产品介绍: |
系统 System
处理器 Processor |
Intel® H110 芯片组,支持 6th Generation Intel® Core™ i7/i5/i3 处理器(LGA1151)TDP 65W CPU 搭配5500RPM FAN |
芯片组 Chipset |
Intel® H110 Chipset |
内存 Memory |
2 x SO-DIMM Slot, DDR4 1866/2133MHz, up to 32GB |
存储 Storage |
1 x 2.5" SATA3.0 HDD/SSD 1 x M.2 2242 SSD slot |
图形 Graphics |
Intel® HD Graphics 530 |
操作系统 OS |
Windows 7, Windows 10, Linux |
看门狗定时器 Watchdog Timer |
Programmable 255 levels timer interval,from 1~255 sec/min |
显示屏 Display
尺寸 Size |
19 inches |
分辨率 Resolution |
1280(H) x 1024(V) |
屏幕宽高比 Ratio |
4:3 |
亮度 Brightness |
250 nits |
可视角 Viewing Angle |
CR ≥ 10,89° (H)/89° (V) |
对比度 Contrast Ratio |
1000 |
背光 Backlight |
LED Backlight |
背光寿命 Backlight Lifetime |
30000Hrs |
触摸屏 Touchscreen
触摸屏 Touch Type |
全平面五线电阻屏5-Wire Resistive Touch |
触击 Touch |
35,000,000 times |
外部接口 External I/O
串口 COM |
2 x COM RS485/232/422(三级防护), 2 x COM RS485/232/422 (可选) |
USB |
4 x USB 3.0 |
网口 Ethernet |
1 x RJ45 Intel® I219-LM GbE (10/100/1000 Mbps) 1 x RJ45 Intel® I210AT GbE (10/100/1000 Mbps) |
显示 Video |
1 x HDMI (up to 4096 x 2304@24hz) 1 x DP (up to 4096x2304@60Hz) |
音频 Audio |
1 x Audio(Line-out&Mic-in 2 in 1), Realtek® ALC888S HD Audio codec 2 x Speaker 3W4Ω |
开关按键Power bottom |
1 x Power bottom W/LED |
远程开关 Remote ON-OFF |
1 x remote off (SW) |
电源输入 Power Input |
1 x Power Connector (4P Phoenix) |
内部接口 Internal I/O
扩展接口 Expansion |
1 x M.2 Key-E 2230 slot 1 x Mini PCIE slot 1 x SIM socket 2 x RS485/232/422(Pin Header 浪涌(冲击)抗扰度 +/- 2KV) 1 x 8 bit GPIO (Pin Header) |
机构 Mechanical
前框 Front Panel |
铝 Aluminum |
铝挤 Heat-Sink |
铝 Aluminum |
底板 Rear Cover |
铁 SECC |
安装方式 Mounting |
Panel Mount, Wall and VESA-mount (100 x 100mm) |
尺寸 Dimension |
428.5x 353.5 x 76.6mm |
建议开孔尺寸Cut Out |
420.5x 345.5mm |
重量 Weight |
6.44 Kg |
环境 Environmental
操作温度 Operation Temp. |
-10℃ ~ 50℃ with 0.7m/s air flow 0℃ ~ 40℃ with 0.7 m/s air flow (HDD) |
存储温度 Storage Temp. |
-40℃ ~60℃ |
湿度 Relative Humidity |
5% ~ 95%, 非凝结状态 Non-condensing |
随机振动 Random Vibration |
5~500Hz, 1Grms (HDD)operation, 5~500Hz, 2Grms (SSD)operation |
正弦振动 Sine Vibration |
5~500Hz, 2G Non-operation |
机械冲击 Shock |
10g 11ms operation, 30g 11ms Non-operation |
前面板防护 Ingress Protection |
Front panel IP66 |
电源 Power
电源输入 Power Input |
10-36V DC |
认证 Certification
安规认证 Safety Certification |
CE/FCC/CCC |
