII ROM EA 30751044-508 30751044-501 PWA, DHPII ROM EA 30751044-508 30751044-502 PWA, DHPII ROM EA 30751044-508 30751044-503 PWB_ASSM CONT II ROM BD _ EA 30751044-508 30751044-504 PWB ASSM CONT II ROM BD EA 30751044-508 30751044-505 PWA, DHPII ROM EA 30751044-508 30751044-506 PWB, DHPII ROM EA 30751044-508 30751044-507 PWB, CTLR II ROM EA 30751044-509 30751044-508 PWA, DHPII ROM EA 30751044-509 PWA, CTLR II ROM EA 30751044-510 PWA, DHPII ROM EA 30751082-008 ID PLATE, KYBD EA 30751083-001 DSG40 KYBD ASSM EA 30751083-003 DSG52 KYBD ASSM EA 30751083-004 DSG55 KYBD ASSM EA 30751083-005 DSG56 KYBD ASSM EA 30751139-001 FLOPPY DISK DRIVE 8IN EA 30751139-002 FLOPPY DISK DRIVE 8IN, 50HZ EA 30751139-003 C-DSD61 DISK DRIVE #1 EA 30751139-004 C-DSD51 DISC DRIVE #1 EA 30751144-001 BLANK 8IN TEST DISK FOR BASIC OPER STATIONS EA 30751144-002 DIAGNOSTIC DISK EA 30751144-003 HIWAY TEST DISK EA 30751793-003 30751144-004 DIAGNOSTIC DISK EA 30751144-005 DIAG DISK FOR R610 OR R615 BASIC OPER STA EA 30751144-360 R360 PRGM DISK EA 30751144-420 R420 PROG DISK EA 30751144-460 R460 PRG DISKETT EA 30751144-610 R610 PRGM DISK EA 30751144-615 R615 PRGM DISK 8IN MEDIA EA 30751153-001 FDD SIGNAL CABLE EA 30751153-002 FDD SIGNAL CABLE EA 30751176-003 C-DSD62 EA 30751176-004 C-DSD52 EA 30751177-001 FLOPYY DISK DRIVE 8IN, NON-UNIV EA 30751177-501 30751177-002 DISK DRIVE EA 30751177-003 DISK DRIVE EA 30751177-004 DISK DRIVE EA 30751177-005 DISK DRIVE 60 HZ EA 30751177-006 DISK DRIVE 50 HZ EA 30751177-501 FLOPPY DISK DRIVE 8I, NON-UNIV EA 30751228-001 C-TBR10 BARRIER RESISTOR MODULE EA 30751238-003 FAN GUARD EA 30751315-001 C-TCB20 CONTROLLER TERMINAL PANEL EA 30751315-002 C-TCB21 CONTROLLER TERMINAL PANEL EA 30751394-001 BASIC DEP/EXT DE EA 30751395-001 BASIC DEP/EXT DE EA 30751404-001 PARTS KIT-OUTPUT C-ARR10 EA 30751473-001 DISKETTE EA 30751731-001 DISK CLEANING KIT FOR 8IN FDD BAS/ENH OP STAT EA 30751793-001 DIAGNOSTIC DISK EA 30751793-002 PROG MEDIA R420 EA 30751793-003 HIWAY TEST DISK EA 30751793-004 DIAGNOSTIC DISK EA 30751793-005 PROG MEDIA R360 EA 30751793-006 PROG MEDIA R460 EA 30751793-007 PROG MEDIA R610 EA 30751793-008 PROG MEDIA R615 EA 30751793-009 R360 5-1/4IN SET EA P-DK361 30751793-010 R615 5-1/4IN SET EA P-DK616 30751853-501 PWA,ERROR DETECT EA 30751856-501 PWA, 128K MEM EA 30752106-001 KYBD UPDATE KIT EA 30752106-002 KEYCAP KIT EA 30752117-002 1MW MEMORY REPLC EA 30752117-003 MEM UPDATE KIT EA 30752117-004 MEM UPDATE KIT EA 30752117-003 30752117-005 MEM UPDATE KIT EA 30752117-003 30752548-501 PWB PANEL ASM EA 30752588-001 PWB, CMOS RAM ASSM DHP 8KX17 EA 30752588-501 30752588-501 PWB, CMOS RAM ASSM DHP 8KX17 EA 30752606-001 BATTERY,STORAGE EA 30752608-001 KIT-DIR FILE UPD EA 30752608-002 HTD UPGRADE KIT EA 30752608-003 PAE UPGRADE KIT EA 30752766-001 PWA, TRANSCEIVER EA 30752766-501 30752766-501 PWA, TRANSCEIVER EA 30752783-001 BATTERY TEST CARD EA 30752787-002 PWA, COMM LOGIC EA 30752787-502 30752787-502 PWA, COMM LOGIC EA 30752787-503 PWA, COMM LOGIC EA 30752832-501 PWA, EIU MICROENGINE EA 30752923-501 EIU PROM CARRIER EA 30752946-001 DHP TEST PANEL EA 30752946-501 30752946-501 DHP TEST PANEL EA 30752948-001 DHP BATTERY ASSM EA 30752948-501 30752948-501 DHP BATTERY ASSM EA 30752981-501 PWA, EIU RAM I/F EA 30752984-501 EIU HWY INTERFACE EA 30752986-501 FILE & BACKPLANE,EIU EA 30753004-001 DHPII_(C-HL200) EA 30753004-002 30753004-002 DHPII (C-HL200) EA 30753004-003 DHP II W/RETRY EA 30753004-502 DHP FILE & BACKPLANE EA 30753004-503 30753004-503 DHP II W/RETRY FILE AND BACKPLANE EA 30753018-001 CABLE ASSY-INTER EA 30753019-001 CABLE ASS'Y DHP EA 30753020-001 I/F CABLE-15' LL EA 30753020-002 I/F CABLE-50' EA 30753022-001 DHP CABLE-15F' MODIFIED EA 30753022-002 DHP CABLE-50FT MODIFIED EA 30753023-001 DHP CABLE-15' EA 30753023-002 DHP CABLE-50' EA 30753024-001 CABLE ASSEMBLY 15',A/B CBL EA 30753024-002 I/F CABLE-50' EA 30753419-001 FLOPPY DISC 60HZ EA 30753732-001 HIWAY COUPLER MO EA 30753732-501 30753732-501 HIWAY COUPLER MO EA 30753985-001 HARNESS ASSY EA 30754051-001 C-KFT02 PRE-TERMIN. FIBER OPTIC CBL 2M EA 30754051-004 C-KFT10 PRE-TERMIN. FIBER OPTIC CBL 10M EA 30754051-006 C-KFT50 PRE-TERMIN. FIBER OPTIC CBL 50M EA 30754096-001 LINK, TERM JMPR EA 30754117-001 DC POWER CABLE EA 30754118-001 CABLE ASM, DISK EA 30754170-001 GENICOM PTR, MODEL C-DSP40 EA 30754171-001 30754171-001 GENICOM PTR, MODEL C-DSP40 EA 30754171-002 PTR & PEDESTAL EA 30754362-001 KIT, PARTS (HCM) EA 30754420-001 PWA, LOOP I/F EA 51196478-101 30754420-002 APHO PWB ASSY EA 30754420-003 PWA, APTR/12 EA 51196478-103 30754420-004 PWA, PRNTHD DRIV EA 51196478-104 30754420-005 PWA, PWR BOARD EA 51196478-105 30754420-006 PWA, ACL/1_REG EA 51196478-106 30754420-007 PRINTHEAD 18WIRE EA 51196478-107 30754420-008 CARRIAGE ASM EA 51196478-108 30754420-009 CABLE, CARRIAGE EA 51196478-109 30754420-010 MOTOR, CARRIAGE EA 51196478-110 30754420-011 CABLE, PRINTHEAD EA 51196478-111 30754420-012 CABLE, PRINTHEAD EA 51196478-112 30754420-013 CARRIAGE STOP EA 51196478-113 30754420-015 SHAFT,TURNAROUND EA 51196478-115 30754420-016 Bracket, Turnaround EA 30754420-017 Ribbon, Printer EA 30754420-018 MOTOR,RIBBON DRI EA 51196478-118 30754420-019 Cable, Printer EA 30754420-020 Left Tractor Asm EA 30754420-021 TRACTOR ASM,RGHT EA 51196478-121 30754420-022 Motor, Paper Feed EA 30754420-023 BUSHING,TRACTOR EA 51196478-123 30754420-024 PAPER DRIVE BELT EA 30754420-025 ROLLER (SET) EA 30754420-026 ROLLER (SET) EA 30754420-027 GEAR, UP FRICTIO EA 51196478-127 30754420-028 GEAR, TRACTOR EA 51196478-128 30754420-029 Knob, Paper Advance EA 30754420-030 FAN & SHROUD ASM EA 51196478-130 30754420-031 STRAP,JUMPER EA 51196478-131 30754420-033 Fuse Link EA 30754420-034 FUSE, 25A 125V EA 51196478-134 30754420-035 FUSE, 3A 125V EA 51196478-135 30754420-036 FUSE, 7A 125V EA 51196478-136 30754420-037 Fuse, 3A, 300V EA 30754420-038 ECPU/1 Card (Printer) EA 30754420-039 RIBBON,REINKABLE EA 51196478-139 30754420-040 PWA,ECPU/I EA 51196478-140 30754420-042 Control Panel, C-DSP40 EA 30754513-001 CABLE ASS'Y KEY EA 30754514-001 CABLE ASS'Y ALAR EA 30754536-001 PWA, REG MONITOR EA 30754536-501 30754536-501 PWA, REG MONITOR EA 30754579-001 FUSE EA 30754584-003 GROUNDSTRAP EA 30754649-001 SPDT RELAY FOR 110V CABINET FAN ASSY EA 30754649-002 SPDT RELAY FOR 220V CABINET FAN ASSY EA 30754651-001 FAN & PLATE ASSM EA 30754651-003 FAN & PLATE ASSM EA 30754651-004 C-EF252 FAN ASSEMBLY24IN, 230V, CENTERED EA 30754661-009 FUSE, MICRO 1/8 EA 30754661-011 FUSE,SUBMINI.25A EA 30754661-014 FUSE, .5 AMP EA 30754661-019 FUSE, 1.0A EA 30754661-021 2 AMP MICROFUSE EA 30754661-022 FUSE, 3A EA 30754718-001 PTR I/F KIT MODEL C-DSP01 EA 3123C PENTIUM II CPU 400MZ EA 31324 POWER CORD 6' EA 3150045 FUSE EA 30076014-001 3150360 FUSE EA 30076014-001 3253E PS2 MOUSE EA 51196982-900 3340D KEYBOARD, 104 EA 340-0291 ADAPTOR, 2940 EA 51196935-907 3593U MOUSE, PS2 EA 38001057-300 5V PWR SUPPLY EA 38001072-100 PWB, KJUMP EA 51401594-200 38001508-100 Adapter, Coupler Module EA 38001774-100 PWB,CLM TIWAY II EA 51195863-100 38001897-100 FTA MOD 120VDIEC EA 38001897-125 38002210-100 IOP, HLAI (CC) EA 51304754-150 38002211-100 A/O IOP PWA (8) EA 51309152-175 38002218-100 FTA,TC_MUX EA 51309223-175 38002669-110 PWR SUPPLY 110V, OPERATOR STATION EA 38002669-220 PWR SUPPLY 220V, OPERATOR STATION EA 38002931-100 MCRAM Battery 3.6VNicD EA 38002994-115 FAN/RELAY KIT 115V EA 38002994-230 FAN/RELAY KIT 230V EA 38002996-100 Monitor, Basic in KOP Furn. EA 51195868-800 38002996-200 Monitor, Basic in Univ. Furn EA 51195868-925 38003025-100 DIN to Phone Adapter Kit EA 38500143-100 LCNE HUB ASSY EA 38500143-200 LCNE HUB ASSY EA 38500143-300 LCNE HUB ASSY EA 38500143-400 LCNE HUB ASSY EA 38500143-500 LCNE HUB Z-FURN EA 38500143-600 RED LCNE HUB Z-FURN EA 38500148-300 LCNE HUB PWR SUPPLY (5 SLOT) EA 3884D 1.44M FLOPPY DR EA 38XEV SI,HNYWL,CD,SCSI,17/40X,680M EA 40079 POWER CORD 6' EA 4023C MOTHERBOARD DELL 400MHZ GX1 EA 40800601-100 PWB, HDLC COM EA 40800601-200 HDLC COMM PWB EA 40800605-100 2GB DAT TAPE DRV EA 40800605-200 4/8 GB TAPE DR EA 40800606-100 1GB OPTICAL DRIV EA 40800621-300 SVGA MONITOR EA 40800624-100 MODEM EA 40800626-050 RS449, CABLE 50M EA 40800627-100 PWB, ETNERNET EA 40800627-102 40800627-102 Ethernet Card EA 40800632-100 TOKEN RING ADPTR EA 40800632-200 TOKEN RING ADPTR EA 40800730-100 DESKTOP SERVER EA 40800730-300 DESK TOP SERVER EA 40800731-100 TOWERSERVER BASE EA 40800731-300 SERVER EA 4123C 450MHz DESKTOP EA 51196982-902 4160U 9GB U160 HARD DRIVE EA 416434 0303 FUSE 3A 250V EA 30076014-009 42601193-002 HARNESS P/E,CIRC BRK EA 42601377-006 AIR FILTER, LCN TS8 RITTAL CABINET EA 42601517-002 RETAINING SPRING, LCN TS8 RITTAL CABINET EA 42601650-003 POWER ENTRY, 240VAC, 2-POLE, LCN TS8 CAB EA 42601650-004 POWER ENTRY, 240VAC, 1-POLE, LCN TS8 CAB EA 42601902-002 Digital Isolator, MTL3052 EA 42601902-009 EMC IS-LL Multiplexer, MTL831B EA 42601902-014 IS-LLMux Receiver, Russian T/C, MTL838B-HONEC EA 42601902-020 IS-LLMux Receiver, MTL838B-HONEC EA 42601902-021 IS-LLMux Receiver, Sgl Hiway, MTL838B-HONEC EA 42602252-001 DO Isolator, MTL4021S EA 42602252-005 DO Magnetic Isolator, MTL4021RS EA 42602252-100 Connector, MTL SPCON01, Yellow EA 42602358-005 CIRCUIT BREAKER, 2A, 2-POLE, HPM TS8 CAB EA 42602358-007 CIRCUIT BREAKER, 10A, 2-POLE, HPM TS8 CAB EA 42602358-010 CIRCUIT BREAKER, 2A, 1-POLE, HPM TS8 CAB EA 42602358-012 CIRCUIT BREAKER, 10A, 1-POLE, HPM TS8 CAB EA 42602367-002 MOUNTING BRACKET, 1 TAP SET, LCN TS8 CAB EA 42602367-012 MOUNTING BRACKET, 2 TAP SETS, LCN TS8 CAB EA 42602375-001 Mounting Plate, FTA "B" Size EA 42621215-001 Mounting Plate, ISLLMUX EA 42622195-001 Temperature Converter, MTL4073 EA 42622195-002 Russian XK T/C Converter, MTL4073 EA 42622212-016 HART Interface Module, MTL4842 EA 42622212-018 HART Communications Module, MTL4841 EA 42622212-019 HART Maintenance System Baseplate EA 42622212-020 RS232-RS485 Converter, Westermo K9999M2000 EA 42622212-021 HART Communications Module-AMS, MTL4841-AMS EA 42622216-001 Connector w/CJS, MTL SCJ01 EA 42623231-001 Cable, HART Bus, 150cm EA 42623231-002 Cable, HART Bus, 80cm EA 42623233-001 Cable, HART/FTA, 70cm EA 42623233-002 Cable, HART/FTA, 90cm EA 42623233-003 Cable, HART/FTA, 140cm EA 42623233-004 Cable, HART/FTA, 180cm EA 42623233-005 Cable, HART/FTA, 220cm EA 42964 CABLE, HD, AUX EA 44WUW PRC,80526,933,256,133,FC,C0 EA 463CD KYBD,104,6P,US,NMB,RD,SB EA 4780D KEYBOARD, 104 EA 51196982-901 4939R KEYBOARD, 104 EA 49788023-001 BARRIER BOX USA C-TBU10 EA 49788023-002 BARRIER BOX C-TBU11 EA 49788023-003 BARRIER BOX EA 49788026-001 C-TB110 INPUT MODULE(IS) EA 49788031-001 LINK MOD (C-TBL10) EA 49788042-001 C-TB010 OUTPUT MOD (IS) EA 4DP7APARR005 RANGE RES PKG EA 30731995-002 4DP7APBIC101 HLPIU BUS INTEGR EA 4DP7APCFA106 HL CCFA EA 4DP7APCFA107 HL PCFA-TRM TYPE EA 4DP7APCFA108 HL PCFA-CON TYPE EA 4DP7APCFA109 HL PCFA EA 4DP7APCFA207 LL PCFA EA 4DP7APCFA208 LL,PCFA ASSY EA 4DP7APCFA209 LL 7100 CFA EA 4DP7APCFA306 LE CCFA(STD MNT) EA 4DP7APCFA309 4DP7APCFA309 LE CCFA(STD MNT) EA 4DP7APCFA402 HL CCFA, R320B EA 4DP7APCFA403 4DP7APCFA403 HL CCFA, R320B EA 4DP7APCFA502 LL CCFA EA 4DP7APCFA601 LE CCFA-BKPNL MT EA 4DP7APCIM104 CSA TC W/NEMA BOX EA 4DP7APCIM204 RTD MUX CONSISTI EA 4DP7APFIM104 FM TC W/NEMA BOX EA 4DP7APFIM204 RTD MUX ASM EA 4DP7APFIM304 ASM,SAT MUX PWA TC EA 4DP7APISB101 P-ISB11 BARR BOX EA 51190843-001 4DP7APISB102 P-ISB12 BARR BOX EA 51104957-100 4DP7APISB103 P-ISB13 BARR BOX EA 51104957-101 4DP7APISB104 P-ISB14 BARR BOX EA 51104957-102 4DP7APISB105 P-ISB15 BARR BOX EA 51104957-103 4DP7APNMA101 NEMA 4 BOX (P-NMA11) EA 4DP7APODP202 HL 24VDC POWER FILTER EA 4DP7APODP203 POWER FILTER EA 4DP7APODP204 DUAL D/I PWR FIL EA 4DP7APOIM104 TC LOGIC&TERM BDS CBLS AND NEMA BOX ASSM EA 4DP7APOIM204 RTD LOGIC&TERM BDS, CBLS AND NEMA BOX EA 4DP7APOIM301 NEMA ASSM-NON IS EA 4DP7APOIM304 TC LOGIC & TERM BDS, MTG HDW CBLS-NON IS EA 4DP7APOIM401 MUX SET W/NEMA EA 4DP7APOIM403 LE-RTD-MUX-LOGIC EA 4DP7APOSE101 PWA, HIWAY SOE EA 4DP7APOSP101 SURGE PROTECT EA 4DP7APXSP111 4DP7APOSP201 SURGE PROTECT EA 4DP7APXSP211 4DP7APOSP301 SURGE PROTECT EA 4DP7APXSP311 4DP7APOSP401 SURGE PROTECT EA 4DP7APXSP411 4DP7APOSP501 SURGE PROTECT EA 4DP7APXSP511 4DP7APPRT101 LE REFERENCE TRANSFORMER, 60HZ EA 4DP7APPRT102 LE REFERENCE TRANSFORMER, 50HZ EA 4DP7APPRT202 LE PHASE REF TRA EA 4DP7APTCK101 CONNECTOR KIT P-TCK11 EA 4DP7APXAD211 A/D CONVERTER R3 EA 4DP7APXAD611 A/D CONVERTER LL EA 4DP7APXAD911 ANALOG DIG CONVE EA 4DP7APXCA111 BARRIER ADAPTOR EA 4DP7APXDH111 PWB, HIWAY I/F EA 4DP7APXDH122 SOE HIWAY I/F EA 4DP7APXDH211 DATA HIGHWAY INT EA 4DP7APXDH233 4DP7APXDH222 PWA, DATA HIWAY I/F EA 4DP7APXDH233 4DP7APXDH233 PWA, DATA HIWAY I/F EA 4DP7APXDH244 PWB, HIWAY LOGIC EA 4DP7APXI0111 I/O BUS CONTROL EA 4DP7APXIO111 4DP7APXIA111 PWA, VOLTAGE INPUT 5V EA 4DP7APXIA122 4DP7APXIA122 PWA, VOLTAGE INPUT 5V P-XIA12 EA 4DP7APXIA211 PWA, 4-20MA W/O XMTR EA 4DP7APXIA222 4DP7APXIA222 PWA, 4-20MA W/O XMTR P-XIA22 EA 4DP7APXIA311 PWA, 4-20MA W/XMTR EA 4DP7APXIA322 4DP7APXIA322 PWA, 4-20MA W/XMTR P-XIA32 EA 4DP7APXIA411 PWA, 5V W/FAST FILTER EA 4DP7APXIA422 4DP7APXIA422 PWA, 5V W/FAST FILTER P-XIA42 EA 4DP7APXIA811 LL AN INPUT MUX P-XIA81 EA 4DP7APXIA911 LL ANALOG INPUT P-XIA91 EA 4DP7APXID111 HL 24V CONTACT LL P-XID11 EA 4DP7APXID211 1 MEC 24V DIG IN P-XID21 EA 4DP7APXID311 HL 48V CONTACT I P-XID31 EA 4DP7APXID411 HL 48V CONTACT 2 P-XID41 EA 4DP7APXID511 HL TTL LOGIC 0.1 P-XID51 EA 4DP7APXID611 HL 125 VDC CONTA P-XID61 EA 4DP7APXID622 HL 125VDC CONTAC P-XID62 EA 4DP7APXIO111 I/O BUS CONTROL EA 4DP7APXIO211 I/O BUS CONTROL EA 4DP7APXIP111 I/O BUS CONTROL P-XIP11 EA 4DP7APXIP211 PULSE INPUT FAST EA 4DP7APXIP411 4DP7APXIP311 PULSE INP SLOW P-XIP31 EA 4DP7APXIP411 PULSE INPUT FAST P-XIP41 EA 4DP7APXMD111 MUX DRIVER EA 4DP7APXMD211 MUX DRIVER EA 4DP7APXOA111 PWA, ANALOG OUTPUT EA 4DP7APXOA311 4DP7APXOA211 ANALOG OUTPUT EA 4DP7APXOA311 4DP7APXOA311 ANALOG OUTPUT P-XOA31 EA 4DP7APXOD111 DIGITAL OUTPUT EA 4DP7APXOD311 4DP7APXOD211 7100 DIGITAL OUTPUT EA 4DP7APXOD411 4DP7APXOD311 DIGITAL OUTPUT P-XOD31 EA 4DP7APXOD411 7100 DIGITAL OUT P-XOD41 EA 4DP7APXPM122 R300 PROM PWA EA 4DP7APXPM133 PROM/MEM HLPIU R EA 4DP7APXPM144 PWA, MEMORY EA 51109323-100 4DP7APXPM155 PWA, HL MEMORY EA 4DP7APXPM222 PWA, PROM EA 4DP7APXPM233 PWA, PROM/RAM EA 4DP7APXPM333 PWA, PROM/RAM EA 4DP7APXPR111 PWA REGULATOR EA 30731808-503 4DP7APXPR211 1 POINT FILE CON EA 51196989-100 4DP7APXPR311 POINT FILE CONVE EA 51196989-100 4DP7APXPU111 MOS CPU PWB EA 30731832-501 4DP7APXRM111 RAM CARD EA 4DP7APXRP111 RTD POWER SUPPLY P-XRP11 EA 4DP7APXSC111 LL SIG COND-CURR P-XSC11 EA 4DP7APXSD111 SIG COND-FEED TH P-XSD11 EA 4DP7APXSJ111 LL SIGNAL COND - REFERENCE EA 51104410-100 4DP7APXSM111 SUB MULTIPLEXER EA 4DP7APXSP111 SURGE PROTECT A/I (HIGH LEVEL) EA 4DP7APXSP211 SURGE PROTECT D/O RELAY AND D/I EA 4DP7APXSP311 SURGE PROTECT A/O AND SOLID STATE D/O EA 4DP7APXSP411 SURGE PROTECT PWR SUPPLY A/I LOW LEVEL EA 4DP7APXSP511 SURGE PROTECT A/I (LOW LEVEL) EA 4DP7APXSR111 PWA, LL RTD SGN COND P-XSR11 EA 4DP7APXSR211 LL SIG COND-RTD P-XSR21 EA 4DP7APXSR311 LL SIG COND-RTD P-XSR31 EA 4DP7APXSV111 LL SIG COND-ATTE P-XSV11 EA 4DP7APXSV211 LL +1-5,10,20,40 P-XSV21 EA 4DP7APZHC301 COAX CABLE EA 51195476-150 4DP7APZHC302 COAX CABLE EA 51195476-500 4DP7APZHC303 COAX CABLE EA 51195477-015 4DP7APZHC304 COAX CABLE EA 4DP7APZHC305 COAX CABLE EA 51195476-022 4DP7APZHC306 COAX CABLE EA 51195476-050 4DP7APZHC307 COAX CABLE EA 51195476-100 4DP7APZHC308 COAX CABLE EA 51195476-200 4DP7APZHC401 CABLE SET, 150CM , EA 51195476-150 4DP7APZHC402 COAX CABLE - SEE NOTE EA 4DP7APZHC403 CABLE SET, 75CM EA 4DP7APZHC404 COAX CABLE - SEE NOTE EA 51100008-300 NAMEPLATE EA 51102863-100 ANALOG CABLE EA 51102866-101 DATA CABLE 2 PT EA 51102866-102 DATA CABLE EA 51102866-103 DATA CABLE EA 51102866-104 DATA CABLE EA 51102866-105 DATA CABLE EA 51103224-100 FILTER BOARD POD EA 51103940-100 TRANSFORMER EA 4DP7APPRT102 51103940-200 TRANSFORMER EA 4DP7APPRT101 51104307-100 TEMP SENSOR PANE EA 51104410-100 REF SIGNAL COND P-XSJ11 EA 51104883-121 CFA LABEL EA 51104886-105 CABLE,DC PWR DIS EA 51104886-106 CABLE,DC PWR DIS EA 51104886-111 DIST CBL CFA-CFA EA 51104886-112 DIST CBL CFA-CFA EA 51104887-100 POWER WIRE 15VDC EA 51104957-100 INTRINSIC BAR BOX -PTB CERTIFIED P-ISB13 EA 51104957-101 INTRISIC BARR BOX - FM CERTIFIED P-ISB13 EA 51104957-102 INTRINSIC BARR BOX -CSA CERTIFIED P-ISB14 EA 51104957-103 P-ISB15 BARR BOX EA 51105208-200 MODIF. ANALOG IN EA 51105244-100 POWER SUPPLY EA 51301926-100 51105347-101 MUX CABLE SET EA 51105347-102 CABLE SET EA 51107137-101 FUSE, 1.6 AMP EA 51107137-102 FUSE, 1.25 AMP EA 51107137-103 FUSE, 3.15A, F03 EA 51107137-117 PRINTHEAD, ASPI 32 PTR EA 51107137-118 HEAD CABLE EA 51107137-119 ASPI 32 PRINT HEAD EA 51107137-117 51107142-105 PRINTHEAD, ASPI 46 PTR EA 51107142-119 BELT, CARRIAGE EA 51107142-120 BELT, PAPER EA 51107142-125 FUSE, 1.6A EA 51107143-101 AYDIN 19IN TUBE EA 51107143-102 FSP-001 CARD ASM EA 51107144-101 FUSE, 3A 250V EA 51107145-112 REMOTE CBL ASSY EA 51107325-101 19IN HITACHI MONITOR A-VMD11 EA 51107403-100 LCN I/O EA 51305072-400 51107424-101 310/320 TO 30B U/G WITH CONVERTER EA 51109322-101 51107550-100 BACKPNL DAUGH BD EA 51107595-100 PWR SUPPLY, WINC EA 51107693-130 VIDEO COPIER 60HZ EA 51107698-143 LABEL ONLY FOR K4 EXTRACTOR WITH 4M INSTALLED EA 51107698-144 LABEL,K4-8 EXTRC EA 51107712-100 JUMPER WIRE EA 51107754-100 MCPU I/O CARD EA 51304286-100 51107754-200 PWB, MCPU I/O EA 38001499-100 51107758-001 PWB VID&DEFLECT EA 51107758-002 DIFFERNTIAL AMP. EA 51107758-004 51107758-004 DIFFERENTIAL AMP EA 51107954-100 PWB, MCPU I/O EA 38001499-100 51107982-100 P-CFA16 SPARE CARDFILE EA 51107982-101 P-CFA17 SPARE CARDFILE EA 51107982-102 P-CFA18 SPARE CARDFILE EA 51107982-103 P-CFA19 SPARE CARDFILE EA 51107982-104 LL CCFA W/O BDS EA 51107982-105 P-CFA27 SPARE CARDFILE EA 51107982-106 LL CF W/O BDS EA 51107982-107 P-CFA29 SPARE CARDFILE EA 51107982-111 P-CFA39 W/O BDS EA 51107982-113 51107982-112 P-CFA41 SPARE CARDFILE EA 51107982-113 P-CFA39 SPARE CARDFILE EA 51107982-114 P-CFA61 SPARE CARDFILE EA 51107982-115 P-CFA43 SPARE CARDFILE EA 51107998-100 FLOPPY DISC I/O EA 51108088-100 PWB, DHI I/O EA 51108088-200 DHI I/O ADAPTOR EA 51108139-100 HITACHI CRT OBSOLETE EA 51108254-100 PRINTER W/BASKET EA 51108254-400 ASPI32 SER PTR EA 51108304-100 ASPI41 PRINTER EA 51108305-100 51108305-100 ASPI41 PRINTER EA 51108305-100REP PTR, ASPI41 EA 51108305-700 ASPI41 RIBBON EA 51108305-900 ASPI41 PRNTR PED EA 51108306-100 TRACKBALL REPLCT EA 51196267-100 51108306-200 TRACKBALL EA 51196714-100 51108307-100 MONITOR 14 IN EA 51196793-100 51108308-100 MONITOR, 19IN INTERLACED EA 51108311-100 CRT EA 51196793-100 51108311-200 CRT, 14IN UWS EA 51196793-100 51108311-300 CRT EA 51196793-100 51108311-400 CRT, 14IN UWS EA 51196793-100 51108312-100 MONITOR 8939 EA 51304449-500 51108313-100 TRACKBALL, US EA 51108313-200 TRACKBALL EA 51108313-300 TRACKBALL EA 51108313-400 51108313-400 TRACKBALL US/UxS EC EA 51108367-100 MOD REMOTE RTD EA 51108385-308 M3X8 PAN HEAD SCREW EA 51108385-310 SCREW PAN HEAD M3X10MM EA 51108385-508 M4X8 PAN HD SCREW EA 51108385-510 SCREW EA 51108387-610 SCREW_HEX_HD_M5_X10MM EA 51108389-001 LOCKNUT M3 EA 51108389-004 NUTS, HEX EA 51108389-006 HEX NUT LOCK M8 EA 51108390-005 FLAT WASHER, M4 EA 51108392-005 LK WASHER, SPLIT M4 EA 51108393-003 LOCKWASHER,EXT-TH M 3 EA 51108393-004 WASHER LOCK EA 51108393-006 WASHER LOCK M5 EA 51108393-008 LOCKWASHER EA 51108436-204 SCREW, PAN HEAD EA 51108436-304 MACH SCR PAN HD #6 EA 51108437-003 WASHER,LOCK,INT #6 EA 51108441-103 GROMMET MATERIAL EA 51108461-001 NUT WASHER ASM EA 51108475-301 GOTHIC BLACK 12 OZ CAN SPRAY PAINT EA 51108475-302 EXECUTIVE WHITE 12 OZ CAN SPRAY PAINT EA 51108475-303 CARIBEAN BLUE 12 OZ CAN SPRAY PAINT EA 51108475-304 DRIFTWOOD 12 OZ CAN SPRAY PAINT EA 51108475-305 OPAQUE BEIGE 12 OZ CAN SPRAY PAINT EA 51108475-306 OPAGUE GREY 12 OZ CAN SPRAY PAINT EA 51108475-307 LIGHT ASH 12 OZ CAN SPRAY PAINT EA 51108475-308 DARK LAVA 12 OZ CAN SPRAY PAINT EA 51108566-100 P/S UPGRADE KIT EA 51108609-100 WHITE LABEL EA 51108623-100 LEVELER GUIDE ADJ. CLASSIC CONSOLE EA 51108687-100 LATCH KEEPER EA 51108695-100 19IN ELECTROHOME MONITOR EA 51108800-100 WREN I DRIVE EA 51108843-100 PWB, SIO I/O EA 51108845-100 PWB, TR PEN TERM EA 51108845-200 PWB, TR PEN TERM EA 51108871-100 CMPLX KIT,FR,NO IKB EA 51108871-200 CMPLX KIT,REAR EA 51108871-300 CMPLX KIT,CBL COVER EA 51108871-400 CMPLX KIT,FR,W/IKB EA 51108880-408 SCREWS EA 51108880-430 PAN HD SCREW M3 .5/30 EA 51108882-005 FLAT WASHER M4 EA 51108882-006 SM M5 FL WSHR, BL/ZI EA 51108883-002 W FLAT WASHER M3.5 EA 51108883-004 LG M5 FL WASHER ZINC EA 51108884-006 LOCK WASHER M5 EA 51108888-508 HEX HD SCREW M4/8 EA 51108888-510 HEX HD SCREW M4 X10MM EA 51108888-610 M5X10 SCREW EA 51108888-612 HEX HD SCREW M5 /12 EA 51108888-616 HEX HD SCREW EA 51108888-820 HEX HD SCREW M8 /20 EA 51108892-100 CARD FILE EA 51196692-100 51108893-100 FILE, 10 SLOT EA 51108893-200 C/F 6/4,3/4 CL EA 51196736-100 51108894-100 POWER SUPPLY EA 51108899-100 PWB, FIBER OP I/O EA 51108899-200 FIBER OPTIC LNK EA 51109040-100 CLI TEST CABLE EA 51109041-100 CLI TESY PLUG EA 51109153-100 C51109153-300 EA 51109153-200 VIDEO DR PCB EA 51109153-300 PWB EA 51109153-400 CRT SOCKET PGB EA 51109153-500 CONTROL CIRCUIT EA 51109153-600 INPUT CIR PWB EA 51109153-700 PWB Sup PCB EA 51109169-010 GROUND CABLE EA 51109169-018 GROUND CABLE EA 51109181-003 LCN COAX CBL SET 3M EA 51308112-003 51109181-005 LCN COAX CBL SET 5M EA 51308112-005 51109181-008 LCN COAX CBL SET 8M EA 51308112-008 51109181-010 LCN COAX CBL SET 10M EA 51308112-010 51109181-015 LCN COAX CBL SET 15M EA 51308112-015 51109181-020 LCN COAX CBL SET 20M EA 51308112-020 51109181-025 LCN COAX CBL SET 25M EA 51308112-025 51109181-030 LCN COAX CBL SET 30M EA 51308112-030 51109181-050 LCN COAX CBL SET 50M EA 51308112-050 51109181-060 LCN COAX CBL SET 60M EA 51308112-060 51109181-075 LCN COAX CBL SET 75M EA 51308112-075 51109181-100 LCN COAX CBL SET 100M EA 51308112-100 51109181-125 LCN COAX CBL SET 125M EA 51308112-125 51109181-150 LCN COAX CBL SET 150M EA 51308112-150 51109181-200 LCN COAX CBL SET 200M EA 51308112-200 51109181-250 LCN COAX CBL SET 250M EA 51308112-250 51109181-300 LCN COAX CBL SET 300M EA 51308112-300 51109182-003 LCN CABLE (SET 3) 3M EA 51109182-025 LCN CABLE (SET 3) 25M EA 51109182-050 LCN CABLE (SET 3) 50M EA 51109182-100 LCN CABLE (SET 3) 100M EA 51109322-100 310/320 TO 320B U/G W/O AD CONVERTER P-ZHL11 EA 51109322-101 310/320 TO 30B U/G WITH CONVERTER EA 51109323-100 310A TO 320B U/G WITH A/D CONVERTER EA 51109399-100 T-SCREEN BRUSH EA 51109417-100 AO MANUAL STANDBY CONNECTOR ADAPTER EA 51109456-100 PM POWER SUPPLY EA 51109684-100 51109456-200 PM POWER SUPPLY EA 51109684-100 51109456-300 PM POWER SUPPLY EA 51198947-200 51109469-100 NYLON WASHER EA 51109470-200 LABEL, APM MODEM EA 51109470-250 Label, APM Modem EA 51109477-150 LABEL, AO (CC) EA 51109482-100 BALL STUD EA 51109485-100 8-DROP TAP ASSM MU-NTAP08 EA 51109487-200 RITTAL PM KEY (No. 3254) EA 51109488-100 LOUVER KIT EA 51109488-200 AIR FILTER EA 51109496-100 NUT SPRING CLIP EA 51109501-100 CONNECTOR KIT EA 51195162-100 51109504-100 UCN SPLICE KIT EA 51195160-100 51109516-100 FAN CABLE 10FT EA 51109516-200 FAN CABLE 5FT EA 51109516-300 FAN CABLE 8FT EA 51109516-400 FAN CABLE 12FT EA 51109516-500 FAN CABLE 15FT EA 51109516-600 FAN CABLE 20FT EA 51109524-100 KIT, CAB COMPLEX EA 51109524-300 HPM DUAL-ACCESS CAB COMPLEXING KIT, TS8-PS EA 51109524-400 HPM SGL-ACCESS CAB COMPLEXING KIT, TS8-PS EA 51109524-600 HPM DUAL-ACCESS CAB COMPLEXING KIT, TS8-TS8 EA 51109524-700 HPM SGL-ACCESS CAB COMPLEXING KIT, TS8-TS8 EA 51109532-100 CAB COMPLEX KIT FOR DUAL ACCESS CAB EA 51109532-200 COMPLEXING KIT FOR SINGLE ACCESS CAB EA 51109541-100 CABINET FILTER FOR PM 15.5 X 24 EA 51109545-100 SCREW M2.5X.045 EA 51198946-100 51109559-100 BB PWR CBL ASM EA 51109583-100 FOAM/COMPLEX - DUAL EA 51109583-200 CABINET INSERT EA 51109594-100 EYEBLT ASM (4) MU-CLBM01 EA 51109612-100 TORQUE WRENCH MU-NKTQ01 EA 51109614-100 BLNK PLATE, FILE EA 51109620-000 G.I. PWR CBL, IN CAB (SEE NOTE) EA 51109620-195 51109620-020 CABLE,(IN CAB) 20IN EA 51109620-030 PWR CABLE (IN CAB) 30IN .76M EA 51109620-040 PWR CABLE (IN CAB) 40IN 1.02M EA 51109620-050 PWR CABLE (IN CAB) 50IN 1.27M EA 51109620-080 PWR CABLE (IN CAB) 80IN EA 51109620-120 PWR CABLE (IN CAB) 120IN EA 51109620-160 PWR CABLE (IN CAB) 160IN EA 51109620-195 PWR CABLE (IN CAB) 5M EA 51109620-390 PWR CABLE (IN CAB) 10M EA 51109625-100 TRIM PANEL BRKT A.C . EA 51109625-200 TRIM PANEL BRKT OPPOSITE EA 51109663-100 LABEL, STIMV EA 51109684-100 PM POWER SUPPLY EA 51198947-100 51109684-200 Y-H ONLY-P/S MIN ORDER 50 EA 51198947-200 51109684-300 PM POWER SUPPLY EA 51198947-100 51109688-100 KIT, PWA MTG EC EA 51109705-100 CRT, 19IN INTERLAC EA 51195793-100 51109705-110 CRT, 19IN INTERLAC EA 51195793-100 51109715-100 DRIVE, WREN II EA 51109806-002 CABLE SET 2M EA 51308111-002 51109818-100 PWR SUPPLY, FD EA 51199164-100 51109823-100 FLOPPY NUT PLATE EA 51109881-100 PWB, LCNE II EA 51304540-100 51109896-100 GROUND CABLE EA 51109919-100 PWB, PCSR EA 51304286-100 51109925-100 FAN, LGE MUFFIN EA 51109931-100 GROUNDING WASHER EA 51109933-001 SERRATED WASHER M6 EA 51109933-002 SERRATED WASHER M8 EA 51109933-003 SERRATED WASHER M5 EA 51151197-100 DRIVE, PRI 525MB EA 51190101-100 RES/ZERO OHM EA 51190102-100 RANGE RES 100OHM EA 51190102-300 250 Ohm Dummy Resistor EA 51190115-114 RESISTOR NETWORK - NOT AVAILABLE EA 51190405-106 PS 48V 60HZ 115V EA 51190422-100 BAT'Y,1.2V NICAD EA 51190424-200 SEALED BATTERY EA 51190424-300 48V BATTERY ASSM EA 51303948-100 51190465-100 PWR SUPPLY, 8AMP EA 51190465-150 PWR SUPPLY, 8AMP COATED EA 51190465-200 PWR SUPPLY,16AMP EA 51190465-250 PWR SUPPLY,16AMP 120V COATED EA 51190467-100 BATTERY,1.5V ALK EA 51190516-100 S.S. RELAY EA 51190516-122 SOLID STATE RELAY EA 51190516-132 RELAY SOLID STAT EA 51190516-134 RELAY SOLID STAT EA 51190516-202 RELAY, FILE ASSY EA 51190516-325 S.S. RELAY EA 51190516-332 RELAY SOLID STAT EA 51190516-400 SOLID STATE RELAY EA 51190516-325 51190516-402 S.S. RELAY EA 51190516-404 RELAY SOLIDSTATE EA 51190516-405 SOLID STATE RELAY EA 51190516-122 51190517-100 ANN CTR W/CBL EA 51303642-600 51190523-100 RELAY EA 51190523-125 51190523-125 RELAY EA 51190523-200 RELAY EA 51190523-225 51190523-225 RELAY EA 51190523-300 RELAY EA 51190523-325 51190523-325 RELAY EA 51190526-100 RELAY, SS EA 51190528-100 RELAY K1 EA 51191945-100 