ÉϺ£ÏéÊ÷ÓÅÊƹ©Ó¦µÂ¹ú¼°Å·ÖÞ¹¤¿Ø²úÆ·¼°ÒÇÆ÷ÒDZí
ѯ¼ÛÇëÌṩƷÅÆ¡¢Ðͺż°ÊýÁ¿£¬²¿·Ö²úÆ·ÐèÌṩÃúÅÆÕÕƬ
רҵ²É¹ºµÂ¹ú¹¤¿Ø²úÆ·¡¢Ô´Í·¹©Ó¦Å·ÖÞ¹¤¿Ø±¸¼þ
1¡¢×ܲ¿Î»Óڵ¹ú°®µÂ¹¤Òµ¿Æ¼¼ÓÐÏÞ¹«Ë¾£¨Eide Tech GmbH£©
2¡¢³§¼Òѯ¼Û±¨¼Û£¬ÏíÊܵ¹ú±¾¹úÆóÒµµÄ¼Û¸ñÕÛ¿Û£¬¼Û¸ñÔÚ¹úÄÚÊг¡Éϸü¾ßÓÅÊÆ£¡
2¡¢µÂ¹ú¹«Ë¾¼¯ÖдÓÏàӦƷÅƳ§¼Ò²É¹º£¬Ã¿ÖÜÈմӵ¹ú×ܲ¿·¢»õ£¡
3¡¢²úÆ·¿ÉÐÞ»ò»»£¬ÓÉÎÒ˾»á¸ºÔð¸ú³§¼Ò¹µÍ¨£¬ÌṩάÐÞ¼ì²â·þÎñ
4¡¢Ö»ÒªÊǵ¹ú¼°Å·Ã˹ú¼ÒµÄ²úÆ·£¬ÎÒÃÇ¿ÉÒÔΪÄúѯ¼Û²¢²É¹º£¡
Ö÷ÒªÓÃÓÚ¹¤ÒµÐÐÒµ£¬ÎÒÃÇÊÇÑÇÖÞ×Ü´úÀí£¡
FSQ3236404 ED100
RMC 2Z-5K
T-100
0496 30Å·
10*S24-1.8/18
13*S21-1,0/13
150Ohm,44W
2*2*FZB300*65-47/47
2,7 0HM 150W FZB160X45-2,7
209-200-1001A0
2XFA3338602
30911
32W/FUWS75x24-1.1
41456
50 OHM 65W FVW135*35-50
6*S29-4,7/28
64*S7-0.068/4.4
8XS26-2.7/22 steel grid
90*S15-0,33/3,3
B7108P-03177 EM100041
BRAKING RESISTOR FA3338602/3,4
F2S 265*24S-2*20.5K+39
FA 3110402-1.08
FA3121402 NR:138400 7KW
FA3133002
FA3133002-1.6
FA3144402-0.97
FAHS 3244406 NR:195500
FAHS3239604-2x1.45
FAQ 3143804 ED100 19000W 8.4oh
FAQ 3236404 ED100 32 KW
FCFLQ3100604
FE 3121506
FE 314 4402-22kW 14.52ohm 10%
FE 314 4404 - 2x11kW 3.6ohm10%
FE 314 4404-2x11kW 8.58ohm 10%
FE 314 4422-11x2kW 0.6ohm 10%
FE 314 4422-11x2kW 0.72ohm 10%
FE 314 4444 - 22x1kW 0.136ohm
FEC 4-2X12 AI 895 H44
FES 3100702-2.13
FES 3100702-5.74
FGFG 3100702 ED100
FGFK3111402-21
FGFKQ 3100804-8.2
FGFL 312502-10
FGFLQ 3100604
FGFLQ 3100604 3KW 18Å·
FGFLQ 3100604ED100%BEI,3KW,
FGFLQ 3132504-5
FGFLQ3100604-18
FGFLQ3100604-18/ED 100 %
FGFLQ3121604-52,8
FGFLQ3121604-52,8
FGFLQ3122004-27
FGFLQ312604-52.8
FGFLQU3100904-25
FGFLQU3100904-35
FGFT3111202
FGFT3132402
fixed resistor 10 430W / 5min
FKES3147206 (3*2.4Ohm 3*8KW)
FKS 4-20
FKS4-20 AI331N1
FKWS660202 34170 K09
FKWS660202,34170£¬K09
FOFCQU 3100904
FPS25F
FUDP300X45
FUM 200x35-1,4 150W
FUM100*35-100
FUM200*35 360HM 180W
FUW 100*24 - 150 1500hm 44W
FUW 100*24 - 75 750HM 44W
FUW 100*35 - 45 450HM 65W
