CPU Type |
Onboard Intel smallest and lowest Atom 230 processor |
CPU Frequency |
1.6GHz |
Chipset |
Intel 945GC + ICH7, FSB 400MHz |
Memory |
2 x 240-pin DDRII DIMM,Support max up to 4GB DDRII 533/667 |
BIOS |
Award 8Mbit PnP with VGA BIOS |
Display |
Inetel Graphics Media Acdelerator(GMA) 950 max share 224M memeory |
LAN |
LAN1£ºIntel 82573L PCI-E Giga Lan |
USB |
6 x USB2.0 |
HDD Interface |
1 x IDE, 2 x SATA II |
Serial Port |
2 x COM Ports,COM1 for RS232,COM2 for RS232/422/485 |
Parallel Port |
1 x ECP/EPP/SPP Support |
Keyboard/Mouse |
1 x 6-pin Mini-DIN connector for mouse and keyboard |
Watchdog |
System reset or non-maskable interrupt software programmable time internal and jumper selectable 255 level |
Audio |
Realtek ALC 662 with Line-in / Line-out / MIC |
Expansion Components |
ITE IT8888G PCI/ISA bridge for ISA expansion solutions
ISA high drive supported |
Power Supply |
Standard ATX power |
Operation Temperature |
0¡æ ~ 60¡æ |
Operation Humidity |
-40¡æ ~ 85¡æ |
Dimension(LxW) |
338mm x 122mm(13.3¡± x 4.8¡±) |
