²úÆ·Ãû³Æ ¸ßµçÁ÷ºãÎÂÆ÷High Ampere Thermostat
²úÆ·¹æ¸ñ£º
ζȷ¶Î§£º0¡æ∼120¡æ
½ÓµãÈÝÁ¿£º30A/220V
½Ó¡¡¡¡µã£ºNO,NC½Óµã
×¼ È· ¶È £º¡À4¡æ
¸ÐΰôSize£º170mm
Size£º80(L) x 46(W) x 71(H)mm
RAINBOW CAPILLARY THERMOSTATS
²úÆ·¼ò½é ¡¡¡¡¸ßµçÁ÷ºãÎÂÆ÷High Ampere Thermostat
²úƷ˵Ã÷ ¡¡¡¡Available Temperature Range : between 0 and 320 ¡É
¡¡¡¡ Maximum Head Temperature : 150¡É
¡¡¡¡ Capillary : CU PE or SUS, 250mm~1,000mm
¡¡¡¡ Sensing Bulb : 5.8©ª~ 9.5©ªaccoring to temp. range
¡¡¡¡ Electric Rating : 30A/250VAC
¡¡¡¡ Switch Circuity : Single pole single throw(SPST)
¡¡¡¡ Mounting : Standard M4 mounting brackets
¡¡¡¡ (28mm center to center)
¡¡¡¡ Terminal Type: Screw Straight type
¡¡¡¡ Thermostat weight: 240g(thermo, knob set, stuffing bolt: 330g)