FUW100*24 -150
FUW100*24 -45
FUW100*24 -75
FUW100*35 1000HM 65W
FUW100*35 100Å· 65W
FUW100*35-100 65W 100Ω
FUW135*35 50Å· 65W
FUW135*35-50
FUW200*45 36Å·180W
FUW200*45-36
FVW100*35-100
FVW200*45-36
FZ 100 X 16F 220Å·
FZ100*24-3/3Å·
FZ500*65 µç×è
FZ63*16AE 23W F15
FZA 400*65F-23 250HM
FZA200*45-24Å·Ä·£¬1.8KW
FZA400*65 F-27
FZA400*65F 25ŷĸ 600W
FZA400x65,F-23 25ohm
FZAS400x80x25-25
FZB 135*35-2
FZB 135*35-25 STEHEND
FZB 135X35-25 STEHEND
FZB135X35 25Ω AG0929 100W F34
FZBS300x65-12
FZCO 400*65 160Ω
FZD135*35-25
FZDMQS300X65-3x22
FZDMQU 300×65 120Ω 860W
FZDMQU 300×65 22Ω 1290W
FZDP 160x45 - 3x0,47
FZDP 200*35S 3*22Å· 3*150W
FZDP165*24S 3*1.2
FZDP200*35-3-22
FZDP300*45-S-33 NR:131822
FZDS165*24-3*0.6
FZDT4000X65
FZECQ 600X65-82
FZECQ400x65-120/0,6
FZECQ400x65-47/0,6
FZECQ600x65-27/1,0
FZECQ600x65-47/1,0
FZECQU 180R 300W
FZECQU600X65-82
FZECQY600X65 1KW 830HMS
FZECU400×65 500A 33Ω
FZG 500x65 800W 56 ohm
FZG600*65 82Ω/1kw
FZG600x65-82 BRAKE RESISTOR 82
FZGQ 600*65-82
FZGQ 600*65-82
FZM 300*65-430W/22 OHM
FZM300*65 100Å·
FZM400x65
FZMU 200*45-20Ω 180W
FZMU 300x45-16
FZPT 160X45 S
FZPT-160-45-S
FZPU 160*45S-425
FZPU 160*45S-620
FZPU 300*45S-310
FZS 265*24S 2.5Å·
FZS 265*24S 39Å·
FZS 300x65-40
FZS150*35S-10R
FZS150X35S-5 220W
FZS265X24S
FZS330x35,680 ohm, 250W
FZS75X24S-18ǧŷ 32w FRIZLEN
FZW 100*35-0.47Ω 65W
FZW 100x35-0,47 ¼û¹æ¸ñÃèÊö
FZW100*24-150 44W 1500V
FZW100*24-150 44W 150Ω
FZW100*35-200Ω 60W
FZW200*35-120
FZW200*35-2
FZZCQ600x65-47/2,0
FZZG 400x65 1200W, 33 ohm
FZZG 500x65 1600W 15 ohm
FZZG 600x65 2000W 15 ohm
FZZGQ 400*65-35
FZZGQ 600*65-82
FZZMQS 300*65-2x1202*430
FZZMQS 300*65-3x22 3*430
FZZMQS300X65-2x120
FZZMQS300X65-2x120
FZZP 300*45S 2*270Å· 2*300W
FZZPU 300*45S-150
GAADU 335X60-5 23965 M01 270W
GLAD100*40-1 42280
GMADU 207*13-8
GMADU 207x13-23 23 Ohm 200W
GWADQ 320*80-56,56 OHM/300W
GYAD 110*80-3Ω 150W
GYAD 320*80-40Ω 300W