51190528-200 RELAY EA 51191945-200 51190528-300 RELAY EA 51191945-200 51190529-200 SOCKET REPLAY SPRING CLIP EA 51190566-110 CIRCUIT BREAKER EA 51190569-115 CIRCUIT BRK,15A EA 51190572-101 FUSE, 1/8 AMP EA 51190572-102 FUSE, 1/4 AMP EA 51190574-014 FUSE, .5 AMP EA 51190574-018 FUSE, .8A EA 51190574-020 FUSE, 1.25A EA 51190574-023 FUSE, 2A EA 51190574-028 FUSE, 5A EA 51190577-150 FUSE, .5 AMP EA 51190582-120 FUSE, .2 AMP EA 51190582-125 FUSE, .25 AMP EA 51190582-210 FUSE, 1 AMP EA 51190582-220 FUSE, 2 AMP EA 51190582-230 FUSE, 3 AMP EA 51190582-240 FUSE, 4 AMP EA 51190582-250 FUSE, 5 AMP EA 51190584-150 FUSE, SLO-BLO .5A EA 51190584-210 FUSE, 1A SLO-BLO EA 51190584-216 FUSE, 1.6A S/B EA 51190584-225 FUSE, 2.5A SLO-BLO EA 51190584-230 FUSE, 3A SLO-BLO EA 51190584-260 FUSE, 6A SLO-BLO EA 51190586-100 FUSE HANDLER EA 51190589-100 TOGGLE SWITCH EA 51190624-902 CONNECTOR MINI JMPR EA 51190660-001 TRANSFORMER, 60MZ EA 4DP7APPRT101 51190696-076 CABLE, 250FT EC EA 51192139-114 51190696-152 CABLE, 500FT EC EA 51192139-124 51190696-305 CABLE, 1000FT EC EA 51192139-134 51190721-101 CONNECTOR EA 51190721-203 SMALL SERVICE POST S1 EA 51190721-205 SERVICE POST EA 51190728-105 COAX TEE CONN EA 51190746-102 BAND TAP EA 51190782-100 TERMINATOR EA 51190787-209 PLUG-IN TERMBLK 8PT 1-8 EA 51190787-309 PLUG-IN TERMBLK 8PT 9-19 EA 51190787-408 PLUGIN TBLK 8PT EA 51190787-411 PLUGIN TBLK 11PT EA 51190787-508 PLUGIN TBLK 8PT EA 51190795-100 CONN, RG-11 CBLE (ORDER AT KIT LEVEL) EA 51195162-100 51190795-200 CRIMP TOOL,RG-11 MU-NKTT01 EA 51190797-100 CONN, RG-6 CABLE EA 51190797-200 CRIMP TOOL, RG-6 MU-NKDT01 EA 51190826-300 PROGRAMMING JUMPER INSULATED EA 51190826-301 PLUG PROGRAM JUMPER EA 51190843-001 P-ISB11 BARR BOX EA 51190876-100 FAN, TUBE AXIAL EA 51190879-006 ADJUSTABLE CABLE CL AMP EA 51190879-010 SMALL TIE-WRAP EA 51190879-017 TIE MOUNT, SMALL EA 51190879-019 TIE WRAP PUSH MTD EA 51190884-101 (E) ENG KEY S/S EA 51190884-102 (S)SUP KEY S/S EA 51190884-200 US KEYLOCK UPGKT EA MP-ZUSKL1-100 51190884-201 (S) SUP KEY D/S EA 51190884-202 (E) ENG KEY D/S EA 51190890-101 TAPE 108FT ROLL EA 51190896-100 CABLE SET EA 51190896-200 51190896-200 CABLE SET EA 51190899-152 UCN RG-11 RAW CBL INDOOR USE 500FT/152M ROLL EA 51190899-305 UCN RG-11 RAW CBL INDOOR USE 1000FT/394M ROLL EA 51190899-762 UCN RG-11 RAW CBL INDOOR USE 2500FT/762M ROLL EA 51190899-914 UCN RG-11 CABLE EA 51190907-100 FILTER EA 51190907-300 PWR LINE FILTER EA 51190908-121 CLICKER EA 51190909-100 KYBD ALARM CABLE EA 51303416-010 51190916-102 2-DROP TAP ASSM EA 51201394-100 51190916-104 ROLLING 4 DRP TAP EA 51190921-100 POWER CORD 110V 2M EA 51190921-110 POWER CORD 110V 3M EA 51190921-200 POWER CORD 220V 2M EA 51190981-100 STRAPPING TAPE EA 51190985-100 FAN, TUBEAXIAL EA 51190985-200 FAN DC 3.62 IN EA 51190985-600 FAN AXIAL DC EA 51195124-500 51191508-100 EC KEYBOARD W/EMI COAT EA 51191510-100 IKB KB FLD KIT EA 51191511-100 IKB SUMMA TB FLD KIT EA 51191512-100 IKB PS/2 FW FLD SVC KIT EA 51191524-100 IKB TRACKBALL BUTTNS EA 51191545-100 LOWER 17 CRT EZ-CONS MTG KIT EA 51191545-200 UPPER 17 CRT EZ-CONS NTG KIT EA 51191554-100 MAU INSULATOR EA 51191556-100 URCD REPLACEMENT KIT FOR BC/EC EA 51191558-100 KVM SWITCH ASM 4 NODE EA 51191560-100 H/D 1.8GB D/L LOGICAL EA MP-ZHMU18-100 51191560-200 H/D 875MB D/L LOGICAL EA MP-ZHMU11-100 51191561-100 SPC FIRMWARE U/G KIT EA 51191564-100 TRAILBLAZER VIDEO BOARD REPLACEMENT KIT EA 51191566-525 SCREW, OVAL HEAD PHILLIPS EA 51191573-100 TOUCHSCREEN PWA 21IN EA 51191575-100 LOWER MONITOR EZ KIT EA 51191575-200 UPPER MONITOR EZ KIT EA 51191578-100 19" IR TOUCHSCREEN PWA EA 51191579-100 1.8 GB DUAL LOGICAL DRIVE EA MP-ZHMU18-100 51191579-200 875 GB DUAL LOGICAL DRIVE EA MP-ZHMU11-100 51191579-300 H/D 9.1GB EA 51191607-152 UCN RG-11 RAW CBL OUTDOOR USE 500FT(152M)ROLL EA 51191607-305 UCN RG-11 RAW CBL OUTDOOR 1000FT(304M)ROLL EA 51191607-457 RAW CBL FOR OUTDOOR USE 475M ROLL EA 51191607-762 UCN RG-11 RAW CBL OUTDOOR 2500FT (762M) ROLL EA 51191607-914 UCN RG-11 RAW CBL FOR OUTDOOR USE 914M ROLL EA 51191673-305 CABLE, SDI/SI 305M (MU-KSX305) EA 51191696-100 MODULE, 4-20MA EA 51192097-200 51191697-100 MODULE, HLAI/GI EA 51191697-200 51191697-200 MODULE, HLAI/GI EA 51191698-100 MODULE, DO FTA EA 51191699-100 MODULE, DI FTA EA 51191737-100 CONNECTOR, CRIMP EA 51191737-201 PIN, CRIMP 14-20 EA 51191738-100 CONNECTOR, COMPR EA 51191783-100 CBL, MAU (USX) EA 51191783-100A CBL, MAU (USX) EA 51191783-100 51191784-100 CRT I/F CBL EA 51191784-200 CBL, CRT SIGNAL EA 51192126-200 51191784-300 CBL, CRT SIGNAL EA 51191785-100 HP DAT ADAPTER EA 51191787-100 CRIMP TOOL FOR GI/I S FTA EA 51191787-200 EXTRACTION TOOL EA 51191792-200 CONNECTOR EA 51191814-100 DAT TAPE BLANK EA 51191817-100 STRIP, MAGNETIC FLEX. SOLD BY FOOT FT 51191819-100 ELEC OUTLET BOX EA 51191839-100 CBL,PTR OUTLET EA 51191902-101 FERRITE, LCN T/C EA 51191902-102 FERRITE, SMALL EA 51191926-100 24 VDC DI GALV EA 51191927-100 DO GALV ISO MOD EA 51191928-100 HLAI, GAL ISOMOD EA 51191945-100 RELAY EA 51191945-200 DC POWER RELAY EA 51191982-100 TERM, HDDT I/O EA 51192039-122 LOAD, RESISTOR EA 51192054-101 CABLE, SCSI 1M EA 51192054-102 CABLE, SCSI 2M EA 51192054-103 CABLE, SCSI 3M EA 51192054-104 CABLE, SCSI 1.5M EA 51192056-206 CONN PLUG 6 POLES EA 51192060-100 NI CAD BATTERY (EA1) EA 51192065-100 BE-CU FINGER CONTACT EA 51192065-300 BE-CU FINGER CONTACT EA 51192091-124 POWER SUPPLY PWB 24V EA 51192094-124 FAN 24VDC EA 51192097-100 MODULE, 4-20MA EA 51192097-200 51192097-200 MODULE, 4-20MA EA 51192107-300 FERRITE BEAD FTC EA 51192125-150 ADAPTER, CONN EA 51192126-200 CBL, CRT INT EA 51192126-400 CBL CRT W/FERR EA 51192139-113 THREE COND, CABLE EC150FT EA 51192139-114 CABLE, 250' EC MU-KLX076 EA 51192139-124 CABLE, 500' EC MU-KLX152 EA 51192139-134 CABLE, 1000' EC MU-KLX305 EA 51192191-100 EMI GASKET EA 51192196-150 CONN APATER 50 PIN EA 51192296-100 GASKET, EMI EA 51192537-100 P/SMODULE MLT4053 EA 51192538-100 P/S MODULE MTL4995 EA 51192565-200 MTL 4046C GI/IS BARR EA 51192615-100 SCSI 1 SCSI 3 ADAPTER EA 51192619-110 THERMOSTAT EA 51192700-100 SCSI M-M IF ADAPTER EA 51192706-100 SCSI TERMINATOR EA 51192707-100 MODLR TERMINATOR EA 51192708-100 T-ADAPTER CAT5 EA 51192887-100 Adapter, ST-SMA EA 51195004-001 BATTERY HOLDER EA 51195018-048 8GA BLK 24.5IN LEAD EA 51195018-248 8GA RED 24.5IN LEAD EA 51195019-053 4GA BLK 29.5IN LEAD EA 51195019-253 LEAD-ELECTRICAL-4GA-RED EA 51195022-001 BBU MTG KIT-24IN(C-SBM02) EA 51195022-002 BBU MTG KIT-19IN (C-SBM01) EA 51195023-001 PWR SPLY MTG KIT EA 51195023-002 PWR SPLY MTG KIT EA 51195023-003 PWR SPLY MTG KIT EA 51195023-004 PWR SPLY MTG KIT EA 51195023-005 PWR SPLY MTG KIT EA 51195023-006 PWR SPLY MTG KIT EA 51195023-891 KIT,PS MTG 24IN EA 51195024-001 KIT-POWER BUS C-PSB02 EA 51195042-100 ALUM._RIVET EA 51195053-100 PWA, ST/DC P-AST10 EA 51195058-100 PWB, PDG TTL I/O EA 51195062-100 CRT 13IN DIGITAL EA 51195066-100 PWR SPLY, 5 SLOT EA 51402184-200 51195066-200 10 SLOT P/S EA 51402184-300 51195083-100 MOUSE KIT EA MP-ZMSE01-100 51195083-200 MOUSE KIT EA MP-ZMSE01-100 51195091-100 ASPI46 SER PTR EA 51195091-100REP PTR, ASPI46 110V EA 51195091-300 ASPI46 PTR, 220V EA 51195091-700 ASPI46 RIBBON EA 51195091-900 PEDESTAL PACKAGE EA 51195093-100 DC/DC CONVERTER EA 51304186-100 51195095-100 5-1/4IN FDD EA 51195439-400 51195095-101 FDD EA 51196659-100 51195095-200 FDD EA 51196659-100 51195095-300 5-1/4"_FDD EA 51196659-100 51195095-300A 5-1/4IN FDD EA 51196659-100 51195096-100 PLCI I/O CARD EA 51195096-200 PLCI I/O ADPTR EA 51195105-100 CABLE I/F P-TCB71 EA 51195111-001 BLANK TEST DISK EA 51195111-005 DIAGNOSTIC DISK EA 51195111-361 R361 SYSTEM DISK EA 51195111-616 R616 SYSTEM DISK EA 51195119-120 WHT/BLK CBL,20FT EA 51195124-100 FAN ASSM EA 51195124-200 FAN ASSM EA 51195124-300 FAN DC_ .62 IN EA 51190985-200 51195124-500 FAN ASSM EA 51195127-100 19" ENH CRT ASSY EA 51304449-500 51195153-001 CABLE SET, 1M RG 6 EA 51195153-002 CABLE SET, 2M RG 6 MU-NKD002 EA 51195153-003 CABLE SET, 3M RG 6 EA 51195153-004 CABLE SET, 4M RG-6, MU-NKD004 EA 51195153-005 CABLE SET, 5M RG 6 MU-NKD005 EA 51195153-010 CABLE SET, 10M RG6 MU-NKD010 EA 51195153-020 CABLE SET, 20M RG6 MU-NKD020 EA 51195153-030 CABLE SET, 30M RG6 MU-NKD030 EA 51195153-040 CABLE SET, 40M RG6 MU-NKD040 EA 51195153-050 CABLE SET, 50M RG6 MU-NKD050 EA 51195153-900 CABLE SET, .5M RG6 EA 51195153-901 CABLE SET, 1.5M RG 6 EA 51195153-902 DROP CBL SET 2.5M EA 51195153-903 CAABLE SET, 3.5M RG6 EA 51195153-904 CABLE SET, 4.5M RG 6 EA 51195154-002 CABLE SET, 2.5M EA 51195199-002 51195154-010 CABLE SET, 10M EA 51195199-010 51195154-020 CABLE SET, 20M EA 51195199-020 51195154-030 CABLE SET, 30M EA 51195199-030 51195155-100 DRIVE, WREN III EA 51195156-100 CARTRIDGE DRIVE, 20MB EA 51195156-300 51195156-200 CARTRIDGE DRIVE, 20MB EA 51195156-300 51195156-300 CARTRIDGE DRIVE, 20MB EA 51195160-100 UCN SPLICE KIT EA 51195161-100 CONNECTOR KIT MU-NKDK01 EA 51195162-100 CONNECTOR KIT MU-NKTK01 (QTY. 24) EA 51195168-510 M4X10 THRD FRMG SCR EW EA 51195168-612 D FORMING SCREW EA 51195168-616 HEX HEAD SCREW EA 51195168-635 THREAD FORMING SCREW, M5X35mm EA 51195169-101 CLEANING KIT, LCN 150MB CARTRIDGE DRIVE EA 51196485-500 51195178-100 TERM ASSY,WREN EA 51195180-100 CARD GUIDE EA 51195190-200 VDG/PIC REPL KIT EA MP-ZUSCP1-100 51195191-100 KYBD REPLACE KIT EA 51195192-100 TCHSCRN RPLC KIT EA 51195195-221 PUB MANUAL K4SS U/G EA 51195195-278 WREN STYLE HM U/G KIT INST 875MB/1.8GB EA 51195195-279 WDA STYLE HM U/G KIT INST 875MB/1.8GB EA 51195199-002 UCN TRUNK CABLE SET, RG-11, 2.5M MU-NKT002 EA 51195199-005 UCN TRUNK CABLE SET, RG-11, 5M MU-NKT005 EA 51195199-010 UCN TRUNK CABLE SET, RG-11, 10M MU-NKT010 EA 51195199-020 UCN TRUNK CABLE SET, RG-11, 20M MU-NKT020 EA 51195199-030 UCN TRUNK CABLE SET, RG-11, 30M MU-NKT030 EA 51195199-050 UCN TRUNK CABLE SET, RG-11, 50M MU-NKT050 EA 51195199-060 UCN TRUNK CABLE SET, RG-11, 60M EA 51195199-075 UCN TRUNK CABLE SET, RG-11, 75M EA 51195199-100 UCN TRUNK CABLE SET, RG-11, 100M MU-NKT100 EA 51195199-150 UCN TRUNK CABLE SET, RG-11, 150M EA 51195199-200 UCN TRUNK CABLE SET, RG-11, 200M MU-NKT200 EA 51195199-300 UCN TRUNK CABLE SET, RG-11, 300M EA 51195199-350 UCN TRUNK CABLE SET, RG-11, 350M EA 51195199-400 UCN TRUNK CABLE SET, RG-11, 400M MU-NKT400 EA 51195199-600 UCN TRUNK CABLE SET, RG-11, 600M MU-NKT600 EA 51195339-101 Cable, UCIO EA 51195439-300 KIT, FDD REPL EA 51195439-400 51195439-400 KIT, FDD REPL EA 51195440-002 PRE-TERMINATED FIBER_OPTIC CABLE 2M P-KFA02 EA 51195440-005 PRE-TERMINATED FIBER OPTIC CABLE 5M P-KFA05 EA 51195440-010 PRE-TERMINATED FIBER OPTIC CABLE 10M P-KFA10 EA 51195440-020 PRE-TERMINATED FIBER OPTIC CABLE 20M P-KFA20 EA 51195440-050 PRE-TERMINATED FIBER OPTIC CABLE 50M P-KFA50 EA 51195454-100 KIT, COLOR CODE EA 51195454-200 LCN CBL CLR KIT EA 51195466-300 GROUNDING STRAP EA 51195466-400 GROUNDING STRAP EA 51195476-022 COAX CABLE SET FM 59 22CM EA 51195476-050 COAX CABEL SET FM59 50CM EA 51195476-100 COAX CABLE SET FM59 100CM EA 51195476-150 COAX CABLE SET FM59 150CM EA 51195476-200 COAX CABLE SET FM59 200CM EA 51195476-300 COAX CABLE SET FM59 300CM EA 51195476-460 COAX CABLE SET FM59 460CM EA 51195476-500 51195476-500 COAX CABLE SET FM59 5M EA 51195476-700 COAX CABLE SET FM59 7M EA 51195477-010 COAX CABLE SET FM59 10M EA 51195477-015 COAX CABLE SET FM59 15M EA 51195477-020 COAX CABLE SET FM59 20M EA 51195477-025 COAX CABLE SET FM59 25M EA 51195477-030 COAX CABLE SET FM59 30M EA 51195477-045 COAX CABLE SET FM59 45M EA 51195479-100 I/O LINK CBL SET EA 51195479-200 I/O LINK CBL SET EA 51195479-300 I/O LINK CBL SET (LINKS FOUR FILES) EA 51195479-400 I/O LINK CBL SET EA 51195479-500 I/O LINK CBL SET EA 51195493-100 PWR SPLY RPL KIT, 110V EA 51195493-200 PWR SPLY RPL KIT, 220V EA 51195497-002 ST/SMA FIBER OPTIC CABLE SET, MODEL P-KFH02. EA 51195497-005 ST/SMA FIBER OPTIC CABLE SET, MODEL P-KFH05. EA 51195497-010 ST/SMA FIBER OPTIC CABLE SET, MODEL P-KFH10. EA 51195497-020 ST/SMA FIBER OPTIC CABLE SET, MODEL P-KFH20. EA 51195497-050 ST/SMA FIBER OPTIC CABLE SET, MODEL P-KFH50. EA 51195498-005 FIBER OPTIC CBL ST/ST 5M P-KFB05 EA 51195498-010 FIBER OPTIC CBL ST/ST 10M P-KFB10 EA 51195498-020 ST/ST FIBER OPTIC CABLE SET, MODEL P-KFB20 EA 51195498-050 F/O CABLE, 50M EA 51195499-100 5 SLOT C/F, CE EA 51196692-100 51195511-100 RS485 BUS TERM EA 51195563-200 POWER CORD EA 51195652-100 19" COLOR CRT EA 51195752-100 C/F 2NODE SPARE EA 51196727-100 51195754-100 K2LCN GROUND CABLE EA 51195755-300 QBC/QWERTY OP KYDB EA 51195757-101 UPPER CRT W/TCH FR EC EA 51195757-102 UPPER CRT W/TCH FR EC EA 51195760-100 NIM MOD. FLD/REP/KIT EA 51195761-100 ALIGNING PIN EA 51195768-100 8PT TERM BLOCK EA 51195769-100 12PT TERM BLOCK EA 51195770-100 CONN BLK 8PT SE EA 51195771-100 CONN BLK 12PT SE EA 51195773-100 CONN BLK 8PT TE EA 51195774-100 CONN BLK 12PT TE EA 51195776-100 CON/BLK+ENDS(6) EA 51195780-100 CRT ASSM 19IN EA 51195787-102 YELLOW LAB LCNA EA 51195787-103 GREEN LCN LABEL LCNB EA 51195792-100 MOUSE KIT EA MP-ZMSE01-100 51195793-100 CRT, 19IN INTERLAC EA 51195794-100 CRT REPLACEMENT 14IN EA 51196793-100 51195795-200 TRAY KIT EA 51195868-200 19" CRT ASSY EA 51195868-300 CRT REPL KIT 19IN EA 51195868-400 CRT, KIT EA 51195868-500 CRT, KIT EA 51195868-510 CRT, KIT EA 51195868-700 51195868-600 CRT, KIT EA 51195868-650 CRT, KIT 45000 EA 51195868-800 51195868-700 MONITOR REPL KIT 19IN EA 51195868-800 MONITOR REPL KIT 19IN EA 51195868-900 MONITOR KIT, BASIC OPER.STA. LCN FURNITURE EA 51195868-925 MONITOR KIT, BASIC OPER. STA. KOP FURNITURE EA 51195868-950 Monitor Kit, 45000 EA 51195870-100 TAB, LOCKING EA 51195904-112 PRINTER CBL 12FT EA 51195904-206 CBL, CRT/COPIER EA 51195949-311 528MB HARD DRIVE EA 51195992-100 MICRO TOUCHSCRN EA 51196045-100 SCREW, SEMS M3.5X20 EA 51196063-100 MTG HDW,WREN III EA 51196074-100 EPLCG INT CABLE EA 51196075-100 CRT, IDEK 21INCH EA 51196092-100 SPACER EA 51196093-100 FTA MTG CHANNEL, NARROW MARKHON W/SH GRND BAR EA 51196093-200 FTA MTG CHANNEL, WIDE MARKHON W/SHIELD GD BAR EA 51196094-100 FTA MTG CHANNEL, NARROW RITTAL W/SH GRND BAR EA 51196094-200 FTA MTG CHANNEL, WIDE RITTAL W/SHIELD GRD BAR EA 51196094-300 SHORT FTA MNTG CHNL W/SHLD BAR NARROW EA 51196211-112 2 PEN ROLL CHART EA MP-DPRU04-200 51196211-113 3 PEN ROLL CHART EA MP-DPRU04-200 51196211-122 2 PEN FAN FOLD EA 51196211-123 3 PEN FAN FOLD EA 51196212-213 DPR1000 CONF. PKG EA 51196214-145 LOAD RESISTOR EA 51196217-107 BLACK INKJET PRINT CARTRIDGE EA 51196217-108 COLOR INKJET PRINT CARTRIDGE EA 51196218-300 HP - 3M CABLE EA 51196220-100 DRIVE_3-1/2 - 210MB EA 51196269-100 51196226-100 ADAPTOR PLATE EA 51196243-100 DRIVE 3-1/2 445MB EA 51196351-100 51196254-100 HP 400MB W/SW EA 51402486-800 51196257-100 DATT TAPE DR 4MW EA 51196865-100 51196257-200 DAT CLEAN TAPE EA 51196863-920 51196264-100 MAPWARE CABLE EA 51196265-100 110V MODEM EA 51196265-200 220V MODEM EA 51196266-100 HR100 REMOD,110V EA 51196266-200 HR100 REMOD,220V EA 51196267-100 TRACKBALL REPLCT EA 51196269-100 210MB REPLACEMENT DRIVE 3-1/2IN EA 51196308-100 MOUSE KIT EA MP-ZMSE01-100 51196308-200 MOUSE, UXS EA 51196713-200 51196314-100 TONER CARTRIDGE EA 51196317-100 51196315-100 TONER CARTRDIGE EA 51196317-100 51196315-500 JETDIRECT CARD EA 51196319-400 51196315-700 CARTRIDGE, PTR EA 51196316-700 51196316-100 HP LJ5 115V EA 51196317-100 51196316-500 LSZRJET ETHERNET EA 51196319-400 51196316-700 TONER CARTRIDGE EA 51196317-100 HP400 110V B&W DSKTPC4118A EA 51196322-100 51196317-101 JETDIRECT 230VAC B&W DSKTP J3111A EA 51196322-200 51196317-202 EDO DIMM FOR HP LJET4000T 4MB EA 51196322-203 51196317-400 JETDIRECT CARD FOR 10BASE2 EA 51196317-500 JETDIRECT CARD FOR 10/100 BASET EA 51196322-500 51196317-700 REPLACEMENT TONER CARTRIDGE EA 51196322-700 51196319-100 HP COLOR LASERJET 5 DESKTOP PRINTER, 115VAC EA 51196983-100 51196319-101 HP COLOR LASERJET 5 DESKTOP PRINTER, 230VAC EA 51196983-101 51196319-208 TONER CARTRIDGE CYANFOR COLOR LASERJET 5 EA 51196319-209 TONER CARTRIDGE, YELFOR COLOR LASERJET 5 EA 51196319-210 TONER CARTRIDGE, MAGFOR COLOR LASERJET 5 EA 51196319-211 TONER CARTRIDGE, BLKFOR COLOR LASERJET 5 EA 51196319-400 JET DIRECT CARD FOR COLOR PRTR(10 BASE2) EA 51196319-500 JETDIRECT CARD FOR COLOR PNTR(10/100 BASET) EA 51196321-100 EDO DIMM 64MB TP-ERM064-100 EA 51196321-200 EDO DIMM 128MB TP-ERM128-100 EA 51196322-100 LJET PRINTER 4050T, 117VAC EA 51196322-101 51196322-101 LJET Printer, HP C8051A EA 51196322-200 LJET Printer 4050T.220VAC EA 51196322-202 4MB DIMM C4140A EA 51196322-203 8MB PRINTER DIMM EA 51196322-500 Ethernet Card, RJ45 10BaseT J3113A EA 51196322-501 51196322-501 Ethernet Card, RJ45 10Base T J4169A EA 51196322-700 REPLACEMENT TONER C4127X EA 51196342-100 SPC FW KIT EA 51191561-100 51196353-100 RCDR OPENING CVT KIT EA 51196363-100 COLOR MONITOR 21IN EA 51196418-300 PWA,ECC 16MB RAM EA 51196418-301 PWA,ECC 32MB RAM EA 51196418-302 PWA,ECC 64MB RAM EA 51196418-400 BATTERY,COPROC EA 51196432-100 DRIVE 1.2G UNPRG EA 51196433-100 525MB W/O SOFTWARE EA 51402486-300 51196454-300 DRIVE, EXT 525MB EA 51196468-100 KIT, LOAD BANK EA 51196478-101 Loop I/F Card (Printer) EA 51196478-102 APHO Card (Printer) EA 51196478-103 APTR/12 Card (Printer) EA 51196478-104 Printhead Driver Card EA 51196478-105 Power Card (Printer) EA 51196478-106 ACL/1 Regulator Card EA 51196478-107 Printhead, 18 Wire EA 51196478-108 Carriage Assembly EA 51196478-109 Cable, Carriage EA 51196478-110 Motor, Carriage EA 51196478-111 CABLE, PRINTHEAD EA 51196478-112 CABLE, PRINTHEAD EA 51196478-113 Carriage Stop EA 51196478-114 Roller, Turnaround EA 51196478-115 Shaft, Turnaround EA 51196478-116 Bracket, Turnaround EA 51196478-117 Switch, Paper Out EA 51196478-118 MOTOR,RIBBON DRI EA 51196478-119 Switch, Paperout EA 51196478-120 TRACTOR ASM,LEFT EA 30754420-020 51196478-121 Tractor Asm, Right EA 51196478-122 Motor, Paperfeed EA 51196478-123 Bushing, Tractor EA 51196478-124 BELT,PAPER DRIVE EA 51196478-132 FUSE,2A 125V EA 51196478-133 FUSE, 7A 125V EA 51196478-134 FUSE, 25A 125V EA 51196478-135 FUSE, 3A 125V EA 51196478-136 FUSE, 7A 125V EA 51196478-139 PTR RIBBON, REINKABLE EA 51196478-140 PWA,ECPU/I EA 51196478-141 PWA, ACPL EA 51196478-142 PWA, CPAR/1 EA 51196478-143 BUSHING, TRACTOR EA 51196478-145 GEAR,UP FRICTION EA 51196478-146 TRACTOR, LEFT EA 51196478-147 TRACTOR, RIGHT EA 51196478-148 GEAR,LWR FRICSHF EA 51196478-149 ROLLER ASM,LWRFR EA 51196478-150 SHAFT ASM,UPRFRI EA 51196478-151 SWITCH,ROCKER AC EA 51196479-100 HP 2GB DRIVE W/O SOFTWARE EA 51402486-800 51196480-100 CD ROM EA 51196480-101 DISK CADDY EA 51196483-100 150MB CART DRIVE EA 51196485-400 CARTRIDGE, 150MB FOR USE W/LCN OR UxS EA 51196485-500 CLEANING KIT, LCN 150MB CARTRIDGE DRIVE EA 51196488-101 AM RED CBL EA 51196489-001 SCSI I/F CBL EA 51196489-002 SCSI CBL EA 51196497-100 CRT REPL KIT 19IN EA 51195868-700 51196497-200 CRT KIT EA 51196650-100 KYBD BEEPER ASSM EA 51196653-100 POWER SUPPLY, 5 SLOT EC EA 51196654-100 P/S 10 SLOT EC EA 51196655-100 P/S DUAL NODE EC EA 51196659-100 FDD 5-1/4IN EA 51196674-100 DPR100 RECORDER EA 51196674-113 BATTERY EA 51196680-100 870MB DRIVE EA 51196680-200 51196680-200 870MB DRIVE ***SEE NOTES EA 51196680-200EXCH 870MB HARD DRIVE EXCHANGE ONLY EA 51196682-100 ANNUNCIATOR EA 51196684-200 10 SLOT TOWER EA 51196689-100 UPGR, BAS CMOS EA 51196689-200 UPGR,EX CTL CMOS EA 51196690-100 PRINTER, 110V EA 51196690-200 PRINTER, 230V EA 51196690-401 RIBBON, BLACK EA 51196690-501 RIBBON, COLOR EA 51196690-800 PAPER TRACTOR EA 51196690-900 PEDESTAL,PRINTER EA 51196690-920 PRINT HEAD EA 51196692-100 CLASSIC 5 SLOT SPARE CARD FILE CE EA 51196694-150 Z KB W/O TRKBL EA 51196694-200 UNIVERSAL KEYBOARD W/TRACKBALL LCN FURNITURE EA 51196694-250 KYBD W/TRACKBALL, Z FURN EA 51196694-300 PS-2 IKB W/TBALL EA 51196694-310 IKB, W/TBALL,PS2 EA 51196694-350 IKB/WTRKBALL, GUS Z-CONSOLE EA 51196694-901 TRACKBALL FOR INTEGRATED KEYBOARD EA 51196694-902 IKB CTRL PWB EA 51196694-903 IKB CTRL GUS EA 51196694-904 K/B FULL TRAVEL EA 51196694-905 LEGENDED KEYCAPS FOR UNIV. KEYBOARD EA 51196694-906 BLANK KEYCAP SET NO LEGEND UNIV KEYBOARD EA 51196694-907 OPERATOR MEMBRANE CONTROL PANEL EA 51196694-908 MEMBRANE FUNCTION KEY PANEL EA 51196694-909 Z CONSOLE FUNCTION KEY PANEL EA 51196694-910 OPERATOR KEYSWITCH WITH KEYS EA 51196694-911 KEYBD INSERTS 3 SETS RELEGENDABLE EA 51196694-912 IKB K/B CBL 36IN (DESKTOP LGTH) EA 51196694-913 IKB K/B CBL 72IN Z CONSOLE EA 51196694-914 T/B CBL FOR IKB LCN (S/M) 72IN EA 51196694-915 IKB K/B CBL 36IN EA 51196694-916 T/B CBL FOR IKB GUS (S/M) 72IN EA 51196694-917 CURSOR BLANKING PLT EA 51196694-919 KEYBOARD FIRMWARE RETROFIT KIT (1KB) EA 51191510-100 51196694-920 TRACKBALL FIRMWARE RETROFIT KIT (SUMMAGR.) EA 51196694-921 TRACKBALL FIRMWARE RETROFIT KIT (PS/2) EA 51196694-922 IKB CONTROLLER BOARDSURFACE MOUNT(SUMMAGRAPH) EA 51196694-923 IKB CONTROLLER BOARDSURFACE MOUNT (PS/2) EA 51196696-100 ENHANCED KIT EA 51304449-500 51196696-200 19IN MONITOR EA 51304449-500 51196701-100 PWB, CLI I/O EA 51196703-100 1.44MB FLPY DRIVE EA 51196704-200 1 GB H/D EA 51196705-100 CONSOLE 250W P/S EA 51196706-200 DAT TAPE MEDIA EA 51196706-300 DAT CLEAN KIT EA 51196707-100 Drive, CD ROM EA 51196708-100 TOWER W/PS EA 51196708-110 TOWER P/S EA 51196708-156 604 132 MHZ BD (GUS MOTHER BOARD) EA 51196708-170 1M GRAPHICS MEM EA 51196708-180 KYBD, W/MOUSE EA 51196709-100 RISER CARD EA 51196710-100 MONITOR, INTECOLOR EA 51195868-700 51196710-200 CRT, 19IN EA 51196710-250 INTCOLOR CRT EA 51195868-800 51196710-300 Monitor, Basic in Univ. Furn. EA 51195868-700 51196710-400 Monitor, Basic in KOP Furn. EA 51196712-100 BEIGE ENG KYBD EA MP-ZEKBF1-100 51196712-200 ENG KYBD, GRAY ROVING EA 51196713-200 MOUSE, USX EA 51196714-100 MICRO TRACKBALL EA 51196720-100 875MB HARD DRIVE EA 51196680-200 51196721-100 MEDIA_DRIVE_ENCL EA 51196721-300 51196721-300 MEDIA DRIVE ENCL EA 51196721-400 MED DRVS ENC ASSM EA 51196722-100 MEDIA DR ACC KIT EA 51196722-300 51196722-200 AC KIT W/O MEDIA EA 51196722-400 51196722-300 MEDIA DR ACC KIT EA 51196722-400 AC KIT W/O MEDIA EA 51196722-600 No Media AccKit IKB EA 51196727-100 C/F 2NODE SPARE EA 51196728-100 C/F 2NODE "Z" EC EA 51196729-100 C/F 5 SLT "Z" EC EA 51196730-100 CLASSIC 3/3/2/2 SPARE FILE EC EA 51196734-100 CONN PLATE ACCM KIT EA 51196734-400 CONN PLATE ACCM KIT EA 51196736-100 CLASSIC 10 SLOT 6/4. 3/4 SPARE EA 51196742-100 VIDEO CABLE EA 51196742-300 DUAL VIDEO CABLE CLASSIC DUAL CRT EC EA 51196742-400 VIDEO CABLE 6 FT EA 51196742-500 VIDEO CABLE 8FT EA 51196744-100 256MB CACHE MEM EA 51196744-106 51196744-106 256MB CACHE MEM EA 51196749-100 SPEAKER 2.25IN EA 51196777-100 FACE PLATE - BLK EA 51196787-100 ATTENTION LABEL EA 51196793-200 MONITOR, SAMSUNG 17" #700IFT EA 51196797-100 BLK FLANGE COVER EA 51196802-100 DUAL NODE PWR SUPPLY EA 51402184-100 51196805-100 P/S 5 CARD N/CE EA 51402184-200 51196810-100 P/S 10 CARD N/CE EA 51402184-300 51196837-100 UCN A LABEL EA 51196837-200 UCN B LABEL EA 51196853-100 HARD DRIVE 4.3GB EA 51191579-300 51196854-100 HARD DRIVE 9.1GB EA 51196968-100 51196856-100 DAT TAPE DRIVE EA 51196863-100 51196856-900 120M DAT CART (SEE NOTE FIELD) EA 51196863-910 51196863-100 INTERNAL DDS2 TAPE DRIVE EA 51196863-900 HP90M DDS-1 CARTRIDGE EA 51196863-910 HP120 DDS-2 CARTRIDGE EA 51196863-920 HP DDS CLEANING CARTRIDGE EA 51196865-100 INTERNAL DDS2 TAPE DR W/TERM EA 51196879-100 UCPU(CB)REPL KIT EA 51196880-100 UCPU(CB) W/DEP EA 51196881-100 UCPU(EC)REPL KIT EA 51196882-100 UCPU(EC) W/DIDEP EA 51196885-100 UDHI REPL KIT EA 51196886-100 UCIO REPL KIT EA 51196886-200 UCIO SPARE KIT EA 51196895-100 1.8GB HARD DRIVE EA 51196895-100EXCH 1.8GB HARD DRIVE EXCHANGE ONLY EA 51196907-200 DAT DRIVE EA 51196706-100 51196908-200 1.44MB FLOPPY DRIVE EA 51196703-100 51196909-200 CD ROM EA 51196707-100 51196919-100 DUAL CRT CONTROLLER EA 51196928-100 51196920-400 CRT CABLE ASSM 9 PIN5BNC 10FT EA 51196927-400 TPS Console Mtg Electronics EA 51196928-100 DUAL CRT CTRL EA 51196929-100 ZIP DRIVE EA 51196930-100 T/S CTRL(ISA CD) EA 51196931-202 2 DRIVE ENCL KIT EA 51196932-100 ZIP DRIVE TP-DZIP00-100 EA 51196932-200 ZIP DRIVE EA 51196929-100 51196933-200 ASY ZIP/F-PLATE EA 51196935-100 DELL GX PRO PC EA 51196935-900 MOUSE, PS2 EA 51196935-901 KEYBOARD, 104 EA 51196935-902 TERM 2ND PROG EA 51196935-903 64MB MEMORY ECC EA 51196935-904 1.44 MB FLOPPY DRIVE EA 51196946-905 51196935-905 8X CD ROM DR EA 51196982-906 51196935-906 ADAPTOR, 2940 EA 51196946-907 51196935-907 2MB VIDEO PWB EA 51196935-922 2GB H/D EA 51191579-300 51196935-924 4GB H/D EA 51196968-100 51196935-928 4GB HARD DRIVE EA 51196854-100 51196936-100 MINICART T/DRIVE EA 51196936-200 MINICART T/MEDIA EA 51196936-300 M/CART CLEAN KIT EA 51196939-100 PS2 MOUSE, INDUSTRIAL CE TP-ICEMS1 EA 51196943-100 QWERTY K/B INDUSTRAL CE TP-ICEKB1 EA 51191508-100 51196944-100 4MB DUAL VIDEO PWB EA 51197011-100 51196944-101 DUAL VIDEO BOARD 4MW EA 51197072-100 51196946-100 DELL 266Mh PENTIUMIIOPTIPLEX GXA DESKTOP EA 51196946-200 DELL 266MHz PENTIUM II OPPLX 4000LX DESK SIDE EA 51196946-900 MOUSE EA 51196982-900 51196946-901 KEYBOARD EA 51196946-903 64MB ECC SDRAM DIMM EA 51196971-100 51196946-904 128MB ECC SDRAM DIMM EA 51196971-101 51196946-905 FLOPPY DR 1.44MB EA 51196946-906 CD, 680MB 12/24X NEC EA 51196982-906 51196946-907 PWA, ADAPT, 2940, PCI/S EA 51196946-910 FILLER PLATE FOR EXTERNAL BAY EA 51196982-910 51196946-911 BASE MOUNT IN DESK SIDE CONFIG. EA 51196962-901 ADAPTEC 2940W DUAL CHANNEL PCI EA 51198718-907 51196966-300 MINICARTRIDGE CLEANING KIT EA
