Ê×Ò³ - ÐÂÎÅ - ÕÐƸ - ÏÂÔØ - ²úÆ· - ³§ÉÌ - ·½°¸ - ÎÄÕª - Çó¹º - Õ¹ÀÀ
²úÆ·Ãû³Æ£º PXIS-2719
ÐÍ ºÅ£º PXIS-2719
Æ· ÅÆ£º ADLINK
Features
  • PXI specification Rev. 2.2 compliant
  • Rack-mountable 19-slot PXI chassis with one system slot and eighteen PXI/CompactPCI peripheral slots
  • Advanced forced-cooling mechanism for efficient and uniform heat dissipation
  • External 10 MHz reference clock input via BNC connector
  • 0?XC to 55?XC extended operating temperature range
  • Intelligent chassis monitoring/control
  • 700 W industrial-grade AC power supply
  • Power, temperature and fan monitoring LEDs
Introduction
ADLINK PXIS-2719 is a 3U PXI chassis with abundant advanced features. The PXIS-2719 provides one system slot and eighteen peripheral slots and is designed to meet or exceed the requirements of large capacity, extended operating temperature range, excellent heat dissipation and exceptional chassis weight and robustness. ADLINK PXIS-2719 features an innovative cooling mechanism to deliver efficiency and uniformity for heat dissipation and is capable to provide superior stability in extended temperature range. The PXIS-2719 also features the intelligent chassis management to dynamically monitor the chassis status and exports them to a remote computer via a standard RS-232 port. The PXIS-2719 comes with an Industrial-grade 700 W AC power supply, external 10 MHz reference clock input, and front panel LED indicators. With innovative features and robust design, the PXIS-2719 is your best choices of PXI platform for all your test and measurement requirements.
Ordering Information
PXIS-2719 3U 19-Slot Smart PXI Chassis with 700 W AC Power Supply
PXIS-2719 rack-mount kit Flexible Rack-mount Kit for PXIS-2719
Associated Software
PXI_Platform_ Description v2.0 PXI Platform Description Files v2.0
¹«Ë¾Ãû³Æ£º Á軪¿Æ¼¼£¨Öйú£©ÓÐÏÞ¹«Ë¾
µç »°£º 010 58858666ת8830 / ÕŸ£Ç¿
ÊÖ»ú£º
µØ Ö·£º ±±¾©º£µíÇøÉϵض«Â·1ºÅÓ¯´´¶¯Á¦´óÏÃE×ù°Ë²ãÎ÷
ÓÊ ±à£º 100085
Ö÷ Ò³£º http://www.adlinktech.com
  • PXIS-2719
  • PXIS-2558T
  • PXI-3910
  • PXI-3920
  • PXI-3950
  • PCIe-RTV24
  • PCI-8144
  • PCI-8102
  • PCI-8124
  • PCI-8134
    °æȨËùÓÐ ¹¤¿ØÍø Copyright@ Gkong.com, All Rights Reserved
