【Abstract】Circuit board glue packer is a machine which can put the processed circuit board to special glue and then pour soak dry, it is a process after the circuit board is processed. This paper mainly introduces a series of Delta tiny PLC, DOP-B series touch screen and sets of B2 servo system in the circuit board glue packer application.
【关键词】台达小型PLC;触摸屏;伺服控制系统
【Keyword】PLC;Human Machine Interface;AC Servo Motor and Drive