51196968-100 9.1 GB HARD DRIVE EA 51191579-300 51196969-100 MOTOROLA PENTIUM II 300 MHz PC DESKTOP EA 51196969-200 MOTOROLA PENTIUM II 300 MHz PC DESKSIDE EA 51196969-900 KEYBD/MOUSE KIT -US (66433577 MOTOROLA PART) EA 51196969-901 KEYBOARD/MOUSE EA 51196969-900 51196969-903 PWB,64MB SDRAM DIMM (96014164) EA 51196321-100 51196969-906 CD ROM DRIVE 2X (96014128) EA 51196982-906 51196969-908 PWB, GRAPHICS, 4MB APG SVAG (96014167) EA 51191564-100 51196969-910 FILLER PLATE EA 51196969-912 SCSI 4GB HARD DRIVE EA 51196968-100 51196969-914 POWER SUPPLY 300W EA 51196969-916 MOTHERBOARD W/300 MHPROCESSOR EA 51196971-100 64MB SDRAM DIMM FOR PENTIUM II EA 51196971-101 128MB SDRAM DIMM FOR PENTIUM II EA 87758 51196972-100 SCSI ADAPTER EA 51196979-100 CRT 20IN MULTISYNC CLASSIC EA 51196982-100 450MHZ GX1 DESKTOP/IN CONSOLE PC EA 51196982-101 450MHZ GX1 DESKTOP/IN CONSOLE PC W/O CD DR EA 51196982-102 500MH PIII DESK CONS W/O CD DRIVE EA 51196982-200 450MHZ DESKSIDE GX1 PC EA 51196982-201 450MHZ GX1 DESKSIDE PC W/O CD DRIVE EA 51196982-202 500MH PIII MINI TOWER W/O CD DRIVE EA 51196982-900 PS2 MOUSE EA 51196982-901 KEYBOARD, 104 EA 51196982-902 450MHZ DESKTOP PROCESSOR EA 51196982-903 POWER SUPPLY 200WATT EA 51196982-904 DIMM, 128, 100M 16X72 4K 168 EA 51196982-905 FLOPPY DRIVE EA 51196982-906 CD 680M, 17/40X EA 51198718-906 51196982-907 SCSI CONTROLLER, 2940 DUAL PCI/S (DELL 6982D) EA 51196982-908 SCSI 9.1GB UWIDE H/D EA 51196982-909 RISER 5 SLOT ACTIVE EA 51196982-910 FILLER PLATE EA 51196982-912 MOTHERBOARD GX1 EA 51196982-913 SCSI ADAPTOR 2940 (DELL 36849) EA 51196982-914 9GB U2W SCSI HD (10K RPM) EA 51196982-915 PROCESSOR KIT 500MH EA 51196982-916 PROCESSOR 550M PIII EA 51196982-953 POWER SUPPLY EA 51196982-903 51196982-959 RISER, 7 SLOT ACTIVE EA 51196983-100 COLOR PRINTER 120VAC HP4500N EA 51196983-101 COLOR PRINTER 240VAC HP4500N EA 51196983-103 51196983-102 HP C7086A/ABA, 120V EA 51196983-103 HP C7086A/ABB, 220V EA 51196983-208 TONER, CYAN EA 51196983-209 TONER, YELLOW EA 51196983-210 TONER, MAGENTA EA 51196983-211 TONER, BLACK EA 51196983-308 DRUM KIT EA 51196983-309 TRANSFER KIT EA 51196983-310 FUSE KIT 120V EA 51196983-311 FUSE KIT 220V EA 51196988-100 DUAL VIDEO BOARD EA 51197072-100 51196988-200 Video Card, Matrox G2+/DUALP-PL EA 51197072-100 51196989-100 UNIVERSAL REGULATOR PWB EA 51197000-100 FST HI RES MON 21IN EA 51197002-100 HI RES CRT EA 51304449-500 51197002-200 HI RES CRT EA 51304449-500 51197004-100 POWER SUPPLY EA 51197004-200 51197004-200 PWR SUPPLY EA 51197004-300 P/S UPPER POD EA 51197005-100 IDEK T/S CTL BOX EA 51197005-200 T/S CON W/O CASE EA 51197006-100 TOUCH SCREEN 21IN EA 51197007-100 IDEK TOUCHSCREEN EA 51197008-100 BUMPER/ PER FOOT EA 51197009-100 EXTERNAL T/S CONTR. CARD EA 51305386-100 51197009-101 TOUCH SCREEN CONTRLR EA 51305386-100 51197011-100 AUGMENT KIT DL VIDEO TP-DCRTVB-100 EA 51197072-100 51197012-100 A4484A 4.55Gb HDRV EA 51402486-800 51197013-200 TOUCH SCREEN 21IN W/ 9 PIN CONN EA 51197013-201 TOUCH SCREEN 21IN W/76IN CABLE EA 51197013-202 TOUCH SCREEN 21IN W/PHONE CONN EA 51197013-300 BEZEL KIT EA 51197013-400 BEZEL BUTTONS (EA4) EA 51197014-100 Monitor, 21" EA 51197015-200 T/S ASSM LCN EC EA 51197015-201 T/S ASSM GUS EC EA 51197015-202 T/S ASSM FOR 21 IN MONITOR W/20 IN CBL EA 51197015-300 BEZEL KIT EA 51197015-400 T/S BUTTONS EA 51197016-100 21IN MONITOR EA 51197017-100 19IN HI-RES MONITOR (OBSOLETE) EA 51304449-500 51197018 100 21" CRT EA 51197018-100 21" CRT (OBSOLETE SEE NOTES) EA 51197019-100 MICRO 21IN T/S EA 51197019-300 BEZEL BUTTONS EA 51197020-100 21IN FST L/RES MON EA 51197021-100 COLOR MONITOR 21 EA 51197022-100 T/S FRAME EA 51197022-200 51197022-200 T/S FRAME, EC EA 51197022-201 TOUCHSCREEN 21IN EA 51197022-400 BEZEL BUTTONS (4each EA 51197024-100 FOAM RUBBER GASKET EA 51197025-100 Z LEVELING GLIDE PS EA 51197031-100 BASKET BRACKET EA 51197035-100 MONITOR MNTG ACCM K IT EA 51197035-400 MOUNTING KIT, LOWER CRT (SONY) EA 51197040-300 UPPER CARDFILE UPGRADE KIT, NON-GUS EA 51197040-400 LOWER CARDFILE UPGRADE KIT, NON-GUS EA 51197040-500 GUS/INTEL UPPER CARDFILE UPGRADE KIT EA 51197041-100 KYBD SHELF ASSM EA 51197041-200 KYBD SHELF ASSM EA 51197044-100 PAPER BASKET ACCM KIT EA 51197049-100 CONSOLE BASE KIT, 1 CF EC EA 51197049-200 CNSL BSK KIT 2 CF ASSM EA 51197049-300 MED CNSL BASE KIT, 0CF EA 51197051-100 KIT,TOUCHSCREEN EA 51197052-500 AUX EQUIP LWR/UPR EA 51197052-600 AUX-EQUIP LWR/UPR EA 51197053-100 AUX PWR STRIP & CBLE EA 51197055-200 BLANK PLATE ASSM EA 51197057-100 PLASTITE SCREW BLAN K EA 51197057-200 SCREW PLASTITE EA 51197058-300 2NODE CARDFILE ST E C EA 51197063-100 MONITOR LABEL EA 51197066-100 PWR ENTRY FILTER EA 51197066-200 A/C POWER ENTRY EA 51197068-100 SPARE 5S ENH CFA EA 51196729-100 51197069-100 C/FC2NODE "Z" EC EA 51196728-100 51197072-100 DUAL VIDEO UPGRADE KIT EA 51197074-100 LABEL EQUIPOTENTIAL EA 51197079-100 LOAD RES KIT EA 51197083-100 12 PORT E NET SWITCH EA 51197083-101 E NET SWITCH CASCADE EA 51197084-100 HI SWITCH 2 NODE EA 51197084-500 KVM 4 Port Switch, Modified EA 51197085-100 DUAL NET IF CARD EA 51197086-100 Junction Box EA 51197087-100 GPS 8 Channel Antenna EA 51197087-200 Antenna, GPS Accutime2000 EA 51197088-200 SONY MONITOR W/TS 21IN EA 51199161-200 51197088-300 MONITOR W/ T/S EA 51197090-100 Z STYLE 21IN MONITOR (SONY) EA 51197096-100 19" SONY CRT EA 51197097-100 Z STYLE 21IN MONITOR (SONY) EA 51197103-101 XPM HDDO (REV F) RETROFIT KIT EA 51197103-103 LCNP4 FLASH PROM PROG DISK N/C RETROFIT EA 51197103-104 LCNP4 SERIAL EPROM N/C RETROFIT EA 51197103-105 CB-UCPU FW RETROFIT KIT EA 51197103-106 UCPU EC RETROFIT KIT RETROFIT #99-01 EA 51197103-107 RETRO99-08 TH IKB FW EA 51197103-108 RETRO98-08 SMT IKBFW EA 51197103-109 RETROIT #97-03 & 99-02 IKBI2 FIRMWARE EA 51197103-110 RETROFIT KIT #2001-02,LLMUX PRE-CAL FW EA 51197103-111 Retro Kit #2001-03 19" Touchscreen` EA 51197103-112 HLAI2 Firmware Upgrade Kit EA 51197155-000 POWER CBL,INTRNL USE EA 51197160-100 LIGHT, HPM TS8 CABINET, UNIVERSAL VOLTAGE EA 51197164-100 TB A/C & TB ALARM EA 51197170-100 HPM PS/FAN ALARM WIR EA 51197173-100 THERMOSTAT, TS8 CABINET EA 51197515-100 WARNING LABEL EA 51197555-300 LCN AUX CAB/KEY EA 51197564-100 UCNE, 2KM 85-236VAC EA 51197564-200 UCNE, 2KM 18-36VDC MU-FOED02 EA 51197577-100 MOUNTING KIT EA 51197597-100 OUTDOOR RH MUST CABLE 1000FT EA 51197597-305 51197597-305 4 WIRE MUX CABLE MU-KLO305 EA 51198706-100 CTLR UPGRADE KIT EA 51198707-100 CTLR UPGRADE KIT EA 51198708-100 CTLR UPGRADE KIT EA 51198709-100 CTLR UPGRADE KIT EA 51198711-100 RESERVE CTLR UPGRADE KIT EA 51198717-100 2ND H/DRIVE TRAY W/H/D (KIT) EA 51198718-100 866MH DESKTOP PC EA 51198718-101 GX200 1GHZ Desktop PC EA 51198718-200 866MH TOWER PC EA 51198718-201 GX200 1GHZ Deskside PC EA 51198718-900 MOUSE, PS2 EA 51198718-901 KEYBOARD, 104 EA 51198718-902 PROCESSOR, 80526, 866, 256, 133, FC EA 51198718-903 POWER SUPPLY 200W EA 51198718-904 MEMORY, 128MB, ECC EA 51198718-905 1.44MH FLOPPY DRIVE EA 51198718-906 CD DRIVE 17/40X, SCSI(PLEXOR) EA 51198718-907 CRD, SCSI CTL, 29160N, XLOB EA 51198718-908 9.1GB 10K RPM H/ D TYPHOON QTM EA 51198718-909 PWA RISER, 5 SLOT(DESKTOP) EA 51198718-910 FILLER PLATE EA 51198718-911 DESKTOP BASE MOUNT EA 51198718-912 GX200 MOTHERBOARD EA 51198718-913 256MB PC700 ECC RDRAM RIMM EA 51198718-914 Processor, 1Ghz EA 51198718-959 PWA RISER, 7 SLOT PCI/ISA,MT(TOWER) EA 51198801-100 UPGRADE KIT UPIU EA 51198920-100 28P PROTECT BOOT EA 51198946-100 M2.5X.045 I/O SCREW EA 51198947-100 PM POWER SUPPLY EA 51198959-200 NAMEPLATE RITTAL EA 51198963-100 HLAI/STI DIN REPLACEMENT KIT (DIN TO PHONE) EA 51198964-100 LLAI FTA REPLACEMENT KIT (DIN TO PHONE) EA 51199156-100 PCI FORMAT 8Mb VIDEO BOARD EA 51191564-100 51199159-100 Z CNS, 15 DEG WEDGE/SHROUD KIT EA 51199159-200 Z CNS, 30 DEG WEDGE/SHROUD KIT EA 51199161-100 FREE STANDING CRT W/O T/S EA 51199161-200 GUS 21" SONY W/TS EA 51199161-300 REPL KIT, 21 SONY MONITOR EA 51199164-100 FLOPPY P/S REPL. KIT EA 51199200-100 RETROFIT 99-01 PP INSTALLATION INSTRUCTIONS EA 51199201-100 RETROFIT 99-02-PP INSTALLATION INSTRUCTIONS EA 51199202-100 RETROFIT 99-004 MAU INSULATOR INSTALL INSTRUC EA 51199203-100 Retrofit 99-05-PP Instructions OSM CONN ASSM EA 51199204-100 Retrofit 99-08 IKB KYBD Frmwre Instal Instr EA 51199205-100 Retrofit99-09 CB-UCPU Frmwr Instal Instruc EA 51199206-100 Retrofit 2001-02 LLMUX FW Instructions EA 51199207-100 Retrofit 2001-03 Installation Instructions EA 51199825-100 8301-HI-IS-HON EA 8301-HI-IS-HON 51199827-100 8304-AO-IS-HON EA 8304-AO-IS-HON 51199828-100 8305-TI-IS-HON EA 8305-TI-IS-HON 51199829-100 8306-TI-IS-HON EA 8306-TI-IS-HON 51199830-100 8315-DO-IS-HON EA 8315-DO-IS-HON 51199831-100 8320-DI-IS-HON EA 8320-DI-IS-HON 51199835-100 MF-FCAR11 EA MF-FCAR11 51199836-100 MF-BIMS11 EA MF-BIMS11 51199837-100 8930-PS-AC-HON EA 8930-PS-AC-HON 51199838-100 8931-PS-AC-HON EA 8931-PS-AC-HON 51199846-100 MF-CIOL11 EA, MF-CIOL11 51199847-100 MF-CAUX11 EA MF-CAUX11 51199848-100 MF-CFCP11 EA MF-CFCP11 51199849-100 MF-CIOE11 EA MF-CIOE11 51199850-100 MF-CAXE11 EA MF-CAXE11 51200523-106 NYLON SPACER EA 51200536-601 FASTENER 1/4IN EA 51200620-100 NEMA BOX, NO CERTIFICATION EA 51303005-101 51200620-101 NEMA BOX EA 51303005-105 51200641-100 SHIELD TERM BLK W/TERM MTG LL P-OTS12 EA 51200641-101 TERMINAL PANEL (HL) EA 51200642-100 COVER EA 51200844-100 PUR SUPPLY BRACKET EA 51200845-100 PWR SUP SUPPORT EA 51200849-100 SWITCH, CFA. 24V EA 51200852-101 CABLE, MUX BOX EA 51200852-102 DATA CABLE ASSY EA 51200852-103 DATA CABLE ASSY EA 51200873-100 CABLE ASSEMBLY EA 51201122-006 VERT MTG RAIL EA 51201200-100 EXTENSION SPRING EA 51201201-100 AIR FILTER 29.13" X 6.70" X 1.00" EA 51201201-200 AIR FILTER 16.41" X 13.81" X .50 EA 51201201-300 AIR FILTER 13.38" X 14.78" X .62" EA 51201201-400 AIR FILTER 16.50" X 6.75" X .62" EA 51201201-500 AIR FILTER 20.81" X 8.72" X .50" EA 51201201-600 AIR FILTER 16.50" X 12.00" X .62" EA 51201201-700 AIR FILTER EA 51201201-800 AIR FILTER 17x4 EA 51201201-900 AIR FILTER EA 51201248-300 AIR DUCT PANEL BLANK EC EA 51201248-400 AIR DUCT BLANK PANEL EC EA 51201254-100 SUPPORT BAR EA 51201255-100 HNG. PN RTNR. FREAST EA 51201261-100 STRAP, COMPLEX EA 51201262-100 KBD CLAMP BAR EA 51201271-100 THUMBWHEEL EA 51201274-100 SUPPORT PLATE EA 51201275-100 RETAINER EA 51201280-100 CRT STOP BAR EA 51201284-100 HORIZ DUCT BRACKET EA 51201288-100 GROUND BLOCK EA 51201298-290 GROUND CABLE EA 51201349-100 FILTER, AIR EA 51201354-001 BATT CBL, N-BLK EA 51201354-002 BATT,CBL P-RED EA 51201354-003 BATTCBL X-ENDRED EA 51201385-100 FDD PLANT PLATE EA P-ZKF56 51201394-100 2-DROP TAP ASSM MU-NTAP02 EA 51201395-100 4-DROP TAP ASSM MU-NTAP04 EA 51201396-002 CABLE, 2M I/O EA 51201396-003 CABLE, 3M I/O MU-KTPC03 EA 51201396-004 CABLE, 4M I/O EA 51201396-005 CABLE, 5M I/O MU-KTPC05 EA 51201396-008 CABLE, 8M I/O EA 51201396-010 CABLE, 10M I/O MU-KTPC10 EA 51201396-015 CABLE, 15M I/O EA 51201396-020 CABLE, 20M I/O MU-KTPC20 EA 51201396-025 CABLE, 25M I/O EA 51201396-030 FTA I/O CBL,30M EA 51201396-050 FTA I/O CBL,50M EA 51201397-001 DS PWR CABLE,1M EA 51201397-002 DS PWR CABLE,2M EA 51201397-004 DS PWR CABLE,4M EA 51201397-005 DS PWR CABLE,5M MU-KDPR05 EA 51201397-006 DS PWR CABLE,6M EA 51201397-008 DS PWR CABLE,8M EA 51201397-010 DS PWR CABLE,10M MU-KDPR10 EA 51201397-015 DS PWR CABLE,15M MU-KDPR15 EA 51201397-020 DS PWR CABLE,20M MU-KDPR20 EA 51201397-025 DS PWR CABLE,25M MU-KDPR25 EA 51201397-030 DS PWR CABLE,30M MU-KDPR30 EA 51201397-035 DS PWR CABLE,35M MU-KDPR35 EA 51201397-040 DS PWR CABLE,40M MU-KDPR40 EA 51201397-050 DS PWR CABLE,50M MU-KDPR50 EA 51201397-915 DS PWR CBLE,1.5M EA 51201398-200 I/O LINK CBL SET EA 51195479-200 51201418-101 SGL BLANK PLATE EA 51201418-300 CABLE CLAMP BRACKET EA 51201418-304 BRKT, CABLE CLMP EA 51201418-305 BRKT,CABLE FTC4 EA 51201418-400 CABLE CLAMP BRACKET EA 51201420-001 FTA I/O CBL, 1M, non-CE EA 51201420-002 FTA I/O CBL, 2M, non-CE MU-KFTA02 EA 51201420-003 FTA I/O CBL, 3M, non-CE EA 51201420-004 FTA I/O CBL, 4M, non-CE EA 51201420-005 FTA I/O CBL, 5M, non-CE MU-KFTA05 EA 51201420-006 FTA I/O CBL, 6M, non-CE EA 51201420-008 FTA I/O CBL, 8M, non-CE EA 51201420-010 FTA I/O CBL, 10M, non-CE MU-KFTA10 EA 51201420-012 FTA I/O CBL, 12M, non-CE EA 51201420-015 FTA I/O CBL, 15M, non-CE MU-KFTA15 EA 51201420-020 FTA I/O CBL, 20M, non-CE MU-KFTA20 EA 51201420-025 FTA I/O CBL, 25M, non-CE MU-KFTA25 EA 51201420-030 FTA I/O CBL, 30M, non-CE MU-KFTA30 EA 51201420-035 FTA I/O CBL, 35M, non-CE MU-KFTA35 EA 51201420-040 FTA I/O CBL, 40M, non-CE MU-KFTA40 EA 51201420-045 FTA I/O CBL, 45M, non-CE MU-KFTA45 EA 51201420-050 FTA I/O CBL, 50M, non-CE MU-KFTA50 EA 51201420-060 FTA I/O CBL, 60M, non-CE EA 51201420-905 Cable, .5m FTA Phone to Phone EA 51201420-915 FTA I/O CBL, 1.5M, non-CE EA 51201421-001 REDUNDANCY CABLE EA 51201421-100 51201421-100 REDUNDANCY CABLE EA 51201436-300 5 SLOT PWR SPLY EA 51201436-400 10 SLOT PWR SPLY EA 51201438-100 FAN GUIDE BRACKET EA 51201443-100 TERMINATOR BRACKET EA 51201450-100 HLAI CALIB TOOL FOR GI/IS MU-GACT02 EA 51201465-100 TRIM LEFT SIDE-FULL EA 51201465-200 TRIM RIGHT SIDE-FULL EA 51201467-100 TRIM BOTTOM FULL EA 51201468-100 TRIM CENTER - FULL EA 51201469-100 TRIM LEFT SIDE - HALF EA 51201469-200 TRIM RIGHT SIDE - HALF EA 51201470-100 TRIM PANEL TOP EA 51201550-100 BRKT, FILLER MTG EA 51201551-100 TRIM FILER PLATE EA 51201551-200 HPM FILLER PLATE EA 51201551-300 FRONT COVER EA 51201553-100 DIN-PHONE ADAPTR MU-ZFTD02 EA 51201557-100 I/O LINK(1) ASSM EA 51201557-150 I/O LINK ASSM CC EA 51201557-300 I/O LINK(3) ASSM EA 51201557-350 I/O LINK ASSM CC EA 51201559-100 CLIP, PANEL EA 51201561-001 CBL, 1M DIN/PHO (SEE NOTES) EA 51201561-003 CBL, 3M DIN/PHO EA 51201561-004 CBL, 4M DIN/PHO EA 51201561-005 CBL, 5M DIN/PHO MU-KFTD05 EA 51201561-010 CBL,10M DIN/PHONE MU-KFTD10 EA 51201561-015 CBL,15M DIN/PHONE MU-KFTD15 EA 51201561-020 CBL,20M DIN/PHONE MU-KFTD20 EA 51201561-025 CBL, 25M DIN/PHONE MU-KFTD25 EA 51201561-030 CBL,30M DIN/PHONE MU-KFTD30 EA 51201561-050 CBL,50M DIN/PHONE MU-KFTD50 EA 51201566-100 SHIELD GRND BAR EA 51201653-100 51201568-200 TRAY, NARROW RITTAL EA 51401246-200 51201602-100 PLUG-IN MODULE, PULSE INPUT EA 51201616-100 PWB, FIBER OPT EA 51201623-100 FTA SPACER RIGHT EA 51201624-100 FTA SPACER LEFT EA 51201645-400 K4 MEZZ-4MW EA 51201645-800 K4 MEZZ 8MW EA 51201653-100 SHIELD GRND BAR EA 51201666-100 MTG CHAN HOZ NAR W/ SGB MU-TMHN02 EA 51201667-100 HPM RED CBL EA 51201691-002 FAN POWER CABLE 2M EA 51201691-005 FAN POWER CABLE 5M EA 51201691-010 FAN POWER CABLE 10M EA 51201699-001 PWR CBL LNK PTR EA 51204127-100 51201736-100 UxS ROLLER, K/B TRA Y EA 51201748-100 LOAD KIT EA 51196468-100 51201748-110 LOAD RESISTOR KIT EA 51197079-100 51201748-120 LOAD KIT EA 51201748-210 LOAD RESISTOR KIT EA 51197079-100 51201759-160 16MW MEZ PWB EA 51201762-100 BRKT, DISK MTG EA 51201766-100 SLEEVE SCREW EA 51201772-100 COVER EA 51201786-100 IKB BUMPER BRACKET EA 51201793-160 K4SS, 16MB EA 51201795-400 K4-SS 4M, Memory EA 51201795-800 K4-SS 8M, Memory EA 51201807-100 GND CABLE EA 51201821-100 RETAINER BRACKET EA 51201829-100 BLANK PLATE EA 51201830-200 CRT BASE CLAMP EA 51201830-400 CRT BASE CLAMP EA 51201835-100 TRACKBALL BUTTON EA 51191524-100 51201840-100 STEEL CABLE EA 51201846-100 CPU EMULATOR (FOR YAMATAKE ONLY) EA 51201862-100 CRT PANEL ASSY(SONY) EA 51201863-100 T/S ASSM Z FURN (SONY) EA TP-ZSTSR1-100 51201872-100 MONITOR CONTROL PNL EA 51201875-100 CRT CTRL PNL ASM(SONY) EA 51202005-100 TRAY GUIDE EA 51202018-100 WEDGE BUMPER BRACKET EA 51202020-100 POWER SUPPLY MTG. BRACKET EA 51202023-100 TABLE SPACER EA 51202023-200 TABLE SPACER EA 51202026-100 RETAINER BLOCK EA 51202027-100 CABLE COVER EA 51202032-100 POWER/FAN BLANK COVER EA 51202034-100 INLINE WEDGE ASSM EA 51202037-100 WEAR CHANNEL EA 51204031-100 MOUNTING ANGLE EA 51204033-002 FTA I/O CBL, 2M, CE EA 51204033-003 FTA I/O CBL, 3M, CE EA 51204033-004 FTA I/O CBL, 4M, CE EA 51204033-005 FTA I/O CBL, 5M, CE MU-KFTS05 EA 51204033-008 FTA_I/O_CBL, 8M, CE EA 51204033-010 FTA I/O CBL, 10M, CE MU-KFTS10 EA 51204033-015 FTA I/O CBL, 15M, CE MU-KFTS15 EA 51204033-020 FTA I/O CBL, 20M, CE MU-KFTS20 EA 51204033-025 FTA I/O CBL, 25M, CE MU-KFTS25 EA 51204033-030 FTA I/O CBL, 30M CE MU-KFTS30 EA 51204033-035 FTA I/O CBL, 35M, CE MU-KFTS35 EA 51204033-040 FTA I/O CBL, 40M, CE MU-KFTS40 EA 51204033-050 FTA I/O CBL, 50M, CE MU-KFTS50 EA 51204037-002 POWER CABLE 2M EA 51204037-004 POWER_CABLE 4M EA 51204037-005 POWER_CABLE 5M EA 51204037-010 POWER_CABLE 10M EA 51204037-015 POWER_CABLE 15M EA 51204037-020 POWER_CABLE 20M EA 51204037-025 POWER_CABLE 25M EA 51204037-030 POWER_CABLE 30M EA 51204037-035 POWER_CABLE 35M EA 51204037-040 POWER_CABLE 40M EA 51204037-050 POWER_CABLE 50M EA 51204039-100 SHROUD, I/O LINK EA 51204042-100 CBL, ASY 2 DROP EA 51204042-200 CBL, ASY 3 DROP EA 51204042-300 CBL, ASY 4 DROP EA 51204042-400 CBL, ASY 5 DROP EA 51204042-500 CBL, ASY 6 DROP EA 51204043-100 ADAPTER KIT EA 51204126-001 PM PWR CBL SET W/LINK PROTECT 1M EA 51204126-002 PM PWR CBL SET W/LINK PROTECT 2M EA 51204126-004 PM PWR CBLE SET W/LINK PROTECT 4M EA 51204126-005 PM PWR CBL SET W/LINK PROTECT 5M EA 51204126-006 PM PWR CBL SET W/LINK PROTECT 6M EA 51204126-915 PM PWR CBL SET W/LINK PROTECT 1.5M EA 51204127-100 PWR CBL LNK PTR EA 51204132-100 BATTERY CABLE EA 51204135-001 BATTERY HOLDER EA 51204138-002 PM PWR CBL, EC EA 51204140-100 PM PWR CBL ADAP SET (EC) EA 51204154-125 FTA, DI 24VDC SCREW, CE EA 51204154-175 FTA, DI 24VDC SCREW, CE, CC EA 51204156-125 FTA, DO 24VDC SCREW, CE EA 51204156-175 FTA, DO 24VDC SCREW, CE, CC EA 51204160-125 FTA, DI 24VDC COMP, CE EA 51204160-175 FTA, DI 24VDC COMP, CE, CC EA 51204162-125 FTA, DO 24VDC COMP, CE EA 51204162-175 FTA, DO 24VDC COMP, CE, CC EA 51204164-125 HD FTA, DO RELAY SCREW, CE EA 51204164-175 HD FTA, DO RELAY SCREW, CE, CC EA 51204166-125 HD FTA, DO RELAY COMP, CE EA 51204166-175 HD FTA, DO RELAY COMP, CE, CC EA 51204168-100 HD FTA, HLAI/STI SCREW EA 51204168-150 HD FTA, HLAI/STI SCREW, CC EA 51204170-100 HD FTA, HLAI/STI COMP EA 51204170-200 51204170-125 HD FTA, HLAI/STI COMP, CE EA 51204170-150 HD FTA, HLAI/STI COMP, CC EA 51204170-250 51204170-175 HD FTA, HLAI/STI COMP, CE, CC EA 51204170-275 51204170-200 HD FTA, HLAI/STI COMP EA 51204170-225 HD FTA, HLAI/STI COMP, CE EA 51204170-250 HD FTA, HLAI/STI COMP, CC EA 51204170-275 HD FTA, HLAI/STI COMP, CE, CC EA 51204172-125 HD FTA, AO COMP W/STBY, CE EA 51204172-175 HD FTA, AO COMP W/STBY, CE, CC EA 51204174-125 HD FTA, AO SCREW W/STBY, CE EA 51204174-175 HD FTA, AO SCREW W/STBY, CE, CC EA 51204176-100 AI ADAPTOR ASM EA 80367163-001 51204178-150 HPM HD I/O IOP EA 80363969-150 51204180-100 DI IOP 24V EA 80363972-100 51204182-150 DO IOP CC EA 80363975-150 51204192-100 HEATER, 120 VAC EA 51204192-200 HEATER, 240 VAC EA 51206056-100 FILTER C/F EA 51301239-100 PWB, LOGIC MUX TC EA 51301256-100 LE MUX TERMINAL EA 51301259-100 PWA, LE RTD LOGIC EA 51301844-300 CABLE EA 51301848-100 SIDE PANEL 7IN EA 51301848-101 SIDE OR REAR PANEL EA 51301850-007 DOOR-VENTED LH H EA 51301850-100 CABINET DOOR LEFT HAND VENTED EA 51301850-101 SOLID 24X77IN EA 51301850-102 DOOR PANEL EA 51301850-103 SOLID 24X70IN EA 51301874-100 PWA, T/C MUS LOGIC EA 51301877-100 PWA, RTD MUX LOGIC EA 51301880-100 PWA, T/C MUX TERM EA 51301882-100 PWA, RTD MUX TERM EA 51301926-100 125V PWR SPLY EA 51301994-100 POINT FILE EXTEN EA 51302287-100 CABLE, TOUCHSCREEN I/F EA 51302297-100 CABLE, TOUCHSCREEN INTERCONNECT EA 51302362-200 MODIFIED P-XID21 PWA EA 51302371-100 FM IS LABEL EA 51302371-101 FM IS LABEL EA 51302390-100 HL I/O BUS INTEG EA 51302607-100 PWA, MUX RTD LOGIC EA 51302608-100 PWA, MUX T/C LOGIC EA 51302804-100 PLATE, TOP COVER EA 51303000-100 F/6 NEMA BOX EA 51303005-101 NEMA BOX, NO CERTIFICATION EA 51303005-105 NEMA BOX EA 51303005-106 LE NEMA BOX EA 51303005-108 ENCL, NEMA BOX EA 51303005-109 ENCL,NEMA BOX EA 51303005-115 BOX,MUX STAINLES EA 51303099-200 LBL RETROFIT R320B EA 51303294-100 POWER SUP CONTL EA 51303378-116 WARNING LABEL EA 51303402-122 KEYBOARD CABLE EA 51303409-122 51303402-305 FLOPPY DISC CABLE EA 51303404-056 FLOPPY AC PWR CA EA 51303406-002 CABLE SET 2M EA 51308111-002 51303406-003 CABLE, CRT COAX EA 51308111-003 51303407-305 FLOPPY DISC CABLE EA 51303409-089 WREN II CABLE EA 51303409-099 WREN II CABLE EA 51303409-089 51303409-122 KEYBOARD CABLE EA 51303409-305 KEYBOARD CABLE EA 51303410-007 PER INTFC CONT V EA 51303411-077 FLOPPY DC PWR CA EA 51303412-132 WREN #1 DATA CBL EA 51303412-190 51303412-190 WREN DATA CABLE EA 51303413-015 TOUCH SCR CABLE EA 51303413-150 K/B T/S CABLE EA 51303414-016 ENG KY CABLE EA 51303415-010 KYBD CLICKER CBL EA 51303416-010 KYBD ALARM CABLE EA 51303417-092 KEYLOCK ASSEMBLY EA 51303419-152 KB INTFC DC PWR EA 51303420-061 CBL, MOD STATUS EA 51303420-561 51303420-081 CBL, MOD STATUS EA 51303420-581 51303420-086 CBL, MOD STATUS EA 51303420-586 51303420-122 MOD STATUS CABLE EA 51303420-622 51303420-152 Module Status CB EA 51303420-561 CBL, MOD STATUS EA 51303420-581 MOD STATUS CBL EA 51303420-586 CBL, MOD STATS EA 51303420-622 CBL, MOD STATS EA 51303420-652 MOD STATUS CABLE EA 51303421-092 125V AC CORD,3FT EA 51303421-152 125V AC CORD,5FT EA 51303421-153 AC 125V PWR CORD EA 51303421-183 125V AC CORD,6FT EA 51303422-088 DUAL FLOPPY DC P EA 51303423-087 DUAL FLOPPY AC P EA 51303497-100 KYBD TMPLTE SET EA 51303501-100 ANGLE BRACKET EA 51303508-100 AC POWER CORD FOR NON-EC P/S EA 51303508-200 PWR CORD, 220V USED ON NON EC P/S EA 51303509-100 COVER, KYBD HNGE EA 51303513-300 WINDOW, VERTICAL EA 51303513-400 WINDOW, HORIZNTL EA 51303521-300 AIR DUCT BAFFLE EA 51303521-400 AIR DUCT BAFFLE EA 51303526-200 RETAINER, W/INSERTS EA 51303534-103 WINC COMMD CABLE EA 51303534-190 COMMAND CABLE EA 51303535-080 WREN II DATA CBL EA 51303535-097 WREN II DATA CBL EA 51303535-190 USE -080 OR -097 EA 51303536-061 WIN DPWR CABLE EA 51303549-100 FAN POWER CABLE EA 51303625-019 CABLE,WINC,19CM EA 51303628-134 COMMAND CABLE EA 51303628-190 WINCHESTER COMM EA 51303628-305 WIN CMD CABLE EA 51303628-762 CABLE, FL DISC EA 51303629-092 250V POWER CORD EA 51303629-152 220V FLOPPY AC CBL 5FT EA 51303629-183 POWER CORD EA 51303629-152 51303630-305 FLOPPY DISK CABL EA 51303631-003 CABLE LCN PTR 3M EA 51303631-005 CABLE LCN PTR 5M EA 51303631-008 Cable, LCN Printer 8m EA 51303631-010 CABLE LCN PTR 10M EA 51303631-015 CABLE LCN PTR 15M EA 51303632-031 SW AC CABLE EA 51303633-022 PWR TREND CBL EA 51303635-061 PWR STATUS CBL EA 51303636-304 TREND I/F CABLE EA 51303639-100 VIDEO ADAPTOR AS EA 51303641-044 TREND DC CABLE EA 51303642-100 ANNUNCIATOR PAN EA 51303642-200 ANNUNCIATOR T/B EA 51303642-400 51303642-300 ANNUNC, Z-FURN EA 51303642-400 ANNUNCIATOR T/B EA 51303642-500 ANNUNCIATOR TB ASSM EA 51303642-600 ANN CTR W/CBL EA 51303642-700 ANNUNCIATOR ASSM EA 51303646-100 BLANK KYBD BEZEL EA 51303646-300 KYBD BEZEL, NEW EA 51303650-100 CHANNEL SUPPORT EA 51303651-100 FRONT PLATE EA 51303654-092 110V AC CBL 3FT EA 51303654-304 110V TREND CABLE EA 51303657-100 BEZEL ASSY,LOWER EA 51303657-200 BEZEL ASM CNSTS EA 51303657-300 BEZEL TOP EA 51303657-400 BEZEL WINDOW ASSM EA 51303657-500 BEZEL ASSM, 520/300 0 EA 51303657-600 BEZEL WINDOW ASY EA 51303657-700 LOWER BEZEL ASM EA 51303657-800 UPPER BEZEL ASSY EA 51303658-100 Front Plate Mtg Brkt, Left EA 51303658-200 Front Plate Mtg Brkt, Right EA 51303659-100 FLOPPY BLANK PAN EA 51303661-003 LCN CABLE, 3M EA 51308112-003 51303661-008 LCN CABLE, 8M EA 51308112-008 51303661-015 LCN CABLE, 15M EA 51308112-015 51303661-050 LCN CABLE, 50M EA 51308112-050 51303661-100 LCN CABLE, 100M EA 51308112-100 51303661-200 LCN CABLE, 200M EA 51308112-200 51303663-100 CRT SUPPORT EA 51303663-200 CRT SUPPORT EA 51303664-100 REMOTE SW MT BKT EA 51303672-100 COMPLEX STR PL EA 51303782-100 POWER ENTRY MTG PLA TE EA 51303790-010 COMPUTER DATA CABLE EA 51303790-015 COMPUTER DATA CABLE EA 51303791-006 CABLE,REDUN REQ EA 51303793-015 CABLE EA 51303793-020 CABLE,GRANT/REQ EA 51303793-025 CABLE,GRANT/REQ EA 51303794-100 CRT SHROUD COVER EA 51303794-200 CRT SHROUD COVER EA 51303799-100 PWR CORD 7.5FT EA 51303799-300 PWR CORD 3.5FT EA 51303800-100 NAMEPLATE, TDC3000 EA 51303816-100 PTR EXT CORD EA 51303816-200 PTR EXT CORD EA 51303817-200 UP/HINGE R/DOOR EA 51303818-100 LOW/HINGE L/DOOR EA 51303818-200 LOW/HINGE R/DOOR EA 51303849-100 BRACKET, FDD MTG EA 51303849-200 BRACKET, FDD MTG EA 51303863-100 OP STN PANEL EA 51303880-100 TREND I/F CABLE EA 51303888-100 PWB, PC I/F EA 51303893-200 CABLE, PC IF 50' EA 51303893-300 CB PCSI TO PC 12FT EA 51303903-100 TERMINAL PANEL P-TCB60 EA 51303905-001 SUPPORT PAN ASSY EA 51303905-002 SUPPORT PAN ASSY EA 51303906-001 MOUNTING PLATE EA 51303907-001 MOUNTING BRACKET EA 51303909-001 BUS BAR DIVIDER EA 51303911-001 BRACKET, LOCKING EA 51303912-001 CABINET BASE EA 51303925-100 PANEL SUPT BRKT EA 51303926-100 FRONT PANEL ASM EA 51303928-100 FTA, D/I 24VDC MU-TDID72 EA 51303928-150 FTA,D/O 24VDC CC EA 51303930-100 FTA, D/I (32) MU-TDIA72 EA 51303930-150 FTA, 120VDI (CC) EA 51303932-201 SER DEV I/F FTA EA 51303932-226 51303932-202 SER DEV I/F FTA EA 51303932-227 51303932-203 FTA, SD I/F UDC6 EA 51303932-228 51303932-226 SER DEV I/F FTA MU-TSDT02 EA 51303932-227 SER DEV I/F FTA MU-TSDM02 EA 51303932-228 FTA, SD I/F UDC6 MU-TSDU02 EA 51303932-251 FTA, SER I/F TOLEDO MC-TSDT02 EA 51303932-276 51303932-252 FTA,SER DEV BASE EA 51303932-277 51303932-253 FTA,SDI UDC6000 EA 51303932-278 51303932-276 SD TOLEDO I/F CC MC-TSDT02 EA 51303932-277 SD MANUAL I/F CC MC-TSDM02 EA 51303932-278 SD UDC6000 IF CC MC-TSDU02 EA 51303932-401 SERIAL I/F EA 51303932-426 51303932-403 SERIAL I/F EA 51303932-428 51303932-426 SERIAL INTERFACE FTA - MODBUS MU-TSIM12 EA 51303932-428 SERIAL INTERFACE - ALLEN BRADLEY MU-TSIA12 EA 51303932-451 Modbus FTA EA 51303932-476 51303932-453 FTA,SDI-AB EC/CC EA 51303932-478 51303933-100 MOUNTING PLATE AC/DC EA 51303934-401 SI RS-232 (SPARE) EA 51303932-426 51303934-403 SI RS-323 (SPARE) EA 51303932-428 51303939-100 BATTERY TRIM PLATE EA 51303940-100 FAN W/ALARM,115V EA 51303940-150 FAN W/ALARM 120V EA 51303940-200 FAN W/ALARM 240V EA 51303940-250 FAN W/ALARM 240V EA 51303948-100 48V BATTERY ASSM EA 51303951-100 FTA,D/I SENS PWR EA 51304425-125 51303953-100 MODULE, A/O FTA See Note Field EA 51303959-100 MODULE, D/O FTA See Note Field EA 51303968-100 CMOS BACKUP ASSY EA 51309206-175 51303968-150 B/U PWB EA 51309206-175 51303976-300 PM COMM MOD,R210 EA 51304685-300 51303976-400 PM COMM MODULE EA 51304685-250 51303979-300 PM,I/O LINK R300 EA 51303979-400 51303979-400 I/O LINK INTERFACE EA 51303979-450 51303979-450 I/O LINK R300 CC EA 51303979-500 APM I/O LINK DRIVER EA 51303979-550 51303979-550 APM I/O LINK DRIVER CC EA 51303982-200 PM-CONTROL W/O DAUGHPWA EA 51303982-300 PM CTLR CARD, R210/R230 REDUNDANT EA 51303982-400 R300 PM CONTROLLER EA 51304518-250 51303982-800 PM CONTROLLER EA 51304518-200 51303982-900 PM CONTROLLER EA 51304518-200 51303985-200 PWA, AO/IOP EA 51309152-175 51303985-300 PWA, IO/IOP EA 51309152-175 51303988-200 LLAI IOP ASSY EA 51304481-100 51303988-300 LLAI IOP ASSY EA 51304481-100 51303991-200 IOP, HLAI (CC) EA 51304754-150 51303991-300 IOP, HLAI (CC) EA 51304754-150 51303994-200 D/O IOP ASSM EA 51304487-100 51303994-300 D/O IOP ASSM EA 51304487-100 51303997-200 D/I IOP ASSM EA 51304485-100 51303997-300 D/I IOP ASSY EA 51304485-100 51304029-092 KEYLOCK SWITCH ASSM EA 51304029-200 KEY/SWITCH CABLE EA 51304029-500 51304029-500 KEYLOCK SWITCH ASSM. EA 51304030-150 SMT FR DATA CBL EA 51304030-300 SMT FR DATA CBL 300CM EA 51304031-150 SMT FR PWR CBL EA 51304031-183 SMT FR PWR CBL EA 51304031-300 