Ê×Ò³ - ÐÂÎÅ - ÕÐƸ - ÏÂÔØ - ²úÆ· - ³§ÉÌ - ·½°¸ - ÎÄÕª - Çó¹º - Õ¹ÀÀ
Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú PXIS-2558T
²úÆ·Ãû³Æ£º PXIS-2558T
ÐÍ ºÅ£º PXIS-2558T
Æ· ÅÆ£º ADLINK
Features
  • Compliant with PXI Specification Rev. 2.2
  • Compact 8-slot PXI chassis with one system slot and seven PXI/CompactPCI peripheral slots
  • 8.4" LCD touch panel, supporting 800x600 resolution
  • 0¡ãC to 55¡ãC extended operating temperature range
  • Intelligent chassis management
  • 41.6 dBA silent operation
  • 350 W industrial-grade AC power supply
  • Power, temperature, and fan monitoring LEDs
Introduction
The PXIS-2558T is ADLINKs new-generation PXI chassis equipped with advanced features and functionalities. Its worlds first bench-top PXI chassis come with a 8.4" LCD touch panel. The PXIS-2558T also boasts of wider operating temperature range, lower operating noise, and robust system build. The 8.4" LCD touch panel, which support 800x600 resolution, is the distinguishing feature of PXIS-2558T. Combined with the 6.4 kg light-weight construction, the PXIS-2558T delivers great portability for your PXI-based applications. Additionally, the PXIS-2558T has plenty of advanced features, including 0~55¡ãC extended operation temperature range, 41.6 dBA ultra-low operation noise, and innovative intelligent chassis management. Its 350 W industrial-grade power supply delivers reliable power to your PXI system. With the advanced features and considerate design, PXIS-2558T is your best choices of PXI platform for test and measurement applications.
Ordering Information
PXIS-2558T-A 3U 8-Slot Smart PXI Chassis with 8.4" LCD Touch Panel for PXI-3800 Controller
PXIS-2558T-B (Recommended!) 3U 8-Slot Smart PXI Chassis with 8.4" LCD Touch Panel for PXI-3910/3920/3950 Controller
Associated Software
PXI_Platform_ Description v2.0 PXI Platform Description Files v2.0
¹«Ë¾Ãû³Æ£º Á軪¿Æ¼¼£¨Öйú£©ÓÐÏÞ¹«Ë¾
µç »°£º 010 58858666ת8830 / ÕŸ£Ç¿
ÊÖ»ú£º
µØ Ö·£º ±±¾©º£µíÇøÉϵض«Â·1ºÅÓ¯´´¶¯Á¦´óÏÃE×ù°Ë²ãÎ÷
ÓÊ ±à£º 100085
Ö÷ Ò³£º http://www.adlinktech.com
  • PXIS-2719
  • PXIS-2558T
  • PXI-3910
  • PXI-3920
  • PXI-3950
  • PCIe-RTV24
  • PCI-8144
  • PCI-8102
  • PCI-8124
  • PCI-8134
    °æȨËùÓÐ ¹¤¿ØÍø Copyright@ Gkong.com, All Rights Reserved