GZID 115×79-72 ohm 150W
L10C3F-14
L10C3F-4
L10C3F-49
L10C3F-6.5
L10CF-71 71Å· 760W ²ÄÁÏCuNi44
L10D-71.6
L3-6.2 AB 392M 3
L8D-15.8
LB10CF-4.6 ×èÖµ¿Éµ÷
LB6CF-2.7
LB6CF-2.7
LB7CF-5.8
LB8CF-12
LB8CF-3.0 3Å·Ä· 895W
LB8D-13
LB8D-3.0
LB8D-3.7
LB8D-6.6
LB9D-3.8
LB9D-3.8
M10 R20-4.7K ´ÓÂÝÎÆ»ù²¿Æð
M-3SEW6U30B/420MG24N9K4
P100 1KO 10% C2 WM110
Q400x65-60
Q400x65-60
R 100 DK, D 57, K 55,2.2 A, 20
R10 4.7K
R10 4.7K
R100 - 3.0K
R100DK D51 K55 22A 20CHM
R10-4.7KÅ· Z42
R150-330 µ÷ÕûÆ÷
R20-2.2K
R20-3.3ǧŷ
R20-4.7kÅ·Ä·
R20-5.0K 10688-RESISTOR
R40-1.0KΩ G03
R40-10K µ÷ËÙµç×è
R40-1KÅ·Ä· AB180 U4
R40ML2 - 1.0K AB0180
R50 1KΩ 5/67
RED WM R20 4700Å· 0.08A
RESISTOR FA3336602/3.4
RK201403.1-25 1/12 132KW
RMC10
RMC40-1.5KΩ
TYPE FSL 723612F KW VOLT
TYPE FSL 743912F KW VOLT
WIDERSTAND FZW75*24-820HM
Y49FZ165*24S 1.5ŷĸ 100W
Y51FZ165*24-4Å·Ä· 100W
TURCK RKSWS4.5[5]-2RSSWS
TURCK NI30U-M30-AP6X
TURCK PS600R-508-LI2UPM8X-H1141
TWK KRD 58-K 8192 R 4096 Z01
TURCK FXDP-XSG16-0001
TURCK FCS-G1/2A4P-AP8X-H1141
TURCK BL20-4DI-24VDC-P
TURCK BI5-G18K-RP6X-H1141
TURCK NI12U-EM18M-VP4X-H1141
TURCK NI12U-M18-AP6X
TURCK BI50U-Q80-AP6X2-H1141
TURCK BI15U-Q20-AP6X2
TWK ZD-P3L4-01
TURCK FCS-N1/2A4P-AP8X-H1141
TURCK NI35-CP40-VP4X2 ½Ó½ü¿ª¹Ø
TWK ZD-P3L4-01
TURCK FLDP-IM8-0001
TWK ZD-P3L4-01
TWK ZKD-D01
TURCK BI10-S30-VP4X/S100
TURCK NI8-M18-LIU
TURCK NI8-M18-AD4X
TWK IWN250/25-0.25-T-C2-N07
TURCK FXDP-IM16-0001
TURCK BL20-P4T-SBBC
TURCK BMWS8251-8.5
TURCK NI15-M30-AP6X
TURCK BL20-S4T-SBBS
TURCK FLDP-OM16-0001
TURCK BL67-GW-DPV1
TURCK BI15-CP40-VP4X2
TURBO Pre-Cleaner Turbo 2, II-46-4.5
TWIFLEX 49.04544.10775
TURBO Pre-Cleaner Turbo 2, II-68-6
TURCK BI15U-M30-AP6X-H1141
TURCK FCS-G1/2A4P-LIX-H1141/D037
TURCK ¿ª¹ØMK96-11-R/24VDC
TURCK NI15-M30-AP6X
TWK IW254/40-0,25-KFN-KHN
TWK ZKD-D01
TURCK FXDP-IM8-0001
TURCK NI20-CP40-Y1X
TWK IWN250/40-0.25-T-C2-N07
TURCK FLDP-IM16-0001