SMT FR PWR CBL EA 51304032-003 K/B CABLE,SUPER EA 51304033-045 MOUSE CABLE EA 51304034-100 PANEL OVERLAY EA 51304036-051 KEYBOARD I/F CBL UWS EA 51304037-183 POWER CORD EA 51304038-100 FLOPPY STAT CBL EA 51304039-122 FLOPPY DC CM CBL EA 51304040-101 FLOPPY COM CBL EA 51304047-152 CBL, ANNUM, 22GU EA 51304047-652 51304047-652 CBL, ANNUM, 22GU EA 51304050-010 CABLE ASSY-10FT EA 51304050-020 CABLE 20 FT EA 51304050-100 CABLE ASSEMBLY EA 51304051-100 WEDGE MTG PLATE P-ZKF55 EA 51304053-200 FDD BRACKET EA 51304063-100 FTA MTG RAIL EA 51304069-100 BEZEL ASSEMBLY EA 51304072-100 IOP CASE EA 51404092-400 51304072-200 MOD CHASSIS ASSM EA 51404092-500 51304074-100 PM CAB 120V FAN ASSM EA 51304074-200 CAB AC FAN 240V 50H Z EA 51304076-100 PWB, D/O STANDBY EA 51304080-100 LLAI 8 MOD EA 51309280-100 51304084-100 FTA, PULSE INPUT EA 51304084-125 51304084-125 FTA, PULSE INPUT MU-TPIX12 COMP TERM. EA 51304084-150 FTA, PUL INP CC EA 51304084-175 51304084-175 FTA, PUL INP CC MC-TPIX12 EA 51304084-200 FTA, PULSE INPUT EA 51304084-225 51304084-225 FTA, PULSE INPUT SCR TERM EA 51304084-275 FTA, PUL INP CC MC-TPIX52 EA 51304085-100 LLAI-8 MOD, EC EA 51309280-100 51304085-150 LLAI MODULE CC EA 51309280-100 51304086-100 VERTICAL TRIM PANEL CC EA 51304086-200 VERTICAL TRIM PANEL EA 51304086-300 VERTICAL TRIM PANEL EA 51304086-400 VERTICAL TRIM PANEL EA 51304086-500 TRIM PNL LEFT SIDE EA 51304086-600 TRIM PNL RIGHT SIDE EA 51304086-700 TRIM PNL CENTER EA 51304095-100 FTA, D/O STNDBY OBSOLETE SEE NOTE FIELD EA 51304095-200 D/O STDBY W/CASE See note field EA 51304096-100 FTA, D/O STNDBY See note field EA 51304098-200 COVER, FAN PM EA 51304154-100 PWA, PLC(培训)G RELAY EA 51304421-200 51304156-100 PWB, SPC I/O EA 51304159-100 PWB, AM RED I/O EA 51304159-200 AM RED I/O EA 51304161-100 Fiber Optic Clock Xmtr EA 51304161-200 Fiber Optic Clock Rcvr EA 51304161-300 Fiber Optic Clock Xmtr EA 51304161-400 Fiber Optic Clock Rcvr EA 51304163-300 PM MODEM EA 51304493-150 51304163-400 APM MODEM EA 51304493-250 51304186-100 DC/DC CONVERTER EA 51304188-102 CBL FIBER OPTIC EA 51308113-102 51304188-202 CABLE,FBR OPT CL EA 51304190-200 PM JUMPER CARD EA 51304190-300 APM JUMPER CARD EA 51304191-100 SGL WIN INT CBL EA 51304191-200 CABLE,WREN 3 SGL EA 51304191-300 SGL WINCHESTER INTF CBL EA 51304192-100 WREN DATA CABLE EA 51304193-100 WREN DATA CABLE EA 51304194-100 WREN DATA CABLE EA 51304197-100 AM I/F CABLE EA 51304197-200 CABLE AM/TPDG/WSI EA 51304198-100 AM REDUN CABLE EA 51304199-100 CABLE, I/F EA 51304199-201 51304199-200 CABLE, I/F EA 51304199-201 51304199-201 CABLE, I/F EA 51304199-300 CABLE, I/F EA 51304203-100 P.S. MTG BRACKET EA 51304207-100 PWB, PAE LOGIC EA 51304208-100 MOUNTING PANEL EA 51304209-100 FAN MTG, BRACKET EA 51304211-100 SNGL DC FW/C CBL EA 51304212-100 FILTER RETAINER EA 51304217-100 DC-DC CONV ASSY EA 51304218-100 CABLE ADAPTOR EA 51304219-100 FTA, D/I 240VAC See note field EA 51304255-100 MOUNTING BRACKET EA 51304260-200 FLR PNL (BEIGE) EA 51309228-300 51304260-300 PMM FILLER PLATE EA 51309228-200 51304260-400 PM FILLER PLATE EA 51309228-200 51304270-100 PWB, EPDGP I/O EA 51304584-100 51304272-100 CABLE, D TO DIN EA 51304279-150 KYBD POWER CABLE EA 51304279-300 CBL, KYBD 300CM EA 51304281-200 ST I/F IOP ASSM EA 51304516-100 51304281-300 ST I/F IOP ASSM EA 51304516-100 51304283-100 PWB, HTD LOGIC EA 51304286-100 PWB, PRECISION CLOCK SOURCE REPEATER (PCSR) EA 51304286-200 PRECISION CLOCK EA 51304290-100 CLOCK CABLE EA 51304315-100 CABINET SPACER EA 51304335-100 AO FTA RED. COMP EA 51304335-125 51304335-125 AO FTA RED. COMP MU-TAOX12 EA 51304335-150 FTA, A/O RED CC EA 51304335-175 51304335-175 FTA, A/O RED CC MC-TAOX12 EA 51304335-200 AO FTA RED. SCRE EA 51304335-225 51304335-225 AO FTA RED. SCREW MU-TAOX52 EA 51304335-250 A/O RED W/SCREW EA 51304335-275 51304335-275 A/O RED W/SCREW MC-TAOX52 EA 51304337-100 FTA, HL/AI MU-TAIH12 COMP TERM. RED. EA 51304337-150 FTA,HLAI RED CC MC-TAIH12 EA 51304337-200 FTA, HLAI/STI MU-TAIH52 SCR TERM. EA 51304337-250 FTA, HLAI-ST CC MC-TAIH52 EA 51304338-100 A/O REDUNDANCY MODULE EA 51304342-100 FORKLIFT BASE, DUAL EA 51304349-100 FORKLIFT BASE, SGL EA 51304357-036 ENG KBD CBL,36CM EA 51304360-100 19IN ENH MONITOR EA 51304362-100 LLAI MUX IOP MU-PLAM02 EA 51304362-150 IOP, LLAI CC MC-PLAM02 EA 51304362-200 IOP,SER DEV I/F MU-PSDX02 EA 51304362-250 IOP, SER DEV CC MC-PSDX02 EA 51304362-300 IOP, SERIAL I/F MU-PSIM11 EA 51304362-350 IOP, SER I/F CC MC-PSIM11 EA 51304366-002 PIX PER DAT CBL EA 51304366-003 CRT I/F CABLE EA 51304367-006 T/S CABLE, 6FT EA 51304374-100 ENH CRT PWR CORD EA 51304374-200 CBL,RTS CRT 230V EA 51304379-100 DUAL WREN CABLE EA 51304386-100 PULSE INPUT IOP MU-PPIX02 EA 51304386-150 IOP,PULSE INP CC MC-PPIX02 EA 51304392-100 CABLE, DISK PWR EA 51304392-200 CABLE, DISK PWR EA 51304392-300 CABLE, DISK PWR EA 51304396-100 CARTRIDGE DISK I/F CABLE NON-EC EA 51304396-200 CARTRIDGE DISK I/F CABLE NON-EC EA 51304398-100 DISK MTG BRKT-LH EA 51304398-200 DISK MTG BRKT-RH EA 51304399-100 CABLE, UWS MONITOR 15 PIN TO 9 PIN EA 51304399-200 51304399-200 UWS CRT CABLE 14IN EA 51304408-100 FTA, 120/240VAC SS D/O COMP EA 51304648-175 51304408-200 FTA, 120/240VAC SS D/O SCREW, CE EA 51304648-225 51304419-100 FIBER OPTIC IOP EA 51304419-150 FIBER OPTIC IOP CC EA 51304421-100 PWA, PLC(培训)G RELAY NON-CE EA 51304421-200 51304421-200 PWA, PLC(培训)G RELAY EA 51304423-100 FTA, 3/30VDC D/O COMP EA 51304650-100 51304423-200 FTA, 3/30VDC D/O SCREW EA 51304650-200 51304425-100 PWR DIST 24VDC EA 51304425-125 51304425-125 PWR DIST 24VDC MU-TDPR02 EA 51304425-150 DI 24VDC PWR DST EA 51304425-175 51304425-175 DI 24VDC PWR DST MC-TDPR02 EA 51304426-300 FTA, 120V RELAY DO COMP EA 51309148-125 51304427-100 FTA, 240V RELAY DO COMP EA 51309150-125 51304427-200 FTA, 240V RELAY DO SCREW EA 51309150-225 51304428-100 FTA, 31/200VDC DO COMP EA 51309154-175 51304428-150 FTA, 31/200VDC DO COMP EA 51309154-175 51304428-200 FTA, 31/200VDC DO SCREW TERM EA 51309154-225 51304428-250 FTA, 31/200VDC DO COMP EA 51309154-175 51304431-100 FTA, D/I 240VAC COMPRESSED TERM EA 51304431-125 51304431-125 FTA, DI 240VAC COMPRESSED TERM MU-TDIA22 EA 51304431-150 FTA, 240VDI (CC) EA 51304431-175 51304431-175 FTA, D/I 240V CC MC-TDIA22 EA 51304431-200 FTA, D/I 240VAC ISOLATED SCREW TERM EA 51304431-225 51304431-225 FTA, D/I 240VAC ISOL SCREW TERM MU-TDIA62 EA 51304431-250 FTA, 240VDI (CC) EA 51304431-275 51304431-275 FTA, D/I 240V CC MC-TDIA62 EA 51304437-100 FTA, LLAI MU-TAIL02 EA 51304437-150 FTA, LLAI CC MC-TAIL02 EA 51304439-100 DI FTA 120 VAC COMPRESSION TERM EA 51304439-125 51304439-125 DI FTA 120 VAC MU-TDIA12 EA 51304439-150 FTA, D/I 120V CC EA 51304439-175 51304439-175 FTA, D/I 120V CC MC-TDIA12 EA 51304439-200 FTA, D/I EA 51304439-225 51304439-225 DI 120VAC SCREW FTA MU-TDIA52 EA 51304439-250 FTA, 120VDI (CC) EA 51304439-275 51304439-275 FTA, D/I 120V CC MC-TDIA52 EA 51304441-100 FTA, D/I 24VDC COMP TERM EA 51304441-125 51304441-125 FTA, D/I 24VDC MU-TDID12 EA 51304441-150 FTA,D/I 24VDC CC EA 51304441-175 51304441-175 FTA,D/I 24VDC CC MC-TDID12 EA 51304441-200 DI FTA 24VDC SCREW TERM EA 51304441-225 51304441-225 DI 24VDC FTA SCREW MU-TDID52 EA 51304441-250 FTA,DIG INPUT 24VDC EA 51304441-275 51304441-275 FTA,DIG INPUT 24VDC MC-TDID52 EA 51304443-100 FTA, DO 120VAC EC COMP TERM EA 51309148-125 51304443-150 DO 120 VAC RELAY FTA EA 51309148-175 51304443-200 FTA, 120V RELAY DO SCREW TERM EA 51309148-225 51304446-100 FTA, D/O NON-ISOL 24VDC COMP TERM MU-TDON12 EA 51304446-150 FTA,D/O NON-ISOL 24VDC COMP CC MC-TDON12 EA 51304446-200 FTA, D/O NON ISOL 24VDC SC TERM MU-TDON52 EA 51304446-250 FTA D/O NON ISOL 24VDC SC TERM CC MC-TDON52 EA 51304449-100 CRT ASSY,NON EC EA 51304449-500 51304449-200 19IN ENH MONITOR EA 51304449-300 51304449-300 19IN ENH MONITOR EA 51304449-500 51304449-400 19IN ENH MONITOR EA 51304449-500 51304449-500 INTECOLOR CRT EA 51304451-100 DO STANDBY MANUAL P WA EA 51304453-100 FTA, HLAI/STI COMP TERM MU-TAIH02 EA 51304453-150 FTA,HLAI/STI COMP TERM CC MC-TAIH02 EA 51304456-100 MONITOR 14IN EA 51196793-100 51304465-000 POWER CABLE (ORDER INDV. LENGTH) EA 51304467-100 FTA, LLMUX/SDI/SI PWR ADAPTER EA 51309204-175 51304467-150 FTA, LLMUX/SDI/SI PWR ADAPTER EA 51309204-175 51304472-100 PWA, NGI I/O EA 51304476-100 FTA, A/O COMPR TERM EA 51304476-175 51304476-125 A/O FTA, COMP CE MU-TAOX02 EA 51304476-150 FTA, A/O EA 51304476-175 51304476-175 FTA, A/O CCCE MC-TAOX02 EA 51304477-100 LLAI RTD MUX FTA EA 51309218-125 51304477-150 FTA,LLAI MUX RTD EA 51309218-175 51304478-100 FTA,LLAI MUX TC (SEE NOTES) EA 51304481-100 LLAI IOP ASSM MU-PAIL02 EA 51304481-150 LLAI IOP ASSM CC MC-PAIL02 EA 51304483-100 PWA, AO/IOP EA 51309152-175 51304485-100 D/I IOP ASSM MU-PDIX02 EA 51304485-150 DI IOP, COATED, PWA EA 51304487-100 D/O IOP ASSM MU-PDOX02 EA 51304487-150 DO IOP, COATED, PWA EA 51304489-100 IOP, HLAI EA 51304754-150 51304490-100 DC POWER CABLE EA 51304769-103 51304490-300 DC POWER CABLE EA 51304769-303 51304493-100 PM MODEM EA 51304493-150 51304493-150 PM MODEM CC, R210/230/300 EA 51304493-200 APM MODEM EA 51304493-250 51304493-250 APM MODEM CC, R400 EA 51304493-300 MODEM BOARD EA 51304495-036 ENH. KB I/F CBL MICRO/UWS EA 51304496-026 CBL, ENG KYBD EA 51304497-051 UWS KYBD I/F CBL EA 51304501-100 PM DRIVER (R300) EA 51304501-150 51304501-150 PMM RED DRIVE PWB EA 51304502-100 CABLE, TRACKBALL EA 51304502-200 CABLE, TRACKBALL EA 51304505-100 TWR TO TWR CBL 5FT EA 51304505-200 CABLE,10M TOWER EA 51304506-100 CBL,PTR ADPT 2M EA 51304506-200 CBL,PTR ADPT 4M EA 51304508-100 TP LCN CABLE EA 51304511-100 PWA, NIM MODEM EA 51304511-200 PWB, SM NIM/LCN EA 51304514-100 RS232 CABLE 50FT EA 51308106-100 51304516-100 PWA, ST I/F (MU-PSTX02) EA 51304516-150 PWA, ST I/F, SMRT TRANSMITTER CC MC-PSTX02 EA 51304516-200 PWA, MV ST I/F (MU-PSTX03) EA 51304516-250 PWA, MV ST I/F, CC (MC-PSTX03) EA 51304518-100 APM ADV CONTROLLER EA 51304518-150 51304518-150 APM ADV CONTROLLER CC EA 51304518-200 R300 PM CONTROLLER EA 51304518-250 51304518-250 R300 CONTROLLER CC EA 51304526-100 FTA, D/O STNDBY PHONE STYLE CONNECTION EA 51304526-200 D/O STDBY W/CASE & CABLE W/PHN CONN MU-SMDC02 EA 51304527-100 FTA, D/O STNDBY PHONE CONN MU-SMDX02 EA 51304528-100 PWB, RAM/EDAC EA 51304532-100 PWB, LD I/O EA 51304532-150 PWB, LD I/O CC EA 51304537-100 PWB, CNI I/O EA 51304537-200 PWA, CNI I/O EC EA 51304540-100 PWB, LCNE II EA 51304540-200 LCN EXT 2 EA 51304542-100 PWB,K2LCN A I/O (SEE NOTE FIELD) EA 51304544-100 PWA, K2LCN B I/O (SEE NOTE FIELD) EA 51304548-101 PTR PAPER TRAY EA 51304584-100 PWB, EPDGP I/O EA 51304584-200 PWB, EPDGP I/O EA 51304584-300 EPDGP I/O Z FURN ONLY EA 51304585-100 FAN PWR CABLE EA 51304585-200 CBL, DC FAN EA 51304585-500 51304585-300 DC FAN CABLE EA 51304585-600 51304585-400 CBL, FAN POWER EA 51304585-500 CBL, DC FAN EA 51304585-600 CBL, DC FAN EA 51304589-100 REMOTE SENSOR EA 51304589-150 TC MUX REM SNSR EA 51304632-100 TAP BRACKET/SCRW EA 51304636-300 GI HLAI FTA, COMPRES EA 51304718-325 51304638-100 FTA, A/O GI/IS COMP EA 51304638-175 51304638-125 FTA, A/O GI/IS COMP. TERM CE MU-GAOX02 EA 51304638-150 FTA, A/O GI/IS COMP, CC EA 51304638-175 51304638-175 FTA, A/O GI/IS COMP, CE, CC MC-GAOX02 EA 51304638-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304638-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304638-300 FTA, A/O GI/IS CRIMP TERM EA 51304638-325 FTA, A/O GI/IS CRIMP, CE MU-GAOX72 EA 51304638-350 FTA, A/O GI/IS CRIMP, CC EA 51304638-375 51304638-375 FTA, A/O GI/IS CRIMP, CE, CC MC-GAOX72 EA 51304638-500 FTA, RED A/O GI/IS COMP EA 51304638-575 51304638-525 FTA, RED A/O GI/IS COMP TERM CE MU-GAOX12 EA 51304638-550 FTA, RED A/O GI/IS COMP, CC EA 51304638-575 51304638-575 FTA, RED A/O GI/IS COMP, CE, CC MC-GAOX12 EA 51304638-600 GI FTA UNPOPULATED (PACE) EA 51304638-625 51304638-625 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304638-650 A/O GALV FTA CC EA 51304638-675 51304638-675 GALV FTA, UNPOPULATED (PACE ORDERS ONLY) EA 51304638-700 FTA, RED A/O GI/IS CRIMP EA 51304638-725 FTA, RED A/O GI/IS CRIMP, CE MU-GAOX82 EA 51304638-750 FTA, RED A/O GI/IS CRIMP, CC EA 51304638-775 51304638-775 FTA, RED A/O GI/IS CRIMP, CE, CC MC-GAOX82 EA 51304640-100 FTA, 24VDC D/I GI/IS COMP EA 51304640-175 51304640-125 FTA, 24VDC D/I GI/IS COMP, CE MU-GDID12 EA 51304640-150 FTA, 24VDC D/I GI/IS COMP, CC EA 51304640-175 51304640-175 FTA, 24VDC D/I GI/IS COMP, CE, CC MC-GDID12 EA 51304640-200 GI FTA UNPOPULATED (PACE) EA 51304640-225 51304640-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304640-250 GI FTA UNPOPULATED (PACE) EA 51304640-275 51304640-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304640-300 FTA, 24VDC D/I GI/IS CRIMP EA 51304640-325 51304640-325 FTA, 24VDC D/I GI/IS CRIMP, CE MU-GDID82 EA 51304640-375 FTA, 24VDC D/I GI/IS CRIMP, CE, CC MC-GDID82 EA 51304642-100 FTA, 24VDC D/O GI/IS COMP EA 51304642-175 51304642-125 FTA, 24VDC D/O GI/IS COMP, CE MU-GDOD12 EA 51304642-175 FTA, 24VDC D/O GI/IS COMP, CE, CC MC-GDOD12 EA 51304642-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304642-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304642-300 FTA, 24VDC D/O GI/IS CRIMP EA 51304642-325 51304642-325 FTA, 24VDC D/O GI/IS CRIMP, CE MU-GDOD82 EA 51304642-375 FTA, 24VDC D/O GI/IS CRIMP, CE, CC MC-GDOD82 EA 51304644-100 PWR DIST PANEL EA 51304644-125 51304644-125 PWR DIST PANEL FTA, GI MU-GPRD02 EA 51304644-175 PNL,GI PWR DIST MC-GPRD02 EA 51304646-100 G/I PNL SCR TERM EA 51309156-125 51304648-100 FTA, 120/240VAC SS D/O COMP EA 51304648-175 51304648-125 FTA, 120/240VAC SS D/O COMP, CE EA 51304648-150 FTA, 120/240VAC SS D/O COMP, CC EA 51304648-175 51304648-175 FTA, 120/240VAC SS D/O COMP, CE, CC MC-TDOA13 EA 51304648-200 FTA, 120/240VAC SS D/O SCREW EA 51304648-225 51304648-225 FTA, 120/240VAC SS D/O SCREW, CE MU-TDOA53 EA 51304648-275 FTA, 120/240VAC SS D/O SCREW, CE, CC EA 51304650-100 FTA, 3/30VDC D/O COMP MU-TDOD13 EA 51304650-150 FTA, 3/30VDC D/O COMP, CC MC-TDOD13 EA 51304650-200 FTA, 3/30VDC D/O SCREW MU-TDOD53 EA 51304650-250 FTA, 3/30VDC D/O SCREW, CC MC-TDOD53 EA 51304672-100 A/O IOP EA 51309152-175 51304672-150 PWA, AO/IOP EA 51309152-175 51304673-100 SW ASM T/B LEFT EA 51304673-100A 51304673-100A SW ASM T/B LEFT EA 51304673-200 SW ASM T/B RIGHT EA 51304673-200A 51304673-200A SW ASM T/B RIGHT EA 51304685-100 APM ADV COMM (SEE NOTES) EA 51304685-150 51304685-150 APM ADV COMM CC (SEE NOTES) EA 51304685-200 R300 COMM PWA EA 51304685-250 51304685-250 PM COMM R300(CC) SEE NOTES EA 51304685-300 PM COMM MOD,R210 SEE NOTES EA 51304690-100 RED DI SOE ASSM EA 51402625-125 51304690-150 RED DI SOE ASSM EA 51402625-175 51304692-200 BLANK OFF PLATE EA 51304693-200 BLANK-OFF PLATE ASM EA 51304695-100 CBL, WREN DC EA 51304718-100 FTA, RED HLAI/STI GI/IS COMP EA 51304718-175 51304718-125 FTA, RED HLAI/STI GI/IS COMP, CE MU-GAIH13 EA 51304718-175 FTA, RED HLAI/STI GI/IS COMP, CE, CC EA 51304718-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304718-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304718-300 FTA, RED HLAI/STI GI/IS CRIMP EA 51304718-325 51304718-325 FTA, RED HLAI/STI GI/IS CRIMP, CE MU-GAIH83 EA 51304718-375 FTA, RED HLAI/STI GI/IS CRIMP, CE, CC EA 51304720-100 FILLER PLATE EA 51304722-125 FTA, RH MUX GI/NI PWR ADAPTER, EC MU-TRPA01 EA 51304722-175 FTA, RH MUX GI/NI PWR ADAPTER, EC, CC EA 51304724-125 GI LLAI MUX POWER ADAPTER FTA MU-GRPA01 EA 51304724-175 GI LLAI MUX PWR ADAPTER FTA CC MC-GRPA01 EA 51304728-100 FTA, SS DI GI/IS COMP EA 51304728-125 51304728-125 FTA, SS DI GI/IS COMP, CE MU-GDID13 EA 51304728-150 FTA, SS DI GI/IS COMP, CC EA 51304728-175 51304728-175 FTA, SS DI GI/IS COMP, CE, CC MC-GDID13 EA 51304728-225 GI FTA, UNPOPULATED (PACE ORDERS ONLY) EA 51304728-275 GI FTA, UNPOPULATED (PACE ORDERS ONLY) EA 51304728-300 FTA, SS DI GI/IS CRIMP EA 51304728-325 51304728-325 FTA, SS DI GI/IS CRIMP, CE MU-GDID83 EA 51304728-375 FTA, SS DI GI/IS CRIMP, CE, CC MC-GDID83 EA 51304730-100 FTA, RED HLAI/STI GI/IS COMP EA 51304730-125 51304730-125 FTA, RED HLAI/STI GI/IS COMP, CE MU-GAIH14 EA 51304730-175 FTA, RED HLAI/STI GI/IS COMP, CE, CC EA 51304730-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304730-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304730-300 FTA, RED HLAI/STI GI/IS CRIMP EA 51304730-375 51304730-325 FTA, RED HLAI/STI GI/IS CRIMP, CE EA 51304730-375 FTA, RED HLAI/STI GI/IS CRIMP, CE, CC EA 51304732-100 COMBINER PNL,LFD TO DI IOP EA 51304732-125 51304732-125 DI/DO PANEL MU-GLFD02 EA 51304732-150 LFD COMB PANEL EA 51304732-175 51304732-175 LFD COMB PANEL EC/CC MC-GLFD02 EA 51304736-100 FTA, DO GI/IS COMP EA 51304736-125 51304736-125 FTA, DO GI/IS COMP,CE MU-GDOL12 EA 51304736-175 FTA, DO GI/IS COMP, COATED, CE MC-GDOL12 EA 51304736-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304736-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304736-300 FTA, DO GI/IS CRIMP EA 51304736-325 51304736-325 FTA, DO GI/IS CRIMP,CE EA 51304736-375 FTA, DO GI/IS CRIMP, COATED, CE MC-GDOL82 EA 51304748-100 FTA, GAL HLAI AUX COMP EA 51304748-125 51304748-125 FTA, GAL HLAI AUX COMP, CE MU-GAIH22 EA 51304748-175 FTA, GAL HLAI AUX COMP, CE, CC MC-GAIH22 EA 51304748-200 HLAI GI/IS FTA UNPOP(PACE) EA 51304748-225 51304748-225 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304748-275 GI FTA UNPOPULATED (PACE ORDERS ONLY) EA 51304748-300 FTA, GAL HLAI AUX CRIMP EA 51304748-325 51304748-325 FTA, GAL HLAI AUX CRIMP, CE MU-GAIH92 EA 51304748-375 FTA, GAL HLAI AUX CRIMP, CE, CC MC-GAIH92 EA 51304754-100 IOP, HLAI EA 51304754-150 51304754-150 IOP, HLAI (CC) MC-PAIH03 EA 51304768-200 CBL, C/D DC PWR EA 51304769-202 51304769-100 CBL, DC POWER EA 51304769-102 51304769-101 DC POWER CABLE EA 51304769-103 51304769-102 CBL, C/D DC PWR EA 51304769-103 CBL, C/D DC PWR EA 51304769-201 CBL, C/D DC PWR EA 51304769-203 51304769-202 CBL, C/D DC PWR EA 51304769-203 CBL, C/D DC PWR EA 51304769-300 C/D DC PWR CBL EA 51304769-302 51304769-301 DC POWER CABLE EA 51304769-303 51304769-302 CBL,C/D DC 10FT EA 51304769-303 CBL, C/D DC PWR EA 51304776-100 PWB, TP 485 I/O EA 51304776-200 PWB, TP485 I/O EA 51304776-300 PWA, TP485 I/O EA 51304776-400 PWA, TR485 I/O EA 51304780-100 AIR BAFFLE EA 51304787-100 CABLE, I/F EA 51304788-046 KYBD I/F CABLE EA 51304789-100 I/O CARD I/F CBL EA 51304791-100 WSI I/O ASSY EA 51304794-100 CABLE, WDA POWER EA 51304795-100 MTG BRACKET CONN EA 51304797-100 PWB, DISPLAY GEN EA 51304808-100 CABLE, WDA I/O EA 51304808-200 CBL, WDA I/O EA 51304812-100 PWB, EPLC(培训) I/O ADAPTER EA 51304812-200 EPLC(培训)I I/O ADAPTR EA 51304814-100 PWB, TREND I/O EA 51304814-200 PWB, TREND I/O EA 51304831-100 TPDG I/O EA 51304833-100 CABLE, SCSI I/O EA 51304836-100 HD/DAT PWR CBL EA 51304837-100 HD DISK CABLE EA 51304838-100 HD DISK PWR CBL EA 51304839-100 HD DISK SIG CBL EA 51305070-100 51304842-100 CART I/F CABLE EA 51304842-200 C/D IF CBL X3000 EA 51304850-100 DISC ADAPTOR PLATE EA 51304854-100 CHANNEL SUPPORT EA 51304854-200 CHANNEL SUPPORT EA 51304871-100 CABLE, RULA SCSI EA 51304871-300 RULA SCSI CABLE EA 51304872-100 RULA CABLE EA 51304875-100 SCSI ADP CBL 24IN EA 51304875-200 SCSI ADAPT CBL 72IN EA 51304875-300 SCSI,CBL EA 51304877-300 CORD, PWR TREND EA 51304878-200 TREND POWER CORD EA 51304878-300 TREND AC PWR CBL 24 0V EA 51304878-400 TREND PWR CABLE EA 51304880-300 CABLE, PTR FERRI EA 51304882-100 RIPPLE DETECTOR EA 51304883-100 CONNECTOR BULKHEAD EA 51304887-100 PRINTER I/C CBL EA 51304888-100 CABLE, MOUSE EA 51304889-100 CABLE, PTR I/F EA 51304897-200 PLATE EA 51304899-100 SMT LED PWB EA 51304901-100 WDA PWA (A/C) EA 51304903-100 WDA I/O MODULE EA 51304903-200 WDI I/I EA 51304904-100 FLEX CKT EA 51304907-100 PWB, SPC II I/O EA 51304907-200 SPC II I/O CARD EA 51304913-100 PWA, HDDT I/O EA 51304913-200 PWB, HDDT I/O EA 51304917-100 SERIAL PORT CABLE EA 51304918-100 CABLE, SCSI EA 51304920-100 51304920-100 EA 51402176-100 51304921-100 CBL, DRIVE PWR EA 51304924-100 PWA, WSI I/O EA 51304924-200 PWB, I/O I/F WORKSTATION EA 51304947-100 WSI 2R I/O EA 51304949-100 CABLE, SCSI EA 51305069-100 CABLE, CONFIG EA 51305070-100 CBL,SCSI W/O DAT EA 51305070-101 CBL, SCSI EA 51305070-102 CBL, SCSI EA 51305070-103 SCSI CBL EA 51305070-104 SCSI CBL 27IN EA 51305070-200 CBL, SCSI W/DAT EA 51305070-202 SCSI CBL EA 51305072-100 PWB, XCVR I/O EA 51305072-200 I/O CARD, K2LCN A EA 51305072-300 I/O CARD, K2LCN B EA 51305072-400 PWA, LCN I/O EA 51305072-500 I/O CARD, K2LCN A EA 51305072-600 I/O CARD, K2LCN B EA 51305072-700 PWB, LCN I/O EA 51305072-800 PWB, CLCN I/O EA 51305072-900 PWB, CLCN I/O EA 51305075-100 PWB, TPDGC I/O EA 51305088-100 PWA, SPC3 I/O EA 51305098-100 DIST BOX ASY EA 51305187-100 CARDFILE TRACK EA 51305282-100 FACE PLATE EA 51305282-200 BLNK FACEPLATE EA 51305293-100 FACE PLATE BLANK EA 51305303-100 VGA_CABLE_TPS10D EA 51305382-100 51305306-100 BRACKET PWR ENT EA 51305309-100 IKBM-Z CONS EA 51305313-100 MAU CABLE EA 51305380-100 51305315-100 PARALLEL DATA CBLE FOR DOT MATRIX PRTR 2M EA 51305315-200 PARALLEL DATA CBL FOR DOT MATRIX PRTR 3M EA 51305315-300 51305315-300 PARALLEL DATA CBL FOR DOT MATRIX PRTR 4.5M EA 51305317-100 PERIPH PWR CBL EA 51305319-100 PWA, LCNP (W/BRACKET FOR NON-DELL PC INSTALL) EA 51402797-100 51305325-100 BRACKET EA 51305328-100 X-CEIVER CBL EA 51305329-100 MOUNTING BRACKET EA 51305334-100 COVER, MAU EA 51305336-100 P/S RESET CBL EA 51305339-100 ANNUNCIATOR CBL EA 51305341-100 DRIVE DC PWR CBL EA 51305342-100 DRIVE PWR CBL EA 51305345-100 8MB LCPM MEM EA 51305348-100 MAU ASSY EA 51305366-100 WDA ENCL ASSM EA 51305380-100 MAU CABLE EA 51305382-100 VGA CABLE TPS10D EA 51305384-100 AC POWER CABLE EA 51305384-200 MONITOR PWR CBL EA 51308020-100 51305386-100 T/S CONTROLLER BOX ASSM EA 51305387-100 GUS TOUCHSCRN CABLE EA 51305387-300 GUS T/S CBL 66IN EA 51305388-100 ANN CTR CBL EA 51305390-100 PWA, UCPU FOR BASIC CTLR EA 51305390-200 PWA, UCPU W/DEP FOR BASIC CTLR EA 51305390-300 PWA, UCPU FOR EXTENDED CTLR EA 51305390-400 PWA, UCPU W/DIDEP FOR EXTENDED CTLR EA 51305406-100 PWA, UCIO EA 51305408-100 PWA, UDHI EA 51305409-200 AC PWR CORD,115V EA 51305409-500 AC POWER CABLE EA 51305410-200 220 AC PWR CORD EA 51305410-500 AC POWER CORD EA 51305413-100 FIBER OPTIC FRONT PANEL EA 51305418-100 OPR KYBD CABLE EA 51305418-300 TPS100 OEP KBD CBL EA 51305419-100 IKB MOUSE CABLE EA 51305430-100 LCNP-4 W/O BRACKETS EA 51403282-200 51305431-100 CABLE, GND EA 51305444-100 WEDGE TOP EA 51305444-105 FOAM INSULATOR EA 51305444-400 FOAM ISOLATION EA 51305444-403 FOAM ISOLATION EA 51305444-500 ISOLATOR FOAM EA 51305444-800 FOAM INSULATOR EA 51305447-100 WEDGE ASSY EA 51305447-200 WEDGE ASSY EA 51305450-400 AC POWER CABLE EA 51305450-500 AC PWR CORD EA 51305450-600 PWR CBL, LWR CRT EA 51305450-700 PWR CBL CRT EA 51305450-800 PWR CBL CRT EA 51305451-400 POWER CORD EA 51305451-500 TPS100 POWER CORD EA 51305458-100 FRONT PANEL EA 51305459-100 GROUND STRAP EA 51305464-100 EXT PER PWR CBL EA 51305465-100 IKB EXTENDED CABLE EA 51305467-100 EMC SHIELD EA 51305469-800 TREND POWER CABLE EA 51305474-100 GUS EXT. ANN. RELAY PWA EA 51305478-100 RMT PRPH I/F ASM EA 51305480-100 EMI DR BLNK ASSM EA 51305482-102 2M 100BT YEL BOOT EA 51305482-105 5M 100BT YEL BOOT EA 51305482-110 10M 100BT YEL BOOT EA 51305482-120 20M 100BT YEL BOOT EA 51305482-150 50M 100BT YEL BOOT EA 51305482-175 75M 100BT YEL BOOT EA 51305482-199 99M 100BT YEL BOOT EA 51305482-202 2M 100BT GRN BOOT EA 51305482-205 5M 100BT GRN BOOT EA 51305482-210 10M 100BT GRN BOOT EA 51305482-220 20M 100BT GRN BOOT EA 51305482-250 50M 100BT GRN BOOT EA 51305482-275 75M 100BT GRN BOOT EA 51305482-299 99M 100BT GRN BOOT EA 51305482-502 CAT5 ScTP ETHERNET CABLE - 2M EA 51305482-503 CAT5 ScTP ETHERNET CABLE 3M EA 51305482-505 CAT5 ScTP ETHERNET CABLE 5M EA 51305482-510 CAT5 ScTP ETHERNET CABLE - 10M EA 51305482-520 CAT5 ScTP ETHERNET CABLE - 20M EA 51305482-530 CAT5 ScTP ETHERNET CABLE - 30M EA 51305482-550 CAT5 ScTP ETHERNET CABLE -50M EA 51305482-599 CAT5 ScTP ETHERNET CABLE -99M EA 51305483-100 MNTG BRK ZIP DRIVE EA 51305489-600 EC/SHLDED PWR CORD 240VAC EA 51305490-600 EC/SHLDED PWR CORD 120VAC EA 51305492-100 GROUNDED TERMINATOR EA 51305503-100 EMI DRIVE SHIELD EA 51305508-100 PWA, XLCNE2 Multimode, Non-CE EA 51305508-200 PWA, XLCNE2 Multimode, CE EA 51305529-100 NON RESTRAINT BRACKET EA 51305538-100 DESKSIDE CD SCSI CBL EA 51305542-100 A/C POWER CORD EA 51305543-200 A/C POWER CORD EA 51305543-300 A/C POWER CORD EA 51305544-200 POWER CORD EA 51305544-300 POWER CORD EA 51305547-100 RT ANGLE CASCADE CBL EA 51305548-100 DC POWER CABLE EA 51305554-100 Cable 50 FT/15.2M EA 51305554-200 Cable 100FT/30.5M EA 51305554-300 Cable 200FT/61M EA 51305559-100 SCSI CABLE EA 51305562-400 .5M 100BT BLK BOOT EA 51305562-402 2M 100BT BLK BOOT EA 51305562-405 5M 100BT BLK BOOT EA 51305562-410 10M 100BT BLK BOOT EA 51305562-420 20M 100BT BLK BOOT EA 51305562-450 50M 100BT BLK BOOT EA 51305562-475 75M 100BT BLK BOOT EA 51305562-499 99M 100BT BLK BOOT EA 51305564-100 PS/S CABLE W/FERRITES EA 51305568-100 I/R WINDOW EA 51305568-200 I/R WINDOW EA 51305569-100 T/S CABLE(SONY) EA 51305579-100 MON RESTRAINT BRKT EA 51305585-100 CRT SHROUD SPACER EA 51305587-100 GUS LOWER FRONT BEZEL ASSY EA 51305588-100 LOWER FRONT BEZEL ASSM EA 51305589-100 UPPER FRONT BEZEL ASSM EA 51305590-100 FRONT BEZEL ASSY-OEP, W/FLR PNL OPNG EA 51305591-100 2ND HARD DRIVE CABLE EA 51305594-100 CABLE, T/S EXT. 5 FT EA 51305704-100 TS IF CBL 6' EC EA 51305722-001 Cable, Jumper 100 Micron 1M EA 51305722-002 Cable, Jumper 100 Micron 2M EA 51305723-001 Cable, Dual 62.5mic Fiber Optic Jumper, 1m EA 51305723-002 Cable, Dual 62.5mic Fiber Optic Jumper, 2m EA 51306152-400 SMT FRME CBL EA 51306154-100 UPIU PWA ASSY EA 51308003-100 C/F AIR FILTER EA 51206056-100 51308012-100 PWB, PW DIST 120 EA 51308014-100 PWR DIST PWB 240V EA 51308015-100 BUMPER BRACKET EA 51308019-100 AC PWR 120V,16IN CBL EA 51308020-100 UPPER MONITOR PWR CABLE EA 51308020-200 MONITOR AC POWER CABLE EA 51308021-100 DIST BTP HARNS EA 51308033-100 FLEXIBLE SPACER BTT M EA 51308035-100 MANIFOLD BOARD EA 51308036-100 FLEXIBLE SPACER - T OP EA 51308037-100 TIE PLATE-ARC EA 51308038-100 FLEXIBLE SPACER - I N LINE EA 51308039-100 COVER MTG. BRACKET EA 51308042-100 FACADE, NAMEPLATE EA 51308046-100 ACCESS COVER BLANK EA 51308047-100 CABLE, TOUCH SCR EA 51308050-100 A/C DIST. BRACKET EA 51308051-200 PS ENCL CBL EA 51308052-200 PS ENC AC CBL EA 51308053-100 CBL, PERF PS A/C EA 51308020-200 51308054-100 AC P/E 120V CBL EA 51308055-100 CBL, DRV DC PWR EA 51308055-200 51308055-200 CBL, DRV DC PWR EA 51308055-300 CBL, DRV