Ïêϸ¹æ¸ñ£º >> System
Processor Socekt LGA775 Support Core 2 Quad Q9000 Series/Core 2 Duo/ Pentium D/Celeron D
Chipset Intel G41 + ICH7/ ICH7R(option by MOQ), FSB 800/1066/1333MHz
DRAM 2 x 240PIN DIMM DDR3 800/1066 max up to 8GB
BIOS 8Mb AMI Flash ROM
Power Supply 1 x 24Pin ATX power connector, support AT/ATX mode
Watchdog Watchdog timer function (Reset: 1~65535 level)
Dimension 305mm x 244mm
>> I/O Ports
HDD 4 x SATA-300 Interface, support RAID 0/1/5/10(ICH7R)
FDD 1 x FDD port
Serial Port 6 x RS232 COM ports
Parallel 1 x Parallel pin-header
Audio Realtek ALC662 HD audio codec, support 5.1CH audio
Keyboard/Mouse 2 x PS/2 for Keyboard and Mouse
LAN 2 x Intel 82574L PCI-E Gigabit Lan
USB 8 x USB2.0 (4 by onboard header)
Digital I/O 4 input; 4 output
Expansion 1 x PCIeX16, 1 x PCIeX1, 5 x PCI slots Expansion
>> Display
Graphics Intel GMA X4500, Max. shared system memory up to 1759MB
VGA 2048 x 1536 maximum resolution
DVI 2048 x 1536 maximum resolution
>> Environment
Operation Temperature 0¡ã~60¡ãC
Humidity 10~90%
¹ØÓÚ°¬Ñ¶ºê´ï
www.grantech.com.cn °¬Ñ¶ºê´ï¿Æ¼¼ÓÐÏÞ¹«Ë¾(¼ò³Æ°¬Ñ¶ºê´ï)¡ª¡ªÊǹúÄÚÁìÏȵŤ¿Ø»úרҵÖÆÔìÉÌ£¬ÓÚ1998ÄêÔÚÖйú´ó½³ÉÁ¢¡£°¬Ñ¶ºê´ï¼¯Ñз¢¡¢Éú²ú¡¢ÏúÊÛÓÚÒ»Ì壬ÖÂÁ¦ÓÚΪÖйú´ó½µØÇø¿Í»§Ìṩ¸üÓоºÕùÁ¦¡¢¸üÊʺϱ¾ÍÁÊг¡µÄ²úÆ·ºÍ¸ü¾ßרҵÐԵķþÎñ¡£
¡¡¡¡¡°ÒÔ¿ÍΪ×ð£¬×·Çó׿Խ¡±ÊÇ°¬Ñ¶ºê´ïµÄ¾ÓªÀíÄî¡£
¡¡¡¡ÒÔÁé»îµÄÊг¡»úÖÆ¡¢ÍêÉƵÄר°¸ÅäºÏºÍOEM/ODM»úÖÆ£¬ÒÀÍÐÓÚ×ÔÉíµÄÑз¢ÖÆÔìʵÁ¦£¬ÕûºĮ̈Íå¡¢ÃÀ¹ú¡¢ÈÕ±¾µÈµØÁªÃ˼¶ºÏ×÷»ï°éµÄ¼¼Êõ×ÊÔ´ºÍ²úÆ·×ÊÔ´£¬°¬Ñ¶ºê´ïÄ¿Ç°ÓµÓÐËÄ´ó²úÆ·ÏßµÄ200¶àÖÖ²úÆ·¡£¸÷ϵÁвúÆ·¹ã·ºÓ¦ÓÃÓÚ¹¤Òµ×Ô¶¯»¯¡¢ÖÇÄÜ/¹ìµÀ½»Í¨¡¢³µÔصçÄÔ¡¢½ðÈÚ×Ô¶¯»¯¡¢¼à¿Ø¡¢ÍøÂç¡¢µçÁ¦¡¢Í¨ÐÅ¡¢Ò½ÁÆ¡¢²©²ÊÒµµÈÁìÓò£¬Ó®µÃÁËÖÚ¶àÐÐÒµÁìÏÈÆóÒµ¿Í»§µÄ¼«´ó¿Ï¶¨¡£
¡¡¡¡Ä¿Ç°£¬°¬Ñ¶ºê´ïÔÚ±±¾©¡¢ÉϺ£¡¢³É¶¼¡¢ÉîÛÚÉèÓзֹ«Ë¾£¬ÔÚ¹ãÖÝ¡¢Î÷°²¡¢ÉòÑôµÈµØÉèÁ¢°ìÊ´¦¡£²¢ÉèÁ¢Í걸µÄ²úÆ·Éú²úÖÐÐÄ¡¢Î¬ÐÞÖÐÐÄ¡¢¼¼ÊõÖ§³ÖÖÐÐÄ¡¢²Ö´¢ÖÐÐĵȲ¿ÃÅ¡£Í¬Ê±£¬ÔŲ́ÍåºÍÉîÛÚ»¹·Ö±ðÉèÓÐרߺÔð²úÆ·Ñз¢ÖÆÔìµÄ¼¯ÍÅ×Ó¹«Ë¾¡£
¾¹ý¶àÄêµÄרÐľӪ£¬°¬Ñ¶ºê´ïÒÑÔÚÖйú´ó½µì¶¨ÁËÉîºñµÄ¿Í»§»ù´¡£¬²¢½¨Á¢ÁËÍêÉƵÄÏúÊÛÍøÂçºÍÊÛºó·þÎñÌåϵ¡£Ï£Íû¾¹ý²»Ð¸Å¬Á¦£¬Äܹ»´òÔì³öÒ»¸ö¼«¾ßÖйúÌØÉ«µÄ¡°°¬Ñ¶ºê´ï¡±Æ·£¬³ÉΪÖйú×î´óµÄ¹¤¿Ø»úרҵÖÆÔìÉÌ¡£
