产品介绍: |
处理器 Processor |
Intel® 6th/7th Gen. Core ™ i3/i5/i7, Pentium®, Celeron® Processor, LGA1151 Socket, TDP up to 65W |
芯片组 Chipset |
Intel® H110 |
内存 Memory |
Dual Channel, 2 x SO-DIMM Slot, DDR4 1866/2133/2400MHz, up to 32GB |
存储 Storage |
2 x SATA3.0, 1 x M.2 2242 (SATA) |
显示 Display |
Intel® HD Graphics |
网口 Ethernet |
2 x RJ45 Intel WGI211AT GbE (10/100/1000 Mbps) |
音频 Audio |
Realtek® ALC269Q HD Audio Codec, 1 x Line-in, 1 x Line-out, 1 x Mic-in |
BIOS |
AMI UEFI BIOS |
外部接口 Rear I/O |
1 x HDMI: max resolution up to 4096 x 2304@24Hz 1 x VGA: max resolution up to 1920 x 1200@60Hz 2 x RJ45 4 x USB2.0, 4 x USB3.0 2 x RS232 1 x Line-in, 1 x Line-out, 1 x Mic-in |
内部接口 Internal I/O |
1 x LVDS: max resolution up to 1920 x 1200@60Hz 1 x USB2.0 (Type-A) 1 x 8 bit GPIO 3 x RS232, 1 x RS232/422/485 1 x F_Panel (Power LED, HDD LED, Power button, reset button) 1 x CPU_Fan, 1 x SYS_Fan |
扩展接口 Expansion |
1 x Mini-PCIe 1 x PCIe X4 1 x M.2 2242 (SATA) |
信赖平台模块 TPM |
fTPM2.0 |
环境 Environment |
操作温度 Operation Temp.: 0℃ ~ 60℃ 存储温度 Storage Temp.: -40℃ ~ 85℃ 操作湿度 Operation Humidity: 5% ~ 95%, 非凝结状态 Non-condensing 存储湿度 Storage Humidity: 5% ~ 95%, 非凝结状态 Non-condensing |
电源输入 Power Input |
12V DC-IN |
尺寸 Dimensions |
Mini-ITX (170 x 170mm) |
操作系统 OS |
6th Gen CPU : Windows7/8/10, Linux 7th Gen CPU : Windows10, Linux |