DC PWR EA 51308056-100 TIE PLATE - IN LINE EA 51308058-100 KYBD I/F CBL EA 51308058-200 KYBD I/F CBL EA 51308059-100 MANIFOLD KB I/C CAB LE EA 51308060-100 ENG KYBD I/F CBL EA 51308061-100 UCN TAP BRACKET EA 51308065-100 T/S CONTRL ASM EA 51308067-100 AC PWR ENTRY CBL (2 40V) EA <, BR>51308069-200 TREND PWR CBL 240V EA 51308070-200 TREND PWR CABLE 120V EA 51308072-100 BEZEL BLANK PLATE EA 51308073-100 TRACKBALL I/C CBL EA 51308075-100 DIST ASM,TREND EA 51308076-200 CBL,TRND REC I/F EA 51308076-400 CBL, TREND REC EA 51308076-500 TREND REC I/F CABLE 15FT EA 51308077-300 CBL, TR I/F JMPR EA 51308077-301 CBL, TDR I/F EA 51308077-600 TREND I/F JUMPER CABLE EA 51308078-300 TREND JUMPER CABLE EA 51308078-301 CBL, TP JMPR EA 51308079-300 TREND REC JMPR EA 51308079-301 TDR PWR JUMPER EA 51308080-200 CBL, CART DR EA 51308080-500 51308080-400 CBL, CART DR EA 51308080-500 CBL, CART DR EA 51308080-600 CBL, CART DR EA 51308080-700 CRT/DAT DRVE CBL EA 51308082-100 MOUSE I/C CBL EA 51308083-200 CABLE, HD DRIVE EA 51308084-200 HD W/DAT CABLE EA 51308086-101 SAFETY BARRIER EA 51308086-201 CF SAFETY BARRIER EA 51308086-202 CF SAFETY BARRIER EA 51308087-200 AC FAN POWER CABLE EA 51308092-100 CBL, AC PWR EA 51308092-200 P/S 120/220 EC EA 51308092-300 PWR CBL EA 51308092-400 CBL, PWR 36IN EA 51308092-500 CBL,AC PWR 48IN EA 51308092-600 CBL, AC PWR 72IN EA 51308092-700 POWER CORD 120IN (EC) EA 51308093-100 CBL, AC PWR 16IN EA 51308093-300 51308093-200 CBL, AC PWR 24IN EA 51308093-300 PWR CORD 120V EC 35" EA 51308093-400 CBL, AC PWR 36IN (ORDER -300) EA 51308093-500 CBL, AC PWR 48IN EA 51308093-600 CBL, AC PWR 72IN EA 51308093-700 CBL, AC PWR 120IN EA 51308093-800 POWER CORD 92IN (EC) EA 51308094-300 PWR CORD, 220V EA 51308094-400 PWR CBL 36IN AC CLASSIC EA 51308094-300 51308094-500 PWR 240V CBL CLASSIC FURN EA 51308094-600 PWR CBL 220V 72IN CLASSIC FURN EA 51308094-800 POWER CORD 92IN (EC) EA 51308095-100 PWA, INTERFACE CABLE EA 51308097-100 IKB TO T/S CBL EA 51308097-200 CBL, T/S I/F EA 51308098-100 CBL, TWR TO JWR EA 51308098-101 CBL, TP485 T-5 EA 51308098-200 CBL, TWR TO TWR EA 51308098-201 CBL, TP485 T-T EA 51308099-100 CBL,EPDGC/MO 30IN EA 51308099-200 CBL,EPDGC/MO 36IN EA 51308099-300 CBL,EPDGC/MO 48IN EA 51308099-400 CBL,EPDGC/MO 21IN EA 51308101-100 CBL, TPDGC I/F EA 51308101-200 CBL, TPDGC I/F EA 51308101-300 CBL, TPDGC I/F EA 51308102-100 CBL, TPDGC I/F EA 51308102-200 CBL, TPDGC I/F M/TB/TS EA 51308102-300 CBL, TPDGC I/F M/TB/TS EA 51308103-003 CBL, PTR (3M) EA 51308103-008 CBL, PTR (8M) EA 51308103-015 CBL, PTR (15M) EA 51308104-100 CBL, LCN KEYBD EA 51308105-100 CBL, KYBD I/F EA 51308105-200 CBL, KYBD I/F EA 51308105-400 K/B IC TO TPD EA 51308106-100 RS232 CABLE 50FT EA 51308107-100 ANNUNC. CABLE EA 51308108-100 CABLE, DESKSIDE GUS ANNC. Y- EA 51308109-100 CBL, CRTG DC EA 51308109-300 DC PWR CBL 14IN EA 51308110-100 CBL, CRTG DC PWR EA 51308110-200 CBL, CRTG DC PWR EA 51308111-002 LCN COAX CBL SET 2M EA 51308111-003 CBL COAX SCT(3M) SEE NOTES EA 51308112-003 LCN COAX CBL SET 3M EA 51308112-005 LCN COAX CBL SET 5M EA 51308112-008 LCN COAX CBL SET 8M EA 51308112-010 LCN COAX CBL SET 10M EA 51308112-015 LCN COAX CBL SET 15M EA 51308112-020 LCN COAX CBL SET 20M EA 51308112-025 LCN COAX CBL SET 25M EA 51308112-030 LCN COAX CBL SET 30M EA 51308112-050 LCN COAX CBL SET 50M EA 51308112-060 LCN COAX CBL SET 60M EA 51308112-075 LCN COAX CBL SET 75M EA 51308112-080 LCN COAX CBL SET 80M EA 51308112-100 LCN COAX CBL SET 100M EA 51308112-125 LCN COAX CBL SET 125M EA 51308112-150 LCN COAX CBL SET 150M EA 51308112-200 LCN COAX CBL SET 200M EA 51308112-250 LCN COAX CBL SET 250M EA 51308112-300 LCN COAX CBL SET 300M EA 51308113-102 CBL FIBER OPTIC EA 51308114-100 TS I/F CBL EA 51308115-100 CBL, T/S I/F EA 51308117-100 CBL, P/S AC EA 51308118-100 CBL, FAN DC PWR EA 51308119-100 CBL, TPDDC I/O EA 51308119-200 TP PGC I/O CBL EA 51308120-002 CBL, ENH CRT EA 51308120-003 CBL, CRT DATA EA 51308121-100 DIST HARNESS EA 51308123-100 CBL, SMART FRAME EA 51308123-200 SMT FRAME CBL EA 51308123-300 CBL, SMART FRAME EA 51308123-400 SMART FRAME CABLE E C EA 51308124-100 CBL, NI ADAPTER EA 51308125-100 CBL, CART DR PWR EA 51308126-100 CBL, KEYBD IF EA 51308129-100 CBL, CART DR PWR EA 51308129-200 51308129-200 SN CART DRV PWR CBL EA 51308130-100 CBL, CD PWR EA 51308132-100 RULA SCSI CBL EA 51308132-200 RULA SCSI CBL EA 51308132-300 RULA SCSI CBL EA 51308133-100 RULA DC ADAPTER CAB LE EA 51308134-100 DC TWR PR CBL EA 51308135-100 RULA TRANSCVR CABLE EA 51308136-100 RULA XCVR CBL EA 51308137-200 RULA SCSI CBL EA 51308138-100 AUI THINK CBL EC EA 51309101-100 RHIO ASSM 1-7L EA 51309101-200 RHIO ASSM 9-15 R EA 51309101-300 RHIO ASSM W/O PS L MU-CBSS11 EA 51309101-400 RHIO ASSM W/O PS R MU-CBSS12 EA 51309101-500 RHIO ASSM 1-7 L 220V EA 51309101-600 RHIO ASSM 1-15R 220V EA 51309107-100 TRIM, HPM LF1-7 EA 51309107-200 TRIM, HPM RT9-15 EA 51309123-100 HPM FUSE PULLER EA 51309136-125 FTA, 6IN HLAI, COMP CE MU-TAIH03 EA 51309136-175 FTA, 6IN HLAI, CE, CC EA 51309138-125 FTA, 12IN HLAI COMP, CE EA 51309138-175 FTA, 12IN HLAI COMP, CE, CC EA 51309138-225 FTA, 12IN HLAI SCREW, CE EA 51309138-275 FTA, 12IN HLAI SCREW, CE, CC EA 51309140-125 FTA, 6IN STI, CE MU-TSTX03 EA 51309140-175 FTA, 6IN STI, CE, CC EA 51309142-125 FTA, 12IN STI COMP, CE MU-TSTX13 EA 51309142-175 FTA, 12IN STI COMP, CE, CC EA 51309142-225 FTA, 12IN STI SCREW, CE EA 51309142-275 FTA, 12IN STI SCREW, CE, CC EA 51309148-125 FTA, 120V RELAY DO COMP, CE MU-TDOR12 EA 51309148-175 FTA, 120V RELAY DO COMP, CE, CC EA 51309148-225 FTA, 120V RELAY DO SCREW, CE EA 51309148-275 FTA, 120V RELAY DO SCREW, CE, CC EA 51309150-125 FTA, 240V RELAY DO COMP, CE EA 51309150-175 FTA, 240V RELAY DO COMP, CE, CC EA 51309150-225 FTA, 240V RELAY DO SCREW, CE EA 51309150-275 FTA, 240V RELAY DO SCREW, CE, CC EA 51309152-125 PWA, AO/IOP (EC)(CC) EA 51309152-175 51309152-175 PWA, AO/IOP (EC)(CC) EA 51309153-125 FTA, 3/30VDC DO COMP, CE EA 51309153-175 FTA, 3/30VDC DO COMP, CE, CC EA 51309153-225 FTA, 3/30VDC DO SCREW, CE EA 51309153-275 FTA, 3/30VDC DO SCREW, CE, CC EA 51309154-125 FTA, 31/200VDC DO COMP, CE EA 51309154-175 FTA, 31/200VDC DO COMP, CE, CC EA 51309154-225 FTA, 31/200VDC DO SCREW, CE EA 51309154-275 FTA, 31/200VDC DO SCREW, CE, CC EA 51309156-125 G/I PNL SCR TERM EA 51309156-175 PNL,GI FTA MAR EA 51309202-125 FTA MOTHERBOARD, LLAI-8 CE MU-TAIL03 EA 51309202-175 FTA MOTHERBOARD, LLAI-8 CE, CC EA 51309204-125 FTA, LLMUX/SDI/SI PWR ADAPTER EA 51309204-175 FTA, LLMUX/SDI/SI PWR ADAPTER, CC EA 51309206-125 CHARGER, UNIV PM EA 51309206-175 CHGR, UNIV PM CC EA 51309208-100 PWA, FIB OPT 5KM EA 51309208-150 PWA, FIB OPT 5KM, CC EA 51309210-125 LLMUX TC DAUGHTERBOARD EA 51309290-125 51309210-175 LLMUX TC DAUGHTERBOARD, CC EA 51309290-175 51309213-125 FTA, LLMUX TC W/RCJR, CE MU-TAMT13 EA 51309213-175 FTA, LLMUX TC W/RCJR, CE, CC EA 51309218-125 FTA, LLMUX RTD, CE MU-TAMR03 EA 51309218-175 FTA, LLMUX RTD, EC, CC EA 51309222-125 order 51309223-125 EA 51309223-125 51309223-125 FTA, LLMUX TC, EC MU-TAMT03 EA 51309223-175 FTA, LLMUX TC, EC, CC EA 51309228-200 FLR PNL (GREY) EA 51309228-300 FLR PNL (BEIGE) EA 51309250-100 RH MUX NEMA4 SS MU-CMSS03 EA 51309250-200 RH MUX NEMA4 SC MU-CMSC03 EA 51309254-125 FIELDBUS I/F FTA, 4 Nets MU-TFBS01 EA 51309254-125MOD MODIF FIELDBUS I/F FTA (INCL 2 PS MTL4053) EA 51309254-175 FIELDBUS I/F FTA, 4 Nets EA 51309254-225 GI/IS FBUS I/F FTA, 4 NETS MU-GFBS01 EA 51309254-275 GI/IS FBUS I/F FTA, 4 nets MU-TFBS11 EA 51309254-325 FIELDBUS I/F FTA, 4 Nets, No PWR Cond EA 51309254-375 FIELDBUS I/F FTA, 4 Nets, No Pwr Cond EA 51309266-100 MTG BRACKET UCNE EA 51309276-150 HPM I/O LINK CC EA 51309280-100 LLAI-8 MOD, EC EA 51309290-125 LLMUX TC DAUGHTER EC EA 51309290-175 LLMUX TC DAUGHTER EC CC EA 51309335-100 HPM GRD CVR, EXTNDE R EA 51309335-200 HPM GRD CVR, EXTNDE R EA 51309510-125 FIELDBUS I/F Processor, 4 Nets EA 51309510-175 51309510-175 FIELDBUS I/F PROCESSOR, 4 NETS CC MC-PFBS01 EA 51309540-125 AO GI/IS FTA (16), HART EA 51309540-175 AO GI/IS FTA (16), HART CC EA 51309542-125 AO FTA (16), HART EA 51309542-175 AO FTA (16), HART CC EA 51309562-100 V-TRIM LEFT W/O BRKR EA 51309562-200 V-TRIM RIGHT W/O BRK EA 51309562-300 V-TRIM LEFT W/BREAKER BOX EA 51309563-100 TOP TRIM W/O BRKR EA 51309564-100 Trim Bottom W/Breaker EA 51309564-200 TRIM BOTTOM W/BRKR EA 51400373-100 PWR SUP SUPPORT EA 51400441-102 P.S. ASSEMBLY EA 51400621-100 SMALL FAN BRACKET EA 51400646-100 FAN ASSY,5 SLOT EA 51400647-100 FAN ASSY,10 SLOT EA 51400647-200 FAN ASSY, MICRO EA 51400666-100 PWA, PERIPH I/F EA 51400667-100 PWB, ENH LCN EA 51401291-100 51400670-100 10 SLOT POWER SUPPLY EA 51201436-400 51400671-100 5 SLOT POWER SUPPLY EA 51201436-300 51400700-100 PWA, DATA HIWAY I/F EA 51400705-100 WHITE SHROUD W/HOLES EA 51400705-200 WHITE SHROUD W/O HOLES EA 51400705-300 BEIGE SHROUD W/HOLES EA 51400705-400 BEIGE SHROUD W/O HOLES EA 51400706-100 BLUE LOWER REAR COVER EA 51400706-200 GRAY LOWER REAR COVER EA 51400712-100 5 SLOT PWR SPLY EA 51201436-300 51400712-200 10 SLOT POWER SUPPLY EA 51201436-400 51400738-100 SUPPORT, TABLE TOP EA 51400738-200 TABLE TOP SUPPORT EA 51400751-100 LOW PROFILE ENG EA 51400751-100REP LOW PROFILE ENG KYBD EA 51400756-100 KYBD, ABCDE MEMBRANE FOR US, UWS AND MICRO EA 51400759-100 KYBD INSERT,WHIT EA 51400760-100 AC ENTRY 120V EA 51402618-120 51400760-200 AC ENTRY 230V EA 51402618-230 51400764-100 FAN ASSM,5 SLOT EA 51400646-100 51400776-100 PWR ENTRY COVER EA 51400777-100 CRT MT CHASSIS EA 51400777-200 CRT MT CHASSIS EA 51400779-100 MTG BRCKT, U/T EA 51400781-100 U/CRT SHROUD, WHITE EA 51400781-200 SHROUD UPPER PD EA 51400782-100 REAR COVER U/T EA 51400782-200 COVER, UPPER CRT EA 51400783-100 ENG KYBD SUPPORT EA 51400784-100 REPLACEMNT KBD TRAY/ NO HARDWARE EA 51400785-100 BEZEL, UPPER CRT EA 51400786-100 BEZEL, L/T CRT EA 51400786-200 BEZEL, LOWER EA 51400788-100 COVER, ENG KYBD WHITE EA 51400788-200 COVER, ENG KYBD BEIGE EA 51400788-300 COVER, ENG KYBD BLACK EA 51400792-100 HALF-POD SHROUD EA 51400792-200 HALF HEIGHT SHROUD EA 51400793-100 HALF-POD R COVER EA 51400793-200 HALF HEIGHT COVER EA 51400794-100 MTG PLATE, FDD EA 51400795-100 FDD FRONT PLATE EA 51400797-100 HALF-POD BEZEL EA 51400808-100 PWR ENTRY 120V EA 51402619-120 51400808-200 PWR ENTRY 230V EA 51402619-230 51400810-100 TABLE TOP FULL WHITE EA 51400810-200 TABLE TOP FULL- BEI GE EA 51400810-300 TABLE TOP FULL BLK EA 51400812-100 TBL TOP SUPPORT EA 51400813-100 TBL TOP SUPPORT EA 51400816-100 FLOPPY TABLE TOP EA 51400816-300 TABLE FLOPPY EA 51400816-500 FLOPPY TABLE BLACK EA 51400817-100 FLOPPY SUPPORT PLAT E EA 51400819-100 REAR SKIRT, FLOPPY EA 51400819-200 REAR FLOPPY SKIRT EA 51400821-100 ENG KYBD ASSEMBLY EA 51400822-100 TOUCH SCREEN EA 51400822-200 51400822-200 19IN TOUCHSCREEN - OBSOLETE EA 51400850-100 FLOPPY MTG BRACKET EA 51400850-200 FLOPPY MTG BRACKET EA 51400851-100 FLOPPY MTG SLIDE EA 51400851-200 FLOPPY MTG SLIDE EA 51400855-100 PWB, SIO (TREND) EA 51400859-100 SLIDE CHASSIS EA 51400860-100 HALF HEIGHT BRACKET EA 51400860-200 HALF HEIGHT BRACKET EA 51400862-200 HALF HGHT FRONT PNL EA 51400863-200 FULL HGHT FNT PNL EA 51400864-100 FULL HEIGHT BRACKET EA 51400864-200 FULL HEIGHT BRACKET EA 51400865-100 TR PWR I/F 120V EA 51400865-400 TR PWR I/F 240V EA 51400866-100 BEZEL, UPPER CRT EA 51400867-100 CRT TRAY EA 51400868-100 CRT PNL SUPPORT EA 51400868-200 CRT PANEL SUPPOR EA 51400869-100 BLANK PANEL EA 51400870-100 BLANK HALF PANEL EA 51400870-200 BLANK FULL PANEL EA 51400891-200 REAR DOOR BEIGE EA 51400892-100 FRONT SKIRT EA 51400892-200 FRONT SKIRT EA 51400893-100 CONSOLE SKIRT EA 51400893-200 CONSOLE SKIRT EA 51400901-100 PWB, EMPU CPU EA 51400902-100 T-SCR VER-WINDOW EA 51400902-200 T-SCR HOR-WINDOW EA 51400902-300 BEZEL, VERTICAL EA 51400902-400 BEZEL,HORIZONTAL EA 51400902-500 VERTICAL BEZEL,SMT TCH SC EA 51400902-600 HORIZONTAL BEZEL,SMT TCH SC EA 51400910-100 PWB, EMEM 1MW EA 51400918-100 5 SLOT MOD COVER EA 51400919-100 10 SLOT COVER EA 51402620-100 51400926-100 PWB, ENH PDG EA 51401286-100 51400955-100 PWB, PNI EA 51400958-001 CABINET FRAME WI EA 51400972-100 PWB, KEYBD, I/F EA 51401570-100 51400972-200 PWB, KYBD I/F EA 51401570-200 51400972-300 PWB, KYBD I/F EA 51401570-100 51400978-100 2MW HYPER KERNEL HMPU EA 51400988-100 SMART TOUCHSCREEN EA 51400988-200 51400988-200 TOUCHSCREEN (EC) EA 51400989-100 OPER KYBD ASSY EA 51400989-200 US OPER KYBD ASY EA 51400989-300 KEYBOARD EA 51400989-400 51400989-400 KEYBOARD EA 51400989-500 ABC KYBD EC EA 51400990-100 KEYBD, UNIV W.S. EA 51400993-100 OPR KYBD W/INTF EA 51400993-400 OPR KYBD W/INTFC EA 51400997-100 PWA, PLC(培训)I EA 51400997-200 PWA, ENH PLC(培训)I EA 51401052-100 PWA, SPCI EA 51401056-100 FILE & BPLANE EA 51401070-100 PWB, AMC REDUND EA 51401072-100 PWA, QMEM 1MW EA 51400910-100 51401072-200 PWB, QMEM 2MW EA 51401072-300 PWB, QMEM 3MW EA 51401072-400 PWB, QMEM 4MW EA 51401074-100 LCN FLOPPY TRAY EA 51401074-200 MTG TRAY FLPY-EC CL EA 51401088-100 PWB, CNI (See note field) EA 51401107-100 FTA, LL A/I DIN EA 51198964-100 51401135-100 PWB, REDUNDANT P/S 115V EA 51401135-150 PWA, 115V RED EA 51401135-200 PWB, P.S. 115VAC EA 51401135-250 51401135-250 PWA, 115V NONRED EA 51401135-300 P/S 240 8A RED EA 51401135-350 PWA, 230V REDUNDANT EA 51401135-400 PWB, 230 V NON-REDUNDANT EA 51401135-450 PWA,230V, NONRED EA 51401140-100 AC ONLY P/S-RED 115V16 AMP MU-PAS121 EA 51401140-150 P/S N RED 115V 16AMP EA 51401140-200 AC ONLY PS-RED 120V 16AMP EA 51401140-250 P/S RED 115V 16AMP CC EA 51401140-300 AC ONLY PS-SGL 240V 16AMP EA 51401140-350 P/S N RED 230V 16AMP CC EA 51401140-400 AC ONLY PS-RED 240V 16AMP EA 51401140-450 P/S RED 230V 16AMP CC EA 51401140-500 AC ONLY PS-SGL 120V 8AMP EA 51401140-550 P/S N-RED 114V 8AMP EA 51401140-600 AC ONLY PS-RED 120V 8AMP MU-PAR111 EA 51401140-650 R/S RED 115V 8AMP EA 51401140-700 AC ONLY PS-SGL 240V 8AMP EA 51401140-750 P/S N RED 230V 8AMP EA 51401140-800 AC ONLY PS-RED 240V 8AMP EA 51401140-850 P/S RED 230V 8 AMP CC EA 51401151-100 ENH TERM PANEL EA 51401157-100 MODULE,D/O S.S. See note field EA 51401163-100 PWA, NIM MODEM EA 51195760-100 51401166-100 PWR SYSTEM BCKPN EA 51401166-150 PS PWB ASSY EA 51401168-200 PS CHASSIS ASSM EA 51404170-125 51401183-100 FTA, LL A/I,DIN EA 51198964-100 51401186-100 FTA,120VAC D/I See Note Field EA 51401191-100 MODULE, D/O FTA See note field EA 51401194-100 MOD, D/O FTA See note field EA 51401201-100 MODULE,24VDC D/I See Note Field EA 51401212-100 FTA, LL A/I,DIN EA 51198964-100 51401214-100 CHASSIS, PWR SYS EA 51401216-100 CHASSIS, PWR SYS EA 51401216-150 POWER SYSTEM CAGE CC EA 51401220-100 MODULE, D/O S.S. See note field. MU-TDOD11 EA 51401223-100 MOD,SS D/O FTA See Note field EA 51401233-100 BEZEL, PWR SPLY EA 51401235-100 PWR SYS BACKPLANE EA 51401238-100 PWR SYS TERM PNL EA 51401246-100 FTA MTG CHANNEL, WIDE RITTAL EA 51401246-200 FTA MTG CHANNEL, NARROW RITTAL EA 51401248-200 BATTERY ASSM EA 51303948-100 51401248-300 48V BATTERY ASSY EA 51303948-100 51401277-100 A/O STANDBY ASSM MU-SMAC01 EA 51401277-200 A/O ST-BY MANUAL MU-SMAC02 EA 51401286-100 PWB, ENH PDG EA 51401286-100EXCH PWA, Enh PDG (Repair/Exchange Only) EA 51401288-100 PWA, HPK2-2MW EA 51401288-200 PWA, HPK2-3MW EA 51401289-100 ENCLOSURE MODIFIED EA 51401291-100 PWB, ENH LCN EA 51401291-100EXCH PWA, ENH LCN (REPAIR/EXCHANGE ONLY) EA 51401303-100 HOOTER ASSY,115V EA 51401303-100A 51401303-100A HOOTER ASSM, CLASSIC FURN, 115V RG-PHA01-100 EA 51401303-200 HOOTER 220V EA 51401303-200A 51401303-200A HOOTER ASSM, CLASSIC FURN, 230V RG-PHA01-200 EA 51401303-300 Z HOOTER, 115V EA 51401303-300A 51401303-300A HOOTER ASSM, Z FURN, 115V RG-PHA01-300 EA 51401303-400 Z HOOTER,220V EA 51401303-400A 51401303-400A HOOTER ASSM, Z FURN, 230V RG-PHA01-400 EA 51401364-100 LLAI MUX MODULE EA 51309218-125 51401370-200 FRONT DOOR BEIGE EA 51401381-100 5 SLOT BACKPANEL EA 51401414-100 2 SLOT BKPNL SUPPOR T EA 51401436-101 KEYBOARD COVER EA 51401436-200 KEYBOARD ENCLOSURE EA 51401437-100 ENH UWS KYBD ASY EA 51401437-300 ENH UWS KYBD ASY EA 51401437-301 ENH UWS KYBD ASY EA 51401437-400 ENH OP/KYBD ASSY EA 51401449-100 CABLE, HARNESS EA 51401457-100 OPERATOR KYBD ASSY INCL KYBD, PWA & CABLES EA 51401469-100 KIT EA 51402184-100 51401473-100 2 NODE FAN PWA EA 51401477-100 3/2 BKPNL ASM EA 51401484-100 BACKPANEL SUPPORT EA 51401486-100 2-NODE MOD COVER EA 51401491-100 FTA,LLAI TC MUX EA 51309223-125 51401491-150 FTA,TC MUX (CC) EA 51309223-175 51401496-100 FAN ASSM, 2 NODE EA 51401497-100 KIT, D.N. P/S EA 51402184-100 51401512-100 PM CAB DUAL ACCESS EA 51401513-120 RITTAL SINGLE CAB EA 51401523-100 SPARE FILE ASSM EA 51198949-150 51401524-100 SPARE FILE ASSY EA 51198948-150 51401525-100 SPARE FILE ASSM EA 51198950-150 51401526-100 PS BEZEL LABEL EA 51401529-100 FTA MTG CHANNEL, NARROW MARKHON EA 51401529-200 FTA MTG CHANNEL, WIDE MARKHON EA 51401531-100 PM FILE FAN ASSY EA 51401546-100 15 SLOT I/O EA 51404127-200 51401546-150 15 SLOT I/O CC EA 51404127-250 51401547-100 SPARE FILE ASSY EA 51401617-150 51401547-150 SPARE FILE ASSM EA 51401617-150 51401548-100 SPARE FILE 5 SLOT EA 51401616-150 51401551-200 PWA, K2LCN 2MW EA 51401551-201 PWA, K2LCN 2MW EA 51401551-300 PWA, K2LCN 3MW EA 51401551-301 51401551-301 PWA, K2LCN 3MW EA 51401551-400 PWA, K2LCN 4MW EA 51402615-400 51401551-401 PWA, K2LCN 4MW EA 51402615-400 51401551-600 PWA, K2LCN 6MW EA 51401551-601 51401551-601 PWA, 6MW K2LCN EA 51401551-800 PWA, K2LCN 8MW EA 51401551-801 PWA, K2LCN 8MW EA 51402615-800 51401560-100 KYBD,QWERTY MEMBRANE FOR US, UWS AND MICRO EA 51401564-100 PWB,TC MUX DAUGH EA 51309223-125 51401570-100 PWB, KYBD I/F EA 51401570-200 PWB, KYBD I/F NO ANNUN LOGIC OR ALARM LEDS EA 51401573-100 FTA, LLAI TC MUX EA 51309213-125 51401573-150 FTA,TC MUX (CC) EA 51309213-175 51401577-100 QWERTY KYBD KIT EA 51401577-300 OPER KYBD ASM EA 51401577-500 51401577-400 QWERTY KYB EA 51401577-500 CLASSIC OPERATOR KEYBOARD EA 51401577-600 OPER KYBD ASSM (PACE) EA 51401583-100 PWB, EPNI EA 51401583-200 PWB, NGI EA 51401594-100 PWB, KJUMP(PCIM) EA 51401594-200 PWB, KJUMP EA 51401596-100 PLC(培训)G RLY MTG PLATE INCLUDES MTG BRACKETS EA 51401596-200 PLC(培训)G RLY MTG PLATE DOES NOT INCLUDE BRACKETS EA 51401604-100 BEIGE SGL CAB EA 51401605-100 MARKHON DUAL CAB (BEIGE) EA 51401605-102 DUAL ACCESS CAB (BL UE) EA 51401616-100 CARD FILE 5 I/O EA 51401616-150 51401616-150 5 IOP FILE (CC) EA 51401617-100 PM/APM FILE 10 I/O EA 51401617-150 51401617-150 FILE,PM 10SLT IO EA 51401618-100 15 SLOT I/O EA 51404127-200 51401618-150 FILE 15 I/O CC EA 51404127-250 51401621-100 FTA CHAN HORIZ MU-TMHN01 EA 51401635-100 COM/CONTROLLER EA 51401635-150 51401635-150 HPM COM/CONTRLR EA 51401639-100 UCN I/F EA 51402573-150 51401639-150 HPM UCN I/F EA 51402573-150 51401642-100 HPM I/O LINK EA 51309276-150 51401642-150 HPM I/O LINK EA 51309276-150 51401698-100 UxS KEYBOARD TRAY EA 51401699-100 UxS TRAY SLIDE EA 51401748-100 TRACKBALL ASSY EA 51401748-200 USX TRACKBALL CONSOLE MOUNT EA 51401748-300 TRACKBALL ASSY EA 51401782-200 C/F 3/3/2/2 SPR EA 51196730-100 51401913-100 MICRO TOUCHSCRN EA 51195992-100 51401914-100 PWA, GGSI (R400) EA 51401917-100 DRIVE TRAY EA 51401929-300 SPARE WD TRAY EA 51401930-100 WDA ENCL ASSM EA 51305366-100 51401946-100 K4LCN Motherboard EA 51401946-100EXCH K4LCN Motherboard (Repair/Exchange Only) EA 51401952-100 OEP PWA EA 51401952-200 KYBD I/F ASSY EA 51401952-300 KEYBOARD ASSM FOR P ACE EA 51401975-100 ENG KYBD, GRAY ROVING EA 51196712-200 51401979-100 KYBD TEMPLATE (QTY 1) EA 51401996-100 EARM ASSY EA 51402000-200 TPDG ASSY EA 51402004-100 HALF HGT REAR CVR BIG EA 51402004-200 HALF HGT REAR CVR BIG EA 51402005-100 FULL HGT REAR CVR BIG EA 51402005-200 FULL HGT REAR CVR BIG EA 51402023-100 PWR I/F CHS,120V IN T EA 51402023-200 PWR IF/ CHS 240V IN T EA 51402023-400 PWR I/F CHS 240V EXT EA 51402030-100 WSI ASSY, 16MB EA 51402030-200 WSI ASSY, 32MB EA 51402041-300 FAN 1/2 HGT ASSM 120V EA 51402041-400 FAN 1/2 HGT ASSM240V EA 51402041-500 FAN 85-250V EA 51402041-600 FAN 85-250V EA 51402042-500 FAN HGT ASM EA 51402075-100 KEYBOARD EA MP-ZEKBF1-100 51402083-100 WSI2, 64MHZ W/O GRAPH EA 51402083-200 WSI2, 100MHZ W/O GRAPH EA 51402083-300 WSI2, 64MHZ W/GRAPH EA 51402083-400 WSI2, 100MHZ W/GRAPH EA 51402089-100 PWA, EPDG2 EA 51402157-100 10 SLOT CARD FILE EA 51402166-100 5 SLOT CARD FILE EA 51402167-100 DUAL NODE CARD FILE EA 51402172-100 UNIVERSAL I/O EC 5 SLOT EA 51402173-100 I/O CARD FILE 10SLOT EA 51402176-100 TRAY, HDDT EA 51402184-100 KIT, D.N. P/S EA 51402184-200 KIT, 5 SLOT P/S EA 51402184-300 KIT, 10 SLOT P/S EA 51402187-100 CART DRIVE BRACKET EA 51402705-100 51402188-100 COVER, CART DRV EA 51402199-100 ENH 5 SLOT CARD FIL E EA 51402447-100 PWB, EPDGC I/O EA 51402447-200 PWA, EPDGC I/O EA 51402453-100 CARD FILE 5 SLOT EA 51402453-200 5 SLT CD FILE XC300 0 EA 51402454-100 DUAL NODE I/O EA 51402455-100 2 NODE CFA EA 51402457-200 DUAL NODE FILE ASSM EA 51402471-200 BLUE CABINET 77 IN EA 51402471-201 CABINET FRAME EA 51402486-100 INCORRECT LEVEL EA 51402486-300 525MB W/O SFTWR EA 51402486-800 51402486-600 2GB W/O SOFTWARE EA 51402486-800 51402486-800 4GB HARD DRIVE W/O SFTW EA 51402491-100 CD FILE ASSM EA 51402492-100 10 SLT MOD COVER EA 51402493-100 HD DISK TRAY ASSM E C EA 51402497-100 ENH OP KB ASSY EA 51402573-100 HPM UCN I/F EA 51402573-150 51402573-150 HPM UCN I/F EA 51402594-100 C/F RHIO L1-7 EA 51402594-200 C/F RHIO R9-15 EA 51402610-200 PWB, TPDGX EA 51402645-200 51402615-200 PWA, K2LCN 2MW EA 51402615-400 PWA, K2LCN 4MW EA 51402615-800 PWA, K2LCN 8MW EA 51402618-120 AC ENTRY 120V EA 51402618-230 AC ENTY 230V EA 51402619-120 CON,120V PWR ENTRY EA 51402619-230 PWR ENTRY 230V EA 51402620-100 10 SLOT COVER EA 51402623-100 HD COVER EA 51402625-125 RED DISOE2 ASSM MU-PDIS12 EA 51402625-175 RED DISOE2(CC) EA 51402645-200 PWB, TPDGX2 EA 51402682-100 CONN. PLATE EC Z EA 51402682-200 CONNECTOR PLATE EA 51402682-300 CONNECTOR EA 51402682-400 CONNECTOR PLATE EA 51402682-500 CONNECTOR PLATE EA 51402683-100 DISK DRIVE PANEL W/ CUTOUT EA 51402683-200 DISK DR PANEL W/O C UTOUT EA 51402684-100 FACADE PANEL EA 51402686-100 WRITING SURF HOLDER EA 51402688-100 UWS ENCL W/CUTOU EA 51402688-200 UWS ENCL W/O CUT EA 51402689-100 CRT-TS BRACKET EA 51402690-100 UWS DRIV TRAY EC EA 51402700-100 MON ASSM W/ TS EA 51402700-200 MON ASSY W/O T/S EA 51402700-300 AYDIN REPL KIT EA 51402700-500 NTS PKG, NEW PWRENT EA 51402700-600 MONITOR ASSM W/TS BOX EA 51402705-100 RULA CRT DRIVE BRAC KET EA 51402706-100 DRIVE PLATE EA 51402707-100 RULA DRIVE BOX TOP EA 51402708-100 RULA DRIVE BOX BASE EA 51402709-100 RULA DRIVE BOX PLAT E EA 51402711-100 DRIVE ENCLOSURE EA 51402712-100 NIM TAP MNTG BRACKET EA 51402714-100 DRV ENCL CLASSIC EC EA 51402716-100 R/PNL ENCL CLASSIC EC EA 51402718-100 UPPER DRV MTG PNL E C EA 51402719-100 IKB SHELF FRAME EA 51402720-100 IKB CABLE COVER EA 51402721-100 IKB DRIVE FACADE EA 51402721-200 IKB DRIVE FACADE EA 51402724-100 BRKT, MAU/NIM MTG EA 51402745-100 BRACKET LH EA 51402745-200 BRACKET RH EA 51402755-100 PWA, K4LCN, SS MOTHERBOARD ONLY - NO MEM EA 51402762-100 AUXILIARY CARD FILE EA 51402763-100 IKB BOTTOM PLATE EA 51402796-100 BEZEL, LOWER EA 51402797-100 PWA, LCNP (W/BRACKET FOR NON-DELL PC INSTALL) EA 51402797-200 PWA, LCNP (INCL BRACKET FOR DELL PC INSTALL) EA 51403001-200 CONSOLE FRAME MED. EA 51403002-100 TRAY, CARD FILE (NON EC Z FURN) EA 51403003-100 CRT BEZEL EA 51403005-100 WINDOW OPTICAL TRANS EA 51403006-100 DUST COVER,NON-OPTIC EA 51403012-100 BOTTOM (FILTER) COV ER EA 51403013-100 HINGED COVER EA 51403015-100 COVER, REAR MON EA 51403021-100 KEYBOARD SUPPORT FR AME EA 51403024-100 K/B SHELF W/KEYHOLE EA 51403024-200 K/B SHELF W/O KEYHO LE EA 51403027-100 LEG COVER, MEDIUM EA 51403027-101 LEG COVER, MEDIUM EA 51403027-200 LEG COVER MEDIUM OLD STYLE WITH FASTENERS EA 51403027-201 LEG COVER, MEDIUM OLD STYLE WITH FASTENERS EA 51403027-300 LEG COVER, SHORT OLD STYLE "Z" FURNITURE EA 51403027-301 LEG COVER, SHORT OLD STYLE "Z" FURNITURE EA 51403027-400 LEG COVER, MEDIUM LONG EA 51403027-500 LEG COVER, MED LATER "Z" WITH SCREWS EA 51403027-600 LEG COVER, SHORT LATER "Z" WITH SCREWS EA 51403030-100 OEP BEZEL EA 51403031-100 WORK SURFACE WEDGE EA 51403034-100 MEDIA DOOR EA 51403036-100 WRITING SURFACE EA 51403037-200 HEAVY FOOTREST EA 51403047-100 HINGE ASSEMBLY EA 51403056-100 BLANK OEP INSERT EA 51403057-100 ENG KEYBOARD TRAY EA 51403064-100 ENG. KEYBOARD ENCLO SURE EA 51403069-100 BEZEL (MODIFIED) EA 51403070-100 CRT MTG. BRACKET EA 51403071-100 CRT-TS BRACKET EA 51402689-100 51403081-100 DISK CHANNEL (NON EC) EA 51403087-100 AYDIN CRT BRACKET EA 51402689-100 51403089-200 UPPER FRONT COVER EA 51403089-300 51403089-300 UPPER FRONT CVR EA 51403090-200 UPPER FRONT COVER EA 51403090-300 51403090-300 LWR FRONT COVER EA 51403095-100 MONITOR MTG. SHROUD EA 51403095-200 MONITOR MTG. SHROUD EA 51403100-100 POWER SUPPLY ENCLOS URE EA 51403106-100 TABLE TOP, PRINTER EA 51403106-200 TABLE TOP, WORK SUR FACE EA 51403114-100 WEDGE TIE PLATE- AR C EA 51403117-100 CARD FILE ENCL ASSM EA 51403124-100 WEDGE TIE PLATE- IN LINE EA 51403135-100 T/S ASSM. 21 IN EA 51197006-100 51403148-200 REAR COVER/W HDWR EA 51403149-100 EMI SHIELD EA 51403152-100 REAR DN COVER EA 51403155-100 PAPER BASKET, STACK EA 51403156-100 PAPER BASKET, FEED EA 51403157-200 POWER SUPPLY ASSM. EA 51403158-100 CONTROL PNL ASSY EA 51403159-100 BEZEL ASSY EA 51403159-200 Z FRONT BEZEL(SONY) EA 51403160-200 CONSOLE FRAME LOW EA 51403161-200 CONSOLE FRAME HIGH EA 51403162-400 LEG COVER, LONG SMA LL EA 51403162-500 LEG COVER, MEDIUM S MALL EA 51403162-600 LEG COVER, SMALL SHORT EA 51403163-400 TALL LONG LEG COVER EA 51403163-500 TALL MED. LEG COVER EA 51403163-600 TALL SHORT LEG COVE R EA 51403165-100 OPERATOR ENT PNL ASSM EA 51403165-300 51403165-200 OPERATOR PANEL ASSM EA 51403165-400 51403165-300 OPR ENT PNL ASSM EA 51403165-400 OPR PNL ASSM EA 51403169-100 TREND PEN BEZEL ASS M EA 51403170-700 TREND PEN ASSM EC EA 51403170-800 TREND PEN ASSM EC EA 51403170-900 TREND PEN ASSM EC EA 51403171-100 REAR COVER AUX POD EA 51403176-100 PWR SUPPLY ENCL HAR D DISK EA 51403178-100 REAR COVER PLATE EA 51403182-100 FAN REAR COVER ASSM 120V EA 51403182-300 FAN REAR COVER ASSM EA 51403185-100 MON T/S ASSM KIT EC EA 51403190-100 CRT MOUNT 15 DEGREE HEAVY EA 51403191-100 CRT MOUNT 30 DEGREE HEAVY EA 51403195-100 5 SLOT CARD FILE EA 51403223-100 FIBER OPTIC MODULE ASSM EA 51403224-200 LCNP PWA BRACKET EA 51403249-100 MOUNTING ENCLOSURE EA 51403254-100 Module Chassis Assembly EA 51403257-100 A/C POWER ENTRY EA 51197066-200 51403280-100 RACK