![±ê׼̫ÑôÄܵç³Ø](http://www.bjnbet.com/uploads/allimg/110428/1-11042Q126150-L.jpg)
±ê׼̫ÑôÄܵç³Ø
NBET-RC22±ê׼̫Äܵç³ØºÍÅ䱸±íÍ·ÊÇÌ«ÑôÄ£ÄâÆ÷У׼¼°Ì«ÑôÄܵç³ØI-VÌØÐÔ²»¿É·Ö¸îµÄÒ»²¿·Ö¡£ËüÓÉÒ»¸öÏÔʾװÖúÍ2×2ÀåÃ×±ê׼̫ÑôÄܵç³Ø¡£µç³ØÅ䱸ÁËÈȵçż·ûºÏIEC60904-2±ê×¼¡£Ö¤Êé±»NISTÈÏ¿É·ûºÏISO-17025±ê×¼£¬Í¬Ê±¿ÉËÝÔ´µ½NRELºÍ¹ú¼Êµ¥Î»ÖÆ£¨SI£©¡£ËûÏÔʾ̫ÑôÄ£ÄâÆ÷¸±ÕÕ¶ÈÔÚÒ»¸öÌ«Ñô³£Êý£¬Ò»¸öÌ«Ñô³£Êý¼´ÔÚ25¡æºÍ¹âÆ×ÔÚAM1.5GÇé¿öϵÄ1000W/m2¡£¶ÔÓÚ¹â·üµç³ØÔÚ±ê×¼Ìõ¼þϲâÊÔÊǷdz£±ØÒªµÄ¡£±íÍ·°üÀ¨Á½¸ùBNC½Ó¿ÚÓÃÓÚÌ«Ñô¸±ÕնȺÍζȵÄÄ£ÄâÊä³ö¡£
²Ù×÷ζȣº10¡æ-40¡æ
²Ù×÷ʪ¶È£º0 – 90% RH Non-Condensing
¸±Õնȣº
·¶Î§
0 – 3.500 Sun
¾«×¼¶È
±0.1% @ 1.0000 Sun @ 23 ºC
±0.2% +2 Counts @ 0.1000 – 1.9500 Sun (Low Display Range) @ 23 ºC
±0.2% +2 Counts @ 1.900 – 3.500 Sun (High Display Range) @ 23 ºC
·Ö±æÂÊ
0.0001 Sun @ 0 – 1.9500 Sun (Low Display Range)
0.001 Sun @ 1.900 – 3.500 Sun (High Display Range)
ζÈÒòÊý
±150 ppm / ºC Max
È¡ÑùƵÂÊ
3 Readings / second
×Ա任Á¿³Ì
Switches to higher display range above 1.950 Sun, lower range below 1.900 Sun
ζȣº
·¶ Χ
0 – 199.9 ºC
¾«È·¶È
±0.5 ºC Typical, ±1.0 ºC Max @ 24 – 26 ºC
±0.7 ºC Typical, ±1.2 ºC Max @ 10 – 40 ºC
·Ö±æÂÊ
0.01 ºC
ζÈÒòËØ
±0.02 ºC / ºC
È¡ÑùƵÂÊ
3 Readings / second
Ä£ÄâÊä³ö£º
¸±ÕÕ¶È
1 volts/sun
ζÈ
10 mV / 1ºC
