²úÆ·Ãû³Æ£º
19´ç¸»Ê¿¿µ¹¤ÒµÆ½°åµçÄÔCEP-19RS-H11E
ÐÍ ºÅ£º
CEP-19RS-H11E
¸»Ê¿¿µ¹¤ÒµÆ½°åµçÄÔ
ϵͳ System
´¦ÀíÆ÷ Processor |
Intel® H110 оƬ×飬֧³Ö 6th Generation Intel® Core™ i7/i5/i3 ´¦ÀíÆ÷£¨LGA1151£©TDP 65W CPU ´îÅä5500RPM FAN |
оƬ×é Chipset |
Intel® H110 Chipset |
ÄÚ´æ Memory |
2 x SO-DIMM Slot, DDR4 1866/2133MHz, up to 32GB |
´æ´¢ Storage |
1 x 2.5" SATA3.0 HDD/SSD 1 x M.2 2242 SSD slot |
ͼÐÎ Graphics |
Intel® HD Graphics 530 |
²Ù×÷ϵͳ OS |
Windows 7, Windows 10, Linux |
¿´ÃŹ·¶¨Ê±Æ÷ Watchdog Timer |
Programmable 255 levels timer interval£¬from 1~255 sec/min |
ÏÔʾÆÁ Display
³ß´ç Size |
19 inches |
·Ö±æÂÊ Resolution |
1280(H) x 1024(V) |
ÆÁÄ»¿í¸ß±È Ratio |
4:3 |
ÁÁ¶È Brightness |
250 nits |
¿ÉÊÓ½Ç Viewing Angle |
CR ≥ 10,89° (H)/89° (V) |
¶Ô±È¶È Contrast Ratio |
1000 |
±³¹â Backlight |
LED Backlight |
±³¹âÊÙÃü Backlight Lifetime |
30000Hrs |
´¥ÃþÆÁ Touchscreen
´¥ÃþÆÁ Touch Type |
ȫƽÃæÎåÏßµç×èÆÁ5-Wire Resistive Touch |
´¥»÷ Touch |
35,000,000 times |
Íⲿ½Ó¿Ú External I/O
´®¿Ú COM |
2 x COM RS485/232/422(Èý¼¶·À»¤), 2 x COM RS485/232/422 (¿ÉÑ¡) |
USB |
4 x USB 3.0 |
Íø¿Ú Ethernet |
1 x RJ45 Intel® I219-LM GbE (10/100/1000 Mbps) 1 x RJ45 Intel® I210AT GbE (10/100/1000 Mbps) |
ÏÔʾ Video |
1 x HDMI (up to 4096 x 2304@24hz) 1 x DP (up to 4096x2304@60Hz) |
񙮵 Audio |
1 x Audio(Line-out&Mic-in 2 in 1), Realtek® ALC888S HD Audio codec 2 x Speaker 3W4Ω |
¿ª¹Ø°´¼üPower bottom |
1 x Power bottom W/LED |
Ô¶³Ì¿ª¹Ø Remote ON-OFF |
1 x remote off (SW) |
µçÔ´ÊäÈë Power Input |
1 x Power Connector (4P Phoenix) |
ÄÚ²¿½Ó¿Ú Internal I/O
À©Õ¹½Ó¿Ú Expansion |
1 x M.2 Key-E 2230 slot 1 x Mini PCIE slot 1 x SIM socket 2 x RS485/232/422(Pin Header ÀËÓ¿£¨³å»÷£©¿¹ÈÅ¶È +/- 2KV) 1 x 8 bit GPIO (Pin Header) |
»ú¹¹ Mechanical
Ç°¿ò Front Panel |
ÂÁ Aluminum |
ÂÁ¼· Heat-Sink |
ÂÁ Aluminum |
µ×°å Rear Cover |
Ìú SECC |
°²×°·½Ê½ Mounting |
Panel Mount, Wall and VESA-mount (100 x 100mm) |
³ß´ç Dimension |
428.5x 353.5 x 76.6mm |
½¨Ò鿪¿×³ß´çCut Out |
420.5x 345.5mm |
ÖØÁ¿ Weight |
6.44 Kg |
»·¾³ Environmental
²Ù×÷ÎÂ¶È Operation Temp. |
-10¡æ ~ 50¡æ with 0.7m/s air flow 0¡æ ~ 40¡æ with 0.7 m/s air flow (HDD) |
´æ´¢ÎÂ¶È Storage Temp. |
-40¡æ ~60¡æ |
ʪ¶È Relative Humidity |
5% ~ 95%, ·ÇÄý½á״̬ Non-condensing |
Ëæ»úÕñ¶¯ Random Vibration |
5~500Hz, 1Grms (HDD)operation, 5~500Hz, 2Grms (SSD)operation |
ÕýÏÒÕñ¶¯ Sine Vibration |
5~500Hz, 2G Non-operation |
»úе³å»÷ Shock |
10g 11ms operation, 30g 11ms Non-operation |
Ç°Ãæ°å·À»¤ Ingress Protection |
Front panel IP66 |
µçÔ´ Power
10-36V DC |
ÈÏÖ¤ Certification
°²¹æÈÏÖ¤ Safety Certification |
CE/FCC/CCC |