MTG KIT 19IN GUS(TP-MOUNTR-100) EA 51403282-100 LCNP4 W/O CARD GUIDE EA 51403299-100 51403282-200 LCNP4 WITH CARD GUIDE EA 51403299-200 51403299-100 LCNP4 GPS W/O CARD GUIDE EA 51403299-200 LCNP4 GPS WITH CARD GUIDE EA 51403299-300 TPNB W/O SPACER EA 51403299-400 TPNB W/SPACER EA 51403355-100 GX1 MODIFIED APP NODE MOTHERBOARD EA 51403355-101 450MHz APP NODE CONSOLE PC EA 51403355-102 450MHz DESKSIDE APP NODE GX1 PC EA 51403355-201 450MHZ GX1 DSKTP/IN CONS APP NODE W/O CD DR EA 51403355-202 450MHZ GX1 DESKSIDE APP NODE W/O CD DRIVE EA 51403355-203 500MH PIII DESK CONS W/O CD DRIVE APP NODE EA 51403355-204 500MH PIII MINI TOWER W/O CD DRIVE APP NODE EA 51403375-100 QWERTY KEYBOARD EA 51196943-100 51403393-100 9 GB DRIVE TRAY ASSY EA MP-ZHMU19-100 51403393-200 6 GB DRIVE TRAY ASSY EA MP-ZHMU12-100 51403397-100 MONITOR REAR COVER EA 51403505-100 FRONT BEZEL DOOR EA 51403530-100 51403519-160 K4SDR 16 MW EA 51403522-100 T/S ASSEMBLY 21IN EA 51403527-100 BEZEL, IR TOUCHSCREEN EA 51403530-100 BEZEL/CTRL PNL ASSM (see notes) EA 51403531-100 BEZEL/TOUCHSCREEN ASSM EA 51403539-100 Window, 19" Infrared T/S EA 51403546-200 Bezel Asm, OEP Lower W/O TS EA 51404088-100 COVER ASSY EA 51404092-300 IOP CASE EA 51404092-400 51404092-400 IOP CASE EA 51404092-500 MOD CHASSIS ASSM EA 51404106-175 RH MUX CC EA 51404109-125 32PT IOP MU-PRHM01 EA 51404109-175 32PT IIOP CC EA 51404125-100 HPM 1-7 SLOT CF EA 51404125-200 51404125-150 HPM 1-7 SLOT CF EA 51404125-250 51404125-200 HPM FILE ASSM 7L EA 51404125-250 HPM FILE ASSM 7L CC EA 51404126-100 HPM 9-15 SLOT CF EA 51404126-200 51404126-150 HPM 9-15 SLOT CF EA 51404126-250 51404126-200 HPM FILE ASSM 7R EA 51404126-250 HPM FILE ASSM 7R CC EA 51404127-100 HPM 15 SLOT CF EA 51404127-200 51404127-150 HPM 15 SLOT CF EA 51404127-250 51404127-200 HPM FILE 15 SLOT EA 51404127-250 HPM FILE 15 SLOT CC EA 51404138-100 PNL, BCU MIGRAT EA 51404169-100 PANEL EA 51404170-125 PS CHASSIS ASM EA 51404170-175 P/S CHASSIS ASM EA 51404172-100 B/P PWS SUPPLY EA 51404172-125 51404172-125 B/P PWR SYS EA 51404172-175 B/P PWR SYS EA 51404174-125 POWER SYSTEM ASSM MU-PSSX04 EA 51404174-175 POWER SYSTEM ASSM EA 51404174-225 POWER SYSTEM ASSM MU-PSRX04 EA 51404174-275 POWER SYSTEM ASSM EA 51404174-325 RED P/S 20 AMP W/BBUAND MTG MU-PSRB04 EA 51404174-375 RED P/S 20 AMP W/BBUAND MTG EA 51404191-125 HPM FILE ASSM 7-LF EC EA 51404191-325 51404191-175 HPM FILE ASSM 7-LF EC CC EA 51404191-375 51404191-225 HPM FILE ASSM 7-LF I/O EC EA 51404191-425 51404191-275 HPM FILE ASSM 7-LF I/O CC EA 51404191-475 51404191-325 HPM 7 SLOT LEFT EA 51404191-375 HPM 7 SLOT LEFT CC EA 51404191-425 HPM 7 SLOT LEFT EC EA 51404191-475 HPM 7 SLOT LEFT CC EA 51404192-125 HPM FILE ASSM 7-RT EC EA 51404192-325 51404192-175 HPM FILE ASSM 7 RT EC CC EA 51404192-375 51404192-225 HPM FILE ASSM 7RT I /O CC EA 51404192-425 51404192-275 HPM FILE ASSM 7-RT I/O CC EC EA 51404192-475 51404192-325 HPM 7 SLOT FILE, RIGHT EA 51404192-375 HPM 7 SLOT R EA 51404192-425 HPM 7 SLOT EA 51404192-475 HPM 7 RT I/O EC CC EA 51404193-125 15 SLOT EC, HPM EA 51404193-325 51404193-175 15 SLOT CC, HPM EA 51404193-375 51404193-225 HPM FILE ASSM 15 SLOT I/O EA 51404193-425 51404193-275 15 SLOT I/O EC EA 51404193-475 51404193-325 HPM 15 SLOT EC EA 51404193-375 HPM 15 SLOT EC CC EA 51404193-425 HPM 15 SLOT EC EA 51404193-475 HPM FILE 15 EC CC EA 51404210-125 15 C/F I/O ENTRY EA 51404193-425 51404210-175 15 SLT IOP FILE EA 51404193-475 51404211-125 PM/APM FILE 10 I/O EA 51404211-175 51404211-175 FILE,PM I/O EA 51404212-125 PM/APM FILE 5 I/O EA 51404212-175 51404212-175 FILE,5SLT IOP EA 51404256-100 MOUNTING PLATE EA 51404331-100 UNCE ENCLOSURE EA 51404331-200 51404331-200 UCNE ENCLOSURE EA 51404365-200 COVER, 7-S (1-7) EA 51404365-300 COVER, 7-S (9-15) EA 51404366-200 COVER, 15-SLOT EA 51404367-200 UCN FRONT PLATE EA 51404367-300 8 SLOT UCNE PNL EA 51404368-200 PLASTIC FRONT PANEL EA 51404368-300 COVER, HPM PWR EA 51404368-400 COVER, HPM AC PWR EA 51404368-500 FILLER PANEL 15 SLOT EA 51404368-600 COVER, UNCE EA 51404368-700 COVER, HPM PWR (CC) EA 51404368-800 COVER, HPM AC (CC) EA 51404372-100 HOFFMAN CAB ASSM DUAL ACCESS (CAB ONLY) EA 51404373-100 REMOTED HARDENED CNTRL CAB 120V MU-RCAB01 EA 51404373-200 REMOTE HARDENED CNTRL CABINET 240V MU-RCAB02 EA 51404374-100 REMOTE HARDENED CONTROLLER UCNE MTG KIT EA 51404376-150 FAN ASSY EA 51404376-250 FAN ASSY EA 51404377-100 RHC BATTERY MOUNTINGKIT W/BATTERY EA 51404383-100 PM POWER CHASSIS LABEL EA 51404383-500 PM POWER CHASSIS LABEL, "CC" EA 51404385-100 PANEL MTG BKG RH EA 51404385-200 PANEL MTG BKT LH EA 51404386-100 HEATER KIT 120V MU-RCHT01 EA 51404386-200 HEATER KIT 240V MU-RCHT02 EA 51450150-100 BEZEL EA 51450151-100 BLANK KB BEZEL EA 51450166-200 CONSOLE BEIGE CRT EA 51450166-300 CONSOLE BEIGE CRT EA 51450166-400 CONSOLE BLACK CRT EA 51450166-500 CONSOLE WORK SURFACEBLK EA 52527 CABLE, CD EA 54090 144MB FLOPPY DR EA 51196946-905 55078 POWER SUPPLY 145W EA 55079 POWER SUPPLY 200W EA 55168 CD, 680MB 12/24X EA 51196982-906 57593 PWA, PLN 440LX KLMTH OPPLX ENH EA 5812E CABLE ASSY UW EA 59362 2GB WIDE DR W/CB EA 5940E NEC 680M IDE 14/32 CD ROM EA 60820 8X CD ROM DR EA 51196935-907 6104E 9.1 GB SCSI UWIDE H/D EA 51196982-908 612167 DUAL CRT CTRL EA 51196928-100 62795601-001 S/L PWB C-ASL00 EA 62795604-001 C-AA190 - PWB EA 62795604-002 PWB C-AA290 EA 62795607-001 PWB C-AZL01 EA 62795607-003 62795607-002 PWB C-AZS01 EA 62795607-004 62795607-003 PWB C-AZL01 INTEGR-LINEAR EA 62795607-004 PWB C-AZS01 SQRT08 EA 62795609-001 P/W BOARD-ADDER/ EA 62795610-001 PWB C-APM00 EA 62795613-001 PWB C-ASC00 W/87 SGL SELECTOR EA 62795646-001 PWB, ASSEMBLY PV EA 62795647-001 PWB, STANDBY EA 62795648-001 SORT PWB EA 62795649-001 62795649-001 LOOP STANDBY EA 62795653-002 SWITCH EA 62795653-003 SWITCH EA 62795654-001 LAMP CARTRIDGE EA 62795655-001 RESISTOR EA 62795729-001 PWB, CALIBRATOR FUNCTION CARD EA 657PW PRC,80526,1GZ,256,133,FC EA 66051 HARD DRIVE 4 GB DELL EA 87512 66433225 DISC DRIVE 1.44MB EA 51196969-905 66433487 POWER SUPPLY 300W (MOTOROLA) EA 51196969-914 66433577 KBM104-US KEYBOARD AND MOUSE EA 51196969-900 68A8537P03 FUSE, 1.5A EA 68A8537P07 FUSE, 5A, 250V EA 68A8976P1 FAN,SMALL MUFFIN EA 68A8976P2 FAN MIN BALL BEA EA 6982D SCSI CONTROLLER EA 51196982-907 69855 CABLE SCSI C/D EA 69885 CABLE, IDE/SCSI, CD-ROM EA 7020T FD,1.44M,F3,NBZ,SONY,F/EJ3 EA 70A2551P108 FUSE, .01 AMP EA 70A2551P111 FUSE, .25 AMP EA 70A2551P114 FUSE, .5 AMP EA 70A2551P119 FUSE, 1 AMP EA 70A2551P120 FUSE, 1.5 AMP EA 70A2552P204 SWITCH COVER EA 70A2553P101 SWITCH MIN PWB EA 70A2801P101 FAN ASSEMBLY EA 70B173612G2 FAN ASSY, 230V EA 70YY19026 ANNUNCIATOR PWB EA 51303642-600 71915 CABLE, FLOPPY DR EA 78140531-001 CARRIAGE ASSM EA 8002-CC-85 Carrier Extension Cable, 0.85m EA 8003-CC-12 Carrier Extension Cable, 1.2m EA 8020-CE-RH Carrier Extender, Right Hand EA 8021-CE-LH Carrier Extender, Left Hand EA 80268 PWA,MOTHER BOARD, 440LX, OPPLX EA 8030-CE-RH IS Carrier Extender, Right-Hand EA 8031-CE-LH IS Carrier Extender, Left-Hand EA 8032-CC-35 IS Carrier Extension Cable Set, 0.35m EA 8033-CC-85 IS Carrier Extension Cable Set, 0.85 EA 80337031-208 CONN BLK 8PT TE EA 51195773-100 8034-CC-12 IS Carrier Extension Cable Set, 1.2m EA 80350091-002 FUSE, .5A EA 80350091-003 FUSE, 1AMP EA 83957061-003 80350091-004 FUSE, 1.6 AMP EA 83957061-004 80350091-006 FUSE, 3.2 AMP EA 83957061-006 80350091-007 FUSE, 5 AMP EA 83957061-007 80350514-003 FUSE 0.125A EA 30076014-011 80350514-008 FUSE, .25A 250V EA 30076014-004 80350514-011 FUSE 0.5A EA 30076014-006 80350514-012 FUSE, 0.6 AMP EA 30076014-023 80350514-013 FUSE, .75 AMP EA 30076014-010 80350514-014 FUSE, 1A 250V EA 30076014-001 80350514-016 FUSE 2A EA 30076014-002 80350514-018 FUSE 3 AMP EA 30076014-009 80350514-019 FUSE, 4 AMP EA 30076014-025 80350514-020 FUSE 5A EA 30076014-003 80350514-023 FUSE 8A EA 30076014-005 80350514-025 FUSE, 10 AMP EA 30076014-012 80350514-026 FUSE 15A EA 30076014-014 80350613-001 LBOS CRT, 9 IN EA 80350656-005 FUSE, 5A EA 80350656-006 FUSE 7.5 AMP EA 80350859-001 J-PCM20,I/O MOD EA 80360136-001 AMC R20 BASE EA 80360137-001 AMC R10 BASE J-MBU00 EA 80360139-001 DIGITAL IN,32PT J-DIM00 EA 80360140-001 DIGITAL OUT,32PT J-DOM10 EA 80360140-011 DIG OUTPUT,16PT J-DOM00 EA 80360140-012 I/O MODULE WITH FRONT TERM 16S/S J-DOF00 EA 80360141-001 R20 A/I MODULE EA 80360141-011 80360141-011 HIGH LEVEL ANALOG INPUT FOR UAC J-HAM10 EA 80360141-012 HIGH LEVEL ANALOG INPUT 16 FOR UAC W/FTB EA 80360142-001 HL ANALOG MUX J-HMM00 EA 80360143-001 R20 A/O MODULE EA 80360143-011 80360143-002 R20 A/O MODULE EA 80360143-012 80360143-011 R20 A/O MODULE J-AOM10 EA 80360143-012 R20 A/O MODULE J-AOF00 EA 80360144-001 HC I/F MODULE J-HCX00 EA 80360145-001 R20 CTRL MODULE EA 80360145-011 80360145-011 R20 CTRL MODULE J-MSC10 EA 80360146-001 R20 HWAY I/F MOD EA 80360146-011 80360146-011 R20 HWAY I/F MOD J-MHM10 EA 80360147-001 R20 UAC DIR MOD J-UDM00 EA 80360155-001 FRONT TERM BLOCK J-FTB00 EA 80360163-001 EC-LINK TERMINATOR, J-ELT00 EA 80360164-001 TERM PANEL SUP EA J-TPX00 80360169-001 AMC R20 BASE,UAC EA 80360170-001 I/O CABLE 1M EA 80360170-010 80360170-010 I/O CABLE 1M (J-RSL01) EA 80360170-015 I/O CABLE 1.5M EA 80360170-020 2M I/O CABLE EA 80360170-030 I/O CBL 3M EA 80360170-050 5M I/O CABLE EA 80360170-080 8M I/O CABLE EA 80360170-150 15M I/O CABLE EA 80360170-300 30M I/O CABLE EA 80360170-500 50M I/O CABLE EA 80360171-020 REDUN I/O CBL 2M J-RRK02/J-RRL20 EA 80360171-030 UAC CABLE, 3M J-RRL30 EA 80360171-050 UAC I/O CABLE 5M J-RRL50 EA 80360171-080 UAC I/O CABLE 8M J-RRL80 EA 80360171-150 UAC CABLE, 15M J-RRK15 EA 80360172-001 R20 UAC MAIN BSE EA 80360169-001 80360173-001 AMC I/O BASE EA 80360175-001 MTG KIT,TERM PNL J-TPX10 EA 80360181-001 PWR DIST PANEL J-PDP00 EA 80360181-002 PWR DIST PANEL EA 80360181-001 80360185-001 PULSE INPUT, AMC J-PIM00 EA 80360185-002 PULSE INPUT MODULE (8) WITH FTB J-PIF00 EA 80360195-001 D/O RELAY MODULE J-DOM20 EA 80360195-002 RELAY D/O MODULE WITH FTB J-DOF20 EA 80360198-001 DIGITAL INPUT MODULE 48VDC J-DIM10 EA 80360198-002 DIGITAL INPUT MODULE - 48VDC W/FTB J-DIF10 EA 80360199-001 SM TRANS I/F-AMC J-STM00 EA 80360206-001 PWA, CLI EA 80360209-001 CLI ADAPT BD ASM EA 80360211-100 PWA, 1 M/W MEMRY EA 80360211-200 3/4 M/W PWA EA 80360230-001 PWB, CLI I/O EA 80360300-501 512K MEMORY PWA EA 80360322-001 FDD CONVERT ASSY EA 80360379-030 SIGNAL CABLE EA 80360573-001 EC-LINK TERMINATOR J-ELT00 EA 80360163-001 80360619-001 CABLE-AMC TO AMC J-HIC00 EA 80360620-001 CABLE-AMC TO I/F J-HIC10 EA 80360620-002 CABLE 3 METER EA 80360621-001 CABLE, 1M EC-LINK INTERNAL CAB USE J-EIC10 EA 80360621-002 EC-LINK CBL-2 EA 80360621-004 CABLE, EC LINK EA 80360621-005 EC-LINK CABLE J-EIC00 EA 80360636-050 ECL CABLE, 5M J-EEK05 EA 80360636-200 CABLE, 20M EC-LINK J-EEK20 EA 80360641-200 HCIM POWER CABLE J-HPA20 EA 80360643-001 BASE UNIT ADAPTER J-BUA00 EA 80360645-001 EC-LINK ADAPTER J-ELA00 EA 80360646-001 EC-LINK ADAPTOR J-ELA10 EA 80360662-001 FDD CBL CONVRT EA 80360677-001 A/I REMOTE T.P. J-RTP10 EA 80360680-001 A/O RTP W/STDBY EA 80360686-001 D/O REMOTE T.P. J-RTP40 EA 80360689-001 PULSE INPUT T.P. J-RTP50 EA 80360693-001 A/O REMOTE T.P. EA 80360695-001 REMOTE DI/DO TP J-RTP00 EA 80360697-001 CBL,.9M UAC INTERNAL CABINET USE J-HIC20 EA 80360713-001 A/I ADAPTER UNIT J-AAU00 EA 80360769-050 CBL, 50 FT EA 80360912-001 I/O ADAPTER J-BCA00 EA 80361024-001 REMOTE D/O T.P.J-RTP80 EA 80361027-001 TERM PNL,ENH D/O EA 80361394-100 HPM HD I/O IOP EA 80363969-150 80361394-150 HPM HD I/O IOP EA 80363969-150 80361395-100 DI IOP 32 ASSY EA 80363972-100 80361396-100 DI IOP 32 ASSY EA 80363975-100 80362958-001 OPR FLIP LEGS EA 80363969-100 HPM HD I/O IOP EA 80363969-150 80363969-150 HPM HD A/O IOP EA 80363972-100 DI IOP 32 ASSM MU-PDIY22 EA 80363972-150 DI IOP COATED MC-PDIY22 EA 80363975-100 DO IOP (NON COATED) MU-PDOY22 EA 80363975-150 HD DO IOP, COATED EA 80364007-100 AO FTA SCR EA 80364007-200 80364007-200 AO FTA SCR MU-TAOY53 EA 80364007-250 AO FTA RED EA 80364010-100 FTA, DI 24VDC SCREW EA 51204154-125 80364010-125 DI 24VDC SCR EA 51204154-125 80364010-175 DI 24V DC SCR EA 51204154-175 80364013-100 FTA, DO 24VDC SCREW EA 51204156-125 80364013-125 DO 24VDC EA 51204156-125 80364013-175 HDIO DO FTA EA 51204156-175 80366177-100 HD FTA, AO COMP W/STBY EA 51204172-125 80366177-200 AO RED COMP MU-TAOY23 EA 80366177-250 AO FTA RED EA 80366180-100 FTA, DI 24VDC COMP EA 51204160-125 80366180-125 D/I RED COMP EA 51204160-125 80366180-175 HDIO DI 24V EA 51204160-175 80366183-100 FTA, DO 24VDC COMP EA 51204162-125 80366183-125 FTA, DO 24VDC COMP EA 51204162-125 80366183-175 HDIO DO FTA EA 51204162-175 80366186-100 HD FTA, DO RELAY SCREW EA 51204164-125 80366186-125 FTA RED SCR EA 51204164-125 80366186-175 HDIO FTA RED EA 51204164-175 80366189-100 HD FTA, DO RELAY COMP EA 51204166-125 80366189-125 DO FTA COMP EA 51204166-125 80366189-175 HDIO DO FTA EA 51204166-175 80366192-100 HLAI FTA SCR - MU-TAIH62 EA 51204168-100 80366192-150 HDIO HLAI/STI EA 51204168-150 80366195-100 HLAI RED COMP EA 51204170-100 80366195-125 HLAI FTA COMPR EA 51204170-125 80366195-150 HDIO HLAI/STI EA 51204170-150 80366195-175 HDIO HLAI FTA EA 51204170-175 80366198-100 BRIDGE CBL 1M MU-KBFT01 EA 80366198-200 CABLE 2M BRIDGE MU-KBFT02 EA 80366481-125 AO COMP EA 51204172-125 80366481-175 HDIO A/O FTA EA 51204172-175 80366484-125 A/O FTA SCREW EA 51204174-125 80366484-175 HPM A/O FTA EA 51204174-175 80367031-208 CONN BLK 8PT TE EA 51195773-100 80367163-001 HPM AI ADAPTER EA 80522 PROCESSOR 266Mh,512KECC EA 83613 80585 MTHRBD,10/100 LT EA 8060-CC-XT RAILBUS EXTENSION CABLE/CONDUIT ASSEMBLY EA 8061-CC-XT RAILBUS EXTENSION CABLE/CONDUIT ASSY-DUST PRT EA 8070-FC-50 FIBER PATCH CABLE, 50cm EA 8101-HI-TX-HON 8-channel AI, 4-20mA w/HART for 2-wire Txmtr EA 8102-HO-IP-HON 8-channel AO, 4-20mA w/HART EA 8104-AO-IP-HON 8-channel AO, 4-20mA EA 8105-TI-TC-HON 4-channel THC/mV input EA 8106-TI-RT-HON 4-channel RTD input EA 8109-DI-DC-HON 8-channel DI, 24Vdc Isolated, Sinking EA 8110-DI-DC-HON 8-channel DI, 24Vdc Non-Isolated, Module Pwrd EA 8111-DI-AC-HON 8-channel DI, 115Vac Isolated, Sinking EA 8112-DI-AC-HON 8-channel DI, 115Vac Non-Isolated, Mod Pwrd EA 8113-DI-AC-HON 8-channel DI, 230Vac Isolated, Sinking EA 8114-DI-AC-HON 8-channel DI, 230Vac Non-Isolated, Module Pwr EA 8115-DO-DC-HON 8-channel DO, 2-60VDC Non-Isolated, Mod Pwrd EA 8116-DO-AC-HON 8-channel DO, 20-250VAC Non-Isolated, Mod Pwr EA 8117-DO-DC-HON 8-channel DO, 2-60VDC Isolated, Unpowered EA 8118-DO-AC-HON 8-channel DO, 20-250VAC Isolated, Unpowered EA 8121-DI-DC-HON 16-channel DI, 24VDC Dry Contact, Module Pwrd EA 8122-DI-DC-HON 16-channel DI, 24VDC Field-powered EA 81442 230W P/S EA 81502507-001 KEYSWITCH ASSY EA 8171E RISER 5 SLOT ACTIVE EA 51196982-909 81730 KEYBOARD EA 51196935-901 8201-HI-IS-HON 8-channel IS AI, 4-20mA with HART EA 8202-HO-IS-HON 8-channel IS AO, 4-20mA with HART EA 8204-AO-IS-HON 8-channel IS AO, 4-20mA EA 8205-TI-IS-HON 8-channel IS THC/mV Input EA 8206-TI-IS-HON 8-channel IS RTD/ohms Input EA 82114805-501 ASSY, TREND I/F EA 82115012-001 82114805-502 TREND ASSM EA 82115012-001 82114814-501 PTR INTERFACE BD EA 82114927-001 PWB, DG (A) R520 EA 82114927-501 82114927-501 PWB, DG (A) R520 EA 82114927-502 PWA, DG (A) R530 EA 82114927-002 82114930-001 PWB, DG (B) R520 EA 82114930-501 82114930-501 PWB, DG (B) R520 EA 82114930-502 PWB, DG (B) R530 EA 82114930-002 82115012-002 ASSY, TREND I/F EA 82115045-001 CONFIG DATA BASE EA 82115046-001 SOPL PROGRAM EA 82115047-001 TREND DATA BASE EA 82115048-001 RECIPE DATA BASE EA 82115049-001 R520 DIAG DISK EA 82115119-001 BLANK DATA BASE EA 82115121-001 UTILITY DISKETTE EA 82115206-001 CONFIG PROG DISK EA 82115207-001 OP PROG w/oRECIP EA 82115208-001 OP PROG W/RECIPE EA 82115280-001 ASM, KEYBD FLAT J-DSG53 EA 82115961-002 CABLE ASSM-10FT EA 51304050-010 82116144-001 CABLE ASSEMBLY EA 82116170-001 CABLE ASSEMBLY EA 82116300-001 KEYSWITCH ASSM EA 81502507-001 82116383-001 M/F SWITCH PANEL EA 82116404-001 OP PROG w/oRECIP EA 82116405-001 OP PROG W/RECIPE EA 82116406-001 CONFIG PROG DISK EA 82116410-001 UTILITY DISKETTE EA 82116412-001 R535 DIAG DISK EA 82116421-001 CONFIG PROG DISK EA 82116424-001 R530 DIAG DISK EA 82117038-001 1MW MEM REPL. EA 30752117-002 82117038-501 1MW MEMORY REPLC(培训) EA 30752117-002 8215-DO-IS-HON 4-channel IS DO, Solenoid Drvr, IIC Gas Group EA 8220-DI-IS-HON 16-channel IS DI, Switch/Proximity Detector EA 8223-PI-IS-HON 2-channel Pulse/Frequency Input Module EA 82250823-005 RIBBON CABLE EA 82250823-008 RIBBON CABLE EA 82277 PWA, RISER, 5 SLOT PASSIVE EA 82325 PWB, RISER, 5 SLOT EA 82407025-100 MC PT CARD FILE J-PF100 EA 82407025-200 MC PT CARD FILE J-PF200 EA 82407026-001 SPARE CARD FILE EA 82407039-001 SPARE M/ FILE EA 82407044-001 J-CD500 FILE EA 82407044-004 RCD FILE EA 82407045-001 J-CDD50 FILE EA 82407046-001 BACKUP MEM FILE J-CDM50 EA 82407372-001 I/O TERM PANEL J-TCB50 EA 82407387-001 PWB, IBC R15/20/30 J-CBC00 EA 82407390-501 PWB, IBI R30 EA 82407390-001 82407438-001 PANEL,TERM J-TPF10 EA 82407441-001 TERM PANEL EA 82407444-001 PANEL,TERM J-TPF40 EA 82407465-001 PWB, REGULATOR A EA 82407468-001 PWB, REGULATOR B EA 51196989-100 82407468-002 PWB, REG. B R15/ EA 82407498-001 CABLE, I/O BUS J-KR050 EA 82407499-001 CABLE, I/O BUS EA 82408007-001 CABLE, I/O 5M J-KE001 EA 82408007-002 CABLE, I/O 5M J-KE002 EA 82408007-003 CABLE, I/O 3M J-KE003 EA 82408007-005 CABLE, I/O 5M J-KE005 EA 82408007-008 CABLE, I/O 8M J-KE008 EA 82408007-015 CABLE, I/O 15M EA 82408007-030 CABLE, I/O 30M EA 82408007-501 CABLE I/O 1.5M J-KE115 EA 82408060-001 ASM RAM BATTERY EA 38002931-100 82408061-001 C-LINK ADP KRA00 EA 82408061-002 82408061-002 C-LINK ADP J-KRA00 EA 82408108-001 FLAT CABLE ASSY EA 82408175-002 C-LINK EXTERNAL CABLE (J-KRE02), 2 METERS. EA 82408175-010 C-LINK EXTERNAL CABLE (J-KRE10), 10 METERS. EA 82408175-020 C-LINK EXTERNAL CABLE (J-KRE20), 20 METERS. EA 82408175-030 C-LINK EXTERNAL CABLE (J-KRE30), 30 METERS. EA 82408175-100 C-LINK CBL 100M EA 82408187-001 DSP. J-PNL EA 82408199-001 DIG DSP BRCH PNL EA 82408205-001 PWB, SBLA III EA 82408485-001 82408208-003 PWB SDLA II R20 EA 82408213-001 A/D ADDER CARD F EA 82408215-001 PWB, IBI A/D R15 EA 82408217-001 PWB, MOS CPU R15 EA 82408217-002 82408217-002 PWA, PROCESSOR W/EMULATOR EA 82408309-002 LOC COMP I/F J-DCC00 EA 82408310-001 E/T/P RELAY ASSM J-PCM40 EA 82408310-002 E/T/P RELAY ASSM J-PCM50 EA 82408330-001 PWB, HIWAY #2 EA 82408363-001 PANEL,TERM J-TPF20 EA 82408433-004 CBL SET J-KRL40 EA 82408440-001 PWB, UAC I/F R30 J-CBC50 EA 82408443-001 8K RAM PWB EA 82408667-005 82408443-002 16K RAM PWB EA 82408443-003 24K RAM PWB EA 82408667-005 82408443-004 ROM PWB EA 82408667-004 82408443-005 PWB, MEMORY EA 82408667-003 82408447-002 LBOS CPU R15 EA 82408452-001 RBCD CONTRL R300 EA 82408452-501 RBCD CONTRL R300 EA 82408452-001 82408456-002 PWB, B/U MEMORY J-CBM55 EA 82408458-002 PWB, B/U MEMORY EA 82408456-002 82408461-001 PWB, B/U MEMORY EA 82408456-002 82408464-001 PWB, SO SWITCH EA 82408467-001 PWB, I/O BUS SW J-CDS50 EA 82408470-001 PWB, I/O BUS SW EA 82408473-001 PWB SO SW M, ODULE EA 82408476-001 PRIM SO JNCT PNL J-JDD50 EA 82408479-001 J-JDD51 R/S/O J/PNL EA 82408482-001 S/O DISTRI PANEL J-DD55 EA 82408485-001 PWB, SBLA III J-CBC03 EA 82408520-001 MEM FILE W/O CDS EA 82408609-101 I/O BUS CBL,1.4M J-KR501 EA 82408609-102 I/O BUS CBL, 5M J-KR505 EA 82408609-104 I/O BUS CBL 10M J-KR510 EA 82408609-105 10' UAC CABLE EA 82408609-201 DATA BUS CABLE 1M J-KDB01 EA 82408609-202 DATA BUS CABLE 5M J-KDB05 EA 82408609-204 DATA BUS CABLE 10M EA 82408609-205 DATA BUS CABLE 3M J-KDB03 EA 82408667-001 PWA, ROM/RAM EA 82408667-002 PWB, ROM/RAM EA 82408667-001 82408667-005 24K RAM PWB EA 82409482-001 OP PROG w/oRECIP EA 82409483-001 OP PROG W/RECIPE EA 82409484-001 DHP CONFIG DISK EA 82409485-001 CONFIG PROG DISK EA 82409486-001 BLANK DATA BASE EA 82409487-001 CONFIG DATA BASE EA 82409488-001 TREND DATA BASE EA 82409489-001 SOPL DATA BASE EA 82409490-001 RECIPE DATA BASE EA 82409491-001 R525 DIAG DISK EA 82409497-001 UTILITY DISKETTE EA 824KH PWR SPLY,200W,PFC,RF,PS/2,8C EA 82665 1.44MB FLOPPY DR EA 51196946-905 8301-HI-IS-HON 8-CH IS AI MODULE,4-20mA WITH HART EA 8304-AO-IS-HON 8-CH IS AO MODULE, 4-20mA EA 8305-TI-IS-HON 8-CH IS TC/mV INPUT MODULE EA 8306-TI-IS-HON 8-CH IS RTD/ohms INPUT MODULE EA 8315-DO-IS-HON 4-CH IS DO MODULE,SOLENOID DRIVER IIC GAS GRP EA 8320-DI-IS-HON 16-CH IS DI MODULE, SWITCH/PROXIMITY DETECTOR EA 83613 PROCESSOR 266Mh,512KECC EA 83957061-002 FUSE 0.5 AMP EA 80350091-002 83957061-003 FUSE 1.0 AMP EA 83957061-004 FUSE, 1.6 AMP EA 83957061-006 FUSE, 3.2 AMP EA 83957061-007 FUSE, 5 AMP EA 83957062-005 FUSE, 5A EA 80350656-005 83957062-006 FUSE 7.5 AMP EA 80350656-006 83970001-103 D/O RELAY EA 83970001-110 RELAY,24V PLUGIN EA 8405-LK-ZE REPLACEMENT LOOP-DISCONNECT LINK (PACK OF 10) EA 8430-TS-MO TAG STRIP KIT (PACK OF 25, CARDS & WINDOWS) EA 8435-PP-24 FIBER OPTIC PATCH PANEL, 24-WAY EA 8445-BP-20 GLAND HOLE BLANKING PLUG, M20 (PACK OF 10) EA 8475-CO-RS RS232/485 CONVERTER, CABLE AND 9V PWR SUPPLY EA 85675 2MB VIDEO PWB EA 51196935-907 8601-FT-NI Field Terminal, Non-Incendive, Standard EA 8602-FT-ST Field Terminal, Standard EA 8603-FT-FU Field Terminal, Non-incendive, Fused EA 8604-FT-FU Field Terminal, Fused EA 8605-FT-TC Field Terminal, thermocouple EA 8606-FT-RT Field Terminal, RTD EA 8610-FT-NA Field Terminal, Non-arcing, Standard EA 8611-FT-FU Field Terminal, Non-arcing, Fused EA 8615-FT-4W Field Terminal, 4-wire, Current Sinking EA 8617-FT-16 Field Terminal, 16-channel DI EA 8621-FT-IS IS FIELD TERMINAL, STANDARD EA 8622-FT-IS IS FIELD TERMINAL, LOOP-DISCONNECT EA 8623-FT-IS IS FIELD TERMINAL, 16-CHANNEL DIGITAL INPUT EA 8624-FT-IS IS Field Terminal, 8-chnl DI, Loop Disconnect EA 8625-FT-IS IS FIELD TERMINAL, 8-CHANNEL T/C INPUT EA 8626-FT-IS IS FIELD TERMINAL, 8-CHANNEL RTD INPUT EA 86619 ADAPTOR, 2940 EA 51196935-907 8707-CA-08 8-module Carrier EA 8710-CA-04 4-module Carrier EA 8716-CA-NS Node Services Carrier EA 8720-CA-04 4-module IS Carrier EA 8724-CA-PS IS Module Power Supply Carrier EA 8725-CA-RB Railbus Isolator Carrier EA 8727-CA-08 8-module IS Carrier EA 8731-CA-NS ZONE 1 CARRIER, BIM + 8 MODULES EA 87346 PWR SUPPLY, 200 W EA 8737-CA-08 ZONE 1 CARRIER, 8 MODULE EXTENTION EA 87757 64MB ECC S DRAM EA 51196971-100 87758 DIMM, 128 ECC SDRAM EA 87760 PWB, 2MB VIDEO BOARDUPGRADE EA 87998 KEYBOARD, 104 EA 4939R 88258 PROCESSOR, 80522,266MHz,512K NONECC EA 83613 88406 MTHRBD,10/100 LT EA 80585 88672 FLOPPY DR 144M F3 NC 2MD EA 886MJ MSE,PS2,6P,2BTN,WHL,MS EA 8913-PS-AC-HON System and Field Power Supply, AC Mains EA 8914-PS-AC-HON Field Power Supply, AC Mains EA 8920-PS-DC-HON IS Module Power Supply, 24VDC Input EA 8922-RB-IS Railbus Isolator EA 8927-PS-AC UNIVERSAL AC PWR SUPPLY & CBL, AUX PORT FCAR EA 8930-PS-AC-HON ZONE 1 POWER SUPPLY, 115VAC INPUT EA 8931-PS-AC-HON ZONE 1 POWER SUPPLY, 230VAC INPUT EA 8940-EN-08-HON ZONE 1 ENCLOSURE, BIM + 8 MODULE SYSTEM EA 8941-EN-XT-HON ZONE 1 ENCLOSURE, 8 MODULE EXTENTION EA 8942-EN-08-HON ZONE 1 ENCLOSURE, BIM + 8 MODULE - DUST PROTC EA 8943-EN-XT-HON ZONE 1 ENCLOSURE, 8-MOD EXTENSION, DUST PROTC EA 8946-GL-00 GLAND PLATE-UNDRILLED, ZONE 1 ENCLOSURE/EXTEN EA 8947-GL-01 GLAND PLATE-DRILLED, ZONE 1 ENCLOSURE/EXTENSN EA 8950-EN-16-HON Field Enclosure, 16-module, 2/2 EA 8951-EN-12-HON Field Enclosure, 12-module, 2/1 EA 8952-EN-12-HON Field Enclosure, 12-module, 2/2 + 2/1 EA 8954-GL-00 Gland Plate, Undrilled 12/16-Module Enclosure EA 89547 PWB, APAPT, NETWORK 10/100 EA 8955-GL-01 Gland Plate Drilled, 12/16-module Enclosure EA 9019C CABLE DATA FD, HM EA 91289 MOUSE, PS2 EA 51196935-900 9171E RISER, 7 SLOT ACTIVE EA 51196982-959 9228C POWER SUPPLY 200 WATT EA 51196982-903 93192 64MB ECC RAM EA 51196935-903 93630 200MHZ PROCESSOR BD EA 93906 PWA, RISER, 5 SLOT EA 95130 KEYBOARD, 104 EA 51196935-901 95267 32MB MEMORY DIMM EA 95362 2GB H/D EA 51196935-922 95821 FLOPPY DRIVE, 1.44MB EA 96013758 HARD DRIVE 4MB SCSI (MOTOROLA PART) EA 51196968-100 96014128 CD ROM DRIVE 2X EA 51196982-906 96014158 MPXPII DESKTOP W/MB,PS, FLOPPY (MOTOROLA) EA 96014159 MPXPII MINITOWER W/ MB, PS, FLPY (MOTOROLA) EA 96014160 MOTHERBOARD W/PROC 300MHZ (MOTOROLA PART) EA 51196969-916 96014164 PWB, 64MB SDRAM DIMM EA 51196321-100 96014166 PWB,SCSI,PCI EA 51196969-907 96014167 PWB,GRAPHICS, 4MB APG SVAG EA 51191564-100 96014375 64MB ECC EDO RAM MEM EA 51196321-100 9603C CD 680M 14/32X EA 51196982-906 96807 SWT ASSM ALARM NTRUS16.5IN EA 97624 PROC 180MH, 256K EA 9C475 PWA,PLN.GX200,NIC,VID,OPLX EA 51198718-912 BC-GART13 RTD(16) GI/IS FTA (4073), Comp Term, Coated EA BC-GART23 RTD(16) GI/IS FTA (4073) w/2nd Cur Output, CC EA BC-GATC13 T/C (16) GI/IS FTA (4073), Comp Term, Coated EA BC-GATC14 T/C(16) GI/IS (4073) FTA, Russian XK Type, CC EA BC-GATC23 T/C(16) GI/IS FTA (4073) w/2nd Cur Output, CC EA BC-GBSF13 AO(8) GI/IS w/Line Fault Detect FTA, Coated EA BC-GDOD13 DO(16) 24VDC SS GI/IS w/Override FTA, Coated EA BC-GDOD14 DO(16) 24VDC SS MAG GI/IS w/Override FTA, CC EA BC-GHAI11 GI/IS FTA, HLAI HART (16), COATED EA BC-THAI11 FTA, HLAI HART (16), COATED EA BU-ELLMUX-MTL LLMUX Kit, Zone 0 EA BU-GHAI11 GI/IS FTA, HLAI HART (16) EA BU-SLLMUX-MTL LLMUX Kit, Zone 0, Single Hiway EA BU-TAOC02 Analog Output Combiner Panel for GI/IS EA BU-TDOC02 Digital Output Combiner Panel for GI/IS EA BU-THAI11 FTA, HLAI HART (16) EA C-AA100 PWB EA 62795604-001 C-AA101 PWB EA 30734772-001 C-AA190 PWB EA 62795604-001 C-AA191 PWB EA 30734772-001 C-AA200 PWB EA 62795604-002 C-AA201 PWB EA 30734772-002 C-AA290 PWB EA 62795604-002 C-AA291 PWB EA 30734772-002 C-AC100 SINGLE UNIT CASE EA 30669206-001 C-ACC01 PWB ANNALOG CALIB CARD EA 62795705-002 C-ACC03 CALIBRATION CARD EA 62795705-004 C-ACJ00 REISTOR ASSM EA 30732138-001 C-ACU00 AU CAL EA 62795705-001 C-AEX01 SQ ROOT EXTR EA 30731722-002 C-AF000 AUXILIARY FILE ASSM EA 30731575-001 C-AF002 AUXILIARY FILE ASSM EA 30731575-002 C-AMH00 AUXILIARY PWA EA 30731723-001 C-AMH90 AUX PWA EA 30731723-001 C-AML01 2MV/I AUX EA 30731721-002 C-AML02 2MV/I AUX EA 30731721-003 C-AML91 2MV/I AUX EA 30731721-002 C-AML92 MV-I CARD,2-100MA EA 30731721-003 C-AML93 C-AML03 2MV/I AX(18) EA 30731721-004 C-APM00 PWB EA 62795610-001 C-APM90 PWB EA 62795610-001 C-AR000 RELAY EA 30731674-001 C-ARB01 R/I FM+CSA APPR EA 30731724-002 C-ARB02 R/I AUX BASEEFA EA 30731724-003 C-ARB03 R/I AUX BASEEFA EA 30731724-004 C-ARB10 R/I FM+CSA APPRO EA 30731724-002 C-ARB91 R/I FM+CSA APPRO EA 30731724-002 C-ARB92 C-ARB02 R/I AUX (11) EA 30731724-003 C-ARB93 C-ARB03 