产品介绍: |
- Configuration of Normal/Bypass mode and WDT time-out period can be deployed by software commands
- Software programmable modes (Bypass, Normal,Open) after reboot
- Two independent bypass segments
- Quad 64-bit Gigabit Ethernet ports based on Intel® 82546GB controllers
- Supports 133MHz PCI-X bus and is backwards compatible with 64/32-bit PCI
- Built-in Watchdog Timer (WDT) to switch Ethernet ports to bypass mode by system hang
- Built with both on-board LED and LED pin-out for LAN status and bypass mode, provides variable LED location for system integration
- Specifications are subject to change without notice.
- Pentium® 4, Pentium® III, Pentium® II and Celeron® are registered trademarks of Intel® Corporation.
- Xeon8482; is a trademark of Intel® Corporation.
- Other trademarks, logos, brands and company names are the property of their respective owners.
