CutMaster A60ÌØÐÔ£º
Ç¿´óµÄ80%¸ßÔÝÔØÂÊʹ¸Ãϵͳ¼´±ãÔÚ×î¶ñÁӵĻ·¾³ÖÐÒ²ÄܽøÐÐÈ«ÌìºòµÄÉú²úÇиî×÷Òµ¡£±ãЯʽÉè¼ÆºÍ·½±ãʵÓõÄ×°Åäµ××ùʹÆäÔÚÈκÎʱºòµÄ°²×°¶¼ÏÔÇáËÉ×ÔÈç¡£¸îǹ·§µÄÉè¼Æ¸üÊÇËõ¶ÌÁ˲¿¼þ¸ü»»Ê±¼ä£¬´Ó¶øÌá¸ßÁËÉú²úÂÊ¡£
µçԴϵͳºóÃæ°åÉè¼ÆÓÐCNCÁ¬½Ó²å¿×£¬²å¿×ÉÏ·Ö±ðÓС°Æô¶¯/Í£Ö¹¡±¶Ë¿ÚºÍ¡°»ú´²Ô˶¯¡±¶Ë¿Ú¡£µçÔ´¶Ë×Ó°åÄÚ°üº¬ÓÐÈ«µç»¡µçѹ½Ó¿Ú¡£Éè¼ÆÈí¼þ¿É×Ô¶¯¼ì²â¸îǹ¹¤×÷״̬£¬²¢½øÐÐ×Ô¶¯ÇиîºÍÊÖ¶¯Çиîģʽ֮¼äµÄÇл»¡£×¨ÓÃÈí¼þµÄÉè¼Æʹ¸ÃϵͳÔںܶàÓ¦ÓÃÁìÓò£¬È籡ÐͲÄÖÊ»ò¹Ü²ÄµÄÇи¶¼ÄÜÔö¼Ó¸ºÔسÖÐøʱ¼ä£¬Ìá¸ß²Ù×÷ÐÔÄÜ¡£
¶î¶¨Êä³ö |
60 Amps |
Êä³ö·¶Î§ |
20- 60Amps, ×î´ó80 Amps,¿Éµ÷ |
¿ª¿×ºÍÇиîÄÜÁ¦ |
(8mm) |
×î´ó¿ª¿×ºÍÇиîÄÜÁ¦ |
(12mm) |
×î´ó±ßÔµÆ𻡠|
1¼" (35mm) |
ÊäÈëµçѹ |
208-230/460V, 1/3ph, 50/60 Hz,
380/400V, 3 ph, 50/60 Hz,
600V, 3 ph, 60 Hz |
ÊäÈëµçÁ÷@×î´óÊä³ö |
1 ph, 208V-99 Amps
3 ph, 208V-49 Amps
1 ph, 230V-95 Amps
3 ph, 230V-45 Amps
3 ph, 380V-28 Amps
3 ph, 400V-27Amps
1 ph, 460V-60 Amps
3 ph, 460V-29 Amps |
Êä³ö¹¦ÂÊ |
9 kW |
ÔÝÔØÂÊ |
80% @ 60 Amps |
×î´ó¿ÕÔصçѹ |
260 VDC |
ÆøÌåÀàÐÍ |
Air @75 psi (5.2 bar) @6.7cfm (189 lpm) |
Òýµ¼»¡Áã¼þ |
Òýµ¼»¡µãȼ¹Ü |
ÖØÁ¿ |
63 lbs. (19.5kg) - °üº¬µçÔ´£¬µçÔ´µçÀÂ, (¸îǹ¼°µ¼Ïß) |
³ß´ç |
H 13.5" (343mm) x W 9.75" (248mm) x L 21.0" (533mm) |
¹¤×÷µçÀ |
20¡¯ (6.1m) |
¿ØÖÆÆ÷ |
CNC ºóÃæ°åÁ¬½Ó²å¿Ú,ÄÚº¬Æô¶¯/¹Ø±Õ¶Ë¿ÚºÍ¡°OK-65533;65533;65533;65533;65533;65533;Ô˶¯¡±65533;65533;65533;¶Ë¿Ú¡£ |
ÊäÈëµçÔ´µçÀ |
10¡¯ (3m) ´ø²åÍ· (208/230V)
6¡¯ (2m) ²»´ø²åÍ· (400V) |
±£ÐÞÆÚ |
µçÔ´±£ÐÞ3Ä꣬¸îǹ±£ÐÞ1Äê- ÃÀ¹úµçÔ´±£ÐÞ3Ä꣬¸îǹ±£ÐÞ1Äê- ¹ú¼Ê |
ÈÏÖ¤ |
IP-23C, CSA, NTRL/C, CE, CCC |
¸îǹÅäÖà |
¸îǹ |
SL100®SV w/ATC®, 180¡ã Automation |