TWIFLEX Öƶ¯Æ÷ GMR P PN:7200773
TURCK FCS-G1/2A4-AP8X-H1141Á÷Á¿¼Æ
TURCK FLDP-IM8-0001
TURBO Pre-Cleaner Turbo 2, II-68-7
TURCK FCS-G1/2A4P-VRX/24VDC
TURCK BL20-S4T-SBBS
TURCK BL20-S4T-SBCS µçÔ´Ä£×éµ××ù
TURCK BI10U-M30-VP4X-H1141
TURCK BL20-2AI-I(0/4-20MA)
TURCK BIM-M12E-AG4X
TURCK SDPB-40A-0007
TWK SWH02-01
TURCK TS-500-LI2UPN8X-H1141
TURCK WWAK3-2/P00
TURCK Ni15-M30-AP6X/S120
TURCK NI15-EM30D-VP6X/S120 DC24V
TURCK WWAK4-10/P00 βÏß
TURCK BI10-EM30D-VP6X/S120 20m CABLE
TURCK IM33-12EX-HI/24VDC
TURCK BS8141-0
TRUMPF 1282211
TURCK BL20-4DO-24VDC-0.5A-P
TURCK BI1.5-EG08-LU-H1341Q µçѹDC24V
TWK IW253/100-0.5-KHN-KFN
TUENKERS 264650
TURCK BL20-S4T-SBBS
TWIFLEX 7200778 SD£¨36KN)
TURCK BI4-M12-VP6X-H1141 ½Ó½ü¿ª¹Ø
TURCK BL20-SWIRE-DIL
TURCK NI10U-EM12WD-AP6X-H1141
TWIFLEX K PART NO.3200654
TURCK BMSWS8251-8.5
TURCK BC5-S18-AP4X
TURCK NI15U-EM18-AP6X-H1141 ½Ó½ü¿ª¹Ø
TURCK NI15-M30-AD4X
TWK CRD66-4096R4096C2Z01
TURCK IM33-12EX-Hi
TURCK MS22-RI T-05 08010
TURCK BI4U-M12-AP6X-H1141
TURCK WWAK3-2/P00
TURCK BI5-M18-AP6X-H1141
TURCK BL20-BR-24VDC-D µçÔ´Ä£°å
Y51FZ265*24-6.8Å·Ä· 300W
TWK IWN250/25-0,25-T-C2-N02
TURCK NI8-M18-AP6X-H1141´ø½ÓÏß
TURCK Ni15-M30-AZ3X
TURCK FCS-G1/2A 4P-VRX/24V Á÷Á¿¿ª¹Ø
TURIAN GH-112-2U/SP 250bar 200RPM 85
TWK KRD58-S8192R4096Z01
TURCK WAK3-2/P00
TRUMPF ÕÛÉä¾µ 961974
TURCK NI5-G12-AN6X 2M
TURCK NI15-M30-AP6X
TWK IW254-40-025-KFN-KHN
TURCK BI10-M30-AP6X/S120
TURCK NI50U-CK40-AP6X2-H1141
TWK ZKD-D01
TURCK NI10-G18-AP6X
TURCK NI15-M30-AD4X
TWK ZKD-D01
TURCK NI8-M18-AZ3X
TURCK FLDP-IOM84-0001
TURCK WWAK3-2/P00
TRUMPF ÐÞÀí¹¤¾ßÏä 354750
TURCK WWAK3-2/P00
TURCK VBBS8141-0
TURCK BI5-G18K-AP6X-H1141
TURCK NI10-G18-AP6X
TWIFLEX 0780123-Z ɲ³µÆ¬
TURCK SKP3-5/S90
TURCK BI7-M18-AD4X
TWK IWN250/20-0.25-C2-N07
TURCK BI10-M30-RD4X
TURCK NI15U-M18-AP6X ½Ó½ü¿ª¹Ø
TWK ZD-P3L4-01
TURCK BI4-M12-AP6X-H1141
TURCK BL20-P4T-SBBC