R/I AUX (11) EA 30731724-004 C-ARM00 RELAY MOUNTING PANEL EA 30731993-001 C-ARR01 XXXX EA 30731995-001 C-ARR02 RANGE RES PKG (8 PER PACKAGE) EA 30731995-002 C-ARR03 RANGE RESISTOR - ORDER 8 30731996-003 EA 30731996-003 C-ARR04 RANGE RES PKG (4 PER PACKAGE) EA 30731995-004 C-ARR05 RANGER RESISORS EA 30731995-005 C-ARR06 RANGE RESISTORS EA 30731995-006 C-ARR10 PARTS KIT-OUTPUT EA 30751404-001 C-ARR11 RANGE RESISTORS EA 30731995-007 C-ARR12 RANGE RESISTORS EA 30731995-008 C-ARR13 RANGE RESISTORS EA 30731995-009 C-ARR14 RANGE RESISTORS EA 30731995-010 C-ARR15 RANGE RESISTORS EA 30731995-011 C-ARR16 RANGE RESISTORS EA 30731995-012 C-ASC00 PWB W/87 SGL SELECTOR EA 62795613-001 C-ASC90 PWB W/87 SGL SELECTOR EA 62795613-001 C-ASD00 PWB (W10/98)C-ARB01 AUX EA 30731719-001 C-ASK00 SPARE PARTS KIT EA 30736356-001 C-ASL00 S/L PWB EA 62795601-001 C-ASL90 S/L PWB EA 62795601-001 C-ATC00 EXT CARD FOR AF000 EA 30731906-001 C-AXD00 (W10/98)MULT/DIV AUX EA 30731720-001 C-AXD90 (W10/98)MULT/DIV AUX EA 30731720-001 C-AZL01 INTEGR-LINEAR EA 62795607-003 C-AZL91 INTEGR-LINEAR EA 62795607-003 C-AZS01 SQRT08 PWB EA 62795607-004 C-AZS91 PWB SQRT08 EA 62795607-004 C-CB020 C-CB020 CTLR I-C EA 30731900-008 C-CB120 CONTROLLER FILE EA 30731900-010 C-CB121 CONTROLLER FILE EA 30731900-011 C-CB200 CONTROLLER FILE EA 30731900-006 C-CB201 CONTROLLER FILE EA 30731900-007 C-CB501 BASIC CTLR W/O DEP EA 30731900-012 C-CB502 BASIC CTLR W/DEP EA 30731900-013 C-CB701 EXTENDED CTLR W/O DIDEP EA 30731900-014 C-CB702 EXTENDED CTLR W/DIDEP EA 30731900-015 C-CBK00 CONTROLLER PARTS KIT EA 30734578-001 C-CBK01 CONTROLLER PARTS KIT EA 30734578-002 C-CBK02 CONTROLLER PARTS KIT EA 30734578-003 C-CBM00 TREND MEMORY PWB EA 30735974-502 C-CBM01 UPGR, BAS CMOS EA 51196689-100 C-CBM05 CONTROLLER UPGRADE KIT EA 30753116-001 C-CBR00 PWA, DHPII ROM EA 30751044-508 C-CBT00 PWB, TREND MEM. EA 30735974-504 C-CD100 RCD FILE EA 30735871-004 C-CD200 EXT CTLR B/DIR EA 30735871-004 C-CD300 UNIVERSAL RESERVE CTLR DIR (URCD) FOR CB/EC EA 30735871-004 C-CDD00 FILE, UAC DIG I/O EA 30750897-001 C-CDM00 PWA, LOOP MANUAL EA 30735873-501 C-CDS00 ANALOG SWTCHCARD EA 30735863-502 C-CDS20 DIGITAL SWITCH CARD OPTIONAL EA 30750768-503 C-DCK00 DISK CLEANING KIT EA 30751731-001 C-DD420 DIAGNOSTIC DISK EA 30751793-001 C-DD700 DIAGNOSTIC DISK EA 30751793-004 C-DEL00 ENTERGY LIMITER EA 30735586-001 C-DH420 HIWAY TEST DISK EA 30751793-003 C-DK360 PROG MEDIA R360 EA 30751793-005 C-DK420 PROG MEDIA R420 EA 30751793-002 C-DK460 PROG MEDIA R460 EA 30751793-006 C-DK610 PROG MEDIA R610 EA 30751793-007 C-DK615 PROG MEDIA R615 EA 30751793-008 C-DP100 PWA DEP I/F EA 30750318-501 C-DP200 PWA, DEP I/F EA 30750318-503 C-DP201 PWA, DEP I/F EA 30750318-502 C-DPD20 PANEL,DATA ENTRY EA 30731765-002 C-DPK00 PANEL,DATA ENTRY EA 30734579-001 C-DPK02 BASIC DEP/EXT DE EA 30751394-001 C-DPK03 BASIC DEP/EXT DE EA 30751395-001 C-DPL00 DEP CBL LEFT_ EA 30731866-001 C-DPR00 DEP CBL RGHT EA 30731866-002 C-DPX00 DEP SELECTOR EA 30731795-001 C-DPX20 DEP SLOT SELECTOR EA 30751287-001 C-DSD55 FDD, 50HZ 8IN EA C-DSD61 DISK DRIVE #1 EA 30751139-003 C-DSD66 FLOPPY DRIVE 60HZ EA 30753419-001 C-DSG40 KYBD ASSM EA 30751083-001 C-DSG52 KYBD ASSM EA 30751083-003 C-DSH00 PWA, 128K MEM EA 30751856-501 C-DSK72 UPGRADE R615/616 EA C-DSM02 CRT KIT EA 51195868-400 C-DSP01 PWB, PRINTER I/F EA 30735887-501 C-DSP40 GENICOM PRINTER EA 30754171-001 C-DSP41 PRINTER&PEDESTAL EA C-DSP50 PRINTER EA 51196697-100 C-DSR01 I/F PWB EA 30732425-501 C-DSX72 MEM UPDATE KIT EA 30752117-003 C-DSX86 OP STATION UPGRADE EA 30751313-007 C-EF051 FAN ASSM, 220/240VAC EA 30733258-008 C-EF060 FAN ASSM, 115VAC EA 30733258-007 C-EF151 FAN ASSEMBLY EA 30733258-002 C-EF160 FAN & PLATE ASSM EA 30733258-001 C-EF162 FAN & PLATE ASSM EA 30754651-001 C-EF251 FAN ASSM 24IN, 220V EA 30733258-005 C-EF260 FAN AND PLATE ASSM EA 30733258-004 C-EF262 FAN AND PLATE ASSM EA 30754651-003 C-EPD10 C-EPD10 EA 30732094-003 C-EPD20 MNTING PLATE EA 30732094-004 C-EPS20 MNTG PLATE 24IN EA 30732094-002 C-FMH00 INTEGRITY CARD W/EXTENDER EA 30736260-001 C-HC100 GPCI EA 30732485-001 C-HCB01 CB/EC HIWAY EA 30732171-004 C-HCB20 KIT HWY I/F EA 30732171-005 C-HCM00 HIWAY COUPLER MO EA 30753732-501 C-HEX00 HIWAY EXERCISER EA 30735907-001 C-HL100 DHPII EA 30753004-002 C-HL200 DHPII EA 30753004-002 C-HL201 DATA HIWAY PORT EA 30753004-003 C-HPE20 ENH HIWAY ACCESS EA 30735150-004 C-HPK20 C-HPE00 TO C-HPE20 UPGRADE KIT EA 30752608-003 C-HTD10 HTD/C-HTD20 EA 30733174-003 C-HTD20 HIWAY TRAFFIC DIRECTOR, ENHANCED EA 30733174-003 C-HTK10 KIT-DIR FILE UPD EA 30752608-001 C-HTK20 C-HTD00 TO C-HTD20 UPGRADE KIT EA 30752608-002 C-JCB00 JNCT PANEL,B.C. EA 30731691-001 C-JDD00 RESERVE JUNC PNL EA 30750780-001 C-JDP00 JNCT PANEL, PRIM EA 30735876-001 C-JDR00 RCD JUNCTION PANEL (UAC) EA 30735879-001 C-JLD00 JNCT PANEL, LONG EA 30731958-001 C-JMP00 TERMINAL PNL EA 30731950-001 C-JR000 RCD JUNCTION PNL EA 30750851-001 C-JSD00 JNCT PANEL,SHORT EA 30731689-001 C-JYS01 Y - DEP EA 30732126-001 C-JYS02 Y-MARSHAL PANEL EA 30732128-001 C-JYS03 Y - MANUAL EA 30732130-001 C-JYS04 Y - AUTO/MANUAL EA 30732132-001 C-JYS05 Y - TERM EA 30732134-001 C-JYS06 Y STANDBY EA 30732135-001 C-JYS07 JUNCT PANEL, DI EA 30750308-001 C-JYS08 Y STANDBY EA 30751219-001 C-KC022 COAX CABLE EA 30732107-001 C-KC050 COAX CABLE EA 30732107-002 C-KC075 COAX CABLE EA 30732107-003 C-KC100 COAX CABLE EA 30732107-004 C-KC200 COAX CABLE EA 30732107-005 C-KCA01 COAX TEE QTY2 EA 30732100-001 C-KCA02 COAX TERM KIT(2) EA 30732107-009 C-KCA03 COAX CON KIT-LGE EA 30732107-006 C-KCA04 COAX SPLICE KIT EA 30732107-007 C-KCA05 SMALL CON KIT(4) EA 30732107-010 C-KCA06 CRIMP TOOL KIT EA 30732107-011 C-KCA07 CONNECTOR KIT EA 30732107-012 C-KCA21 DIRECT BUR KIT EA 30752094-002 C-KCA23 KIT,DIRECT BURIA EA 30751989-002 C-KCF00 COM I/F CABLE EA 30732485-002 C-KD000 CBL SPLICE EA 30732038-002 C-KD001 CABLE ASSEMBLY 50 COND (1M) EA 51201420-001 C-KD002 CABLE ASSEMBLY 50 COND (2M) EA 51201420-002 C-KD003 CABLE ASSEMBLY 50 COND (3M) EA 51201420-003 C-KD005 CABLE ASSEMBLY 50 COND (5M) EA 51201420-005 C-KD008 CABLE ASSEMBLY 50 COND (8M) EA 51201420-008 C-KD015 CABLE ASSEMBLY 50 COND (15M) EA 51201420-015 C-KD030 CABLE ASEMBLY 50 COND (30M) EA 51201420-030 C-KD045 CABLE ASSEMBLY 50 COND (45M) EA 51201420-045 C-KD060 CABLE ASSEMBLY 50 COND (60M) EA 51201420-060 C-KD901 CABLE ASSEMBLY 50 CON (1.5M) EA 51201420-915 C-KD902 CABLE ASSEMBLY 50 CON (3M) EA 51201420-003 C-KDP01 DIGITAL CABLE 1.25M EA 30750509-001 C-KDP02 DIGITAL CABLE 2M EA 30750509-002 C-KDP03 DIGITAL CBL 3M EA 30750509-003 C-KDP05 DIGITAL CBL 5M EA 30750509-005 C-KDP08 DIGITAL CBL 8M EA 30750509-008 C-KFN02 FIBR OP CBL ASSY-SMA/SMA EA 30754051-007 C-KFN10 FIBR OP CBL ASSY-SMA/SMA EA 30754051-010 C-KFN50 FIBER OPTIC CABLE ASSM EA 30754051-012 C-KFT02 FIBER OPTIC CBL 2M EA 30754051-001 C-KFT10 FIBER OPTIC CBL 10M EA 30754051-004 C-KFT50 FIBER OPTIC CBL 50M EA 30754051-006 C-KHA11 CABLE ASSEMBLY 15',A/B CBL EA 30753024-001 C-KHA19 50',A/B CBL EA 30753024-002 C-KHM11 DEP CABLE 15FT EA 30753023-001 C-KHM19 DHP CABLE 50' EA 30753023-002 C-KHM31 DHP CABLE MODIFIED 15' EA 30753022-001 C-KHM39 DHP CABLE MODIFIED 50' EA 30753022-002 C-KHM41 CABLE LL 15FT EA 30753020-001 C-KHM49 I/F CABLE 50FT EA 30753020-002 C-KR001 RBN CBL FOR UAC 1M EA 30735893-001 C-KR002 RBN CBL FOR UAC 2M EA 30735893-002 C-KR003 RBN CBL FOR UAC 3M EA 30735893-003 C-KR005 RBN CBL FOR UAC 5M EA 30735893-005 C-KR008 RBN CBL FOR UAC 8M EA 30735893-008 C-LA201 AUTO/MANUAL W/SNDBY MANL CAP EA 30731737-006 C-LAK00 ANALOG DISP KIT EA 30735465-001 C-LAS00 ANALOG DISPLAY ASSM EA 30731737-003 C-LC101 MANUAL W/STANDBY MANUAL CAP EA 30731737-005 C-LC201 MANUAL W/STDBY EA 30731740-002 C-LD100 SGL INDICTOR EA 30731738-002 C-LD200 ASSM,DUAL VERT EA 30731738-003 C-LMD00 MANUAL LOADRW/INDICATOR EA 30731739-002 C-LPC00 ANALOG DISPLAY EA 30731738-001 C-LPX00 COVER EA 30731944-001 C-LSL00 ANALOG DISPLAY SCALES EA 30734478-001 C-LSM01 ONE LOOP STANDBY EA 30734592-001 C-LSM04 FOUR LOOP STANDBY EA 62795649-001 C-LSN00 ANALOG DISPLAY SCALES EA 30734479-001 C-LT200 TRIM KIT DUAL TRIM_ EA 30731963-001 C-LTK00 PARTS KIT EA 30736357-001 C-MH121 BACKPANEL KIT 21IN EA 30732101-008 C-MH128 BACKPANEL KIT 28IN EA 30732101-001 C-MH156 MOUNTING HARDWARE EA 30732101-002 C-MH163 MOUNTING HDW EA 30732101-003 C-MH177 BACKPANEL KIT 77IN EA 30732101-005 C-MH200 MOUNTING HARDWARED EA 30732101-006 C-MH400 SUPPORT TRAY ASSEMBLY EA 30751519-001 C-MHK00 ANGLE BRACKET EA 30732160-001 C-MHK01 ANGLE BRACKET EA 30732160-002 C-MHP00 SIDE PLATE EA 30732101-007 C-MPK00 MOUNTING KIT EA 30732160-001 C-MPK01 ANGLE BRACKET EA 30732160-002 C-PSM01 PWR SPLY MTG KIT EA 51195023-004 C-PSM02 POWER SUPPLY MOUNTING KIT EA 51195023-001 C-PSM03 PWR SPLY MTG KIT EA 51195023-005 C-PSM04 PWR SPLY MTG KIT EA 51195023-006 C-PSM05 PWR SPLY MTG KIT EA 51195023-002 C-PSM06 PWR SPLY MTG KIT EA 51195023-003 C-RP260 TDC RECORDER EA 30670667-999 C-RT200 RECRD TRIP STRIP EA 30734551-001 C-RTM01 TERM PNL,REMOTE EA C-SBH01 BBU MOUNTING HARDWARE EA 30734680-001 C-SBK01 BBU PARTS KIT EA 30735088-001 C-SBK11 BBU TRAY KIT EA 30735088-002 C-SBM01 BBU MTG KIT-19 IN EA 51195022-002 C-SBM02 BBU MTG KIT-24 IN EA 51195022-001 C-SBU01 BATTERY BACKUP ASSM EA 30734500-003 C-SBU02 BATTERY BACKUP ASSM EA 30734500-004 C-SBU11 BATT B/U110/115V W/MERC RELAY EA 30734500-001 C-SCD61 24VAC XFMR, 60HZ EA 30732495-001 C-SDA00 RED'T PWR DISTRI EA 30732220-001 C-SJA00 P/S JUNCTASM+24V AND COM EA 30732175-001 C-SSC51 7A 50HZ PWR SPLY EA 30732106-005 C-SSC61 7A PWR SPLY KIT EA 30732106-001 C-STC50 20A 50HZ PWR SP EA 30732106-004 C-STC51 20A 50HZ PWR SPL EA 30732106-006 C-STC61 20A PWR SPLY KIT EA 30732106-002 C-SW204 PWR JUNC BLK EA 30732172-204 C-SW904 PWR JUNC BLK EA 30732172-904 C-TAF00 TERM PANEL, AUX EA 30731391-001 C-TB010 OUTPUT MOD (IS) EA 49788042-001 C-TBL10 LINK MOD EA 49788031-001 C-TBR10 BARRIER RESISTOR MODULE EA 30751228-001 C-TBU10 BARRIER BOX USA EA 49788023-001 C-TBU11 BARRIER BOX EA 49788023-002 C-TBU12 BARRIER BOX EA 49788023-003 C-TCB20 CONTROLLER TERMINAL PANEL EA 30751315-001 C-TCB21 CONTROLLER TERMINAL PANEL EA 30751315-002 C-TCB30 TERMINAL PANEL EA 30671513-001 C-TPDI-01 HLPIU INPUT PNL EA C-TPM01 REMOTE MARSHALLING PANEL EA 30731865-001 C-TPM02 LOCAL MARSHALLING PANEL EA 30731857-001 C-TRD00 TERM PANEL RED/IND EA 30731408-001 CREDIT SPECIAL CREDIT EA EJG00-05300 FUSE 3A EA 80350750-003 FBT-2 FIELDBUS WIRE TESTER EA FBT-3 FIELDBUS NETWORK TESTER EA H94364700 FILTER,AIR EA 51107109-291 HI-ASPI01-100 GUS D/M PRNTR //PORT EA HI-ASPIP1-100 GUS D/M PRNTR PEDESTAL EA HI-DZIP00-100 ZIP DRIVE KIT EA 51196932-100 HI-TPMED1 ORDER QTY 5, 51196706-200 INDIVIDUAL CARTRIDG EA HI-ZHIKB1-100 Z GUS TO IKB EA HI-ZLRPD1-200 DUAL NODE RELOCATIONKIT FOR GUS, Z CONS. MED EA HI-ZLRPD1-300 DUAL NODE RELOCATIONKIT FOR GUS, Z CONS. TALL EA HI-ZPMED1-100 BLNK ZIP CTDG (10PK) EA 51196929-160 J-AAU00 A/I ADAPTER UNIT EA 80360713-001 J-AOF00 R20 A/O MODULE EA 80360143-012 J-AOF10 R20 A/O MODULE EA 80360143-012 J-AOM00 A/O MODULE EA 80360143-011 J-AOM10 A/O MODULE EA 80360143-011 J-BCA00 I/O ADAPTER EA 80360912-001 J-BCK30 BASE UNIT CONTACT CABLE I/O (3M) EA 80361088-300 J-BTP00 TERMINAL PANEL EA 80360915-001 J-BUA00 BASE UNIT ADAPTER EA 80360643-001 J-CBC00 IBC I/O BUS CARD EA 82407387-001 J-CBC03 PWB, SBLA III EA 82408485-001 J-CBC50 PWB, UAC I/F R30 EA 82408440-001 J-CBM55 PWB, B/U MEMORY EA 82408456-002 J-CDD50 FILE EA 82407045-001 J-CDM50 BACKUP MEM FILE EA 82407046-001 J-CDS50 PWB, I/O BUS SW EA 82408467-001 J-DBK00 BLANK DISKS (10) EA J-DBK05 BLANK DISKS (10) EA J-DBK10 CONFIG DISKS(10) EA J-DBK15 CONFIG DISKS(10) EA J-DBK20 TREND DB PKG(10) EA J-DBK25 TREND DISKS (10) EA J-DBK30 SOPL DISKS (10) EA J-DBK35 SOPL DISKS (10) EA J-DBK40 RECIPE DISKS(10) EA J-DBK45 RECIPE DISKS(10) EA J-DCC00 LOC COMP I/F EA 82408309-002 J-DCL10 OPTIC BARRIER EA 82408646-002 J-DD520 R520 DIAG PKG EA J-DD525 R525 DIAG PKG EA J-DD530 R530 DIAG PKG EA J-DIF00 D/I MODULE W/FTB EA 80360139-002 J-DIF10 DIGITAL INPUT MODULE -48VDC W/FTB EA 80360198-002 J-DIM00 DIGITAL INPUT MODULE (32) EA 80360139-001 J-DIM10 DIGITAL OUTPUT MODULE -48VDC EA 80360198-001 J-DK520 R520 DISK PKG EA P-DK520 J-DOF00 D/O MODULE WITH FRONT TERM 16S/S EA 80360140-012 J-DOF10 D/O MODULE W/FTB EA J-DOF20 RELAY D/O MODULE WITH FTB EA 80360195-002 J-DOM00 DIGITAL OUTPUT MODULE 16 SOLID STATE EA 80360140-011 J-DOM10 DIGITAL OUTPUT MOD 16+16 SO-SOLID STATE EA 80360140-001 J-DOM20 DIGITAL OUTPUT MODULE -16 RELAY OUTPUTS EA 80360195-001 J-DSG53 ASM, KEYBD FLAT EA 82115280-001 J-DST52 ASSM, TREND I/F EA 82115012-001 J-DST53 TREND I/F ASSM EA 82115012-002 J-EEK02 EC-LINK EXTERNAL CABLE 2M EA 80360636-020 J-EEK05 EC-LINK EXTERNAL CABLE 5M EA 80360636-050 J-EEK20 CABLE, 20M EC-LINK EA 80360636-200 J-EIC00 EC-LINK CABLE EA 80360621-005 J-EIC10 CABLE, 1M EC-LINK INTERNAL CABINET USE EA 80360621-001 J-ELA00 EC-LINK ADAPTER EA 80360645-001 J-ELA10 EC-LINK ADAPTOR EA 80360646-001 J-ELT00 EC-LINK TERMINATOR EA 80360163-001 J-FTB00 FRONT TERMINAL PANEL EA 80360155-001 J-HAF00 HL A/I MOD W/FTB EA 80360142-001 J-HAF10 HIGH LEVEL ANALOG INPUT 16 FOR UAC W/FTB EA 80360141-012 J-HAM00 HIGH LEVEL ANALOG INPUT EA 80360141-011 J-HAM10 HIGH LEVEL ANALOG INPPUT FOR UAC EA 80360141-011 J-HCX00 HC I/F MODULE EA 80360144-001 J-HIC00 CABLE-AMC TO AMC EA 80360619-001 J-HIC10 CABLE-AMC TO I/F EA 80360620-001 J-HIC20 CBL,.9M UAC INTERNAL CABINET USE EA 80360697-001 J-HMF00 HL ANA MUX W/FTB EA J-HMM00 HIGH LEVEL ANALOG MULTIPLEXER MODULE EA 80360142-001 J-HPA20 HCIM POWER CABLE EA 80360641-200 J-JDD50 PRIM SO JNCT PNL EA 82408476-001 J-JDD51 RESERVE SO JCT PNL ASSM EA 82408479-001 J-JDD55 S/O DISTRI PANEL EA 82408482-001 J-KDB01 DATA BUS CABLE 1M EA 82408609-201 J-KDB03 DATA BUS CABLE 3M EA 82408609-205 J-KDB05 DATA BUS CABLE 5M EA 82408609-202 J-KDB10 DATA BUS CABLE 10M EA 82408609-204 J-KE001 CABLE, I/O 1M EA 82408007-001 J-KE002 CABLE, I/O 2M EA 82408007-002 J-KE003 CABLE, I/O 3M EA 82408007-003 J-KE005 CABLE, I/O 5M EA 82408007-005 J-KE008 CABLE, I/O 8M EA 82408007-008 J-KE030 CABLE, I/O 30M EA 82408007-030 J-KE115 CABLE, I/O 1.5M EA 82408007-501 J-KR050 CABLE, I/O BUS EA 82407498-001 J-KR051 CABLE, I/O BUS EA 82407499-001 J-KR501 I/O BUS CBL,1.4M EA 82408609-101 J-KR505 I/O BUS CBL, 5M EA 82408609-102 J-KR510 I/O BUS CBL 10M EA 82408609-104 J-KRA00 C-LINK ADP EA 82408061-002 J-KRE02 CBL,C-LINK 2M EA 82408175-002 J-KRE10 CBL,C-LINK 10M EA 82408175-010 J-KRE20 CBL,C-LINK 20M EA 82408175-020 J-KRE30 CBL,C-LINK 30M EA 82408175-030 J-KRL30 CBL SET EA 82408433-003 J-KRL40 CABLE SET EA 82408433-004 J-KRS20 CABLE SET 2M EA 82408433-001 J-MBU00 AMC R10 BASE EA 80360137-001 J-MBU01 AMC R20 BASE EA 80360136-001 J-MHM00 HWAY I/F MOD EA 80360146-011 J-MHM10 R20 HWAY I/F MOD EA 80360146-011 J-MSC00 CTRL MODULE EA 80360145-011 J-MSC10 R20 CTR MODULE EA 80360145-011 J-PCM20 I/O MOD EA 80350859-001 J-PCM40 E/T/P RELAY ASSM EA 82408310-001 J-PCM50 E/T/P RELAY ASSM EA 82408310-002 J-PDP00 PWR DIST PANEL EA 80360181-001 J-PF100 MC PT CARD FILE EA 82407025-100 J-PF200 MC PT CARD FILE EA 82407025-200 J-PIF00 PULSE IN W/FTB EA 80360185-002 J-PIM00 PULSE INPUT MODULE 8 INPUTS EA 80360185-001 J-RRK02 REDUN I/O CBL 2M EA 80360171-020 J-RRK15 UAC I/O CABLE 15M EA 80360171-150 J-RRL20 UAC I/O CABLE 2M EA 80360171-020 J-RRL30 CABLE, 30M UAC EA 80360171-030 J-RRL50 UAC I/O CABLE 5M EA 80360171-050 J-RRL80 UAC I/O CABLE 8M EA 80360171-080 J-RSK01 I/O CABLE 1M EA 80360170-001 J-RSK02 I/O CABLE 2M EA 80360170-020 J-RSK03 I/O CABLE 3M EA 80360170-030 J-RSK05 I/O CABLE 5M EA 80360170-050 J-RSK08 I/O CABLE 8M EA 80360170-080 J-RSK15 I/O CABLE 15M EA 80360170-150 J-RSK30 I/O CABLE 30M EA 80360170-300 J-RSK50 50M I/O CABLE EA 80360170-500 J-RSL15 I/O CABLE 1.5M EA 80360170-015 J-RTP00 DIGITAL I/O REMOTE TERMINAL PANEL EA 80360695-001 J-RTP10 A/I REMOTE T.P. EA 80360677-001 J-RTP20 ANALOG OUTPUT REMOTE TERMINAL PANEL EA 80360693-001 J-RTP30 ANALOG OUTPUT RTP W/STANDBY MANUAL JACK EA 80360680-001 J-RTP40 DUAL DIGITAL OUTPUT PANEL EA 80360686-001 J-RTP50 PULSE INPUT TERMINAL PANEL EA 80360689-001 J-RTP80 DIGITAL OUTPUT REMOTE TERMINAL PANEL EA 80361024-001 J-STF00 SMT TR I/F W/FTB EA J-STM00 SM TRANS I/F-AMC EA 80360199-001 J-SWP00 M/F SWITCH PANEL EA 82116383-001 J-TCB50 I/O TERM PANEL EA 82407372-001 J-TPF10 TERMINAL PANEL EA 82407438-001 J-TPF20 TERMINAL PANEL EA 82408363-001 J-TPF40 TERMINAL PANEL EA 82407444-001 J-TPX00 TERM PANEL SUP EA J-TPX10 MTG KIT,TERM PNL EA 80360175-001 J-UDM00 R20 UAC DIR MOD EA 80360147-001 KBM-US KYBD, W/MOUSE EA 51196708-180 L2-M011-2010 110V MODEM EA 51196265-100 L2-M012-2010 220V MODEM EA 51196265-200 L5-R051-2100 HR100 REMOD,110V EA 51196266-100 L5-R052-2100 HR100 REMOD,220V EA 51196266-200 L6-M000-2000 MAPWARE CABLE EA 51196264-100 MC-FAN511 240V FAN W/ALARM-SEE NOTE FIELD EA MC-FAN611 120V FAN W/ALARM-SEE NOTE FIELD EA MC-GAIH13 HLAI/STI GI/IS FTA RED. W/COMPRN TERM EA 51304718-175 MC-GAIH14 HL/STI GI/COMP CC EA 51304730-175 MC-GAIH22 HL GI FTA COMP CC EA 51304748-175 MC-GAIH83 FTA,_RED_HLAI/STI_GI/IS_CRIMP,_CE,_CC EA 51304718-375 MC-GAIH84 FTA,_RED_HLAI/STI_GI/IS_CRIMP,_CE,_CC EA 51304730-375 MC-GAIH92 FTA,_GAL_HLAI_AUX_CRIMP,_CE,_CC EA 51304748-375 MC-GAOX02 FTA,_A/O_GI/IS_COMP,_CE,_CC EA 51304638-175 MC-GAOX12 FTA,_RED_A/O_GI/IS_COMP,_CE,_CC EA 51304638-575 MC-GAOX72 FTA,_A/O_GI/IS_CRIMP,_CE,_CC EA 51304638-375 MC-GAOX82 FTA, RED A/O GI/IS CRIMP, CE, CC EA 51304638-775 MC-GDID12 FTA, GI DI MTL COMP CE/CC EA 51304640-175 MC-GDID13 DI 24VDC FTA GI COMP EA 51304728-175 MC-GDID82 GI/IS DI FTA EA 51304640-375 MC-GDID83 GI/IS DI FTA EA 51304728-375 MC-GDOD12 FTA,_24VDC_D/O_GI/IS_COMP,_CE,_CC EA 51304642-175 MC-GDOD82 FTA,_24VDC_D/O_GI/IS_CRIMP,_CE EA 51304642-375 MC-GDOL12 FTA,_DO_GI/IS_COMP,_COATED,_CE EA 51304736-175 MC-GDOL82 FTA,_DO_GI/IS_CRIMP,_COATED,_CE EA 51304736-375 MC-GFBS01 GI/IS FIELDBUS I/F FTA, 4 NETS EA 51309254-275 MC-GHA011 AO GI/IS FTA (16), HART CC EA 51309540-175 MC-GHAO11 FTA, GI/IS AO HART EA 51309540-175 MC-GIAH83 FTA, RED HLAI/STI GI/IS CRIMP, CE CC EA 51304718-375 MC-GOAX72 FTA, A/O GI/IS CRIMP, CE, CC EA 51304638-375 MC-GRMT01 RH MUX CC EA 51404106-175 MC-GRPA01 IS FTA CC EA 51304724-175 MC-HPFH01 HPM FILE ASSM 7L CC EA 51404125-250 MC-HPFH11 HPM FILE ASSM 7R CC EA 51404126-250 MC-HPMR01 HPM BD REDN BRD SET-SEE NOTE FIELD EA MC-HPMS01 HPM BD SET-SNGL-COAT-SEE NOTE FIELD EA MC-IOFX03 HPM FILE 15 EC CC EA 51404193-475 MC-PAIH03 IOP, HLAI (CC) EA 51304754-150 MC-PAIL02 IOP, LLAI CC EA 51304481-150 MC-PAOX03 PWA, AO/IOP (EC)(CC) EA 51309152-175 MC-PAOY22 HPM HD I/O IOP EA 80363969-150 MC-PAR111 PWR SUPPLY 115V 8A REDUNDANT CC EA 51401140-650 MC-PAR121 P/S RED 115V 16AMP CC EA 51401140-250 MC-PAR211 AC-ONLY POWER SYSTEM-RED,240VAC,8AMP,NON-CE EA 51401140-850 MC-PAR221 AC-ONLY POWER SYSTEM-RED,240VAC,16AMP,NON-CE EA 51401140-450 MC-PAS111 AC-ONLY POWER SYSTEM-SGL,120VAC,8AMP,NON-CE EA 51401140-550 MC-PAS121 AC-ONLY POWER SYSTEM-SGL,120VAC,16AMP EA 51401140-150 MC-PDIS11 RED DISOE2(CC) EA 51402625-175 MC-PDIS12 DI-SOE REDUNDANT IOP, CC EA 51402625-175 MC-PDIX02 DI IOP, COATED, PWA EA 51304485-150 MC-PDIY22 DI IOP COATED EA 80363972-150 MC-PDOX02 DO IOP, COATED, PWA EA 51304487-150 MC-PDOY22 DO IOP, COATED, PWA EA 80363975-150 MC-PFBS01 FIELDBUS I/F PROCESSOR, 4 NETS CC EA 51309510-175 MC-PLAM02 IOP, LLAI CC EA 51304362-150 MC-PPIX02 IOP,PULSE INP CC EA 51304386-150 MC-PSDX02 IOP, SER DEV CC EA 51304362-250 MC-PSIM11 IOP, SER I/F CC EA 51304362-350 MC-PSRB04 P/S RED 10A W/BBU & MNTG EA 51404174-375 MC-PSRX04 P/S 20A RED W/MNTG EA 51404174-275 MC-PSSX04 P/S SGL 20A W/MNTG EA 51404174-175 MC-PSTX02 MV STI PWA EA 51304516-150 MC-PSTX03 MV STI PWA EA 51304516-250 MC-TAIH02 FTA,HLAI-ST CC EA 51304453-150 MC-TAIH03 FTA, 6IN HLAI, CE, CC EA 51309136-175 MC-TAIH12 FTA,HLAI RED CC EA 51304337-150 MC-TAIH13 FTA, 12IN HLAI COMP, CE, CC EA 51309138-175 MC-TAIH22 HD FTA, HLAI/STI COMP, CC EA 51204170-250 MC-TAIH23 HD FTA, HLAI/STI COMP, CE, CC EA 51204170-275 MC-TAIH52 FTA, HLAI-ST CC EA 51304337-250 MC-TAIH53 FTA, 12IN HLAI SCREW, CE, CC EA 51309138-275 MC-TAIH62 HD FTA, HLAI/STI SCREW, CC EA 51204168-150 MC-TAIL02 FTA, LLAI CC EA 51304437-150 MC-TAIL03 FTA MOTHERBOARD, LLAI-8 CE, CC EA 51309202-175 MC-TAMR02 FTA, LLMUX RTD, EC, CC EA 51309218-175 MC-TAMR03 FTA, LLMUX RTD, EC, CC EA 51309218-175 MC-TAMT02 FTA, LLMUX TC, EC, CC EA 51309223-175 MC-TAMT03 FTA, LLMUX TC, EC CC EA 51309223-175 MC-TAMT12 FTA, LLMUX TC W/RCJR, CE, CC EA 51309213-175 MC-TAOX02 FTA, A/O CCCE EA 51304476-175 MC-TAOX12 FTA, A/O RED CC EA 51304335-175 MC-TAOX52 A/O RED W/SCREW EA 51304335-275 MC-TAOY22 HD FTA, AO COMP W/STBY, CE, CC EA 51204172-175 MC-TAOY23 AO FTA RED EA 80366177-250 MC-TAOY52 HD FTA, AO SCREW W/STBY, CE, CC EA 51204174-175 MC-TAOY53 AO FTA RED EA 80364007-250 MC-TDIA12 FTA, D/I 120V CC EA 51304439-175 MC-TDIA22 FTA, D/I 240V CC EA 51304431-175 MC-TDIA52 FTA, D/I 120V CC EA 51304439-275 MC-TDIA72 FTA, 120VDI (CC) EA 51303930-150 MC-TDID12 FTA,D/I 24VDC CC EA 51304441-175 MC-TDID52 FTA,DIG INPUT 24VDC EA 51304441-275 MC-TDID72 FTA,D/O 24VDC CC EA 51303928-150 MC-TDIY22 FTA, DI 24VDC COMP, CE, CC EA 51204160-175 MC-TDIY62 FTA, DI 24VDC SCREW, CE, CC EA 51204154-175 MC-TDOA13 FTA, 120/240VAC SS D/O COMP, CE, CC EA 51304648-175 MC-TDOD13 FTA, 3/30VDC D/O COMP, CC EA 51304650-150 MC-TDOD23 FTA, 21/200VDC DO COMP, CE, CC EA 51309154-175 MC-TDOD53 FTA, 3/30VDC D/O SCREW, CC EA 51304650-250 MC-TDOD54 DO 3-30VDC SCRW T E C CC EA 51309153-275 MC-TDOR12 FTA, 120V RELAY DO COMP, CE, CC EA 51309148-175 MC-TDOR22 FTA, 240V RELAY CC EA 51309150-175 MC-TDOR52 FTA, 120V RELAY DO SCREW, CE, CC EA 51309148-275 MC-TDOY22 FTA, DO 24VDC COMP, CE, CC EA 51204162-175 MC-TDOY23 HD FTA, DO RELAY COMP, CE, CC EA 51204166-175 MC-TDOY62 FTA, DO 24VDC SCREW, CE, CC EA 51204156-175 MC-TDOY63 HD FTA, DO RELAY SCREW, CE, CC EA 51204164-175 MC-TDPR02 FTA D/I PWR DIST EC EA 51304425-175 MC-TFBS01 FIELDBUS I/F FTA, 4 NETS EA 51309254-175 MC-TFBS11 FIELDBUS I/F FTA, 4 NETS, NO PWR CONDITIONERS EA 51309254-375 MC-THA011 AO FTA (16), HART CC EA 51309542-175 MC-THAO11 FTA, AO HART, COATED EA 51309542-175 MC-TLPA02 FTA, LLMUX/SDI/SI PWR ADAPTER, CC EA 51309204-175 MC-TPIX12 PI-FTA CONFORM EA 51304084-175 MC-TSDU02 FTA, SDI I/F CC EA 51303932-278 MC-TSTX13 HLAI/STI EA 51309142-175 MC-TSTX53 FTA, 12IN STI SCREW, CE, CC EA 51309142-275 MC-ZAPR01 APM UPG RED (CC) EA MC-ZAPS01 APM UPG SGL (CC) EA MC-ZHMR01 HPMM RED UPGD EA MC-ZHMR02 HPM 7 SLOT RED EA MC-ZHMR11 HPM 15SLOT RED U/G KIT EC EA MC-ZHMR12 HPM 7 SLOT RED U/G EA MC-ZHPR01 PM/APM TO HPM EA MC-ZHPR02 PM-APM TO HPM UG EA MC-ZHPR03 NON RED PM/APM TO RED HPM EA MC-ZHPR11 PM/APM TO HPM U/G EA MC-ZHPR12 PM/APM TO HPM U/G EA MC-ZHPR13 N/RED PM/APRM TO REDHPM EA MC-ZHPS01 PM/APM TO HPM CONTAINS 2 7 SLOT FILES EA MC-ZHPS11 PM/APM TO HPM U/G EA MC-ZPSR04 HPM PWR UG (CC) EA MC-ZPSUG1 PM PWR SUP UPGRD EA MF-BIMS11 BUS INTERFACE MODULE, 1/1 VERSION EA MF-CAUX11 AUX/HART SIGNAL CABLE EA MF-CAXE11 AUX/HART SIGNAL CABLE EXTENTION EA MF-CFCP11 FCA/R POWER CABLE EA MF-CIOE11 IOLA & IOLA SIGNAL CABLE EXTENSION PAIR EA MF-CIOL11 IOLA & IOLB SIGNAL CABLE PAIR EA MF-FCAR11 ZONE 1 FIBRE/COPPER ADAPTER EA MF-PWRM2X Power Fail Module EA MNTW35WIKXN NT BOOKS W/SFTWR EA 51196708-190 MP-C8DD01-100 DOOR, DOUBLE, LCN RITTAL TS8 CABINET EA MP-C8SD01-100 DOOR, FULL-SIZE, LCN RITTAL TS8 CABINET EA MP-CARDR2-100 SINGLE ZIP DRIVE EA MP-DCDCK1 US CRTRGE CLEANING KIT EA 51196485-500 MP-DCDDC2-100 35MB CRTG 5 PAK EA MP-DCDDC3-100 MP-DCDDC3-100 150MB CRTG 5 PAK EA MP-DPRU02-112 RECORDER EA MP-DPRU04-200 MP-DPRU02-122 2 PEN FAN FOLD EA 51196211-122 MP-DPRU03-113 RECORDER EA MP-DPRU04-200 MP-DPRU03-123 3 PEN FAN FOLD EA 51196211-123 MP-DPRU04-200 3 PEN RECORDER EA MP-EZCLP1-100 Universal CRT Clamp Kit EA MP-EZEE01-100 AUX EQUIP ENCLOSURE EA MP-EZMP01-100 SNGL CRT MOUNT, EZ EA MP-EZMP02-100 EZ CNSL,DUAL CRT MOUNT EA MP-FHSP10-200 SUPPORT CRT MNTG KIT EA 51197035-400 MP-FLSP04-200 PRIM CRT MNTG KIT EA MP-FOMK02-100 UCNE MTG LCN CAB 120 EA MP-FOMK03-100 UCNE MTG LCN CAB 240 EA MP-FOMK04-100 UCNE MTG LCN CL 120 EA MP-FOMK05-100 UCNE MTG LCN CL 240 EA MP-FOMK06-100 UCNE MTG LCN Z MED EA MP-FOMK06-200 UCNE MTG LCN Z TALL EA MP-M04K4S-100 K4SS 4MW Memory Mezzanine EA MP-M08K4S-100 8MW DIMM BOARD-K4 EA MP-M16K4S-100 16MW DIMM BOARD-K4 EA MP-MEXT01-200 LCNE SET NON-CE EA MP-MMEP41-100 BLANK POD&KYBD FILLER EA MP-MMEP42-100 Blank Faceplate, Upper or Lower Tier EA 51197055-200 MP-MMEP51-100 CURVED BASE ALIGN KIT EA MP-MMEP52-100 STRAIGHT BASE ALIGN KIT EA MP-MMEP53-100 15DEG UPPER TIER KIT EA MP-MMEP54-100 CRT MOUNT 30 DEGREE HEAVY EA 51403191-100 MP-MMPR07-100 PRINTER 120V EA 51196690-100 MP-MMPR07-200 PRINTER, 230V EA 51196690-200 MP-MMPR08-100 PEDESTAL,PRINTER EA 51196690-900 MP-MPPT01 PTR PAPER TRAY EA 51304548-101 MP-NIMR73-100 Redundant NIM Board, power supply, K4LCN EA MP-NIMS73-100 SNGL/NIM K4-4 EA MP-REPLC(培训)8-100 RED/EPLC(培训)G K4-4 EA MP-USCRT1-100 MONITOR EA MP-USEL72-100 US-K4 W/O MEMORY EA MP-USFM02-200 US FST CRT 21IN EA MP-USQT01-100 US,QWERTY OP KYBD W/TKBALL EA MP-USTS10-100 TOUCHSCREEN EA MP-XLAD10-100 SPARE DRIVE 4GB EA 51402486-800 MP-ZDNCF1-100 DUAL NODE CARD FILE UPGRADE KIT EA MP-ZEAMR1-100 Enh Red AM Upgrade Kit EA MP-ZECRT1-100 CRT UPGRADE KIT EA MP-ZECRT1-200 ENH 220V CRT KIT EA MP-ZECRT2-100 CRT UPGRADE 14IN EA MP-ZECRT4-100 CRT UPGRADE 21IN EA MP-ZEKBF1-100 ROVING ENG KYBD REPLACEMENT KIT EA MP-ZEPLN1-100 EPLC(培训) UPGRADE KIT EA MP-ZEPLR1-100 EPLC(培训) UPGRADE KIT EA MP-ZEPLR2-100 EPLC(培训) UPGRADE KIT EA MP-ZFHUP1-100 FULL UPR POD UPGRADE BLUE/BLK EA MP-ZFHUP1-200 FULL HGT U/POD U/G EA MP-ZFHUP2-100 FULL UPR POD UPGRADE GREY EA MP-ZFHUP2-200 FULL HGT U/POD U/G EA MP-ZFHUP3-100 U/POD U/G KIT EA MP-ZFHUP4-100 Z-FURN UPR POD UPGR EA MP-ZFZIP1-100 SGL FLOPPY TO SGL ZIP DR, TABLE MOUNT EA MP-ZFZIP2-100 SGL OR DUAL FLPY TO DUAL ZIP DR, TBL MOUNT EA MP-ZFZIP3-100 UWS-DFLPY-ZIP EA MP-ZFZIP3-200 UWS TO ZIPDRV 220V EA MP-ZGCRT1-100 M/SYNC CRT 21IN EA TP-ZSCRT1-100 MP-ZGCRT2-100 2ND CRT 21IN UXS U/G EA TP-ZSCRT1-100 MP-ZHHUP1-100 HALF UPR POD UPGRADE BLUE/BLK EA MP-ZHHUP2-100 HALF UPR POD UPGRADE GREY EA MP-ZHMK03-100 WREN UPGRADE KIT EA MP-ZHMK04-200 WREN UPGRADE KIT EA MP-ZHMK05-100 WREN UPGRADE KIT EA MP-ZHMK07-200 HM UPGRADE KIT EA MP-ZHMK11-100 HM UPGRADE KIT EA MP-ZHMK12-100 HM UPGRADE KIT EA MP-ZHMK13-100 HM UPGRADE KIT EA MP-ZHMK14-100 HM UPGRADE KIT EA MP-ZHMK15-100 HM UPGRADE KIT EA MP-ZHMK16-100 HM UPGRADE KIT EA MP-ZHMK21-100 HM UPGRADE KIT EA MP-ZHMK22-100 HM UPGRADE KIT EA MP-ZHMK23-100 HM UPGRADE KIT EA MP-ZHMK31-100 HM UPGRADE KIT EA MP-ZHMK32-100 HM UPGRADE KIT EA MP-ZHMK33-100 HM UPGRADE KIT EA MP-ZHMK34-100 HM UPGRADE KIT EA MP-ZHMK35-100 HM UPGRADE KIT EA MP-ZHMK36-100 HM UPGRADE KIT EA MP-ZHMK41-100 HM UPGRADE KIT EA MP-ZHMK42-100 HM UPGRADE KIT EA MP-ZHMK43-100 HM UPGRADE KIT EA MP-ZHMK51-100 HM UPGRADE KIT EA MP-ZHMK52-100 HM UPGRADE KIT EA MP-ZHMK53-100 HM UPGRADE KIT EA MP-ZHMK54-100 HM UPGRADE KIT EA MP-ZHMU01-100 HM UPGRADE KIT ONE 875 DRIVE (SEE NOTES) EA MP-ZHMU02-100 HM KIT, WDA TRAY EA MP-ZHMU12-100 MP-ZHMU03 HM KIT,ADAPT ASM EA MP-ZHMU03-100 MP-ZHMU03-100 HM KIT,ADAPT ASM EA MP-ZHMU04-100 HM KIT, SPC EA MP-ZHMU05-100 HM KIT, REDUND EA MP-ZHMU06-100 HM KIT, CABLES (SEE NOTE FIELD) EA MP-ZHMU07-100 HM KIT, CHASSIS EA MP-ZHMU08-100 1.8 GB HARD DR EA MP-ZHMU11-100 HM U/G KIT/MOD: DUAL 875MB W/O TRAY EA MP-ZHMU12-100 HM U/G KIT/MOD: DUAL 875MB W/ TRAY EA MP-ZHMU15-100 HM U/G KIT/MODULAR: CABLE KIT EA MP-ZHMU18-100 HM U/G KIT/MOD: DUAL 1.8GB DR W/O TRAY EA MP-ZHMU19-100 HM U/G KIT/MOD: DUAL 1.8GB DR W/ TRAY EA MP-ZIKBT1-100 KIT, IKB W/TB Z CONSOLE EA MP-ZIKBZ1-100 IKB W/O TRACKBAL FOR US/UXS EA MP-ZIP100-100 SGL BERNOULLI TO SGL ZIP DRIVE U/G EA MP-ZIP101-100 2ND BURN TO ZIP DRIVE U/G EA MP-ZIP102-100 DUAL BERNOULLI TO ZIP DRIVE U/G EA MP-ZKLCN2-100 K2LCN UPG 2MW EA MP-ZKLCN3-100 K2LCN UPG 3MW EA MP-ZKLCN4-100 K2LCN UPG 4MW EA MP-ZKLCN6-100 K2LCN-6MW:PWA/XCVR KIT EA MP-ZKLCN8-100 K2LCN UPG 8MW EA MP-ZLCNIO-100 LCN SXCR I/O PWB UG EA MP-ZLCNP4-100 LCNP3 TO LCNP4(16MW)U/G-R110 SW REQUIRED EA MP-ZMD150-100 UPG20/150MB CAR OBSOLETE EA MP-ZMSE01-100 MOUSE KIT EA MP-ZNMR03-100 REDUN NIM UPGRD EA MP-ZNMS03-100 SNGL NIM UPGRADE EA MP-ZPRC04-100 K4SS-4 PROCESSOR/MEMORY U/G PWA EA MP-ZPSC04-100 MP-ZPRC08-100 K2LCN 8MW UPGRADE KIT EA MP-ZPSC08-100 MP-ZPRC16-100 K4SS08 PROCESSOR/MEMU EA MP-ZPSC16-100 MP-ZPROC2-100 2M U/G K2 EA MP-ZPROC4-100 K2LCN UPGR KIT, 4MW EA MP-ZPROC6-100 K2LCN UPGR KIT, 6MW EA MP-ZPROC8-100 MP-ZPROC8-100 K2LCN 8MW UPGRADE KIT EA MP-ZPSC04-100 K4SS-4 PROCESSOR/MEMORY U/G PWA EA MP-ZPSC08-100 K4SS-8 PROCESSOR/MEMORY UPGRADE PWA EA MP-ZPSC16-100 Upgrade Kit, K4SDR-16MW EA MP-ZUCRT1-100 US 21IN AYDIN TO INTERCOLOR CRT REPLACEMENT EA MP-ZUSCP1-100 EPDG2 AND EPDGP I/O KIT EA MP-ZUSKL1 US KEYLOCK UPGKT EA MP-ZUSKL1-100 MP-ZUSKL1-100 US KEYLOCK UPGKT EA MP-ZUSUK8-100 ABC TO QWERTY KB U/G KIT FOR UNIV STATION EA MP-ZUXTS1-100 TOUCHSREEN 19IN U/G EA MP-ZUXTS2 FST CRT T/S 24IN U/G FOR Z CONS NON/EC EA 51197051-100 MP-ZUXTS2-100 FST CRT TOUCHSCREEN 21IN U/G (NEW CONSOLE) EA MP-ZXCRT1-100 USX,AYDIN TO INT OBSOLETE EA MPX300PII512-K PC Platform, 300Mhz Pentium II EA MTRISER RISER CARD EA 51196709-100 MU-C8DRD1 DOOR, DOUBLE, HPM RITTAL TS8 CABINET EA MU-C8DRS1 DOOR, FULL-SIZE, HPM RITTAL TS8 CABINET EA MU-C8DSS1 SIDE SKIN, DUAL-ACCESS RITTAL TS8 CABINET EA MU-C8SSS1 SIDE SKIN, SGL-ACCESS RITTAL TS8 CABINET EA MU-CBSS01 C/F RHIO L1-7 EA 51309101-100 MU-CBSS02 CF RHIO R9-15 EA 51309101-200 MU-CBSS11 RHIO LEFT W/O PS EA 51309101-300 MU-CBSS12 RHIO RIGHT W/O PS EA 51309101-400 MU-CLBM01 EYEBOLT ASSM (4) EA 51109594-100 MU-CMSC03 RH MUX NEMA4 SC EA 51309250-200 MU-CMSS03 RH MUX NEMA4 SS EA 51309250-100 MU-FAN511 240V FAN W/ALARM-SEE NOTE FIELD EA MU-FAN611 120V FAN W/ALARM-SEE NOTE FIELD EA MU-FOEA02 UCN FIBER OPTIC EXT SET, 2KM 85-236VAC EA MU-FOED02 UCN FIBER OPTIC EXT SET, 2KM 18-36VDC EA MU-FOMK01 PM MOUNTING KIT EA MU-FOMK10 UCNE MOUNTING KIT PM CAB EA MU-GACT02 HLAI CALIBRATOR FOR GI/IS FTAS EA 51201450-100 MU-GAIH13 FTA, HLAI/STI GI RED/COMP EA 51304718-125 MU-GAIH14 FTA,_RED_HLAI/STI_GI/IS_COMP,_CE EA 51304730-125 MU-GAIH22 FTA, GAL HLAI AUX COMP, CE EA 51304748-125 MU-GAIH83 FTA, RED HLAI/STI GI/IS CRIMP, CE EA 51304718-325 MU-GAIH84 FTA,_RED_HLAI/STI_GI/IS_CRIMP,_CE_ EA 51304730-325 MU-GAIH92 FTA, GAL HLAI AUX CRIMP, CE EA 51304748-325 MU-GAOX02 FTA,_A/O_GI/IS_COMP._TERM_CE EA 51304638-125 MU-GAOX12 FTA,_RED_A/O_GI/IS_COMP_TERM_CE EA 51304638-525 MU-GAOX72 FTA, A/O GI/IS CRIMP, CE EA 51304638-325 MU-GAOX82 FTA, RED A/O GI/IS CRIMP, CE EA 51304638-725 MU-GDID12 FTA, 24VDC D/I GI/IS COMP, CE, CC EA 51304640-125 MU-GDID13 FTA, SS DI GI/IS COMP, CE EA 51304728-125 MU-GDID82 FTA, 24VDC D/I GI/IS CRIMP, CE EA 51304640-325 MU-GDID83 FTA, SS DI GI/IS CRIMP, CE EA 51304728-325 MU-GDOD82 FTA, 24VDC D/O GI/IS CRIMP, CE EA 51304642-325 MU-GDOL12 FTA, DO GI/IS COMP,CE EA 51304736-125 MU-GDOL82 FTA, DO GI/IS CRIMP,CE EA 51304736-325 MU-GFBS01 GI/IS FBUS I/F FTA, 4 NETS EA 51309254-225 MU-GHA011 AO GI/IS FTA (16), HART EA 51309540-125 MU-GHAO11 FTA, GI/IS AO HART EA 51309540-125 MU-GMAR52 G/I PNL SCR TERM EA 51309156-125 MU-GPRD02 PWR DIST PANEL EA 51304644-125 MU-GRPA01 GI LLAI MUX POWER ADAPTER FTA EA 51304724-125 MU-HPFH11 HPM FILE ASSM 7R EA 51404126-200 MU-IOFX02 I/O CARD FILE EA MU-KBFT01 BRIDGE CBL 1M EA 80366198-100 MU-KBFT02 CABLE 2M BRIDGE EA 80366198-200 MU-KDPR00 DS PWR CABLE EA MU-KDPR01 POWER CABLE, 1M EA 51201397-001 MU-KDPR02 DI POWER CABLE, 2M EA 51201397-002 MU-KDPR04 POWER CABLE, 4M EA 51201397-004 MU-KDPR05 DS PWR CABLE,5M EA 51201397-005 MU-KDPR10 DS PWR CABLE,10M EA 51201397-010 MU-KDPR15 DS PWR CABLE,15M EA 51201397-015 MU-KDPR20 DS PWR CABLE,20M EA 51201397-020 MU-KDPR25 DS PWR CABLE,25M EA 51201397-025 MU-KDPR30 DS PWR CABLE,30M EA 51201397-030 MU-KDPR35 DS PWR CABLE,35M EA 51201397-035 MU-KDPR40 DS PWR CABLE,40M EA 51201397-040 MU-KDPR50 DS PWR CABLE,50M EA 51201397-050 MU-KFTA00 FTA I/O CABLE (SEE NOTE FIELD) EA MU-KFTA02 CABLE, FTA I/O (2M) EA 51201420-002 MU-KFTA03 FTA I/O CABLE, 3M EA 51201420-003 MU-KFTA04 FTA I/O CABLE, 4M EA 51201420-004 MU-KFTA05 FTA I/O CBL, 5M EA 51201420-005 MU-KFTA06 FTA CABLE, 6M EA 51201420-006 MU-KFTA08 FTA CABLE, 8M EA 51201420-008 MU-KFTA10 FTA I/O CBL, 10M EA 51201420-010 MU-KFTA15 FTA I/O CBL, 15M EA 51201420-015 MU-KFTA20 FTA I/O CBL, 20M EA 51201420-020 MU-KFTA25 FTA I/O CBL, 25M EA 51201420-025 MU-KFTA30 FTA I/O CBL, 30M EA 51201420-030 MU-KFTA35 FTA I/O CBL, 35M EA 51201420-035 MU-KFTA40 FTA I/O CBL, 40M EA 51201420-040 MU-KFTA45 FTA I/O CBL 45M EA 51201420-045 MU-KFTA50 FTA I/O CBL 50M EA 51201420-050 MU-KFTD05 CBL, 5M DIN/PHONE EA 51201561-005 MU-KFTD10 CBL,10M DIN/PHONE EA 51201561-010 MU-KFTD15 CBL,15M DIN/PHONE EA 51201561-015 MU-KFTD20 CBL,20M DIN/PHONE EA 51201561-020 MU-KFTD25 CBL, 25M DIN/PHONE EA 51201561-025 MU-KFTD30 CBL,30M DIN/PHONE EA 51201561-030 MU-KFTD50 CBL,50M DIN/PHONE EA 51201561-050 MU-KFTS00 FTA CABLE, EC - SEE NOTE FIELD EA MU-KFTS02 FTA I/O CABLE, 2M, EC EA 51204033-002 MU-KFTS03 FTA CABLE, 3M SHIELDED EA 51204033-003 MU-KFTS04 FTA CABLE, 4M SHIELDED EA 51204033-004 MU-KFTS05 FTA I/O CBL (5M) EA 51204033-005 MU-KFTS10 FTA I/O CBL (10M) EA 51204033-010 MU-KFTS15 FTA I/O CBL (15M) EA 51204033-015 MU-KFTS20 FTA I/O CBL (20M) EA 51204033-020 MU-KFTS25 FTA I/O CBL (25M) EA 51204033-025 MU-KFTS30 FTA I/O CBL (30M) EA 51204033-030 MU-KFTS35 FTA I/O CBL (35M) EA 51204033-035 MU-KFTS40 FTA I/O CBL (40M) EA 51204033-040 MU-KFTS50 FTA I/O CBL (50M) EA 51204033-050 MU-KGPR00 G.I. PWR CBL, IN CAB EA MU-KGPR05 PWR CABLE (IN CAB) 5M EA 51109620-195 MU-KGPR10 G.I. PWR CBL, 10M EA 51109620-390 MU-KLAM00 CABLE, LL MUX EA 51304465-000 MU-KLAM04 TWISTED PR CBL W/SHLD (400cm) EA 51304465-400 MU-KLAM05 LLMUX PWR CBL, 300CM EA 51304465-500 MU-KLO305 RHMUS OUTDOOR PA TO FTA CABLE - 1000' EA 51197597-305 MU-KLX076 CABLE, 250' EC EA 51192139-114 MU-KLX152 CABLE, 500' EC EA 51192139-124 MU-KLX305 CABLE, 1000' EC EA 51192139-134 MU-KTPC03 CABLE, 3M I/O EA 51201396-003 MU-KTPC05 CABLE, 5M I/O EA 51201396-005 MU-KTPC10 CABLE, 10M I/O EA 51201396-010 MU-KTPC20 CABLE, 20M I/O EA 51201396-020 MU-NCSK01 UCN SPLICE KIT EA 51195160-100 MU-NCTK01 CRIMP TOOL,RG-11 EA 51190795-200 MU-NKD000 UCN DROP CABLE - MUST ORDER SPECIFIC LENGTH EA MU-NKD002 CABLE SET, 2M RG 6 EA 51195153-002 MU-NKD005 CABLE SET, 5M RG 6 EA 51195153-005 MU-NKD010 CABLE SET, 10M RG6 EA 51195153-010 MU-NKD020 CABLE SET, 20M RG6 EA 51195153-020 MU-NKD030 CABLE SET, 30M RG6 EA 51195153-030 MU-NKD040 CABLE SET, 40M RG6 EA 51195153-040 MU-NKD050 CABLE SET, 50M RG6 EA 51195153-050 MU-NKDK01 CONNECTOR KIT EA 51195161-100 MU-NKDT01 CRIMP TOOL, RG-6 EA 51190797-200 MU-NKT002 CABLE SET, 2.5M EA 51195199-002 MU-NKT005 CABLE SET, 5M EA 51195199-005 MU-NKT010 CABLE SET, 10M EA 51195199-010 MU-NKT020 CABLE SET, 20M EA 51195199-020 MU-NKT030 CABLE SET, 30M EA 51195199-030 MU-NKT050 CABLE SET, 50M EA 51195199-050 MU-NKT100 CABLE SET, 100M EA 51195199-100 MU-NKT200 CABLE SET, 200M EA 51195199-200 MU-NKT400 CABLE SET, 400M EA 51195199-400 MU-NKT600 CABLE SET, 600M EA 51195199-600 MU-NKTK01 CONNECTOR KIT EA 51195162-100 MU-NKTQ01 TORQUE WRENCH EA 51109612-100 MU-NKTT01 CRIMP TOOL RG11 EA 51190795-200 MU-NTAP02 2-DROP TAP ASSM EA MU-NTAP04 4-DROP TAP ASSM EA MU-NTAP08 8-DROP TAP ASSM EA MU-PAIH01 IOP, HLAI (CC) EA 51304754-150 MU-PAIH02 IOP, HLAI EA 51304754-150 MU-PAIH03 IOP, HLAI (CC) EA 51304754-150 MU-PAIL02 LLAI IOP ASSM EA 51304481-100 MU-PAOX01 PWA, AO/IOP EA 51309152-175 MU-PAOX02 PWA, AO/IOP EA 51309152-175 MU-PAOX03 PWA, AO/IOP EA 51309152-175 MU-PAOY22 HPM HD I/O IOP EA 80363969-150 MU-PAR111 PWR SUPPLY 115 V 8A REDUNDANT EA 51401140-600 MU-PAS111 P/S 8A 120V SINGLE EA 51401140-500 MU-PAS121 AC ONLY P/S RED 115V16AMP EA 51401140-100 MU-PDIS11 RED DISOE2 ASSM EA 51402625-125 MU-PDIS12 RED DISOE2 ASSM EA 51402625-125 MU-PDIX01 D/I IOP ASSM EA 51304485-100 MU-PDIX02 D/I IOP ASSM EA 51304485-100 MU-PDIY22 DI IOP 32 ASSM EA 80363972-100 MU-PDOX01 D/O IOP ASSM EA 51304487-100 MU-PDOX02 D/O IOP ASSM EA 51304487-100 MU-PDOY22 DO IOP (NON COATED) EA 80363975-100 MU-PFBS01 FIELDBUS I/F PROCESSOR, 4 NETS EA 51309510-175 MU-PFPX01 I/O FILLER PLATE, BEIGE EA 51309228-300 MU-PLAM02 LLAI MUX IOP EA 51304362-100 MU-PMFR03 FILE,5 SLOT IOP EA 51404212-175 MU-PPIX02 PULSE INPUT IOP EA 51304386-100 MU-PRHM01 32PT IOP EA 51404109-125 MU-PSDX02 IOP,SER DEV I/F EA 51304362-200 MU-PSIM11 IOP, SERIAL I/F EA 51304362-300 MU-PSRB04 P/S RED 10A W/BBU & MNTG EA 51404174-325 MU-PSRX04 P/S RED 20A W/MNTG EA 51404174-225 MU-PSSX04 P/S SGL 20A W/MNTG EA 51404174-125 MU-PSTX02 ST I/F IOP ASSM EA 51304516-100 MU-PSTX03 ST MV I/F PROC EA 51304516-200 MU-RCAB01 REMOTE HARDENED CNTRL CAB 120V EA 51404373-100 MU-RCAB02 REMOTE HARDENED CNTRL CABINET 240V EA 51404373-200 MU-RCHT01 HEATER KIT 120V EA 51404386-100 MU-RCHT02 HEATER KIT 240V EA 51404386-200 MU-SMAC01 A/O STANDBY ASSM EA 51401277-100 MU-SMAC02 A/O STANDBY MANUAL EA 51401277-200 MU-SMDC01 D/O STDBY W/CASE EA 51304095-200 MU-SMDC02 D/O STDBY W/CASE EA 51304526-200 MU-SMDX01 FTA, D/O STNDB EA 51304096-100 MU-SMDX02 FTA, D/O STNDBY EA 51304527-100 MU-TAIH01 MOD, HL A/I FTA EA 51303956-100 MU-TAIH02 FTA, HLAI/STI EA 51304453-100 MU-TAIH03 FTA, 6IN HLAI, CE EA 51309136-125 MU-TAIH12 FTA, HL/AI EA 51304337-100 MU-TAIH22 HD FTA, HLAI/STI COMP EA 51204170-200 MU-TAIH23 HD FTA, HLAI/STI COMP, CE EA 51204170-225 MU-TAIH52 FTA, HLAI/STI EA 51304337-200 MU-TAIH62 HLAI FTA SCR EA 80366192-100 MU-TAIL01 FTA, LL A/I,DIN EA 51198964-100 MU-TAIL02 FTA, LLAI EA 51304437-100 MU-TAIL03 FTA MOTHERBOARD, LLAI-8 CE EA 51309202-125 MU-TAMR02 FTA, LLMUX RTD, CE EA 51309218-125 MU-TAMR03 FTA, LLMUX RTD, CE EA 51309218-125 MU-TAMT02 FTA, LLMUX TC, EC EA 51309223-125 MU-TAMT03 FTA, LLMUX TC, EC EA 51309223-125 MU-TAMT12 LL TC FTA-REMOTE EA MU-TAMT13 FTA, LLMUX TC W/RCJR, CE EA 51309213-125 MU-TAOX01 MODULE, A/O FTA EA 51303953-100 MU-TAOX02 FTA, A/O CCCE EA 51304476-175 MU-TAOX12 AO FTA RED. COMP EA 51304335-125 MU-TAOX52 AO FTA RED. SCREW EA 51304335-225 MU-TAOY22 HD FTA, AO COMP W/STBY, CE EA 51204172-125 MU-TAOY23 AO RED COMP EA 80366177-200 MU-TAOY52 HD FTA, AO SCREW W/STBY, CE EA 51204174-125 MU-TAOY53 AO FTA SCR EA 80364007-200 MU-TDIA11 FTA,120VAC D/I EA 51401186-100 MU-TDIA12 DI FTA 120 VAC EA 51304439-125 MU-TDIA22 DI, FTA EA 51304431-12, 5 MU-TDIA52 FTA, D/I EA 51304439-225 MU-TDIA62 FTA, D/I EA 51304431-225 MU-TDIA72 FTA, D/I (32) EA 51303930-100 MU-TDID11 MODULE,24VDC D/I EA 51401201-100 MU-TDID12 FTA, D/I EA 51304441-125 MU-TDID52 DI FTA 120 VA EA 51304441-225 MU-TDID72 FTA, D/I 24VDC EA 51303928-100 MU-TDIY22 FTA, DI 24VDC COMP, CE EA 51204160-125 MU-TDIY62 FTA, DI 24VDC SCREW, CE EA 51204154-125 MU-TDOA11 MODULE,D/O S.S EA 51401157-100 MU-TDOA12 FTA, 120/240VAC SS D/O COMP, CE, CC EA 51304648-175 MU-TDOA13 FTA, 120/240VAC SS D/O COMP, CE, CC EA 51304648-175 MU-TDOA52 FTA, 120/240VAC SS D/O SCREW, CE EA 51304648-225 MU-TDOA53 FTA, 120/240VAC SS D/O SCREW, CE EA 51304648-225 MU-TDOD11 MODULE, D/O S.S EA 51401220-100 MU-TDOD12 FTA, 3/30VDC D/O COMP EA 51304650-100 MU-TDOD13 FTA, 3/30VDC D/O COMP EA 51304650-100 MU-TDOD22 FTA, 31/200VDC DO COMP, CE, CC EA 51309154-175 MU-TDOD52 FTA, 3/30VDC D/O SCREW EA 51304650-200 MU-TDOD53 FTA, 3/30VDC D/O SCREW EA 51304650-200 MU-TDOD62 FTA, 31/200VDC DO SCREW, CE EA 51309154-225 MU-TDOD63 FTA, 31/200VDC DO SCREW, CE EA 51309154-225 MU-TDON12 FTA, D/O EA 51304446-100 MU-TDON52 FTA, D/O EA 51304446-200 MU-TDOR02 FTA, 240V RELAY DO SCREW EA 51309150-225 MU-TDOR11 MODULE, D/O FTA EA 51401191-100 MU-TDOR12 FTA, DO 120VAC EC EA 51309148-125 MU-TDOR22 FTA, 240V RELAY DO COMP, CE EA 51309150-125 MU-TDOR52 FTA, 120V RELAY DO SCREW, CE EA 51309148-225 MU-TDOR62 FTA, 240V RELAY DO SCREW, CE EA 51309150-225 MU-TDOY22 FTA, DO 24VDC COMP, CE EA 51204162-125 MU-TDOY23 HD FTA, DO RELAY COMP, CE EA 51204166-125 MU-TDOY62 FTA, DO 24VDC SCREW, CE EA 51204156-125 MU-TDOY63 HD FTA, DO RELAY SCREW, CE EA 51204164-125 MU-TDPR01 PWR DIST 24VDC EA 51304425-125 MU-TDPR02 PWR DIST 24VDC EA 51304425-125 MU-TFBS01 FIELDBUS I/F FTA, 4 NETS EA 51309254-125 MU-TFBS11 FIELDBUS I/F FTA, 4 NETS, NO PWR COND EA 51309254-325 MU-THA011 AO FTA (16), HART EA 51309542-125 MU-THAO11 FTA AO HART EA 51309542-125 MU-TLPA02 FTA, LLMUX/SDI/SI PWR ADAPTER, CC EA 51309204-175 MU-TMCN01 FTA MTG CHANNEL, NARROW RITTAL EA 51401246-200 MU-TMCN02 FTA MTG CHANNEL, NARROW RITTAL W/SH GRND BAR EA 51196094-100 MU-TMCN11 FTA MTG CHANNEL, NARROW MARKHON EA 51401529-100 MU-TMCN12 FTA MTG CHANNEL, NARROW MARKHON W/SH GRND BAR EA 51196093-100 MU-TMCN22 FTA CHASSIS ASSEMBLY EA 51196094-300 MU-TMCW01 FTA MTG CHANNEL, WIDE RITTAL EA 51401246-100 MU-TMCW02 FTA MTG CHANNEL, WIDE RITTAL W/SHIELD GRD BAR EA 51196094-200 MU-TMCW11 FTA MTG CHANNEL, WIDE MARKHON EA 51401529-200 MU-TMCW12 FTA MTG CHANNEL, WIDE MARKHON W/SHIELD GR BAR EA 51196093-200 MU-TMHN01 HORIZ. FTA TRAY EA 51401621-100 MU-TMHN02 HORIZ. FTA TRAY W/GB EA 51201666-100 MU-TPIX12 FTA, PULSE INPUT EA 51304084-125 MU-TPIX52 FTA, PULSE INPUT EA 51304084-225 MU-TRPA01 FTA, RH MUX GI/NI PWR ADAPTER, EC EA 51304722-125 MU-TSDM02 SER DEV I/F FTA EA 51303932-227 MU-TSDT02 SER DEV I/F FTA EA 51303932-226 MU-TSDU02 FTA, SD I/F UDC6 EA 51303932-228 MU-TSIA12 SERIAL INTERFACE - ALLEN BRADLEY EA 51303932-428 MU-TSIM12 SERIA INTERFACE FTA - MODBUS EA 51303932-426 MU-TSTX03 FTA, 6IN STI, CE EA 51309140-125 MU-TSTX13 FTA, 12IN STI COMP, CE EA 51309142-125 MU-ZAPR01 PM TO APM U/G KIT EA MC-ZAPR01 MU-ZAPS01 PM-APM U/G KIT EA MC-ZAPS01 MU-ZBCAB1 CB/EC PWA MTG KT EA MU-ZBCJP1 CB/EC UG KIT PWA EA MU-ZDICS1 DI-IOP KIT EA MU-ZDICS1-100 DI-IOP KIT EA MU-ZDICS1 MU-ZFTD02 DIN-PHONE ADAPTR EA 51201553-100 MU-ZLLRT1 LLAI OC DETECTKT FIRMWARE UPGRADE EA MU-ZPFI03 HPM TO I/O TO I/O ONLY FILE CONV KIT (CE) EA MU-ZPFI03-100 HPM I/O TO I/O ONLY FILE CONV KIT (CE) EA MU-ZPFI03 MU-ZPSR04 HPM PWR UG EA MU-ZSTIM1 UPGR KIT, STI-MV EA MX-MTLC10 CABLE,10M TOWER EA 51304505-200 P-AST10 PWA, STDC EA 51195053-100 P-CFA17 HL PCFA-TRM TYPE EA 4DP7APCFA107 P-CFA18 HL, PCFA-CON TYPE EA 4DP7APCFA108 P-CFA19 HL PCFA EA 4DP7APCFA109 P-CFA27 LL PCFA EA 4DP7APCFA207 P-CFA28 LL PCFA ASSM EA 4DP7APCFA208 P-CFA29 LL 7100 CFA EA 4DP7APCFA209 P-CFA39 CARD FILE ASSM EA 4DP7APCFA309 P-CFA43 HL CCFA, R320B EA 4DP7APCFA403 P-CFA52 LL CCFA EA 4DP7APCFA502 P-CFA61 LE CCFA BKPANEL EA 4DP7APCFA601 P-CIM14 CSA TC W/NEMA BOX EA 4DP7APCIM104 P-CIM24 SAT MUX PWA RTD EA 4DP7APCIM204 P-DK361 R360 5-1/4IN SET EA P-DK520 R520 DISK PKG 8IN FOR R520 OPS 12 DISKS EA P-DK525 R525 DISK PKG 5 1/4IN PKG OF 12 EA P-DK530 R530 8IN DISK PKG OF 13 DISKS EA P-DK535 R535 5 1/4IN DISK PKG 13 DISKS EA P-DK616 R615 5-1/4IN SET EA P-DSG54 ASM, KEYBD FLAT EA 82115280-001 P-DSG56 KYBD ASSM EA 30751083-005 P-DSX81 R520 TO R530 KIT EA P-DSX82 R420 TO R530/535 EA P-DSX83 R460/615 TO R530 EA P-ETP14 TERMINAL PANEL EA 82407438-001 P-FAN19 FAN COVER PLATE EA 51302804-100 P-FIM14 FM TC W/NEMA BOX EA 4DP7APFIM104 P-FIM24 RTD MUX ASSM EA 4DP7APFIM204 P-FUP51 FDD UPGRADE KIT EA P-FUP52 FDD UPGRADE KIT EA P-FUT51 FDD UPGRADE KIT EA P-FUT52 FDD UPGRADE KIT EA P-ISB12 INTRINSIC SAFETY BARRIERS & BOX PTB CERT EA 51104957-100 P-ISB13 INTRINSIC SAFETY BARRIERS & BOX FM CERT EA 51104957-101 P-ISB14 INTRINSIC SAFETY BARRIERS & bOX CSA CERT EA 51104957-102 P-ISB15 INTRINSIC SAFETY BARRRIERS & BOX BASEEFA CERT EA 51104957-103 P-KFA02 PRE-TERMINATED FIBER OPTIC CABLE (2M) EA 51195440-002 P-KFA05 PRE-TERMINATED FIBER OPTIC CABLE (5M) EA 51195440-005 P-KFA10 PRE-TERMINATED FIBER OPTIC CABLE (10M) EA 51195440-010 P-KFA20 PRE-TERMINATED FIBER OPTIC CABLE (20M) EA 51195440-020 P-KFA50 PRE-TERMINATED FIBER OPTIC CABLE (50M) EA 51195440-050 P-KFB01 FIBER OPTIC CBL 1M ST/ST EA 51195498-001 P-KFB02 ST/ST FIB CBL 2M EA 51195498-002 P-KFB05 FIBER OPTIC CBL 5M ST/ST EA 51195498-005 P-KFB10 FIBER OPTIC CBL ST/ST 10M EA 51195498-010 P-KFB20 FIBER OPTIC CBL ST/ST 20M EA 51195498-020 P-KFH01 CABLE SET, 1M EA 51195497-001 P-KFH02 CABLE SET, 2M EA 51195497-002 P-KFH05 CABLE SET, 5M EA 51195497-005 P-KFH10 CABLE SET, 10M EA 51195497-010 P-KFH20 CABLE SET, 20M EA 51195497-020 P-KFH50 CABLE SET, 50M EA 51195497-050 P-NMA11 NEMA 4 BOX EA 4DP7APNMA101 P-ODP22 HL 24VDC POWER FILTER EA 4DP7APODP202 P-ODP23 POWER FILTER EA 4DP7APODP203 P-ODP24 DUAL D/I PWR FILTER EA 4DP7APODP204 P-OIM14 TC LOGIC&TERM BDS CBLS AND NEMA BOX ASSM EA 4DP7APOIM104 P-OIM24 RTD LOGIC&TERM BDS, CBLS AND NEMA BOX EA 4DP7APOIM204 P-OIM31 NEMA ASSM-NON IS EA 4DP7APOIM301 P-OIM34 TC LOGIC & TERM BDS, MTG HDW CBLS-NON IS EA 4DP7APOIM304 P-OIM41 MUX SET W/NEMA EA 4DP7APOIM401 P-OIM43 LE RTD MUX LOGIC EA 4DP7APOIM403 P-OSP11 SURGE PROTECT A/I HL EA 4DP7APXSP111 P-OSP21 SURGE PROTECT D/O RELAY AND D/I EA 4DP7APXSP211 P-OSP31 SURGE PROTECT A/O AND SOLID STATE D/O EA 4DP7APXSP311 P-OSP41 SURGE PROTECT POWER SUPPLY EA 4DP7APXSP411 P-OSP51 SURGE PROTECT A/I LL EA 4DP7APXSP511 P-OTS12 SHIELD TERM BLK W/TERM MTG LL EA 51200641-100 P-PRT11 LE PHASE XFMR-STD TRAY MNT 120V 60HZ EA 4DP7APPRT101 P-TCB60 TERMINAL PANEL EA 51303903-100 P-TCB71 ST3000 STATUS OUTPUT TERMINAL PANEL EA 51195105-100 P-TCK11 CONNECTOR KIT EA 4DP7APTCK101 P-XCA11 BARRIER ADAPTOR EA 4DP7APXCA111 P-XIA12 VOLTAGE INPUT 5V EA 4DP7APXIA122 P-XIA22 4-20MA W/O XMTR EA 4DP7APXIA222 P-XIA32 4-20MA XMTR PWR EA 4DP7APXIA322 P-XIA42 5V WITH FAST FIL EA 4DP7APXIA422 P-XIA81 LL AN INPUT MUX EA 4DP7APXIA811 P-XIA91 LL ANALOG INPUT EA 4DP7APXIA911 P-XID11 HL 24V CONTACT EA 4DP7APXID111 P-XID21 1 MEC 24V DIG IN EA 4DP7APXID211 P-XID31 HL 48V CONTACT EA 4DP7APXID311 P-XID41 HL 48V CONTACT 2 EA 4DP7APXID411 P-XID51 HL TTL LOGIC 0.1 EA 4DP7APXID511 P-XID61 HL 125 VDC CONTACT EA 4DP7APXID611 P-XID62 HL 125VDC CONTACT EA 4DP7APXID622 P-XIP11 HL SLOW FORM A/C EA 4DP7APXIP111 P-XIP31 PULSE INP SLOW EA 4DP7APXIP311 P-XIP41 PULSE INPUT FAST EA 4DP7APXIP411 P-XOA31 ANALOG OUTPUT EA 4DP7APXOA311 P-XOD31 DIGITAL OUTPUT EA 4DP7APXOD311 P-XOD41 7100 DIGITAL OUTPUT EA 4DP7APXOD411 P-XRP11 RTD POWER SUPPLY EA 4DP7APXRP111 P-XSC11 LL SIG COND EA 4DP7APXSC111 P-XSD11 SIG COND EA 4DP7APXSD111 P-XSJ11 LL SIGNAL CON - REFERENCE EA 51104410-100 P-XSR11 PWA LL RTD EA 4DP7APXSR111 P-XSR21 LL SIG CON EA 4DP7APXSR211 P-XSR31 LL SIG COND EA 4DP7APXSR311 P-XSV11 LL SIG COND EA 4DP7APXSV111 P-XSV21 LL +1-5, 10, 20 EA 4DP7APXSV211 P-ZHL11 310/320 TO 320B U/G W/O AD CONVERTER EA 51109322-100 P-ZHL12 310/320 TO 30B U/G WITH CONVERTER EA 51109322-101 P-ZHL13 310A TO 320B U/G WITH A/D CONVERTER EA 51109323-100 P-ZKC51 UPGRADE KIT EA P-ZKC52 BASIC CASS UPGRD KIT,TWO 5-1/4IN FDD, POD/PNL EA P-ZKC53 UPGRADE KIT EA P-ZKC54 UPGRADE KIT EA P-ZKF51 BASIC 8IN FDD U/G, ONE 5-14IN FDD, POD/PNL EA P-ZKF52 BASIC 8IN FDD U/G, TWO 5-1/4IN FDD, POD/PNL EA P-ZKF53 UPGRADE KIT EA P-ZKF54 UPGRADE KIT EA P-ZKF55 WEDGE PIE PLATE EA 51304051-100 P200-16F 16MB MEMORY EA 51196743-104 P220-16F 16MB MEM ECC EA 51196743-204 P270-1MBF 1M GRAPHICS MEM EA 51196708-170 P851-DC2F 2GB DATA CASS EA 51196706-100 P862-1GBF 1 GB H/D EA 51196704-200 P862-545F 1.44MB FLPY CBL EA 51196703-100 P881-600LCF CD ROM EA 51196707-100 PHA-01 HOOTER ASSEMBLY EA RAL9705-100 RETROFIT KIT EA 51197103-101 RG-PHA01-100 HOOTER ASSM, CLASSIC FURN, 115V EA 51401303-100A RG-PHA01-200 HOOTER ASSM, CLASSIC FURN, 230V EA 51401303-200A RG-PHA01-300 HOOTER ASSM, Z FURN, 115V EA 51401303-300A RG-PHA01-400 HOOTER ASSM, Z FURN, 230V EA 51401303-400A S1-W4685C03A 16MB SIMM MEMORY EA 51196743-104 SCI72-201-001 CON,120V PWR ENTRY EA 51402619-120 TP-10HD09-100 9.3GB ADDITIONAL HARD DRIVE EA 51198717-100 TP-CTSC01-100 TOUCHSCREEN CLASSIC CONSL 19IN EA TP-CTSC02-100 TOUCHSCREEN, Z CNSL 21IN EA TP-CZUMVB-100 U/T 21IN CRT EA TP-CZUMVD-100 U/T 21IN CRT EA TP-DCRTVC-100 DUAL VIDEO BOARD EA 51196988-100 TP-DIKBTA-100 IKB W/TKBL, DESKTOP EA TP-DLBP03-100 HP B/W LZRJT 120V EA TP-DM17SA-100 CRT 17IN DESKTOP EA TP-DM21SY-200 CRT 21IN EZ CNSL EA TP-DOKBNA-100 OEP KYBD,DESKSIDE GUS EA TP-DTAP00-100 STREAMING TAPE DRIVE 1/4IN EA 51196966-100 TP-DTSD00-100 TOUCH FRAME OPTION 21IN EA TP-DZIP00-100 ZIP DRIVE EA 51196932-100 TP-ERM064-100 EDORAM DIMM 64MB EA 51196321-100 TP-ERM128-100 EDORAM DIMM 128MB EA 51196321-200 TP-EUM21B-100 EZ-UPPER TIER 21IN MONITOR EA TP-EUM21Y-100 EZ CNSL U/TIER CRT EA TP-EZCBL1-100 Monitor Cable Kit EA TP-HDGB09-100 9.3GB H/DRIVE ADDER EA TP-ICEKB1-100 QWERTY K/B INDUSTRIAL CE EA 51191508-100 TP-ICEMS1-100 PS2 MOUSE, IND EA 51196939-100 TP-MOUNTR-100 RACK MONITOR GUS 19IN EA 51403280-100 TP-MOUNTR-200 Rack Mount Kit 120V EA TP-NCBP01-100 GUS HP LZRJT N/W I/F EA TP-NDAT08-100 INTERNL DAT TAPE KIT EA 51196863-100 TP-NHD09G-100 HARD DRIVE 9.1GB EA 51196968-100 TP-QCRTVC-100 DUAL VIDEO UPGRADE KIT EA 51197072-100 TP-RAM064-100 64MB MEMORY ECC EA 51196935-903 TP-RMKBDM-100 Rack Mntg Kit for Montr, Kbd & Mouse, 120V EA TP-RMKBDM-200 Rack Mntg Kit for Montr, Kbd & Mouse, 220V EA TP-SRM064-100 64MB DIMM RAM EA 51196971-100 TP-SRM128-100 128MB SDRAM DIMM FOR PENTIUM II ADDL RAM EA 87758 TP-XM128D-100 DIMM, 128, 100M 16X72 4K 168 EA 51196982-904 TP-XM128E-100 128MB RDRAM EA 51198718-904 TP-XM256E-100 256MB PC700 ECC RDRAM RIMM EA 51198718-913 TP-ZCAPPC DESKTOP APP REPLACEMENT STATION FOR CG EA TP-ZCAPPD DESKSIDE APP REPLACEMNT STATION FOR CG EA TP-ZCCRT1-200 GUS CRT U/G KIT 19IN 220V EA TP-ZCIKB1-100 INTEG KB (IBK) U/G EA TP-ZCLDUG US/UXS DUAL TO GUS U/G ORDER THRU CONFIGURATR EA TP-ZCLDUS-100 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZCLDUG TP-ZCLDUS-200 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZCLDUT-200 TP-ZCLDUT-100 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZCLDUG TP-ZCLDUT-200 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZCLSUG US/UXS SGL TO GUS CLASSIC ORDER THRU CONFIG. EA TP-ZCLSUS-100 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZCLSUG TP-ZCLSUS-200 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZCLSUT-200 TP-ZCLSUT-100 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZCLSUG TP-ZCLSUT-200 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZCRPER-100 REMOTE PERIPHERAL KIT CLASSIC EA TP-ZCRWSP-100 GUS REMOTE PERIPHRL U/G CLASSIC W/S EA TP-ZEC100-100 Upgrade Kit, XLCNE2 100 Micron CE EA TP-ZEC625-100 Upgrade Kit, XLCNE2 62.5 Micron CE EA TP-ZEN100-100 Upgrade Kit, XLCNE2 100 Micron N-CE EA TP-ZEN625-100 Upgrade Kit, XLCNE2 62.5 Micron N-CE EA TP-ZEPKC1-100 IKB TO OEP REPLACEMENT IN CLASSIC EA TP-ZEPKZ1-100 IKB TO OEP RELACEMENT IN Z-CONSOLE EA TP-ZG2G01 GUS TO GUS CONSOLE UPGRADE EA TP-ZG2G01-100 GUS TO GUS 450MHZ FOR CONSOLE MNT & DESKTOP EA TP-ZG2G02 GUS TO GUS DESKSIDE UPGRADE EA TP-ZG2G02-100 GUS TO GUS 450MHZ FOR DESKSIDE EA TP-ZGAPPC DESKTOP APP REPLACEMENT STATION EA TP-ZGAPPD DESKSIDE APP REPLACEMENT STATION EA TP-ZHAPPC DESKTOP APP REPLACEMENT STATION EA TP-ZHAPPD Deskside APP Replacement Station HI-SPEC EA TP-ZLAPPC DESKTOP APP REPLACMENT STATION FOR PLNM EA TP-ZLAPPD DESKSIDE APP REPLACEMENT STTION FOR PLNM EA TP-ZPAPPC DESKTOP APP REPLACEMENT STATION FOR PCNM EA TP-ZPAPPD DESKSIDE APP REPLACMENT STTION FOR PCNM EA TP-ZRPER1-100 GUS Rem Peripheral Single Upgrade Kit Z Con EA TP-ZRPER1-200 GUS Rem Peripheral Dual Upgrade Kit Z Console EA TP-ZRSDS1 UWS, UxS OR US UPGRADE TO DESKSIDE GUS EA TP-ZSCLC1-100 CRT/LWR OEP BEZEL ASSY W/O T/S EA TP-ZSCLCT-100 CRT/LWR OEP BEZEL ASSY W/ T/S EA TP-ZSCLH1-100 CRT/LW OEP BZL ASSY W/O T/S, W/FLR PNL OPNG EA TP-ZSCLHT-100 CRT/LWR OEP BEZEL ASSY W/T/S, W/FLR PNL OPNG EA TP-ZSCLN1-100 GUS CRT/LWR IKB BEZEL ASSY WO/T/S EA TP-ZSCLNT-100 GUS CRT/LWR IKB BEZEL ASSY W/T/S EA TP-ZSCLTT-100 CLASSIC 19" TOUCHSCREEN UG EA TP-ZSCLU1-100 CRT/ UPR BEZEL WO/T/S EA TP-ZSCLUT-100 CRT/ UPR BEZEL W/T/S EA TP-ZSCRT1-100 CRT SONY 21IN U/G W/O TS EA TP-ZSCRTT-100 CRT SONY 21IN U/G W/ TS EA TP-ZSTSR1-100 TOUCHSCREEN UG SONY 21IN EA TP-ZTSCC1-100 TOUCHSCREEN CONTROLLER UPGRADE FOR GUS EA TP-ZXAPPC DESKTOP APP REPLACEMENT STATION FOR AXM EA TP-ZXAPPD DESKSIDE APP REPLACEMENT STATION FOR AXM EA TP-ZXZD01-100 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZXZD1G TP-ZXZD01-200 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZXZD1T-200 TP-ZXZD1G UX/UXS DUAL TO GUS CONSOLE ORDER THRU CONFIG EA TP-ZXZD1T-100 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZXZD1G TP-ZXZD1T-200 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZXZS01-100 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZXZS1G TP-ZXZS01-200 MUST BE ORDERED THRUTOTALPLANT CONFIGURATOR EA TP-ZXZS1T-200 TP-ZXZS1G US/UXS SGL TO GUS CONSOLE-ORDER THRU CONFIG EA TP-ZXZS1T-100 UX/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA TP-ZXZS1G TP-ZXZS1T-200 US/UXS TO GUS U/G ORDER THRU CONFIGURATOR EA UB604-132PO 604 132 MHZ BD EA 51196708-156 V-PWR51 POWER SUPPLY 20A, 50HZ, 105/120VAC EA 30731565-004 V-PWR52 POWER SUPPLY 20A, 50HZ, 220/240VAC EA 30731565-006 V-PWR61 20A PWR SPLY KIT EA 30731565-002 V-PWR71 7A PWR SPLY KIT EA 30731565-001 V-PWR72 PWR SPLY, 7A/24V, 240V/50HZ EA 30731565-005 V-PWR73 POWER SUPPLY 7A, 50HZ, 115 VAC EA 30731565-003
关 键 词: |
HONEYWELL DCS 卡件 |
公司名称:
南京益工科技有限公司
联 系 人: |
韩工
电 话: |
025-85363991
手 机: |
13814078406 |
地 址: |
南京市建邺区福园街129号万达广场商务楼E座19楼 |
邮 编: |
210017 |
主 页: |
